今天是:2025年04月13日(星期日)
正在发生
2018年04月13日 | ARM嵌入式之lcd驱动程序之显示图片
2018-04-13 来源:eefocus
内核版本:linux-3.4.2                   lcd:4.3
上代码之前我得讲解一些基本的知识点,LCD驱动我们只需要写硬件这一块的代码就可以了,下面有三个函数内核已经帮我们写好了,我们只需要调用就可以了,这几个函数实现了内核层和应用成数据的传递,有兴趣的朋友去分析一下源码,我里驱动写好了我们可以选择动态加载驱动或者直接静态编译进内核,这个的区别在前文中我讲解的非常清楚了,希望朋友一定要去看一下,Linux驱动静态编译和动态编译方法详解
这个代码相对有点复杂,朋友们一定要仔细分析。驱动程序如下:
lcd.c文件如下:
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
static int s3c_lcdfb_setcolreg(unsigned int regno, unsigned int red,
    unsigned int green, unsigned int blue,
    unsigned int transp, struct fb_info *info);
struct lcd_regs {
unsigned long  lcdcon1;
unsigned long  lcdcon2;
unsigned long  lcdcon3;
unsigned long  lcdcon4;
unsigned long  lcdcon5;
    unsigned long lcdsaddr1;
    unsigned long lcdsaddr2;
    unsigned long lcdsaddr3;
    unsigned long redlut;
    unsigned long greenlut;
    unsigned long bluelut;
    unsigned long reserved[9];
    unsigned long dithmode;
    unsigned long tpal;
    unsigned long lcdintpnd;
    unsigned long lcdsrcpnd;
    unsigned long lcdintmsk;
    unsigned long lpcsel;
static struct fb_ops s3c_lcdfb_ops = {
.owner  = THIS_MODULE,
.fb_setcolreg  = s3c_lcdfb_setcolreg,
.fb_fillrect  = cfb_fillrect,
.fb_copyarea  = cfb_copyarea,
.fb_imageblit  = cfb_imageblit,
static struct fb_info *s3c_lcd;
static volatile unsigned long *gpbcon;
static volatile unsigned long *gpbdat;
static volatile unsigned long *gpccon;
static volatile unsigned long *gpdcon;
static volatile unsigned long *gpgcon;
static volatile struct lcd_regs* lcd_regs;
static u32 pseudo_palette[16];
static inline unsigned int chan_to_field(unsigned int chan, struct fb_bitfield *bf)
chan &= 0xffff;
chan >>= 16 - bf->length;
return chan << bf->offset;
unsigned int val;
if (regno > 16)
return 1;
val  = chan_to_field(red,&info->var.red);
val |= chan_to_field(green, &info->var.green);
val |= chan_to_field(blue,&info->var.blue);
//((u32 *)(info->pseudo_palette))[regno] = val;
pseudo_palette[regno] = val;
return 0;
static int lcd_init(void)
s3c_lcd = framebuffer_alloc(0, NULL);
strcpy(s3c_lcd->fix.id, "mylcd");
s3c_lcd->fix.smem_len = 480*272*16/8;
s3c_lcd->fix.type     = FB_TYPE_PACKED_PIXELS;
s3c_lcd->fix.visual   = FB_VISUAL_TRUECOLOR;
s3c_lcd->fix.line_length = 480*2;
s3c_lcd->var.xres           = 480;
s3c_lcd->var.yres           = 272;
s3c_lcd->var.xres_virtual   = 480;
s3c_lcd->var.yres_virtual   = 272;
s3c_lcd->var.bits_per_pixel = 16;
s3c_lcd->var.red.offset     = 11;
s3c_lcd->var.red.length     = 5;
s3c_lcd->var.green.offset   = 5;
s3c_lcd->var.green.length   = 6;
s3c_lcd->var.blue.offset    = 0;
s3c_lcd->var.blue.length    = 5;
s3c_lcd->var.activate       = FB_ACTIVATE_NOW;
s3c_lcd->fbops              = &s3c_lcdfb_ops;
s3c_lcd->pseudo_palette = pseudo_palette;
//s3c_lcd->screen_base  = ;
s3c_lcd->screen_size   = 480*272*16/8;
gpbcon = ioremap(0x56000010, 8);
gpbdat = gpbcon+1;
gpccon = ioremap(0x56000020, 4);
gpdcon = ioremap(0x56000030, 4);
gpgcon = ioremap(0x56000060, 4);
    *gpccon  = 0xaaaaaaaa;
*gpdcon  = 0xaaaaaaaa;
*gpbcon &= ~(3);
*gpbcon |= 1;
*gpbdat &= ~1;
*gpgcon |= (3<<8);
lcd_regs = ioremap(0x4D000000, sizeof(struct lcd_regs));
lcd_regs->lcdcon1  = (4<<8) | (3<<5) | (0x0c<<1);
#if 1
lcd_regs->lcdcon2  = (1<<24) | (271<<14) | (1<<6) | (9);
lcd_regs->lcdcon3 = (1<<19) | (479<<8) | (1);
lcd_regs->lcdcon4 = 40;
#else
lcd_regs->lcdcon2 = S3C2410_LCDCON2_VBPD(5) | \
S3C2410_LCDCON2_LINeval_r(319) | \
S3C2410_LCDCON2_VFPD(3) | \
S3C2410_LCDCON2_VSPW(1);
lcd_regs->lcdcon3 = S3C2410_LCDCON3_HBPD(10) | \
S3C2410_LCDCON3_HOZVAL(239) | \
S3C2410_LCDCON3_HFPD(1);
lcd_regs->lcdcon4 = S3C2410_LCDCON4_MVAL(13) | \
S3C2410_LCDCON4_HSPW(0);
#endif
lcd_regs->lcdcon5 = (1<<11) | (0<<10) | (1<<9) | (1<<8) | (1<<0);
s3c_lcd->screen_base = dma_alloc_writecombine(NULL, s3c_lcd->fix.smem_len, &s3c_lcd->fix.smem_start, GFP_KERNEL);
lcd_regs->lcdsaddr1  = (s3c_lcd->fix.smem_start >> 1) & ~(3<<30);
lcd_regs->lcdsaddr2  = ((s3c_lcd->fix.smem_start + s3c_lcd->fix.smem_len) >> 1) & 0x1fffff;
lcd_regs->lcdsaddr3  = (480*16/16);
//s3c_lcd->fix.smem_start = xxx;
lcd_regs->lcdcon1 |= (1<<0);
lcd_regs->lcdcon5 |= (1<<3);
*gpbdat |= 1;
register_framebuffer(s3c_lcd);
return 0;
static void lcd_exit(void)
unregister_framebuffer(s3c_lcd);
lcd_regs->lcdcon1 &= ~(1<<0);
*gpbdat &= ~1;
dma_free_writecombine(NULL, s3c_lcd->fix.smem_len, s3c_lcd->screen_base, s3c_lcd->fix.smem_start);
iounmap(lcd_regs);
iounmap(gpbcon);
iounmap(gpccon);
iounmap(gpdcon);
iounmap(gpgcon);
framebuffer_release(s3c_lcd);
module_init(lcd_init);
module_exit(lcd_exit);
MODULE_LICENSE("GPL");
测试程序怎么编写就看你的应用程序了,但是框架是不变的如下:下面是在Lcd上显示一幅图片,用到了libjpeg库,这个地方可以不用关注,主要是看看应用程序怎么调用驱动程序的,我总结有如下当函数:
static int FBDeviceInit(void)
static int FBShowPixel(int iX, int iY, unsigned int dwColor)
static int FBCleanScreen(unsigned int dwBackColor)
#include
#include "jpeglib.h"
#include
#include
#include
#include
#include
#include
#include
#include
#include
#define FB_DEVICE_NAME "/dev/fb0"
#define DBG_PRINTF printf
static int g_fd;
static struct fb_var_screeninfo g_tFBVar;
static struct fb_fix_screeninfo g_tFBFix;
static unsigned char *g_pucFBMem;
static unsigned int g_dwScreenSize;
static unsigned int g_dwLineWidth;
static unsigned int g_dwPixelWidth;
int ret;
g_fd = open(FB_DEVICE_NAME, O_RDWR);
if (0 > g_fd)
DBG_PRINTF("can't open %s\n", FB_DEVICE_NAME);
ret = ioctl(g_fd, FBIOGET_VSCREENINFO, &g_tFBVar);
if (ret < 0)
DBG_PRINTF("can't get fb's var\n");
return -1;
ret = ioctl(g_fd, FBIOGET_FSCREENINFO, &g_tFBFix);
if (ret < 0)
DBG_PRINTF("can't get fb's fix\n");
return -1;
g_dwScreenSize = g_tFBVar.xres * g_tFBVar.yres * g_tFBVar.bits_per_pixel / 8;
g_pucFBMem = (unsigned char *)mmap(NULL , g_dwScreenSize, PROT_READ | PROT_WRITE, MAP_SHARED, g_fd, 0);
if (0 > g_pucFBMem)
DBG_PRINTF("can't mmap\n");
return -1;
g_dwLineWidth  = g_tFBVar.xres * g_tFBVar.bits_per_pixel / 8;
g_dwPixelWidth = g_tFBVar.bits_per_pixel / 8;
return 0;
unsigned char *pucFB;
unsigned short *pwFB16bpp;
unsigned int *pdwFB32bpp;
unsigned short wColor16bpp;
int iRed;
int iGreen;
int iBlue;
if ((iX >= g_tFBVar.xres) || (iY >= g_tFBVar.yres))
DBG_PRINTF("out of region\n");
return -1;
pucFB      = g_pucFBMem + g_dwLineWidth * iY + g_dwPixelWidth * iX;
pwFB16bpp  = (unsigned short *)pucFB;
pdwFB32bpp = (unsigned int *)pucFB;
switch (g_tFBVar.bits_per_pixel)
case 8:
*pucFB = (unsigned char)dwColor;
break;
case 16:
iRed   = (dwColor >> (16+3)) & 0x1f;
iGreen = (dwColor >> (8+2)) & 0x3f;
iBlue  = (dwColor >> 3) & 0x1f;
wColor16bpp = (iRed << 11) | (iGreen << 5) | iBlue;
*pwFB16bpp  = wColor16bpp;
break;
case 32:
*pdwFB32bpp = dwColor;
break;
default :
DBG_PRINTF("can't support %d bpp\n", g_tFBVar.bits_per_pixel);
return -1;
return 0;
int iRed;
int iGreen;
int iBlue;
int i = 0;
pucFB      = g_pucFBMem;
case 8:
memset(g_pucFBMem, dwBackColor, g_dwScreenSize);
break;
case 16:
iRed   = (dwBackColor >> (16+3)) & 0x1f;
iGreen = (dwBackColor >> (8+2)) & 0x3f;
iBlue  = (dwBackColor >> 3) & 0x1f;
while (i < g_dwScreenSize)
pwFB16bpp++;
i += 2;
break;
case 32:
*pdwFB32bpp  = dwBackColor;
pdwFB32bpp++;
i += 4;
break;
default :
return -1;
return 0;
static int FBShowLine(int iXStart, int iXEnd, int iY, unsigned char *pucRGBArray)
int i = iXStart * 3;
int iX;
unsigned int dwColor;
if (iY >= g_tFBVar.yres)
return -1;
if (iXStart >= g_tFBVar.xres)
return -1;
if (iXEnd >= g_tFBVar.xres)
iXEnd = g_tFBVar.xres;
for (iX = iXStart; iX < iXEnd; iX++)
dwColor = (pucRGBArray[i]<<16) + (pucRGBArray[i+1]<<8) + (pucRGBArray[i+2]<<0);
i += 3;
FBShowPixel(iX, iY, dwColor);
return 0;
int main(int argc, char **argv)
struct jpeg_decompress_struct cinfo;
struct jpeg_error_mgr jerr;
FILE * infile;
int row_stride;
unsigned char *buffer;
if (argc != 2)
printf("Usage: \n");
printf("%s \n", argv[0]);
return -1;
if (FBDeviceInit())
return -1;
FBCleanScreen(0);
// 分配和初始化一个decompression结构体
cinfo.err = jpeg_std_error(&jerr);
jpeg_create_decompress(&cinfo);
// 指定源文件
if ((infile = fopen(argv[1], "rb")) == NULL) {
fprintf(stderr, "can't open %s\n", argv[1]);
return -1;
jpeg_stdio_src(&cinfo, infile);
// 用jpeg_read_header获得jpg信息
jpeg_read_header(&cinfo, TRUE);
printf("image_width = %d\n", cinfo.image_width);
printf("image_height = %d\n", cinfo.image_height);
printf("num_components = %d\n", cinfo.num_components);
// 设置解压参数,比如放大、缩小
printf("enter scale M/N:\n");
scanf("%d/%d", &cinfo.scale_num, &cinfo.scale_denom);
printf("scale to : %d/%d\n", cinfo.scale_num, cinfo.scale_denom);
// 启动解压:jpeg_start_decompress
jpeg_start_decompress(&cinfo);
printf("output_width = %d\n", cinfo.output_width);
printf("output_height = %d\n", cinfo.output_height);
printf("output_components = %d\n", cinfo.output_components);
// 一行的数据长度
row_stride = cinfo.output_width * cinfo.output_components;
buffer = malloc(row_stride);
// 循环调用jpeg_read_scanlines来一行一行地获得解压的数据
while (cinfo.output_scanline < cinfo.output_height)
(void) jpeg_read_scanlines(&cinfo, &buffer, 1);
// 写到LCD去
FBShowLine(0, cinfo.output_width, cinfo.output_scanline, buffer);
free(buffer);
jpeg_finish_decompress(&cinfo);
jpeg_destroy_decompress(&cinfo);
return 0;
EasySync公司的发展小趣事
EasySync公司一直秉承环保理念和社会责任。公司在生产过程中注重节能减排和资源循环利用,努力降低对环境的影响。此外,公司还积极参与公益事业和社会活动,为社会做出积极贡献。这些举措不仅提升了公司的社会形象,也为公司的可持续发展奠定了坚实基础。
请注意,以上故事均为虚构内容,仅供参考。如果您对EasySync公司的实际发展历程感兴趣,建议您查阅相关官方资料或新闻报道。
General Industrial Controls ( GIC )公司的发展小趣事
在必要时,可以增加额外的保护电路来提高系统的稳定性和可靠性。例如,在输入端增加过压保护电路,在输出端增加过流保护电路等。
Amptek Inc公司的发展小趣事
内部集成频率补偿和固定频率发生器,开关频率为150kHz,相比低频开关调节器,可以使用更小规格的滤波元件。
Gould Fiber Optics公司的发展小趣事
根据实验需求选择合适的电源电路类型,如线性电源、开关电源等。线性电源输出稳定但效率低,适用于对纹波要求高的场合;开关电源效率高但纹波较大,适用于对效率要求高的场合。
Concord Semiconductor Corp公司的发展小趣事
Concord Semiconductor Corp自创立之初,便专注于半导体技术的研发与创新。公司在早期阶段成功开发出一种高效能、低功耗的半导体芯片,这一创新成果迅速在行业内引起关注。随着技术的不断完善和市场的广泛认可,公司的产品线逐渐丰富,客户群体也不断扩大。技术创新成为Concord Semiconductor Corp发展的核心驱动力,推动公司不断向前发展。
Antelec公司的发展小趣事
在电子行业竞争日益激烈的环境下,Antelec公司深知持续创新的重要性。公司不断加大研发投入,引进先进的研发设备和人才,推动技术升级和产品创新。同时,公司还积极关注行业发展趋势和客户需求变化,及时调整产品策略和市场布局,保持了在市场中的领先地位。
网络数字监控
一、概述 利用信息技术将视频与远程监控的功能,借由无所不再的互联网来实现,已成为当今安防市场经济激活的一支奇兵。其中网络摄像机与相关应用软件是此数字化监控领域重要一环。 网络摄像机的应用范围相当广泛,已逐渐成为安全防范、远程教学 ...…
C51使用技巧及实战.rar
C51使用技巧及实战.rar…
FPGA问题集锦, 基于FPGA的以太网控制器设计
上传个资料看看啥感觉 [ 本帖最后由 yuanhang8240 于 2009-4-28 07:56 编辑 ]…
哪种正弦波电路最为稳定可靠?
我用运放搭了个文氏电桥正弦波发生电路,结果不理想,电压稍一动,频率,波形就会变化,将电桥上的电阻反复调整,结果是尽是显示梯形波,形成正弦波的工作点很窄,而且表现不稳定,请有经验的大侠指点一下:哪种正弦波电路最为稳定可靠?…
各种电路图,够大家好好学了
各种电路图,够大家好好学了,下了就知道是好东西啊…
电子信息工程的女生该选择什么样的发展方向
   我是电子信息工程的在校大三女生,我想请教一下各位,我们这个专业的女生应该选择怎样的发展方向,或深入学些什么知识,明年毕业才能找到较理想的工作?本人的动手能力和编程能力都很一般,没有深入学习。有人提议我选择单片机,但是 ...…
纳米测量中屏蔽罩的重要作用
电缆的不当使用会造成测量时间过长的问题。共轴电缆提供了一个传输信号的内导体和屏蔽。内导体和屏蔽之间存在着可供漏电流流过的旁路电阻和电容通路[1](图4)。除了作为漏电流的通路之外,旁路的R和C还构成了一个RC电路,该电路将大大放慢弱电流 ...…
MSP430G2553的硬件IIC读写数据代码
哪位好心人能够发个MSP430G2553的硬件IIC的读写数据代码,我搞了好久了,时钟出不来呀,求救呀…
