[经验] MSP430使用IAR时FLASH不够用的解决办法
littleshrimp   2017-9-10 22:52 楼主
今天终于把MSP430G2553的16KByte FLASH写冒了使用手工和编译器做代码优化后空间还是不够用
最后修改IAR配置后轻松解决
Error[e104]: Failed to fit all segments into specified ranges. Problem discovered in segment CODE. Unable to place 138 block(s) (0x378a byte(s) total) in 0x2dd2
byte(s) of memory. The problem occurred while processing the segment placement command "-P(CODE)CODE=C000-FFDF", where at the moment of placement
the available memory ranges were "CODE:d20e-ffdf"
Error while running Linker
把full改成small把default改成smaller
再编译
11 094 bytes of CODE  memory
    287 bytes of DATA  memory (+ 53 absolute )
  4 563 bytes of CONST memory
虾扯蛋,蛋扯虾,虾扯蛋扯虾
回复评论 (3)
前提是不能用printf,sprintf,scanf……这些函数操作No specifier a, A, no specifier n, no float nor long long, ,我的代码里使用了sprintf打印double,结果悲剧了,还要改回来 QQ图片20170910231535.png
虾扯蛋,蛋扯虾,虾扯蛋扯虾
点赞  2017-9-10 23:15
希望做一些大家觉得好用的东西!
点赞  2017-9-11 08:15
对于430这些函数都不建议用,太占资源,做产品也用不到
点赞  2017-9-11 08:32
    写回复
