今天是:2025年06月03日(星期二)
2018年06月03日 | STM32L系列+ADXL345的I2C调试
2018-06-03 来源:eefocus
STM32的硬件I2C调试确实要比模拟麻烦很多啊,一大堆的配置,调通F系列的,本以为直接移植到L系列会很轻松,没想到问题依然很多,现直接附上STM32L系列的I2C初始化及读写函数:
1.GPIO的初始化:
static void ADXL_LowLevel_Init(void)
GPIO_InitTypeDef GPIO_InitStructure;
/* 使能与 I2C1 有关的时钟 */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB,ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz;
GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_Init(GPIOB, &GPIO_InitStructure);
/*!< Configure sEE_I2C pins: SDA */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
/* Connect PXx to I2C_SCL*/
GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_I2C1);
/* Connect PXx to I2C_SDA*/
GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_I2C1);
2.I2C的初始化:
void I2C_ADXL_Init(void)
I2C_InitTypeDef I2C_InitStructure;
ADXL_LowLevel_Init();
I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
I2C_InitStructure.I2C_OwnAddress1 = ADXL_ADRESS;
I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
I2C_InitStructure.I2C_ClockSpeed = I2C_Speed;
/* ADXL_I2C Peripheral Enable */
I2C_Cmd(I2C1, ENABLE);
/* Apply MEMS_I2C configuration after enabling it */
I2C_Init(I2C1, &I2C_InitStructure);
3.读
u8 I2C_ADXL_ByteRead(u8 ReadAddr)
u8 RxData;
/*wait until I2C bus is not busy*/
while(I2C_GetFlagStatus(I2C1, I2C_FLAG_BUSY));
/* Send START condition */
I2C_GenerateSTART(I2C1, ENABLE);
/* Test on EV5 and clear it */
while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT));
/* Send ADXL address for write */
I2C_Send7bitAddress(I2C1, ADXL_ADRESS, I2C_Direction_Transmitter);
/* Test on EV6 and clear it */
while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
/* Send the ADXL's Register address to write to */
I2C_SendData(I2C1, ReadAddr);
while(I2C_GetFlagStatus(I2C1, I2C_FLAG_BTF) == RESET);
/* Send STRAT condition a second time */
/* Send ADXL address for read */
I2C_Send7bitAddress(I2C1, ADXL_ADRESS, I2C_Direction_Receiver);
while(I2C_GetFlagStatus(I2C1, I2C_FLAG_ADDR) == RESET);
/* Disable Acknowledgement */
I2C_AcknowledgeConfig(I2C1, DISABLE);
(void)I2C1->SR2;
/*!< Send STOP Condition */
I2C_GenerateSTOP(I2C1, ENABLE);
while(I2C_GetFlagStatus(I2C1, I2C_FLAG_RXNE) == RESET);
/* Read a byte from the ADXL Register */
RxData = I2C_ReceiveData(I2C1);
while(I2C1->CR1 & I2C_CR1_STOP);
I2C_AcknowledgeConfig(I2C1, ENABLE);
return RxData;
4. 写
void I2C_ADXL_ByteWrite(u8 pBuffer, u8 WriteAddr)
while(I2C_GetFlagStatus(I2C1,I2C_FLAG_BUSY));
/* Send MMA address for write */
/* Send the MMA's Register address to write to */
I2C_SendData(I2C1, WriteAddr);
/* Test on EV8 and clear it */
while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
/* Send the byte to be written */
I2C_SendData(I2C1, pBuffer);
/* Send STOP condition */
下一篇:STM32 串口初始化时的BUG
要求:按下开关灯亮,断开开关灯灭。 我用switch语句,按下开关灯亮了,可断开开关灯就是不灭,我改了n次了它还是不灭,我已经拿它没办法了,求哥哥们给个C语言的程序,谢谢! 比如:按k1,led1亮;按k2,led2与led3亮;按 ...… 查看全部问答> |
有没有哪位高人用过OK2440开发板?小弟我刚开始学习,遇到很奇怪的问题,就是使用DNW的USB下载内核文件nk.bin或者nk.nb0时,一直提示checksum error!MEM:1502 DN:200 Invalid BIN file signature!24,d0,24,6c,af,d0,24 &nbs ...… 查看全部问答> |
CE5下怎么基于现有BSP复制出一个新的BSP(名称不同),并且能够在新BSP上建立新的CE工程,要些改什么地方? CE5下怎么基于现有BSP复制出一个新的BSP(名称不同),并且能够在新BSP上建立新的CE工程,要些改什么地方?… 查看全部问答> |
从网上找了个sqlite3.exe,就这一个文件, 直接双击,就是sqlite> 在网上查了一下,建库有好多的方法,什么$,sqlite3 xxx.db等, 执行就报sql error。 直接create table .....OK。 insert .......OK。 .exit以后再打开sqlite3.exe时,刚才建 ...… 查看全部问答> |
用modelsim 6.5仿真为什么会报下面的错误?请高手指教 vsim work.vtf_test# vsim work.vtf_test # Loading work.vtf_test(fast)# Loading work.modelsim_test(fast)# Loading work.maxii_io(fast)# Loading work.maxii_lcell(fast)# Loading work. ...… 查看全部问答> |
