找一个包含有SensorTile项目的例程,比如BlueMicrosystem2
打开SensorTile_BlueNRG.h
复制里边SPI部分的宏定义
// SPI Instance #define BNRG_SPI_INSTANCE SPI1 #define BNRG_SPI_CLK_ENABLE() __SPI1_CLK_ENABLE()
// SPI Configuration #define BNRG_SPI_MODE SPI_MODE_MASTER #define BNRG_SPI_DIRECTION SPI_DIRECTION_2LINES #define BNRG_SPI_DATASIZE SPI_DATASIZE_8BIT #define BNRG_SPI_CLKPOLARITY SPI_POLARITY_LOW #define BNRG_SPI_CLKPHASE SPI_PHASE_1EDGE #define BNRG_SPI_NSS SPI_NSS_SOFT #define BNRG_SPI_FIRSTBIT SPI_FIRSTBIT_MSB #define BNRG_SPI_TIMODE SPI_TIMODE_DISABLED #define BNRG_SPI_CRCPOLYNOMIAL 7 #define BNRG_SPI_BAUDRATEPRESCALER SPI_BAUDRATEPRESCALER_16 #define BNRG_SPI_CRCCALCULATION SPI_CRCCALCULATION_DISABLED
// SPI Reset Pin: PH.0 #define BNRG_SPI_RESET_PIN GPIO_PIN_0 #define BNRG_SPI_RESET_MODE GPIO_MODE_OUTPUT_PP #define BNRG_SPI_RESET_PULL GPIO_PULLUP #define BNRG_SPI_RESET_SPEED GPIO_SPEED_LOW #define BNRG_SPI_RESET_ALTERNATE 0 #define BNRG_SPI_RESET_PORT GPIOH #define BNRG_SPI_RESET_CLK_ENABLE() __GPIOH_CLK_ENABLE()
// SCLK: PA.5 #define BNRG_SPI_SCLK_PIN GPIO_PIN_5 #define BNRG_SPI_SCLK_MODE GPIO_MODE_AF_PP #define BNRG_SPI_SCLK_PULL GPIO_PULLDOWN #define BNRG_SPI_SCLK_SPEED GPIO_SPEED_HIGH #define BNRG_SPI_SCLK_ALTERNATE GPIO_AF5_SPI1 #define BNRG_SPI_SCLK_PORT GPIOA #define BNRG_SPI_SCLK_CLK_ENABLE() __GPIOA_CLK_ENABLE()
// MISO (Master Input Slave Output): PA.6 #define BNRG_SPI_MISO_PIN GPIO_PIN_6 #define BNRG_SPI_MISO_MODE GPIO_MODE_AF_PP #define BNRG_SPI_MISO_PULL GPIO_NOPULL #define BNRG_SPI_MISO_SPEED GPIO_SPEED_HIGH #define BNRG_SPI_MISO_ALTERNATE GPIO_AF5_SPI1 #define BNRG_SPI_MISO_PORT GPIOA #define BNRG_SPI_MISO_CLK_ENABLE() __GPIOA_CLK_ENABLE()
// MOSI (Master Output Slave Input): PA.7 #define BNRG_SPI_MOSI_PIN GPIO_PIN_7 #define BNRG_SPI_MOSI_MODE GPIO_MODE_AF_PP #define BNRG_SPI_MOSI_PULL GPIO_NOPULL #define BNRG_SPI_MOSI_SPEED GPIO_SPEED_HIGH #define BNRG_SPI_MOSI_ALTERNATE GPIO_AF5_SPI1 #define BNRG_SPI_MOSI_PORT GPIOA #define BNRG_SPI_MOSI_CLK_ENABLE() __GPIOA_CLK_ENABLE()
// NSS/CSN/CS: PB.2 #define BNRG_SPI_CS_PIN GPIO_PIN_2 #define BNRG_SPI_CS_MODE GPIO_MODE_OUTPUT_PP #define BNRG_SPI_CS_PULL GPIO_PULLUP #define BNRG_SPI_CS_SPEED GPIO_SPEED_HIGH #define BNRG_SPI_CS_ALTERNATE 0 #define BNRG_SPI_CS_PORT GPIOB #define BNRG_SPI_CS_CLK_ENABLE() __GPIOB_CLK_ENABLE()
// IRQ: PC.5 #define BNRG_SPI_IRQ_PIN GPIO_PIN_5 #define BNRG_SPI_IRQ_MODE GPIO_MODE_IT_RISING #define BNRG_SPI_IRQ_PULL GPIO_NOPULL #define BNRG_SPI_IRQ_SPEED GPIO_SPEED_HIGH #define BNRG_SPI_IRQ_ALTERNATE 0 #define BNRG_SPI_IRQ_PORT GPIOC #define BNRG_SPI_IRQ_CLK_ENABLE() __GPIOC_CLK_ENABLE()
// EXTI External Interrupt for SPI // NOTE: if you change the IRQ pin remember to implement a corresponding handler // function like EXTI0_IRQHandler() in the user project #define BNRG_SPI_EXTI_IRQn EXTI9_5_IRQn #define BNRG_SPI_EXTI_IRQHandler EXTI9_5_IRQHandler #define BNRG_SPI_EXTI_PIN BNRG_SPI_IRQ_PIN #define BNRG_SPI_EXTI_PORT BNRG_SPI_IRQ_PORT //#define RTC_WAKEUP_IRQHandler RTC_WKUP_IRQHandler |
在你的HID项目中找到tm32l4xx_nucleo_bluenrg.h
打开stm32l4xx_nucleo_bluenrg.h文件,用刚才复制的SPI宏定义替换
引用: littleshrimp 发表于 2017-4-21 10:21
找一个包含有SensorTile项目的例程,比如BlueMicrosystem2打开SensorTile_BlueNRG.h 复制里边SPI部分 ...
