今天是:2025年03月09日(星期日)
2018年03月09日 | 基于HI-TECH C的PIC12C508读写93LC4源程序
2018-03-09 来源:eefocus
* Processer : MICroChip PIC12C508 *
* Compiler : Hi-TECH PICC 8.00 PL2 *
* Writer : Jason Kuo *
* Description : It CAN read/write 93LC46 (64 x 16-bit organization) *
static volatile unsigned char RTCC @ 0x01;
static volatile unsigned char TMR0 @ 0x01;
static volatile unsigned char PCL @ 0x02;
static volatile unsigned char STATUS @ 0x03;
static unsigned char FSR @ 0x04;
static volatile unsigned char OSCCAL @ 0x05;
static volatile unsigned char GPIO @ 0x06;
static unsigned char control OPTION @ 0x00;
static volatile unsigned char control TRIS @ 0x06;
/* STATUS bits */
static bit GPWUF @ (unsigned)&STATUS*8+7;
static bit PA0 @ (unsigned)&STATUS*8+5;
static bit TO @ (unsigned)&STATUS*8+4;
static bit PD @ (unsigned)&STATUS*8+3;
static bit ZERO @ (unsigned)&STATUS*8+2;
static bit DC @ (unsigned)&STATUS*8+1;
static bit CARRY @ (unsigned)&STATUS*8+0;
/* OPTION bits */
#define GPWU (1<<7)
#define GPPU (1<<6)
#define T0CS (1<<5)
#define T0SE (1<<4)
#define PSA (1<<3)
#define PS2 (1<<2)
#define PS1 (1<<1)
#define PS0 (1<<0)
/* OSCCAL bits */
static volatile bit CAL3 @ (unsigned)&OSCCAL*8+7;
static volatile bit CAL2 @ (unsigned)&OSCCAL*8+6;
static volatile bit CAL1 @ (unsigned)&OSCCAL*8+5;
static volatile bit CAL0 @ (unsigned)&OSCCAL*8+4;
static volatile bit GP5 @ (unsigned)&GPIO*8+5;
static volatile bit GP4 @ (unsigned)&GPIO*8+4;
static volatile bit GP3 @ (unsigned)&GPIO*8+3;
static volatile bit GP2 @ (unsigned)&GPIO*8+2;
static volatile bit GP1 @ (unsigned)&GPIO*8+1;
static volatile bit GP0 @ (unsigned)&GPIO*8+0;
#define CONFIG_ADDR 0xFFF
/* code protection */
#define MCLREN 0xFFFF // memory clear enable
#define MCLRDIS 0xFFEF // memory clear dISAble
/*watchdog*/
#define WDTEN 0xFFFF // watchdog timer enable
#define WDTDIS 0xFFFB // watchdog timer disable
#define PROTECT 0xFFF7 // protect the program code
#define UNPROTECT 0xFFFF // do not protect the program code
/*osc configurations*/
#define EXTRC 0xFFFF // external resistor/caPACitor
#define INTRC 0xFFFE // internal
#define XT 0xFFFD // crystal/resonator
#define LP 0xFFFC // low power crystal/resonator
/* 93LC46 I/O PIN define */
#define CS GP0 //Chip Select
#define CLK GP1 //Serial Data CLOCk
#define DI GP2 //Serial Data Input
#define DO GP4 //Serial Data Output
void Delay(unsigned int counter);
void Pulse(void);
void StartBit(void);
void EWEN(void);
void EWDS(void);
extern void Write93LC46(unsigned char Offset_Addr, unsigned int tx_data);
extern unsigned int Read93LC46(unsigned char Offset_Addr);
void InitPIC(void);
#define CLRWDT() asm(" clrwdt")
#define SLEEP() asm(" sleep")
#define ___mkstr1(x) #x
#define ___mkstr(x) ___mkstr1(x)
#define __CONFIG(x) asm("tpsect config,class=CONFIG,delta=2");
asm("tglobaltconfig_word");
asm("config_word");
asm("tdw "___mkstr(x))
#define __IDLOC(w) asm("tpsect idloc,class=IDLOC,delta=2");
asm("tglobaltidloc_word");
asm("idloc_word");
asm("tirpct__arg," ___mkstr(w));
asm("tdw 0&__arg&h");
asm("tendm")
__CONFIG(MCLRDIS & WDTDIS & EXTRC & PROTECT);
Function : Delay
Input : unsigned int (counter)
Output : None
Description : Delay routine
if counter=1 delay 35us , if counter=10 delay 134us,
if counter=100 delay 1.12ms,
These delay is base on internal 4MHz
while(counter>0) counter--;
Function : Pulse
Input : None
Output : None
Description : Send a pulse (10) to Serial Data Clock(CLK)
void Pulse(void)
CLK = 1;
Delay(25);
CLK = 0;
Function : StartBit
Input : None
Output : None
Description :
1. Set Chip Select(CS) = 1 (high)
2. Set a Start Bit(1) to Serial Data Input(DI)
void StartBit(void)
CS = 1;
DI = 1;
Pulse();
Function : EWEN
Input : None
Output : None
Description : ERASE/WRITE Enable
void EWEN(void)
unsigned char i,temp;
StartBit(); /* 1 */
temp = 0x80; /* 0011xxxx ,(opcode:00, Address:11xxxx) */
for(i=0; i<8; i++) {
if(0x30 & temp)
DI = 1;
else
DI = 0;
Pulse();
temp >>= 1;
CS = 0;
Function : EWDS
Input : None
Output : None
Description : ERASE/WRITE DISAble
void EWDS(void)
unsigned char i;
StartBit(); /* 1 */
DI = 0; /* 0000xxxx, (opcode:00, Address:00xxxx) */
for(i=0; i<8; i++)
Pulse();
CS = 0;
Function : Write93LC46
Input : unsigned char Offset Address, unsigned int tx_data
Output : None
Description : Write 16bits data in to 93LC46 Offset Address
unsigned char Addr, i;
unsigned int temp;
EWEN();
StartBit(); /* 1 */
Offset_Addr=Offset_Addr&0x3F; /* 6bits address */
Addr = Offset_Addr + 0x40; /* 01AAAAAA ,(opcode:01, address:AAAAAA) */
temp = 0x0080;
if(Addr & temp)
DI = 1;
else
DI = 0;
Pulse();
temp >>= 1;
temp = 0x8000; /* DDDDDDDDDDDDDDDD(16bits data)*/
for(i=0; i<16; i++) {
if(tx_data & temp)
DI = 1;
else
DI = 0;
Pulse();
temp >>= 1;
CS = 0;
EWDS();
Function : Read93LC46
Output : unsigned int
Description : Read 16bits data from 93LC46 offset address
unsigned char Addr, i, temp;
unsigned int rx_data;
StartBit(); /* 1 */
Offset_Addr = Offset_Addr&0x3F; /* 6bits address */
Addr = Offset_Addr + 0x80; /* 10AAAAAA ,(opcode:10, address:AAAAAA) */
temp = 0x80;
if(Addr & temp)
DI = 1;
else
DI = 0;
Pulse();
temp >>= 1;
rx_data = 0x0000; /* DDDDDDDDDDDDDDDD(16bits data)*/
Pulse();
if(DO)
rx_data |= 0x0001;
if(i < 15)
rx_data <<= 1;
CS = 0;
return(rx_data);
void InitPIC(void)
OPTION = (GPWU | GPPU | PS2 | PS1 | PS0);
TRIS = 0x10;
CS = 0;
CLK = 0;
DI = 0;
/* Main routine */
void main(void)
unsigned char addr;
unsigned int rx_buf;
InitPIC();
/* Read a word then +1 and write back to 93LC46 */
for (addr = 0; addr < 10; addr++)
rx_buf = Read93LC46(addr);
rx_buf = rx_buf+1;
Write93LC46(addr, rx_buf);
子式工具组,工作简单快捷,舒适安全,且一人便可独立完成。工具组主要功用是:①测试制动液的湿沸点,确定是否应该更换。②使用独有的工具进行旧制动液的排放和新制动液的加注。③换液时,工具中采用先进的电子传感显示技术的部件,能准确有效地判 ...… 查看全部问答> |
老生常谈:如何学习嵌入式--------希望能给初学者一点帮助 最近不断有学生问我嵌入式很有意思,但是应该如何入手呢?有些学生虽然在指导下做了一些小东西,但事后却往往不知道学到了些什么!只知道似乎很有意思。那么该如何学习嵌入式呢?学习嵌入式需要哪些知识呢?   ...… 查看全部问答> |
请问tcl语言中如何将内容打印到文件啊,比如下面这句:puts [ format \"%40s%13s%13s%13s\"\"name\" \"num\" \"code\" \"com\"]在modelsim中执行后会在modelsim命令窗口打印相应字符,如果想把这些打印到文件中,该用什么命令呢。刚开始学习tcl,还 ...… 查看全部问答> |
我现在找了很久ise foundation 10.1或webpack的开发软件,有谁有的可以给我提供以下吗,我在学校,去xilinx网站下要花很大的流量,下不起,图书馆借了个光盘也不能用,哪位好心人能帮我一下,感激涕零啊!邮箱:ffxsppan@163.com… 查看全部问答> |
我在工作中使用的测量仪器原本是由PC通过RS232来控制的。现在我需要将这种测量仪器放在工地,PC仍留在室内。请问是否可以使用GPRS或其它无线通信技术来实现?我原本编写的通过RS232端口控制仪器的程序要改写吗?请高手指教,最好能够合作!… 查看全部问答> |
