今天是:2025年02月07日(星期五)
2018年02月07日 | 低功耗无线PIR运动检测参考设计--TIDA-01476解决方案
2018-02-07 来源:互联网
TI公司的TIDA-01476是低功耗无线PIR运动检测参考设计,能创建工业传感器到云端节点,连接到IoT网络网关和云数据提供者.参考设计采用微功耗运放,比较器和SimpleLink™超低功耗小于1GHz无线微控制器(MCU)平台等器件,以形成超低功耗传感器-云运动检测器,具有超长电池寿命和不需要连线.连接长度高达1000米,满足IEEE 802.15.4e/g标准,主要用在运动检测,照明传感器,无线控制和建筑物自动化.本文介绍了参考设计TIDA-01476主要特性和系统指标,框图,电路图,材料清单和PCB设计图.
The TIDA-01476 reference design demonstrates howto create an industrial sensor-to-cloud end nodecapable of connecting to an IoT network gateway andcloud data provider. This design uses TexasInstruments’ nano-power operational amplifiers,comparators, and the SimpleLink™ ultra-low-powerSub-1 GHz wireless microcontroller (MCU) platform todemonstrate an ultra-low-power sensor-to-cloudmotion detector, leading to extremely long battery lifeand no required wiring.
This reference design demonstrates how to create an industrial sensor-to-cloud end node capable of connecting to an IoT network gateway and cloud data provider. This design uses Texas Instruments’ nano-power operational amplifiers, comparators, and the SimpleLink™ ultra-low-power Sub-1 GHz wireless microcontroller (MCU) platform to demonstrate an ultra-low-power sensor-to-cloud motion detector, leading to extremely long battery life and no required wiring.
Many industrial and building automation systems use motion detectors to control different functions basedon human presence, such as lighting, for achieving higher efficiency of those functions by turning them offwhen not needed. Additionally, these systems require increasing numbers of wireless sensor nodes toreduce the installation costs and the make the systems more flexible for future expansion by eliminatingwiring. However, one of the major limitations for a large wireless network is power. Because thesesystems are battery powered, the maintenance cost associated with periodic battery replacement can become prohibitive. Depending on the power consumption and battery configuration, typical batterypoweredPIR motion detectors can run anywhere from four to seven years before the batteries need to bereplaced.
Enabled by Texas Instruments ’nano-power amplifiers, comparators, and the SimpleLink ultra-low-powerwireless MCU platform, the Low-Power Wireless PIR Motion Detector Reference Design demonstrates amotion detector circuit solution requiring no wiring while also fully maximizing the battery life.
At a high level, this TI Design consists of a CR2032 coin cell battery, two nano-power op amps, two nanopowercomparators, an ultra-low-power wireless MCU, and a PIR sensor with analog signal output. Thetwo op amps form an amplified band-pass filter with a high-input impedance, which allows it to beconnected directly to the sensor without loading it. The two comparators form a window comparator, whichis used to compare the amplified sensor output to fixed reference thresholds so that motion can bedistinguished from noise. The two outputs of the window comparator then serve as interrupts to the wireless MCU. This way, the MCU can operate in its lowest power sleep mode during times where there isno motion being detected and only wakes up to send messages back to a remote host when motion hasbeen detected. Due to the nano-amp operation of the analog signal chain components, this TI Designachieves a 10-year battery life from a single CR2032 coin cell battery.
This design guide addresses component selection, design theory, software and the testing results of thisTI Design system. The scope of this design guide gives system designers a head-start in integrating TI’snano-power analog components, and the SimpleLink ultra-low-power wireless MCU platform along with astarting point for sensor-to-cloud software integration.
参考设计TIDA-01476主要特性:
• Large Network-to-Cloud Connectivity EnablingLong Range, Up to 1 km (Line of Sight)
• IEEE 802.15.4e/g Standards-Based Sub-1 GHzSolution With TI 15.4-Stack
• Use of Nano-Power Analog for Ultra-Low-PowerDesign, Resulting in 10-Year Battery Life FromSingle CR2032 Coin Cell
• Low Standby Current of 1.65 μA (PIR SensorRemains Active in Standby)
• Interrupt Driven Sub-1 GHz WirelessCommunication of Motion for Increased Power Savings
• Motion Sensitivity up to 30 ft
参考设计TIDA-01476应用:
• Motion Detection
• Lighting Sensors
• Wireless Controls
• Building Automation
大多数嵌入式产品的显示终端都选择LCD,但在某些需要大屏幕显示的应用中,工业级LCD的价格比较昂贵,且现有的大屏幕显示器(包括CRT显示器和LCD显示器)一般都采用统一的15针VGA显示接口.三星公司ARM9芯片S3C2410以其强大的功能和高性价比在目前嵌入式产 ...… 查看全部问答> |
我用的单片机是F149,在程序中发现有只用一次的屏幕显示函数被调用多次,请大家给分析一下,我自己认为是TimerA引起的。 我的这段程序是单片机C语言,在运行时发现屏幕显示函数被多次调用,实际我只用了一次。大家给点意思看看是哪里的问题。我自 ...… 查看全部问答> |
各位ggjj求助:IAR中修改程序,可是可执行文件没有变化! 我在IAR编译器中,直接修改程序代码,进行编译以后,生成的可执行文件,跟修改之前的一模一样,没有变化。 我整整调试了一晚上了,出现这种问题,好郁闷!!! 这是怎么回事,我该怎么解决???… 查看全部问答> |
MCBSP2 外接ALC5621 codec IC,在播放音乐时,不能发声,输出仅变成了高电平。 MCBSP2_CLKX 1.536M,MCBSP2_FSX 48K,以下是相关寄存器 配置。 MCBSPLP_PCR_REG配置成下降沿发送数据, CLKXP Transmit Clock Polarity RW 0x0 0x0: Transmit dat ...… 查看全部问答> |
本设计要求作出一种多路模拟信号采集模块,从多个通道轮流采集数据一次,并将数据保存于记录。本系统采用AT89C52作为控制系统,核心器件采用TI公司的高精度12BIT ,11通道一步采样AD芯片TLC2543。分别从11路采样模拟信号,实现11路数据采集。为了做 ...… 查看全部问答> |
实现功能 将音频频谱显示在BBB 的液晶屏上 硬件设计电路 音频采集电路,以及一些信号放大电路 软件设计 使用BBB的AD 将信号前端处理后的信号进行AD 转换,然后使用fftw进行傅里叶变换,根据需要决定是否使用neon指令集和posix线程库 预 ...… 查看全部问答> |
【瑞萨R7F0C80212试用】一步一步玩R7F0C80212之第二弹 上电初实验 根据第一弹的描述,相信大家对于板子的所有套件以及板子的布局已经了如指掌了,既然已经开始拿到板子了,我们就开始来上电试试有什么效果吧。。 开发板 ...… 查看全部问答> |
这是在国赛前做的,为准备国赛练练手,没做全题 动力用的是57步进;步进电机驱动器是 TB-6560;1000线编码器;F103主控。 使用编码器需要注意的问题:虽然使用编码器能够得到准确的角度信息,基本用不上滤波,可以直接使用,但是对角速度信 ...… 查看全部问答> |
