NRF51822好东西,还是玩玩原汁原味的好,给nenbit 加块oled 0.96 iic
SCL--->30
SDA--->0
代码:
- #include "oled.h"
- #include "stdlib.h"
- #include "oledfont.h"
- #include "nrf_delay.h"
- //OLED的显存
- //存放格式如下.
- //[0]0 1 2 3 ... 127
- //[1]0 1 2 3 ... 127
- //[2]0 1 2 3 ... 127
- //[3]0 1 2 3 ... 127
- //[4]0 1 2 3 ... 127
- //[5]0 1 2 3 ... 127
- //[6]0 1 2 3 ... 127
- //[7]0 1 2 3 ... 127
- //IIC Start
- //IIC Start
- void IIC_Start()
- OLED_SCLK_Set() ;
- OLED_SDIN_Set();
- OLED_SDIN_Clr();
- OLED_SCLK_Clr();
- //IIC Stop
- void IIC_Stop()
- OLED_SCLK_Set() ;
- // OLED_SCLK_Clr();
- OLED_SDIN_Clr();
- OLED_SDIN_Set();
- void IIC_Wait_Ack()
- //GPIOB->CRH &= 0XFFF0FFFF; //设置PB12为上拉输入模式
- //GPIOB->CRH |= 0x00080000;
- // OLED_SDA = 1;
- // delay_us(1);
- //OLED_SCL = 1;
- //delay_us(50000);
- /* while(1)
- if(!OLED_SDA) //判断是否接收到OLED 应答信号
- //GPIOB->CRH &= 0XFFF0FFFF; //设置PB12为通用推免输出模式
- //GPIOB->CRH |= 0x00030000;
- return;
- OLED_SCLK_Set() ;
- OLED_SCLK_Clr();
- // IIC Write byte
- void Write_IIC_Byte(unsigned char IIC_Byte)
- unsigned char i;
- unsigned char m,da;
- da=IIC_Byte;
- OLED_SCLK_Clr();
- for(i=0;i<8;i++)
- m=da;
- m=m&0x80;
- if(m==0x80)
- {OLED_SDIN_Set();}
- else OLED_SDIN_Clr();
- da=da<<1;
- OLED_SCLK_Set();
- OLED_SCLK_Clr();
- // IIC Write Command
- void Write_IIC_Command(unsigned char IIC_Command)
- IIC_Start();
- Write_IIC_Byte(0x78); //Slave address,SA0=0
- IIC_Wait_Ack();
- Write_IIC_Byte(0x00); //write command
- IIC_Wait_Ack();
- Write_IIC_Byte(IIC_Command);
- IIC_Wait_Ack();
- IIC_Stop();
- // IIC Write Data
- void Write_IIC_Data(unsigned char IIC_Data)
- IIC_Start();
- Write_IIC_Byte(0x78); //D/C#=0; R/W#=0
- IIC_Wait_Ack();
- Write_IIC_Byte(0x40); //write data
- IIC_Wait_Ack();
- Write_IIC_Byte(IIC_Data);
- IIC_Wait_Ack();
- IIC_Stop();
- void OLED_WR_Byte(unsigned dat,unsigned cmd)
- if(cmd)
- Write_IIC_Data(dat);
- else {
- Write_IIC_Command(dat);
- // fill_Picture
- void fill_picture(unsigned char fill_Data)
- unsigned char m,n;
- for(m=0;m<8;m++)
- OLED_WR_Byte(0xb0+m,0); //page0-page1
- OLED_WR_Byte(0x00,0); //low column start address
- OLED_WR_Byte(0x10,0); //high column start address
- for(n=0;n<128;n++)
- OLED_WR_Byte(fill_Data,1);
- /***********************Delay****************************************/
- void Delay_50ms(unsigned int Del_50ms)
- unsigned int m;
- for(;Del_50ms>0;Del_50ms--)
- for(m=6245;m>0;m--);
- void Delay_1ms(unsigned int Del_1ms)
- unsigned char j;
- while(Del_1ms--)
- for(j=0;j<123;j++);
- //坐标设置
- void OLED_Set_Pos(unsigned char x, unsigned char y)
- { OLED_WR_Byte(0xb0+y,OLED_CMD);
- OLED_WR_Byte(((x&0xf0)>>4)|0x10,OLED_CMD);
- OLED_WR_Byte((x&0x0f),OLED_CMD);
- //开启OLED显示
- void OLED_Display_On(void)
- OLED_WR_Byte(0X8D,OLED_CMD); //SET DCDC命令
- OLED_WR_Byte(0X14,OLED_CMD); //DCDC ON
- OLED_WR_Byte(0XAF,OLED_CMD); //DISPLAY ON
- //关闭OLED显示
- void OLED_Display_Off(void)
- OLED_WR_Byte(0X10,OLED_CMD); //DCDC OFF
- OLED_WR_Byte(0XAE,OLED_CMD); //DISPLAY OFF
- //清屏函数,清完屏,整个屏幕是黑色的!和没点亮一样!!!
- void OLED_Clear(void)
- u8 i,n;
- for(i=0;i<8;i++)
- OLED_WR_Byte (0xb0+i,OLED_CMD); //设置页地址(0~7)
- OLED_WR_Byte (0x00,OLED_CMD); //设置显示位置—列低地址
- OLED_WR_Byte (0x10,OLED_CMD); //设置显示位置—列高地址
- for(n=0;n<128;n++)OLED_WR_Byte(0,OLED_DATA);
- } //更新显示
- void OLED_On(void)
- u8 i,n;
- for(i=0;i<8;i++)
- for(n=0;n<128;n++)OLED_WR_Byte(1,OLED_DATA);
- } //更新显示
- //在指定位置显示一个字符,包括部分字符
- //x:0~127
- //y:0~63
- //mode:0,反白显示;1,正常显示
- //size:选择字体 16/12
- void OLED_ShowChar(u8 x,u8 y,u8 chr,u8 Char_Size)
- unsigned char c=0,i=0;
- c=chr-' ';//得到偏移后的值
- if(x>Max_Column-1){x=0;y=y+2;}
- if(Char_Size ==16)
- OLED_Set_Pos(x,y);
- for(i=0;i<8;i++)
- OLED_WR_Byte(F8X16[c*16+i],OLED_DATA);
- OLED_Set_Pos(x,y+1);
- for(i=0;i<8;i++)
- OLED_WR_Byte(F8X16[c*16+i+8],OLED_DATA);
- else {
- for(i=0;i<6;i++)
- OLED_WR_Byte(F6x8[c][i],OLED_DATA);
- //m^n函数
- u32 oled_pow(u8 m,u8 n)
- u32 result=1;
- while(n--)result*=m;
- return result;
- //显示2个数字
- //x,y :起点坐标
- //len :数字的位数
- //size:字体大小
- //mode:模式 0,填充模式;1,叠加模式
- //num:数值(0~4294967295);
- void OLED_ShowNum(u8 x,u8 y,u32 num,u8 len,u8 size2)
- u8 t,temp;
- u8 enshow=0;
- for(t=0;t<len;t++)
- temp=(num/oled_pow(10,len-t-1))%10;
- if(enshow==0&&t<(len-1))
- if(temp==0)
- OLED_ShowChar(x+(size2/2)*t,y,' ',size2);
- continue;
- }else enshow=1;
- OLED_ShowChar(x+(size2/2)*t,y,temp+'0',size2);
- //显示一个字符号串
- void OLED_ShowString(u8 x,u8 y,u8 *chr,u8 Char_Size)
- unsigned char j=0;
- while (chr[j]!='\0')
- { OLED_ShowChar(x,y,chr[j],Char_Size);
- x+=8;
- if(x>120){x=0;y+=2;}
- j++;
- //显示汉字
- void OLED_ShowCHinese(u8 x,u8 y,u8 no)
- u8 t,adder=0;
- for(t=0;t<16;t++)
- OLED_WR_Byte(Hzk[2*no][t],OLED_DATA);
- adder+=1;
- for(t=0;t<16;t++)
- OLED_WR_Byte(Hzk[2*no+1][t],OLED_DATA);
- adder+=1;
- /***********功能描述:显示显示BMP图片128×64起始点坐标(x,y),x的范围0~127,y为页的范围0~7*****************/
- void OLED_DrawBMP(unsigned char x0, unsigned char y0,unsigned char x1, unsigned char y1,unsigned char BMP[])
- unsigned int j=0;
- unsigned char x,y;
- if(y1%8==0) y=y1/8;
- else y=y1/8+1;
- for(y=y0;y<y1;y++)
- OLED_Set_Pos(x0,y);
- for(x=x0;x<x1;x++)
- OLED_WR_Byte(BMP[j++],OLED_DATA);
- //初始化SSD1306
- void OLED_Init(void)
- nrf_gpio_cfg_output(CLK);
- nrf_gpio_cfg_output(SDA);
- nrf_delay_ms(200);
- OLED_WR_Byte(0xAE,OLED_CMD);//--display off
- OLED_WR_Byte(0x00,OLED_CMD);//---set low column address
- OLED_WR_Byte(0x10,OLED_CMD);//---set high column address
- OLED_WR_Byte(0x40,OLED_CMD);//--set start line address
- OLED_WR_Byte(0xB0,OLED_CMD);//--set page address
- OLED_WR_Byte(0x81,OLED_CMD); // contract control
- OLED_WR_Byte(0xFF,OLED_CMD);//--128
- OLED_WR_Byte(0xA1,OLED_CMD);//set segment remap
- OLED_WR_Byte(0xA6,OLED_CMD);//--normal / reverse
- OLED_WR_Byte(0xA8,OLED_CMD);//--set multiplex ratio(1 to 64)
- OLED_WR_Byte(0x3F,OLED_CMD);//--1/32 duty
- OLED_WR_Byte(0xC8,OLED_CMD);//Com scan direction
- OLED_WR_Byte(0xD3,OLED_CMD);//-set display offset
- OLED_WR_Byte(0xD5,OLED_CMD);//set osc division
- OLED_WR_Byte(0x80,OLED_CMD);//
- OLED_WR_Byte(0xD8,OLED_CMD);//set area color mode off
- OLED_WR_Byte(0x05,OLED_CMD);//
- OLED_WR_Byte(0xD9,OLED_CMD);//Set Pre-Charge Period
- OLED_WR_Byte(0xF1,OLED_CMD);//
- OLED_WR_Byte(0xDA,OLED_CMD);//set com pin configuartion
- OLED_WR_Byte(0x12,OLED_CMD);//
- OLED_WR_Byte(0xDB,OLED_CMD);//set Vcomh
- OLED_WR_Byte(0x30,OLED_CMD);//
- OLED_WR_Byte(0x8D,OLED_CMD);//set charge pump enable
- OLED_WR_Byte(0x14,OLED_CMD);//
- OLED_WR_Byte(0xAF,OLED_CMD);//--turn on oled panel
- #ifndef __OLED_H
- #define __OLED_H
- #include "nrf_gpio.h"
- typedef uint32_t u32;
- typedef uint16_t u16;
- typedef uint8_t u8;
- #define OLED_MODE 0
- #define SIZE 8
- #define XLevelL 0x00
- #define XLevelH 0x10
- #define Max_Column 128
- #define Max_Row 64
- #define Brightness 0xFF
- #define X_WIDTH 128
- #define Y_WIDTH 64
- //-----------------OLED IIC端口定义----------------
- #define CLK 30
- #define SDA 0
- #define OLED_SCLK_Clr() nrf_gpio_pin_clear(CLK)//CLK
- #define OLED_SCLK_Set() nrf_gpio_pin_set(CLK)
- #define OLED_SDIN_Clr() nrf_gpio_pin_clear(SDA)//SDA
- #define OLED_SDIN_Set() nrf_gpio_pin_set(SDA)
- //#define OLED_RST_Clr() nrf_gpio_pin_clear(GPIOB,GPIO_Pin_11)//RES
- //#define OLED_RST_Set() nrf_gpio_pin_set(GPIOB,GPIO_Pin_11)
- #define OLED_CMD 0 //写命令
- #define OLED_DATA 1 //写数据
- //OLED控制用函数
- void OLED_WR_Byte(unsigned dat,unsigned cmd);
- void OLED_Display_On(void);
- void OLED_Display_Off(void);
- void OLED_Init(void);
- void OLED_Clear(void);
- void OLED_DrawPoint(u8 x,u8 y,u8 t);
- void OLED_Fill(u8 x1,u8 y1,u8 x2,u8 y2,u8 dot);
- void OLED_ShowChar(u8 x,u8 y,u8 chr,u8 Char_Size);
- void OLED_ShowNum(u8 x,u8 y,u32 num,u8 len,u8 size);
- void OLED_ShowString(u8 x,u8 y, u8 *p,u8 Char_Size);
- void OLED_Set_Pos(unsigned char x, unsigned char y);
- void OLED_ShowCHinese(u8 x,u8 y,u8 no);
- void OLED_DrawBMP(unsigned char x0, unsigned char y0,unsigned char x1, unsigned char y1,unsigned char BMP[]);
- void Delay_50ms(unsigned int Del_50ms);
- void Delay_1ms(unsigned int Del_1ms);
- void fill_picture(unsigned char fill_Data);
- void Picture();
- void IIC_Start();
- void IIC_Stop();
- void Write_IIC_Command(unsigned char IIC_Command);
- void Write_IIC_Data(unsigned char IIC_Data);
- void Write_IIC_Byte(unsigned char IIC_Byte);
- void IIC_Wait_Ack();
- #endif
main:
- #include <stdbool.h>
- #include <stdint.h>
- #include "led.h"
- #include "oled.h"
- #include "bmp.h"
- * [url=home.php?mod=space&uid=159083]@brief[/url] Function for application main entry.
- int main(void)
- int t;
- // Configure LED-pins as outputs
- LED_Init();
- OLED_Init(); //初始化OLED
- OLED_Clear();
- // LED 0 and LED 1 blink alternately.
- while(true)
- // LED1_Open();
- // LED2_Close();
- // nrf_nrf_nrf_delay_ms(500);
- // LED2_Open();
- // LED1_Close();
- OLED_Clear();
- t++;
- if(t>'~')t=' ';
- OLED_ShowNum(103,6,t,3,16);//显示ASCII字符的码值
- OLED_DrawBMP(0,0,128,8,BMP1); //图片显示(图片显示慎用,生成的字表较大,会占用较多空间,FLASH空间8K以下慎用)
- nrf_delay_ms(8000);
此内容由EEWORLD论坛网友ihalin原创,如需转载或用于商业用途需征得作者同意并注明出处
