今天在版主@
littleshrimp的帮助下终于把手机通信搞通了,调试使用的是@
littleshrimp的上位机,可以从
https://bbs.eeworld.com.cn/thread-607573-1-1.html中下载。MCU代码是在BLE Beacon Demo中修改的。 调试过程中走了一个弯路,使用BlueNRG-1 Navigator烧录的hex路径是C:\Program Files (x86)\STMicroelectronics\BlueNRG-1_2 DK 2.5.0\Firmware\BLE_Examples\BlueNRG-1\,不是工程所在路径下的hex,需要用MDK编译完复制到BLE_Examples\BlueNRG-1\对应的路径下。
- /******************** (C) COPYRIGHT 2016 STMicroelectronics ********************
- * File Name : BLE_Beacon_main.c
- * Author : AMS - VMA RF Application Team
- * Version : V1.1.0
- * Date : 20-May-2016
- * Description : BlueNRG-1 main file for beacon device
- * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
- * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
- * AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
- * INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
- * CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
- * INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
- /** @addtogroup BlueNRG1_demonstrations_applications
- * BlueNRG-1 Beacon demo \see BLE_Beacon_main.c for documentation.
- /** \cond DOXYGEN_SHOULD_SKIP_THIS
- /* Includes ------------------------------------------------------------------*/
- #include <stdio.h>
- #include <string.h>
- #include "BlueNRG1_it.h"
- #include "BlueNRG1_conf.h"
- #include "ble_const.h"
- #include "bluenrg1_stack.h"
- #include "sleep.h"
- #include "SDK_EVAL_Config.h"
- #include "Beacon_config.h"
- #include "OTA_btl.h"
- #define H16(x) (((int) (x)) >> 8)
- #define L16(x) (((int) (x)))
- #define H32(x) (((int) (x)) >> 24)
- #define MH32(x) (((int) (x)) >> 16)
- #define L32(x) (((int) (x)) >> 8)
- #define XL32(x) (((int) (x)))
- float vlotage = 3.3;//V
- uint32_t time = 2500;//ms
- float pressure = 101.5;//hPa
- float temperature = 26.2;//degC
- float angleX = 10.2;//deg
- float angleY = 0.3;//deg
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- #define BLE_BEACON_VERSION_STRING "1.1.0"
- /* Set to 1 for enabling Flags AD Type position at the beginning
- of the advertising packet */
- #define ENABLE_FLAGS_AD_TYPE_AT_BEGINNING 1
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- /* Private function prototypes -----------------------------------------------*/
- /* Private functions ---------------------------------------------------------*/
- void Device_Init(void)
- uint8_t ret;
- uint16_t service_handle;
- uint16_t dev_name_char_handle;
- uint16_t appearance_char_handle;
- /* Set the TX Power to -2 dBm */
- ret = aci_hal_set_tx_power_level(1,4);
- if(ret != 0) {
- printf ("Error in aci_hal_set_tx_power_level() 0x%04xr\n", ret);
- while(1);
- /* Init the GATT */
- ret = aci_gatt_init();
- if (ret != 0)
- printf ("Error in aci_gatt_init() 0x%04xr\n", ret);
- else
- printf ("aci_gatt_init() --> SUCCESS\r\n");
- /* Init the GAP */
- ret = aci_gap_init(0x01, 0x00, 0x08, &service_handle,
- &dev_name_char_handle, &appearance_char_handle);
- if (ret != 0)
- printf ("Error in aci_gap_init() 0x%04x\r\n", ret);
- else
- printf ("aci_gap_init() --> SUCCESS\r\n");
- * [url=home.php?mod=space&uid=159083]@brief[/url] Start beaconing
- * @param None
- * @retval None
- static void Start_Beaconing(void)
- uint8_t ret = BLE_STATUS_SUCCESS;
- #if ENABLE_FLAGS_AD_TYPE_AT_BEGINNING
- /* Set AD Type Flags at beginning on Advertising packet */
- uint8_t adv_data[] = {
- /* Advertising data: Flags AD Type */
- 0x02,
- 0x01,
- 0x06,
- 0x17,
- 0x11,
- 0x22,
- 0x33,
- 0x44,
- 0x55,
- 0x66,
- 0x77,
- 0x88,
- 0x99,
- H16(vlotage * 10),
- L16(vlotage * 10),
- H32(time),
- MH32(time),
- L32(time),
- XL32(time),
- H16(pressure * 10),
- L16(pressure * 10),
- H16(temperature * 10),
- L16(temperature * 10),
- H16(angleX * 10),
- L16(angleX * 10),
- H16(angleY * 10),
- L16(angleY * 10),
- #else
- uint8_t manuf_data[] = {
- 26, //len
- AD_TYPE_MANUFACTURER_SPECIFIC_DATA, //manufacturer type
- 0x30, 0x00, //Company identifier code (Default is 0x0030 - STMicroelectronics: To be customized for specific identifier)
- 0x02, // ID
- 0x15, //Length of the remaining payload
- 0xE2, 0x0A, 0x39, 0xF4, 0x73, 0xF5, 0x4B, 0xC4, //Location UUID
- 0xA1, 0x2F, 0x17, 0xD1, 0xAD, 0x07, 0xA9, 0x61,
- 0x00, 0x00, // Major number
- 0x00, 0x00, // Minor number
- 0xC8 //2's complement of the Tx power (-56dB)};
- #endif
- /* disable scan response */
- ret = hci_le_set_scan_response_data(0,NULL);
- if (ret != BLE_STATUS_SUCCESS)
- printf ("Error in hci_le_set_scan_resp_data() 0x%04x\r\n", ret);
- return;
- else
- printf ("hci_le_set_scan_resp_data() --> SUCCESS\r\n");
- /* put device in non connectable mode */
- //32 = 20ms
- ret = aci_gap_set_discoverable(ADV_NONCONN_IND, 160, 160, PUBLIC_ADDR, NO_WHITE_LIST_USE,
- 0, NULL, 0, NULL, 0, 0);
- printf ("Error in aci_gap_set_discoverable() 0x%04x\r\n", ret);
- return;
- else
- printf ("aci_gap_set_discoverable() --> SUCCESS\r\n");
- /* Set the ADV data with the Flags AD Type at beginning of the
- advertsing packet, followed by the beacon manufacturer specific data */
- ret = hci_le_set_advertising_data (sizeof(adv_data), adv_data);
- printf ("Error in hci_le_set_advertising_data() 0x%04x\r\n", ret);
- return;
- else
- printf ("hci_le_set_advertising_data() --> SUCCESS\r\n");
- #else
- /* Delete the TX power level information */
- ret = aci_gap_delete_ad_type(AD_TYPE_TX_POWER_LEVEL);
- printf ("Error in aci_gap_delete_ad_type() 0x%04x\r\n", ret);
- return;
- else
- printf ("aci_gap_delete_ad_type() --> SUCCESS\r\n");
- /* Update the ADV data with the BEACON manufacturing data */
- ret = aci_gap_update_adv_data(27, manuf_data);
- printf ("Error in aci_gap_update_adv_data() 0x%04x\r\n", ret);
- return;
- else
- printf ("aci_gap_update_adv_data() --> SUCCESS\r\n");
- #endif
- static void Update_Beaconing(void)
- 0x02,
- 0x01,
- 0x06,
- 0x17,
- 0x11,
- 0x22,
- 0x33,
- 0x44,
- 0x55,
- 0x66,
- 0x77,
- 0x88,
- 0x99,
- H32(time),
- MH32(time),
- L32(time),
- XL32(time),
- H16(angleX * 10),
- L16(angleX * 10),
- H16(angleY * 10),
- L16(angleY * 10),
- hci_le_set_advertising_data (sizeof(adv_data), adv_data);
- int main(void)
- uint8_t ret;
- uint16_t delay = 0;
- /* System Init */
- SystemInit();
- /* Identify BlueNRG-1 platform */
- SdkEvalIdentification();
- /* Init the UART peripheral */
- SdkEvalComUartInit(UART_BAUDRATE);
- /* BlueNRG-1 stack init */
- ret = BlueNRG_Stack_Initialization(&BlueNRG_Stack_Init_params);
- if (ret != BLE_STATUS_SUCCESS) {
- printf("Error in BlueNRG_Stack_Initialization() 0x%02x\r\n", ret);
- while(1);
- /* Init the BlueNRG-1 device */
- Device_Init();
- #if ST_USE_OTA_SERVICE_MANAGER_APPLICATION
- /* Initialize the button */
- SdkEvalPushButtonInit(BUTTON_1);
- #endif /* ST_USE_OTA_SERVICE_MANAGER_APPLICATION */
- /* Start Beacon Non Connectable Mode*/
- Start_Beaconing();
- printf("BlueNRG-1 BLE Beacon Application (version: %s)\r\n", BLE_BEACON_VERSION_STRING);
- while(1)
- /* BlueNRG-1 stack tick */
- BTLE_StackTick();
- delay = 10000;
- while(delay--);
- Update_Beaconing();
- /* Enable Power Save according the Advertising Interval */
- BlueNRG_Sleep(SLEEPMODE_NOTIMER, 0, 0);
- if (SdkEvalPushButtonGetState(BUTTON_1) == RESET)
- OTA_Jump_To_Service_Manager_Application();
- /****************** BlueNRG-1 Sleep Management Callback ********************************/
- SleepModes App_SleepMode_Check(SleepModes sleepMode)
- if(SdkEvalComIOTxFifoNotEmpty())
- return SLEEPMODE_CPU_HALT;
- return SLEEPMODE_NOTIMER;
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- void assert_failed(uint8_t* file, uint32_t line)
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* Infinite loop */
- while (1)
- #endif
- /******************* (C) COPYRIGHT 2015 STMicroelectronics *****END OF FILE****/
- /** \endcond
