今天是:2025年01月06日(星期一)
2018年01月06日 | 步进电机LCD显示可设定转数程序
2018-01-06 来源:eefocus
步进电机LCD显示可设定转数程序
#include
#include
#define uchar unsigned char
#define uint unsigned int
#define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};
uchar code FFW[8]={0xf1,0xf3,0xf2,0xf6,0xf4,0xfc,0xf8,0xf9};
uchar code REV[8]={0xf9,0xf8,0xfc,0xf4,0xf6,0xf2,0xf3,0xf1};
sbit K1 = P1^4; //运行与停止
sbit K2 = P1^5; //设定圈数
sbit K3 = P1^6; //方向转换
sbit K4 = P1^7; //速率调整
sbit BEEP = P3^7; //蜂鸣器
sbit LCD_RS = P2^0;
sbit LCD_RW = P2^1;
sbit LCD_EN = P2^2;
bit on_off=0; //运行与停止标志
bit direction=1; //方向标志
bit rate_dr=1; //速率标志
bit snum_dr=1; //圈数标志
uchar code cdis1[ ] = {" STEPPING MOTOR "};
uchar code cdis2[ ] = {"CONTROL PROCESS"};
uchar code cdis3[ ] = {" STOP "};
uchar code cdis4[ ] = {"NUM: RATE: "};
uchar code cdis5[ ] = {" RUNNING "};
uchar m,v=0,q=0;
uchar number=0,number1=0;
uchar snum=5,snum1=5; //预设定圈数
uchar rate=8; //预设定速率
uchar data_temp,data_temp1,data_temp2;
/* 延时t毫秒
/* 11.0592MHz时钟,延时约1ms
void delay(uint t)
uchar k;
while(t--)
for(k=0; k<125; k++)
void delayB(uchar x) //x*0.14MS
uchar i;
while(x--)
for (i=0; i<13; i++)
void beep()
uchar j;
for (j=0;j<100;j++)
delayB(4);
BEEP=!BEEP; //BEEP取反
BEEP=1; //关闭蜂鸣器
delay(170);
/*检查LCD忙状态
/*lcd_busy为1时,忙,等待。为0时,闲,可写指令与数据。
bit lcd_busy()
bit result;
LCD_RS = 0;
LCD_RW = 1;
LCD_EN = 1;
delayNOP();
result = (bit)(P0&0x80);
LCD_EN = 0;
return(result);
/*写指令数据到LCD
/*RS=L,RW=L,E=高脉冲,D0-D7=指令码。
void lcd_wcmd(uchar cmd)
while(lcd_busy());
LCD_RS = 0;
LCD_RW = 0;
LCD_EN = 0;
_nop_();
_nop_();
P0 = cmd;
delayNOP();
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
/*写显示数据到LCD
/*RS=H,RW=L,E=高脉冲,D0-D7=数据。
void lcd_wdat(uchar dat)
while(lcd_busy());
LCD_RS = 1;
LCD_RW = 0;
LCD_EN = 0;
P0 = dat;
delayNOP();
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
/* LCD初始化设定
void lcd_init()
delay(30);
lcd_wcmd(0x38); //16*2显示,5*7点阵,8位数据
delay(5);
lcd_wcmd(0x38);
delay(5);
lcd_wcmd(0x38);
delay(5);
lcd_wcmd(0x0c); //显示开,关光标
delay(5);
lcd_wcmd(0x06); //移动光标
delay(5);
lcd_wcmd(0x01); //清除LCD的显示内容
delay(5);
/* 设定显示位置
void lcd_pos(uchar pos)
lcd_wcmd(pos | 0x80); //数据指针=80+地址变量
/* LCD1602初始显示子程序
void LCD_init_DIS()
delay(10); //延时
lcd_init(); //初始化LCD
lcd_pos(0); //设置显示位置为第一行的第1个字符
m = 0;
while(cdis1[m] != ’\0’)
{ //显示字符
lcd_wdat(cdis1[m]);
m++;
lcd_pos(0x40); //设置显示位置为第二行第1个字符
m = 0;
while(cdis2[m] != ’\0’)
lcd_wdat(cdis2[m]); //显示字符
m++;
delay(3000); //延时
m = 0;
while(cdis3[m] != ’\0’)
{ //显示字符
lcd_wdat(cdis3[m]);
m++;
m = 0;
while(cdis4[m] != ’\0’)
lcd_wdat(cdis4[m]); //显示字符
m++;
for(m=0;m<2;m++)
lcd_pos(0x0c+m); //显示方向符号
lcd_wdat(0x3e);
/*数据转换子程序
void data_conv()
data_temp1=data_temp/10; //高位
if(data_temp1==0)
{data_temp1=0x20;} //高位为0不显示
else
{data_temp1=data_temp1+0x30;}
data_temp2=data_temp%10; //低位
data_temp2=data_temp2+0x30;
/*数据显示子程序
void data_dis()
data_temp = snum; //显示圈数
data_conv();
lcd_pos(0x44);
lcd_wdat(data_temp1);
lcd_pos(0x45);
lcd_wdat(data_temp2);
data_temp = rate; //显示速率
data_conv();
lcd_pos(0x4d);
lcd_pos(0x4e);
/* 显示运行方向符号
void motor_DR()
if(direction==1) //正转方向标志
{ for(m=0;m<2;m++)
lcd_wdat(0x3e);
else
{ for(m=0;m<2;m++) //反转方向标志
lcd_wdat(0x3c);
/* 显示运行状态
void motor_RUN()
if(on_off==1)
{ TR0=1;
m = 0;
while(cdis5[m] != ’\0’)
{ lcd_wdat(cdis5[m]); //RUNNING
m++; }
motor_DR(); //
else
{ TR0=0; P1 =0xf0;
m = 0;
{ lcd_wdat(cdis3[m]); //STOP
m++; }
motor_DR(); //
snum=snum1; //
number1=0; //清圈数计数器
* 主程序
main()
LCD_init_DIS();
TMOD = 0x01; //T0定时方式1
TL0 = 0x33;
TH0 = 0xf5;
EA = 1;
ET0 = 1;
P1 = 0xf0;
while(1)
if(K1==0)
beep();
while(K1==0); //等待键释放
on_off=~on_off;
motor_RUN();
} //K1 end
if(K2==0)
beep();
if(snum_dr==1)
{ snum++;
snum1=snum;
if(snum==0x14)
{ snum_dr=~snum_dr;}
else
{snum--;
snum1=snum;
if(snum==0x01)
{ snum_dr=~snum_dr; }
} //K2 end
if(K3==0)
beep();
direction=~direction;
motor_DR();
}//K3 end
if(K4==0)
beep();
if(rate_dr==1)
{ rate++;
if(rate==0x10)
{ rate_dr=~rate_dr;}
else
rate--;
if(rate==0x01)
{ rate_dr=~rate_dr; }
} //K4 end
if(number1==snum1) //与设定圈数是否相等
{ number1=0;
on_off=0;
TR0=0;
snum=snum1;
P1 =0xf0;
motor_RUN();
data_dis();
} // while(1) end
} //main end
/* 定时器 0 中断
void motor_onoff() interrupt 1
TL0 = 0x33;
TH0 = 0xf5;
q++;
if(q < rate)
{ return; }
else
{ q=0;
number++; //脉冲计数
if(number==96) //96个脉冲电机转一圈
{ snum--;
number=0;
number1++; } //电机转动圈数
if(direction==1) //方向标志
{ if(v<8)
{P1 = FFW[v];v++;} //取数据,正转
if(v==8)
{ v=0; }
else
{ if(v<8)
{P1 = REV[v];v++;} //取数据,反转
if(v==8)
{ v=0; }
在SPI驱动里面接收SPI数据,怎么及时处理SPI数据缓冲区才不会让一帧数据跟下一帧数据起冲突。 在SPI驱动里面接收SPI数据,怎么及时处理SPI数据缓冲区才不会让一帧数据跟下一帧数据起冲突。… 查看全部问答> |
有一台控制器设备,有LAN接口,IP地址是200.200.200.* 直接通过网线连接到电脑上,电脑的IP地址设为200.200.200.*,DNS是255.255.255.0网关设为192.168.1.1则可以连接到控制器,若把IP地址和网关设为其他的却不行,控制器软件只有一个IP地址,把IP ...… 查看全部问答> |
麻烦高手看一下,我用的是增强型uart,pc发送一个“s”给单片机,单片机受到后会给pc发送一个response at 9600 baud 。不知程序是否有问题??? 程序如下: #include \"reg932.h\" #define uchar unsigned char uchar temp; char text[]= ...… 查看全部问答> |
最近又在电子元件技术网上看一个产品介绍中看到了这样的说法“本产品采用16位高精度ADC”,看到这样的文章我真想把这句话改为“本产品采用16位,高精度ADC”。因为实际上16位是分辨率,分辨率和转换精度是一个有联系但本质不同的概念。这也 ...… 查看全部问答> |
