今天是:2025年01月12日(星期日)
2018年01月12日 | 智能家居控制系统C程序
2018-01-12 来源:eefocus
#include
bit r_flag;
enum eepromtype {M2401,M2402,M2404,M2408,M2416,M2432,M2464,M24128,M24256};
extern bit RW24XX(unsigned char *DataBuff,unsigned char ByteQuantity,unsigned int Address, unsigned char ControlByte,enum eepromtype EepromType);
sbit key = P2^0;
bit key_flag;
sbit dog = P0^7;
sbit LED = P0^0;
sbit TELA = P3^6;
sbit TEL = P3^7;
sbit RING = P3^2;
sbit switching =P0^4;
unsigned char mode;
bit passwordflag;
unsigned char password[6];
unsigned char passwordtest[6];
void dlms(unsigned int x);
void reset(void);
void open(void);
// INT1中断服务程序 //
unsigned char ring_fluctuation;
unsigned char ring_count;
bit ring_flag;
void servICe_int0() interrupt 0 using 1
if(ring_fluctuation<10)
ring_fluctuation++;
// t1 定时中断 //
unsigned char ring_dlsm;
unsigned char ring_time;
unsigned int ring_reset_time;
unsigned char dlms_time;
void timer1 (void) interrupt 3 using 0
TH1=0x3c;
TL1=0xb0;
dlms_time++;
if(ring_fluctuation>5)
EX0=0;//INT1_OFF;
ring_dlsm++;
if(ring_dlsm==20)//等待一秒
ring_dlsm=0;
EX0=1;//INT1_ON;
ring_fluctuation=0;
ring_count++;//震铃次数
if(ring_flag)//有效振铃
if(ring_count==6)
ring_count=7;
mode=1;
else//无效振铃
if(ring_count>2)
ring_reset_time=800;
if((ring_count==2)|(ring_count==1))
ring_time++;
if(ring_time==200)
ring_flag=1;
if((ring_count>0)&(ring_count<6))
LED=INT0;
else if(passwordflag)
LED=~LED;
if(ring_count>0)
ring_reset_time++;
if(ring_reset_time==1100)//55s
reset();
LED=0;
dlms(100);
LED=1;
dlms(100);
LED=0;
dlms(100);
LED=1;
dlms(100);
LED=0;
dlms(100);
LED=1;
dlms(100);
LED=0;
dlms(100);
LED=1;
dlms(100);
LED=0;
dlms(100);
LED=1;
dlms(100);
LED=0;
dlms(100);
LED=switching;
// INT1中断服务程序 //
unsigned char DTMF;
void service_int1() interrupt 2 using 1
EX1=0;
DTMF=P1;
DTMF=DTMF>>4;
void main(void)
TMOD=0x11;
TH1=0x3c;
TL1=0xb0;
TR1=1;
ET1=1;
IT0=1;
EX0=1;
IT1=0;
EX1=1;
reset();
EA=0;
r_flag=RW24XX(password,6,0x0000,0xa1,M2402);//R
if(P2_0==0)
dlms(20);
if(P2_0==0)
ring_flag=1;
mode=1;
passwordflag=1;
ring_count=7;
ring_fluctuation=6;
EA=1;
while(1)
open();
dog=~dog;
switch(mode)
case 0:;
break;
case 1:
TEL=1;
LED=0;//
dlms_time=0;
ring_reset_time=0;
while(dlms_time<40)
dlms(1);
TELA=~TELA;
ring_reset_time=0;
LED=1;//
TELA=0;
mode++;
DTMF=255;
EX1=1;
LED=switching;
break;
case 2://password
if(DTMF!=255)
passwordtest[0]=DTMF;
if(INT1==1)
dlms_time=0;
while(dlms_time<2);
if(INT1==1)
DTMF=255;
mode++;
dlms_time=0;
while(dlms_time<10)
dlms(2);
TELA=~TELA;
EX1=1;
TELA=0;
break;
case 3://password
if(DTMF!=255)
passwordtest[1]=DTMF;
if(INT1==1)
dlms_time=0;
while(dlms_time<2);
if(INT1==1)
DTMF=255;
mode++;
dlms_time=0;
while(dlms_time<10)
dlms(2);
TELA=~TELA;
EX1=1;
TELA=0;
break;
case 4://password
if(DTMF!=255)
passwordtest[2]=DTMF;
if(INT1==1)
dlms_time=0;
while(dlms_time<2);
if(INT1==1)
DTMF=255;
mode++;
dlms_time=0;
while(dlms_time<10)
dlms(2);
TELA=~TELA;
EX1=1;
TELA=0;
break;
case 5://password
if(DTMF!=255)
passwordtest[3]=DTMF;
if(INT1==1)
dlms_time=0;
while(dlms_time<2);
if(INT1==1)
DTMF=255;
mode++;
dlms_time=0;
while(dlms_time<10)
dlms(2);
TELA=~TELA;
EX1=1;
TELA=0;
break;
case 6://password
if(DTMF!=255)
passwordtest[4]=DTMF;
if(INT1==1)
dlms_time=0;
while(dlms_time<2);
if(INT1==1)
DTMF=255;
mode++;
dlms_time=0;
while(dlms_time<10)
dlms(2);
TELA=~TELA;
EX1=1;
TELA=0;
break;
case 7://password
if(DTMF!=255)
passwordtest[5]=DTMF;
if(INT1==1)
dlms_time=0;
while(dlms_time>2);
if(INT1==1)
DTMF=255;
mode++;
//EX1=1;
break;
case 8:
if(passwordflag==0)
if((passwordtest[0]==password[0])&(passwordtest[1]==password[1])&(passwordtest[2]==password[2])&(passwordtest[3]==password[3])&(passwordtest[4]==password[4])&(passwordtest[5]==password[5]))
mode++;
dlms_time=0;
else
reset();
else
dlms_time=0;
while(dlms_time<10)
dlms(2);
TELA=~TELA;
TELA=0;
password[0]=passwordtest[0];
password[1]=passwordtest[1];
password[2]=passwordtest[2];
password[3]=passwordtest[3];
password[4]=passwordtest[4];
password[5]=passwordtest[5];
EA=0;
r_flag=RW24XX(password,6,0x0000,0xa0,M2402);//W
EA=1;
reset();
break;
case 9:
while(dlms_time<20)
dlms(1);
TELA=~TELA;
while(dlms_time<25)
while(dlms_time<45)
dlms(1);
TELA=~TELA;
TELA=0;
EX1=1;
mode++;
break;
case 10:
switch(DTMF)
case 1:
if(ring_reset_time<1050)
dlms_time=0;
switching=0;
LED=0;
while(dlms_time<10)
while(dlms_time<20)
dlms(2);
TELA=~TELA;
while(dlms_time<30)
while(dlms_time<40)
dlms(2);
TELA=~TELA;
TELA=0;
DTMF=255;
EX1=1;
break;
case 2:
dlms_time=0;
switching=1;
LED=1;
while(dlms_time<10)
while(dlms_time<20)
dlms(4);
TELA=~TELA;
while(dlms_time<30)
while(dlms_time<40)
dlms(4);
TELA=~TELA;
TELA=0;
DTMF=255;
EX1=1;
break;
case 12:
reset();
break;
break;
default:;
void reset(void)
TEL=0;
TELA=0;
ring_fluctuation=0;
ring_count=0;
ring_flag=0;
ring_dlsm=0;
ring_time=0;
dlms_time=0;
ring_reset_time=0;
key_flag=0;
mode=0;
EX1=1;
DTMF=255;
LED=switching;
passwordflag=0;
passwordtest[0]=255;
passwordtest[1]=255;
passwordtest[2]=255;
passwordtest[3]=255;
passwordtest[4]=255;
passwordtest[5]=255;
void open(void)
if((key==0)&(key_flag==0)&(passwordflag==0))
dlms_time=0;
while(dlms_time<2);
if(key==0)
reset();
key_flag=1;
switching=~switching;
LED=switching;
dlms_time=0;
if((key==1)&(dlms_time>10))
key_flag=0;
unsigned int i;
while (x-->0)
dog=~dog;
for (i=0;i<163;i++)
//24cxx
//----------------------------------------------START----------------------------------------------//
//enum eepromtype {M2401,M2402,M2404,M2408,M2416,M2432,M2464,M24128,M24256};
//extern bit RW24XX(unsigned char *DataBuff,unsigned char ByteQuantity,unsigned int Address,
// unsigned char ControlByte,enum eepromtype EepromType);
// flag=RW24XX(&x,1,0x0000,0xa0,M24256);//W 24C256
// flag=RW24XX(&x,1,0x0000,0xa1,M24256);//R 24C256
#include
//#pragma ot(6,SIZE)
#include
#define ERRORCOUNT 10
sbit SDA=P2^7;//对应硬件
sbit SCL=P2^6;//对应硬件
enum eepromtype EepromType;
//DataBuff为读写数据输入/输出缓冲区的首址
//ByteQuantity 为要读写数据的字节数量
//Address 为EEPROM的片内地址
//ControlByte 为EEPROM的控制字节,具体形式为(1)(0)(1)(0)(A2)(A1)(A0)(R/W),其中R/W=1,
//表示读操作,R/W=0为写操作,A2,A1,A0为EEPROM的页选或片选地址;
//EepromType为枚举变量,需为M2401至M24256中的一种,分别对应24C01至24C256;
//函数返回值为一个位变量,若返回1表示此次操作失效,0表示操作成功;
//ERRORCOUNT为允许最大次数,若出现ERRORCOUNT次操作失效后,则函数中止操作,并返回1
void Delay(unsigned char DelayCount);
void IICStart(void);
void IICStop(void);
bit IICRecAck(void);
void IICNoAck(void);
void IICAck(void);
unsigned char IICReceiveByte(void);
void IICSendByte(unsigned char sendbyte);
unsigned char data j,i=ERRORCOUNT;
bit errorflag=1;
while(i--)
IICStart();
IICSendByte(ControlByte&0xfe);
if(IICRecAck())
continue;
if(EepromType>M2416)
IICSendByte((unsigned char)(Address>>8));
if(IICRecAck())
continue;
IICSendByte((unsigned char)Address);
if(IICRecAck())
continue;
if(!(ControlByte&0x01))
j=ByteQuantity;
errorflag=0; //********clr errorflag
while(j--)
IICSendByte(*DataBuff++);
if(!IICRecAck())
continue;
errorflag=1;
break;
if(errorflag==1)
continue;
break;
else
IICStart();
IICSendByte(ControlByte);
if(IICRecAck())
continue;
while(--ByteQuantity)
*DataBuff++=IICReceiveByte();
IICAck();
*DataBuff=IICReceiveByte(); //read last byte data
IICNoAck();
errorflag=0;
break;
IICStop();
Delay(255);
Delay(255);
Delay(255);
Delay(255);
return(errorflag);
/*****************以下是对IIC总线的操作子程序***/
/*****************启动总线**********************/
void IICStart(void)
SCL=0; //
SDA=1;
SCL=1;
_nop_();
_nop_();
_nop_();
SDA=0;
_nop_();
_nop_();
_nop_();
_nop_();
SCL=0;
SDA=1; //
/*****************停止IIC总线****************/
void IICStop(void)
SCL=0;
SDA=0;
SCL=1;
_nop_();
_nop_();
_nop_();
SDA=1;
_nop_();
_nop_();
_nop_();
SCL=0;
/**************检查应答位*******************/
bit IICRecAck(void)
SCL=0;
SDA=1;
SCL=1;
_nop_();
_nop_();
_nop_();
_nop_();
CY=SDA; //因为返回值总是放在CY中的
SCL=0;
return(CY);
/***************对IIC总线产生应答*******************/
void IICACK(void)
SDA=0;
SCL=1;
_nop_();
_nop_();
_nop_();
_nop_();
SCL=0;
_nop_();
SDA=1;
/*****************不对IIC总线产生应答***************/
void IICNoAck(void)
SDA=1;
SCL=1;
_nop_();
_nop_();
_nop_();
_nop_();
SCL=0;
/*******************向IIC总线写数据*********************/
unsigned char data j=8;
for(;j>0;j--)
SCL=0;
sendbyte<<=1; //无论C51怎样实现这个操作,始终会使CY=sendbyte^7;
SDA=CY;
SCL=1;
SCL=0;
/**********************从IIC总线上读数据子程序**********/
register receivebyte,i=8;
SCL=0;
while(i--)
SCL=1;
receivebyte=(receivebyte<<1)|SDA;
SCL=0;
return(receivebyte);
/***************一个简单延时程序************************/
while(DelayCount--);
上一篇:智能家居控制系统VB上的代码
下一篇:单片机双机通信c51程序
装上ccs3.3之后,tds510不能仿真c6713,能进入也能load程序,就是执行其他操作就出问题,说什么芯片保护不让仿真器读写寄存器。过去使用3.1的时候没有出现这个问题的。不知道是怎么回事。:L… 查看全部问答> |
对于一般比较小的程序,我们可以通过观察仿真波形来查看我们的设计,但当程序稍微复杂一点,面对着仿真波形,我们有时眼都看花了,说不定还把错误给漏了,真的得不尝失啊,别急,这时我们可以采用另一种重型武器—Verilog提供的那些用于仿真的语句 ...… 查看全部问答> |
目标:启用RTC CPU:ARM 710 过程: >0x18跳到中断服务例程指令(IRQ) >配置RTC各参数.最后使能RTC_CRH.GEN >配置EIC.有EIC_SIR3(配置服务例程偏移及等级(15),RTC全局中断向量号为3) EIC_IVR(配置服务例 ...… 查看全部问答> |
各位前辈就是这样的如题,这个是个作业老师布置的哎,,,可是老师上课没教,还说这个自己了解下,可是网上的资料很不完整,各位前辈教教我我希望有图和完整的程序拜托给位前辈了哈我邮箱是598856544@qq.com… 查看全部问答> |
《Google Android开发技术》,西电出版,作者:张勇,2011.10 内 容 简 介 Android系统是安装在智能移动设备上的嵌入式操作系统,包括Linux内核、系统库与Java运行时、应用程序框架和应用程序层等四部分,具有公开源代码 ...… 查看全部问答> |
