[其他]
vl53l0x测距程序,使用STM32L4R5
STM32CubeMX工程
D15->SCL->PB8
D14->SDA->PB9
- * @file : main.c
- * [url=home.php?mod=space&uid=159083]@brief[/url] : Main program body
- ** This notice applies to any and all portions of this file
- * that are not between comment pairs USER CODE BEGIN and
- * USER CODE END. Other portions of this file, whether
- * inserted by the user or by software development tools
- * are owned by their respective copyright owners.
- * COPYRIGHT(c) 2018 STMicroelectronics
- * Redistribution and use in source and binary forms, with or without modification,
- * are permitted provided that the following conditions are met:
- * 1. Redistributions of source code must retain the above copyright notice,
- * this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright notice,
- * this list of conditions and the following disclaimer in the documentation
- * and/or other materials provided with the distribution.
- * 3. Neither the name of STMicroelectronics nor the names of its contributors
- * may be used to endorse or promote products derived from this software
- * without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
- * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
- * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
- * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
- * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
- /* Includes ------------------------------------------------------------------*/
- #include "main.h"
- #include "stm32l4xx_hal.h"
- /* USER CODE BEGIN Includes */
- #include "component.h"
- #include "stdio.h"
- #include "nucleo144_prox.h"
- /* USER CODE END Includes */
- /* Private variables ---------------------------------------------------------*/
- I2C_HandleTypeDef hi2c1;
- UART_HandleTypeDef hlpuart1;
- /* USER CODE BEGIN PV */
- #ifdef __GNUC__
- #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
- #else
- #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
- #endif /* __GNUC__ */
- void *VL53L0X_0_handler;
- UART_HandleTypeDef UARTHandle;
- volatile uint8_t no_VL53L0X;
- uint16_t range;
- /* USER CODE END PV */
- /* Private function prototypes -----------------------------------------------*/
- void SystemClock_Config(void);
- static void MX_GPIO_Init(void);
- static void MX_I2C1_Init(void);
- static void MX_LPUART1_UART_Init(void);
- /* USER CODE BEGIN PFP */
- /* USER CODE END PFP */
- /* USER CODE BEGIN 0 */
- void PROX_Measurement(void)
- uint8_t proxStatus, pDataready;
- BSP_PROX_IsInitialized( VL53L0X_0_handler, &proxStatus );
- if(proxStatus == 1)
- BSP_PROX_Start_Measurement(VL53L0X_0_handler);
- do
- BSP_PROX_Get_Measurement_DataReady( VL53L0X_0_handler, &pDataready);
- while(!pDataready);
- BSP_PROX_Get_Range(VL53L0X_0_handler, &range);
- /* USER CODE END 0 */
- * @brief The application entry point.
- * @retval None
- int main(void)
- /* USER CODE BEGIN 1 */
- /* USER CODE END 1 */
- /* MCU Configuration----------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* USER CODE BEGIN Init */
- /* USER CODE END Init */
- /* Configure the system clock */
- SystemClock_Config();
- /* USER CODE BEGIN SysInit */
- /* USER CODE END SysInit */
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- MX_I2C1_Init();
- MX_LPUART1_UART_Init();
- /* USER CODE BEGIN 2 */
- if (BSP_PROX_Init( VL53L0X_0, &VL53L0X_0_handler) == COMPONENT_ERROR)
- no_VL53L0X=1;
- printf("BSP_PROX_Init.\r");
- /* USER CODE END 2 */
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- while (1)
- /* USER CODE END WHILE */
- /* USER CODE BEGIN 3 */
- PROX_Measurement();
- printf("%d\r",range);
- /* USER CODE END 3 */
- * @brief System Clock Configuration
- * @retval None
- RCC_OscInitTypeDef RCC_OscInitStruct;
- RCC_ClkInitTypeDef RCC_ClkInitStruct;
- RCC_PeriphCLKInitTypeDef PeriphClkInit;
- /**Configure the main internal regulator output voltage
- if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1_BOOST) != HAL_OK)
- _Error_Handler(__FILE__, __LINE__);
- /**Initializes the CPU, AHB and APB busses clocks
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_MSI;
- RCC_OscInitStruct.MSIState = RCC_MSI_ON;
- RCC_OscInitStruct.MSICalibrationValue = 0;
- RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_6;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_MSI;
- RCC_OscInitStruct.PLL.PLLM = 1;
- RCC_OscInitStruct.PLL.PLLN = 60;
- RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
- RCC_OscInitStruct.PLL.PLLQ = RCC_PLLQ_DIV2;
- RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV2;
- if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
- RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
- |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
- RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
- if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
- PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_LPUART1|RCC_PERIPHCLK_I2C1;
- PeriphClkInit.Lpuart1ClockSelection = RCC_LPUART1CLKSOURCE_PCLK1;
- PeriphClkInit.I2c1ClockSelection = RCC_I2C1CLKSOURCE_PCLK1;
- if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
- /**Configure the Systick interrupt time
- HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
- HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
- /* SysTick_IRQn interrupt configuration */
- HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
- /* I2C1 init function */
- hi2c1.Instance = I2C1;
- hi2c1.Init.Timing = 0x107075B0;
- hi2c1.Init.OwnAddress1 = 0;
- hi2c1.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT;
- hi2c1.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE;
- hi2c1.Init.OwnAddress2 = 0;
- hi2c1.Init.OwnAddress2Masks = I2C_OA2_NOMASK;
- hi2c1.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE;
- hi2c1.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE;
- if (HAL_I2C_Init(&hi2c1) != HAL_OK)
- /**Configure Analogue filter
- if (HAL_I2CEx_ConfigAnalogFilter(&hi2c1, I2C_ANALOGFILTER_ENABLE) != HAL_OK)
- /**Configure Digital filter
- if (HAL_I2CEx_ConfigDigitalFilter(&hi2c1, 0) != HAL_OK)
- /* LPUART1 init function */
- hlpuart1.Instance = LPUART1;
- hlpuart1.Init.BaudRate = 115200;
- hlpuart1.Init.WordLength = UART_WORDLENGTH_8B;
- hlpuart1.Init.StopBits = UART_STOPBITS_1;
- hlpuart1.Init.Parity = UART_PARITY_NONE;
- hlpuart1.Init.Mode = UART_MODE_TX_RX;
- hlpuart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
- hlpuart1.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
- hlpuart1.Init.ClockPrescaler = UART_PRESCALER_DIV1;
- hlpuart1.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
- hlpuart1.FifoMode = UART_FIFOMODE_DISABLE;
- if (HAL_UART_Init(&hlpuart1) != HAL_OK)
- if (HAL_UARTEx_SetTxFifoThreshold(&hlpuart1, UART_TXFIFO_THRESHOLD_1_8) != HAL_OK)
- if (HAL_UARTEx_SetRxFifoThreshold(&hlpuart1, UART_RXFIFO_THRESHOLD_1_8) != HAL_OK)
- /** Configure pins as
- * Analog
- * Input
- * Output
- * EVENT_OUT
- * EXTI
- PD8 ------> USART3_TX
- PD9 ------> USART3_RX
- PA8 ------> USB_OTG_FS_SOF
- PA9 ------> USB_OTG_FS_VBUS
- PA10 ------> USB_OTG_FS_ID
- PA11 ------> USB_OTG_FS_DM
- PA12 ------> USB_OTG_FS_DP
- GPIO_InitTypeDef GPIO_InitStruct;
- /* GPIO Ports Clock Enable */
- __HAL_RCC_GPIOC_CLK_ENABLE();
- __HAL_RCC_GPIOH_CLK_ENABLE();
- __HAL_RCC_GPIOB_CLK_ENABLE();
- __HAL_RCC_GPIOD_CLK_ENABLE();
- __HAL_RCC_GPIOG_CLK_ENABLE();
- HAL_PWREx_EnableVddIO2();
- __HAL_RCC_GPIOA_CLK_ENABLE();
- /*Configure GPIO pin Output Level */
- HAL_GPIO_WritePin(GPIOB, LD3_Pin|LD2_Pin, GPIO_PIN_RESET);
- HAL_GPIO_WritePin(USB_PowerSwitchOn_GPIO_Port, USB_PowerSwitchOn_Pin, GPIO_PIN_RESET);
- /*Configure GPIO pin : B1_Pin */
- GPIO_InitStruct.Pin = B1_Pin;
- GPIO_InitStruct.Mode = GPIO_MODE_IT_RISING;
- GPIO_InitStruct.Pull = GPIO_NOPULL;
- HAL_GPIO_Init(B1_GPIO_Port, &GPIO_InitStruct);
- /*Configure GPIO pins : LD3_Pin LD2_Pin */
- GPIO_InitStruct.Pin = LD3_Pin|LD2_Pin;
- GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
- GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
- HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
- /*Configure GPIO pins : STLK_RX_Pin STLK_TX_Pin */
- GPIO_InitStruct.Pin = STLK_RX_Pin|STLK_TX_Pin;
- GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
- GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
- GPIO_InitStruct.Alternate = GPIO_AF7_USART3;
- HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
- /*Configure GPIO pin : USB_OverCurrent_Pin */
- GPIO_InitStruct.Pin = USB_OverCurrent_Pin;
- GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
- HAL_GPIO_Init(USB_OverCurrent_GPIO_Port, &GPIO_InitStruct);
- /*Configure GPIO pin : USB_PowerSwitchOn_Pin */
- GPIO_InitStruct.Pin = USB_PowerSwitchOn_Pin;
- HAL_GPIO_Init(USB_PowerSwitchOn_GPIO_Port, &GPIO_InitStruct);
- /*Configure GPIO pins : USB_SOF_Pin USB_ID_Pin USB_DM_Pin USB_DP_Pin */
- GPIO_InitStruct.Pin = USB_SOF_Pin|USB_ID_Pin|USB_DM_Pin|USB_DP_Pin;
- GPIO_InitStruct.Alternate = GPIO_AF10_OTG_FS;
- HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
- /*Configure GPIO pin : USB_VBUS_Pin */
- GPIO_InitStruct.Pin = USB_VBUS_Pin;
- HAL_GPIO_Init(USB_VBUS_GPIO_Port, &GPIO_InitStruct);
- /* USER CODE BEGIN 4 */
- PUTCHAR_PROTOTYPE
- HAL_UART_Transmit(&hlpuart1 , (uint8_t *)&ch, 1, 0xFFFF);
- return ch;
- /* USER CODE END 4 */
- * @brief This function is executed in case of error occurrence.
- * @param file: The file name as string.
- * @param line: The line in file as a number.
- * @retval None
- void _Error_Handler(char *file, int line)
- /* USER CODE BEGIN Error_Handler_Debug */
- /* User can add his own implementation to report the HAL error return state */
- while(1)
- /* USER CODE END Error_Handler_Debug */
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t* file, uint32_t line)
- /* USER CODE BEGIN 6 */
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* USER CODE END 6 */
- #endif /* USE_FULL_ASSERT */
- /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
学习学习,后面要做这个模块,
欢迎大家来到电机驱动控制技术天地,一起在EEworld交流、学习。
init(I2C.MASTER, baudrate=20000)
优秀
深圳市全球芯科技 有限公司(加密芯片/SRAM/pSRAM/图像传感器 13924645577 )
