电路图
首页 > 音频视频电路 >耳机放大 > 计算机麦克风电路图
计算机麦克风电路图
2017/02/22
本文所应用到的相关键器件资料: BC413B The sound card for a PC generally has a microphone input, speaker output and sometimes line inputs and outputs. The mic input is designed for dynamic microphones only in impedance range of 200 to 600 ohms. Lazar has adapted the sound card to use a common electret microphone using this circuit. He has made a composite amplifier using two transistors. The BC413B operates in common emitter to give a slight boost to the mic signal. This is followed by an emitter follower stage using the BC547C. This is necessary as the mic and circuit and battery will be some distance from the sound card, the low output impedance of the circuit and screened cable ensuring a clean signal with minimum noise pickup.
提问/讨论
这里还没有内容,您有什么问题吗?
我要提问/讨论
可能感兴趣的电路图
可能感兴趣的器件
推荐帖子
