今天是:2025年05月20日(星期二)
2018年05月20日 | STM8S 模拟I2C程序
2018-05-20 来源:eefocus
STM8S的硬件I2C还是存在问题,不敢贸然使用.
#define SCL PE_ODR_ODR1
#define SDA PE_ODR_ODR2
#define SDAM PE_IDR_IDR2
#define SET_SCL_OUT() {PE_DDR_DDR1=1; PE_CR1_C11 = 1; PE_CR2_C21 = 0;}
#define SET_SDA_OUT() {PE_DDR_DDR2=1; PE_CR1_C12 = 1; PE_CR2_C22 = 0;}
#define SET_SDA_IN() {PE_DDR_DDR2=0; PE_CR1_C12 = 0; PE_CR2_C22 = 0;}
// Prototype : void I2C_Start(void)
// Calls : Delay_5us()
// Description : Start Singnal
void I2C_Init(void)
I2C_CR1 &= 0xFE; // PE=0, disable I2C module
SET_SCL_OUT();
SET_SDA_OUT();
// Prototype : void Delay_5us(void)
// Description : 大约延时5us
uchar i; //fcpu 8MHz 时
for (i=50; i>0; i--);
// SDA 1->0 while SCL High
SDA = 1;
SCL = 1;
Delay_5us();
SDA = 0;
Delay_5us();
SCL = 0;
// Prototype : void I2C_Stop(void)
// Description : Stop Singnal
void I2C_Stop(void)
// SDA 0->1 while SCL High
SDA = 0;
SCL = 1;
Delay_5us();
SDA = 1;
Delay_5us();
// Prototype : void I2C_SendACK(uchar ack);
// Parameters : bit ack:1-noack, 0-ack
// Description : Master device send ACK to slave device.
if(ack == 0)
SDA = 0;
else
SDA = 1;
SCL = 1;
Delay_5us();
SCL = 0;
Delay_5us();
// Prototype : uchar I2C_SendByte(uchar sendDAT)
// Parameters : uchar sendDAT---data to be send
// Return Value : CY--slave ack (1---noack,0---ack)
// Description : Send one byte to I2C
uchar i,revack;
for (i= 0 ; i< 8; i++)
SCL = 0;
Delay_5us();
if (sendDAT & 0x80) // write data
SDA = 1;
else
SDA = 0;
sendDAT <<= 1;
SCL = 1;
Delay_5us();
SCL = 0;
Delay_5us();
SET_SDA_IN();
SCL = 1;
asm("nop");
asm("nop");
revack = (uchar)SDAM;
Delay_5us();
SCL = 0;
SET_SDA_OUT();
Delay_5us();
return revack;
// Prototype : uchar I2C_RecvByte()
// Parameters : none
// Return Value : revDAT- received data
// Description : Receive one byte from I2C
uchar i;
uchar revDAT = 0;
SDA = 1; // latch the Data port befor reading
SET_SDA_IN();
for (i=0; i<8; i++)
revDAT <<= 1;
SCL = 1;
asm("nop");
asm("nop");
if (SDAM)
revDAT |= 0x01;
else
revDAT &= 0xfe;
Delay_5us();
SCL = 0;
Delay_5us();
SET_SDA_OUT();
return revDAT;
// Prototype : void Write_PT2314(uchar wdata)
// Calls : I2C_Start(), I2C_Stop(),I2C_SendByte()
// Parameters : RegAddr-- target memory address,
// wrdata--- data to be writing
// Description : Write one byte to target memory
void Write_24c02(uchar regadd,uchar wdata)
I2C_Start();
I2C_SendByte(0xA0); // Device Addr + Write (operation)
I2C_SendByte(regadd);
I2C_SendByte(wdata);
I2C_Stop();
uchar Read_24c02(uchar regadd)
uchar revdata;
I2C_Start();
I2C_Start();
I2C_SendByte(0xA1); // Device Addr + Write (operation)
revdata = I2C_RecvByte();
I2C_SendACK(1);
I2C_Stop();
return revdata;
下一篇:STM8单片机的中断优先级
关于DDK开发中的Build SoftICE Symbols的问题,我编译的工程生成了.sys文件,但没有生成.nms等用于调试的文件,不知是否和下面的出错信息 以下是出错的内容,我不明白“Matching PDB file not found.”是什么意思,是不是说生成的.sys文件里面没有编译信息? --------------------Configuration: RepSample - Win32 Free-------------------- Compiling resources with DDK resource c ...… 查看全部问答> |
RT,目前要吧windows上的一个程序移植到wince上去,其他功能都实现了,唯独关于excel部分有些错误 windows上的方法是AfxOleInit()之后就用CWorksheet、CWorkBook.....这几个类操作,在windows上运行没有错误 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ...… 查看全部问答> |
1. LPC2366的三个VDD(DCDC)(3V3)引脚是否一定要接3.3V电源?周立功的资料说这三个引脚不使用可以悬空。。。但是当这三个引脚悬空时整个单片机根本就没有工作,H-JTAG无法识别芯片,ISP也无法连接,说明这三个脚应该是给内部某些关键模块供电的 ...… 查看全部问答> |
ST-LINK2进行STM32FLASH调试偶尔不能进入调试(有图) 我使用ST-link2进行FLASH调试,前一段时间偶尔出现不能进入调试界面,给板子断电,然后关闭IAR,重新打开IAR又可以 ...… 查看全部问答> |
