今天是:2025年01月24日(星期五)
2018年01月24日 | 89C51单片机控制HT1621B驱动LCD(C程序)
2018-01-24 来源:eefocus
//********WAVE-E6000/T***************
//*MCU: AT89C51 *
//*MCU-crystal: 12M *
#include
#include
#define uint unsigned int
#define uchar unsigned char
sbit P1_0=P1^0;
sbit P1_1=P1^1;
sbit P1_2=P1^2;
sbit P2_0=P2^0;
sbit P2_1=P2^1;
sbit P2_2=P2^2;
sbit P2_3=P2^3;
sbit P2_4=P2^4;
sbit P2_5=P2^5;
sbit P2_6=P2^6;
sbit P2_7=P2^7;
sbit P3_6=P3^6;
sbit P3_7=P3^7;
sbit P0_7=P0^7;
//定义LCD的连接端口
#define LCD_RS P2_5
#define LCD_RW P2_6
#define LCD_EN P2_7
#define BUSY P0_7
#define LCDPort0 P0
#define SCL P3_6
#define SDA P3_7
#define K1 P1_0
#define K2 P1_1
#define K3 P1_2
static uchar bdata StateREG; //可位寻址的状态寄存器
sbit CY1 = StateREG^1; //状态
uchar Command_Code;
uchar Command_Code_No;
uchar Buf_Code;
uchar Buf_Add;
uchar cont;
uchar code Table[]={0x48,0x65,0x6c,0x6c,0x6f,0x20,0x52,0x49,
0x53,0x49,0x4f,0x4e,0x00}; //"Hello RISION"
//函数原型声明 *****************
void LCDBusy(void);
void LCDWrite_Command(void);
void LCDWrite_Command_No(void);
void INITLCD(void);
void LCDWrite_Data(uchar Buf_Data);
void _nop_(void);
void delay_ms(uchar ms);
void LCDWrite_String(void);
void STA(void);
void STOP(void);
void Write_DATA();
void Read_DATA();
void WRBYT(uchar EEROM_Buf);
//延时最大255毫秒
uchar i,j;
for(j=0;j
_nop_();
//写一个命令字节,不进行忙检测
void LCDWrite_Command_No()
LCD_EN=0;
LCD_RS=0;
LCD_RW=0;
LCDPort0=Command_Code_No;
LCD_EN=1 ;
_nop_();
LCD_EN=0;
//写一个命令字节,进行忙检测
void LCDWrite_Command()
LCDBusy();
LCD_EN=0;
LCD_RW=0;
LCD_RS=0;
LCD_EN=1;
LCDPort0=Command_Code;
LCD_EN=0;
//LCD状态检测
void LCDBusy()
uchar BUSY_A;
do{
LCDPort0=0xFF;
LCD_EN=0;
LCD_RS=0;
LCD_RW=1;
LCD_EN=1;
BUSY_A=LCDPort0;
LCD_EN=0;
while ((BUSY_A&0x80)!=0x00);
void INITLCD()
delay_ms(15);
Command_Code=0x38;
LCDWrite_Command_No();
delay_ms(5);
Command_Code=0x38;
delay_ms(5);
Command_Code=0x38;
Command_Code=0x38;
LCDWrite_Command(); //设定LCD为16*2显示,5*7点阵,8位数据接口
Command_Code=0x01;
LCDWrite_Command(); //显示清屏。
Command_Code=0x06;
LCDWrite_Command(); //显示光标自动右移,整屏不移动。
Command_Code=0x0C;
LCDWrite_Command(); //开显示,不显示光标
//写一个命令字节,进行忙检测
void LCDWrite_Data(uchar Buf_Code)
// Buf_Code=Buf_Code|0x40;
LCDBusy();
LCD_EN=0;
LCD_RW=0;
LCD_RS=1;
LCD_EN=1;
LCDPort0=Buf_Code;
LCD_EN=0;
void LCDWrite_String()
Command_Code=0xC2;cont=0;
do{
LCDWrite_Command();
Command_Code++;
LCDWrite_Data(Table[cont]);
cont++;
while(Table[cont]!=0x00);
return;
void STA()
SDA=1;
_nop_();
_nop_();
SCL=1;
_nop_();
_nop_();
SDA=0;
void STOP()
SDA=0;
_nop_();
_nop_();
SCL=1;
_nop_();
_nop_();
SDA=1;
void main()
INITLCD();
Command_Code=0x80;
LCDWrite_Command(); //将数据指针设置到第一行的第一个字符。
LCDWrite_Data(0x37);
LCDWrite_String();
while(1);
由于CPLD数字设计结构化的趋势,将出现针对CPLD不同层次的IP(Intellectual Property)核。各个IP核可重复利用,可大大提高设计能力和效率。国外各大公司都推出了专门的IP核,我国也迫切需要发展自己的IP核。本文针对I2C的主方式串行扩展通信的特点, ...… 查看全部问答> |
LED 的排列方式及LED 光源的规范决定着基本的驱动器要求。LED 驱动器的主要功能就是在一定的工作条件范围下限制流过LED 的电流, 而无论输入及输出电压如何变化。最常用的是采用变压器来进行电气隔离。文中论述了LED 照明设计需要考虑的因素 一、L ...… 查看全部问答> |
ARM7 44b0,用ADS1.20编译调试。 代码中定义了这样一个函数device_run,如下。 BOOL device_run(BYTE type) { BYTE setAttributeValue; MAC_ENUM status; ...… 查看全部问答> |
各位仁兄: 小弟有项目如下: 基于S3C2416的串口驱动程序,串口芯片16550, 现在有MDD+PDD(中间层)缺少最低层对16550的初始化代码 由于时间关系,现将项目外包 ...… 查看全部问答> |
VS2008如何开发WINDOWS CE .NET 4.2的应用程序 我现在手里有一个MOTOROLA MC1000的设备,装的系统是WINDOWS CE .NET 4.2 在网上看了下 说.NET 可以开发移动设备的程序,所以就下了个试了下 我打开VS2008 - 新建 智能设备项目 - 目标平台我选的是 WINDOWS CE - .NET CF 我选的是 CF2.0 写了个T ...… 查看全部问答> |
