今天是:2025年01月07日(星期二)
2018年01月07日 | AT89C2051简易正弦波\三角波\方波发生器
2018-01-07 来源:eefocus
简易正弦波\三角波\方波发生器
使用keil C51,12MHz晶振,AT89C2051
#include "reg51.h"
#define uchar unsigned char
#define uint unsigned int
#define key P3 //键盘口
#define dataout P1 //正弦波等数据输出口
/*************************正弦波数据表*****************************/
uchar code sin_tab[256]=
{0x80,0x83,0x85,0x88,0x8A,0x8D,0x8F,0x92,
0x94,0x97,0x99,0x9B,0x9E,0xA0,0xA3,0xA5,
0xA7,0xAA,0xAC,0xAE,0xB1,0xB3,0xB5,0xB7,
0xB9,0xBB,0xBD,0xBF,0xC1,0xC3,0xC5,0xC7,
0xC9,0xCB,0xCC,0xCE,0xD0,0xD1,0xD3,0xD4,
0xD6,0xD7,0xD8,0xDA,0xDB,0xDC,0xDD,0xDE,
0xDF,0xE0,0xE1,0xE2,0xE3,0xE3,0xE4,0xE4,
0xE5,0xE5,0xE6,0xE6,0xE7,0xE7,0xE7,0xE7,
0xE7,0xE7,0xE7,0xE7,0xE6,0xE6,0xE5,0xE5,
0xE4,0xE4,0xE3,0xE3,0xE2,0xE1,0xE0,0xDF,
0xDE,0xDD,0xDC,0xDB,0xDA,0xD8,0xD7,0xD6,
0xD4,0xD3,0xD1,0xD0,0xCE,0xCC,0xCB,0xC9,
0xC7,0xC5,0xC3,0xC1,0xBF,0xBD,0xBB,0xB9,
0xB7,0xB5,0xB3,0xB1,0xAE,0xAC,0xAA,0xA7,
0xA5,0xA3,0xA0,0x9E,0x9B,0x99,0x97,0x94,
0x92,0x8F,0x8D,0x8A,0x88,0x85,0x83,0x80,
0x7D,0x7B,0x78,0x76,0x73,0x71,0x6E,0x6C,
0x69,0x67,0x65,0x62,0x60,0x5D,0x5B,0x59,
0x56,0x54,0x52,0x4F,0x4D,0x4B,0x49,0x47,
0x45,0x43,0x41,0x3F,0x3D,0x3B,0x39,0x37,
0x35,0x34,0x32,0x30,0x2F,0x2D,0x2C,0x2A,
0x29,0x28,0x26,0x25,0x24,0x23,0x22,0x21,
0x20,0x1F,0x1E,0x1D,0x1D,0x1C,0x1C,0x1B,
0x1B,0x1A,0x1A,0x1A,0x19,0x19,0x19,0x19,
0x19,0x19,0x19,0x19,0x1A,0x1A,0x1A,0x1B,
0x1B,0x1C,0x1C,0x1D,0x1D,0x1E,0x1F,0x20,
0x21,0x22,0x23,0x24,0x25,0x26,0x28,0x29,
0x2A,0x2C,0x2D,0x2F,0x30,0x32,0x34,0x35,
0x37,0x39,0x3B,0x3D,0x3F,0x41,0x43,0x45,
0x47,0x49,0x4B,0x4D,0x4F,0x52,0x54,0x56,
0x59,0x5B,0x5D,0x60,0x62,0x65,0x67,0x69,
0x6C,0x6E,0x71,0x73,0x76,0x78,0x7B,0x7D};
/***************************三角波数据表**************************/
uchar code thr_tab[256]=
{0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,
0x88,0x89,0x8A,0x8B,0x8C,0x8D,0x8E,0x8F,
0x90,0x91,0x92,0x93,0x94,0x95,0x96,0x97,
0x98,0x99,0x9A,0x9B,0x9C,0x9D,0x9E,0x9F,
0xA0,0xA1,0xA2,0xA3,0xA4,0xA5,0xA6,0xA7,
0xA8,0xA9,0xAA,0xAB,0xAC,0xAD,0xAE,0xAF,
0xB0,0xB1,0xB2,0xB3,0xB4,0xB5,0xB6,0xB7,
0xB8,0xB9,0xBA,0xBB,0xBC,0xBD,0xBE,0xBF,
0xBF,0xBE,0xBD,0xBC,0xBB,0xBA,0xB9,0xB8,
0xB7,0xB6,0xB5,0xB4,0xB3,0xB2,0xB1,0xB0,
0xAF,0xAE,0xAD,0xAC,0xAB,0xAA,0xA9,0xA8,
0xA7,0xA6,0xA5,0xA4,0xA3,0xA2,0xA1,0xA0,
0x9F,0x9E,0x9D,0x9C,0x9B,0x9A,0x99,0x98,
0x97,0x96,0x95,0x94,0x93,0x92,0x91,0x90,
0x8F,0x8E,0x8D,0x8C,0x8B,0x8A,0x89,0x88,
0x87,0x86,0x85,0x84,0x83,0x82,0x81,0x80,
0x7F,0x7E,0x7D,0x7C,0x7B,0x7A,0x79,0x78,
0x77,0x76,0x75,0x74,0x73,0x72,0x71,0x70,
0x6F,0x6E,0x6D,0x6C,0x6B,0x6A,0x69,0x68,
0x66,0x66,0x65,0x64,0x63,0x62,0x61,0x60,
0x5F,0x5E,0x5D,0x5C,0x5B,0x5A,0x59,0x58,
0x55,0x55,0x55,0x54,0x53,0x52,0x51,0x50,
0x4F,0x4E,0x4D,0x4C,0x4B,0x4A,0x49,0x48,
0x44,0x44,0x45,0x44,0x43,0x42,0x41,0x40,
0x40,0x41,0x42,0x43,0x44,0x45,0x46,0x47,
0x48,0x49,0x4A,0x4B,0x4C,0x4D,0x4E,0x4F,
0x50,0x51,0x52,0x53,0x55,0x55,0x56,0x57,
0x58,0x59,0x5A,0x5B,0x5C,0x5D,0x5E,0x5F,
0x60,0x61,0x62,0x63,0x66,0x65,0x66,0x67,
0x68,0x69,0x6A,0x6B,0x6C,0x6D,0x6E,0x6F,
0x70,0x71,0x72,0x73,0x77,0x75,0x76,0x77,
0x78,0x79,0x7A,0x7B,0x7C,0x7D,0x7E,0x7F};
uint data THHL=65535; //T1的16位定时器初值
uchar data keyword,n=0; //键值存放,查表指针
bdata sinthr;
sbit sin_thr=sinthr^0; //正弦波\三角波标志(1为正弦波)
sbit ww=key^7; // 方波输出口
/*******************************键扫描子函数***********************************/
keysCAN()
keyword=key&0x07;
if(keyword!=0x07)
while((key&0x07)!=0x07);//等待键释放
switch(keyword)
case 6:{if(THHL>=65235)THHL=65535;else{THHL=THHL+255;}break;}//
case 5:{if(THHL<=500)THHL=0;else{THHL=THHL-255;}break;}//
case 3:{sin_thr=~sin_thr;break;}//
default:{break;}//
/***************************初始化函数****************************************/
clearmen()
key=0xff,dataout=0x00;THHL=65535;//按键输入状态,波形输出为0
TH1=THHL/256;TL1=THHL%256;//装定时初值(T1用)
TMOD=0X11;ET1=1;TR1=1;EA=1;//16 位定时模式,T1中断允许,开定时器,开总中断
/*********************************主函数***************************************/
main()
clearmen();
while(1)
keyscan();
/***********************************T1中断函数**********************************/
void time_intt1(void) interrupt 3
EA=0;TR1=0;TH1=THHL/256;TL1=THHL%256;TR1=1;
if(sin_thr){dataout=sin_tab[n];}
else {dataout=thr_tab[n];}
if(n>=255){n=0;}else{ n++;}
ww=~ww;
EA=1;
//***********************************结束****************************************//
上一篇:AT89C51快热式热水器程序
下一篇:51单片机快热式热水器程序
最近想做一个Wince下的程序,能在程序中显示网页。 由于wince不支持htmlview类,所以使用了IWebBrowser2来实现 参考http://www.vckbase.com/document/viewdoc/?id=1145做了一个, 但是程序窗口本身不能显示网页,是另外打开了IE来显示网页。 大 ...… 查看全部问答> |
OS Image中已经添加了sdbus和自己的SDHC的驱动、SDMemory,注册表中也添加了相关的设置,现在的情况是:使用类似“DSK1:”这样的名字CreateFile获得的句柄可以通过DeviceIoControl 获得到相应的SD Card的ID,而使用“\\\\Storage Card\\\\VOL:”来C ...… 查看全部问答> |
在nmd中回车的功能是进入下一级页面。但并不是靠VK_RETURN消息实现的,代码中有句注释如下 // NOTE: VK_RETURN is actualy handled by LBN_DBLCLK in the WMCommand handler 但我搜遍整个nmd目录未发现那里有将回车消息转换了,难道是在nmd目录外 ...… 查看全部问答> |
我需要通过read_reg()读取VK3224(扩展芯片)寄存器的值,但是在接收中断处理时,接收FIFO中会有好几个数据,导致读取出来的是错误数据,unsigned char send(unsigned char data1,unsigned char data2) { unsigned int temp1, i; unsigned char t ...… 查看全部问答> |
