今天是:2024年09月02日(星期一)
2018年09月02日 | STM32 can配置PA11 PA12
2018-09-02 来源:eefocus
/* Private variables ---------------------------------------------------------*/uint16_t CAN_ID;
uint8_t CAN_DATA0,CAN_DATA1,CAN_DATA2,CAN_DATA3,CAN_DATA4,CAN_DATA5,CAN_DATA6,CAN_DATA7;
uint8_t CanFlag,Display;
void CAN_GPIO_Config(void)
GPIO_InitTypeDef GPIO_InitStructure;
/* CAN Periph clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA ,ENABLE);
// RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO,ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);
/* Configure CAN pin: TX */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* Configure CAN pin: RX */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
// GPIO_PinRemapConfig(GPIO_Remap1_CAN1 , ENABLE);
void CAN_NVIC_Configuration(void)
NVIC_InitTypeDef NVIC_InitStructure;
#ifdef VECT_TAB_RAM
/* Set the Vector Table base location at 0x20000000 */
NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else /* VECT_TAB_FLASH */
/* Set the Vector Table base location at 0x08000000 */
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
/* enabling interrupt */
NVIC_InitStructure.NVIC_IRQChannel=USB_LP_CAN1_RX0_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
void can_init(void)
CAN_InitTypeDef CAN_InitStructure;
CAN_FilterInitTypeDef CAN_FilterInitStructure;
CAN_GPIO_Config();
CAN_NVIC_Configuration();
/* CAN register init */
CAN_DeInit(CAN1);
CAN_StructInit(&CAN_InitStructure);
/* CAN cell init */
CAN_InitStructure.CAN_TTCM = DISABLE; /* 时间触发禁止, 时间触发:CAN硬件的内部定时器被激活,并且被用于产生时间戳 */
CAN_InitStructure.CAN_ABOM = DISABLE; /* 自动离线禁止,自动离线:一旦硬件监控到128次11个隐性位,就自动退出离线状态。在这里要软件设定后才能退出 */
CAN_InitStructure.CAN_AWUM = DISABLE; /* 自动唤醒禁止,有报文来的时候自动退出休眠*/
CAN_InitStructure.CAN_NART = DISABLE; /* 报文重传, 如果错误一直传到成功止,否则只传一次 */
CAN_InitStructure.CAN_RFLM = DISABLE; /* 接收FIFO锁定, 1--锁定后接收到新的报文摘不要,0--接收到新的报文则覆盖前一报文*/
CAN_InitStructure.CAN_TXFP = DISABLE; /* 发送优先级 0---由标识符决定 1---由发送请求顺序决定*/
CAN_InitStructure.CAN_Mode = CAN_Mode_Normal; /* 模式*/
CAN_InitStructure.CAN_SJW = CAN_SJW_1tq; /* 重新同步跳宽,只有can硬件处于初始化模式时才能访问这个寄存器 */
CAN_InitStructure.CAN_BS1 = CAN_BS1_9tq; /* 时间段1 */
CAN_InitStructure.CAN_BS2 = CAN_BS2_6tq; /* 时间段2 */
CAN_InitStructure.CAN_Prescaler = 8; /* 波特率预分频数 */
CAN_Init(CAN1, &CAN_InitStructure); // 初始化CAN1
/* 波特率计算方法 */
/* CANbps= Fpclk/((BRP+1)*((Tseg1+1)+(Tseg2+1)+1) 此处计算为 CANbps=64000000/(16*(13+2+1))=250kHz */
/* 配置大方向: Tseg1>=Tseg2 Tseg2>=tq; Tseg2>=2TSJW */
/* 使用CAN波特率计算器得到CANBTR = 0x001C000F 具体某些位对应SJW BS1 BS2 介绍网址http://blog.csdn.net/flydream0/article/details/8170185 */
if (CAN_Init(CAN1,&CAN_InitStructure) == CANINITFAILED) //F
rt_kprintf("CAN error \r\n");
/* 初始化时先设置CAN_MCR的初始化位 */
/* 然后查看硬件是否真的设置了CAN_MSR的初始化位来确认是否进入了初始化模式 */
/* 配置CAN过滤器 */
/* 32位对应的id */
/* stdid[10:0],extid[17:0],ide,rtr */
/* 16位对应的id */
/* stdid[10:0],ide,rtr,extid[17:15] */
/* 一般使用屏蔽模式 */
/* 要注意的是fifo接收存满了中断,还有就是fifo的概念,即取的一直是最早那一个数据, 要释放才能取下一个数据 */
/* 常使用的中断有 */
/* 1,有信息中断,即fifo挂号中断 */
/* 2,fifo满中断 */
/* 3,fifo满之后又有信息来则中断,即fifo溢出中断 */
CAN_FilterInitStructure.CAN_FilterNumber=0; /* 过滤器0 */
CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask; /* 屏敝模式 */
CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit; /* 32位 */
CAN_FilterInitStructure.CAN_FilterIdHigh=0x0000; /* 以下四个都为0, 表明不过滤任何id */
CAN_FilterInitStructure.CAN_FilterIdLow=0x0000;
CAN_FilterInitStructure.CAN_FilterMaskIdHigh=0x0000;
CAN_FilterInitStructure.CAN_FilterMaskIdLow=0x0000;
CAN_FilterInitStructure.CAN_FilterFIFOAssignment=CAN_FIFO0; /* 能够通过该过滤器的报文存到fifo0中 */
CAN_FilterInitStructure.CAN_FilterActivation=ENABLE;
CAN_ITConfig(CAN1, CAN_IT_FMP0, ENABLE); /* 挂号中断, 进入中断后读fifo的报文函数释放报文清中断标志 */
CAN_FilterInit(&CAN_FilterInitStructure);
void CanWData(void)
CanTxMsg TxMessage;
#if 0
/* transmit 1 message */
// TxMessage.StdId=0x12;
// TxMessage.ExtId=0x34;
TxMessage.StdId=0x00; //???00
TxMessage.ExtId=0x00; //???00
TxMessage.IDE=CAN_ID_EXT;
TxMessage.RTR=CAN_RTR_DATA;
TxMessage.DLC=2;
// TxMessage.Data[0]=0xDE;
// TxMessage.Data[1]=0xCA;
TxMessage.Data[0]=0xBB; //???BB
TxMessage.Data[1]=0xBB; //???BB
CAN_Transmit(CAN1,&TxMessage);
#else
uint32_t ID = 0x5a5;
CAN_DATA0=rand()%0xff; CAN_DATA1=rand()%0xff;
CAN_DATA2=rand()%0xff; CAN_DATA3=rand()%0xff;
CAN_DATA4=rand()%0xff; CAN_DATA5=rand()%0xff;
CAN_DATA6=rand()%0xff; CAN_DATA7=rand()%0xff;
/* transmit */
TxMessage.StdId = ID; /* 设置标准id 注意标准id的最高7位不能全是隐性(1)。共11位 */
//TxMessage.ExtId = 0x00; //设置扩展id 扩展id共18位
TxMessage.RTR = CAN_RTR_DATA; /* 设置为数据帧 */
TxMessage.IDE = CAN_ID_STD; /* 使用标准id */
TxMessage.DLC = 8; /* 数据长度, can报文规定最大的数据长度为8字节 */
TxMessage.Data[0] = CAN_DATA0;
TxMessage.Data[1] = CAN_DATA1;
TxMessage.Data[2] = CAN_DATA2;
TxMessage.Data[3] = CAN_DATA3;
TxMessage.Data[4] = CAN_DATA4;
TxMessage.Data[5] = CAN_DATA5;
TxMessage.Data[6] = CAN_DATA6;
TxMessage.Data[7] = CAN_DATA7;
CAN_Transmit(CAN1,&TxMessage); /* 返回这个信息请求发送的邮箱号0,1,2或没有邮箱申请发送no_box */
#endif
void USB_LP_CAN1_RX0_IRQHandler(void)
CanRxMsg RxMessage;
int i=0;
CAN_Receive(CAN1, 0, &RxMessage);
for(i=0;i<8;i++)
printf("rxbuf[%d]:%d\r\n",i,RxMessage.Data[i]);
上一篇: STM32之CAN控制器
下一篇:STM32时钟使能及应用总结
一、概述 某地区新建一大楼,有40层。该楼为智能化程度要求比较高的综合性办公楼,该楼25层以下为出租的写字楼,25层以上为该市民防办的办公和指挥中心,因此意义重大,对于防盗报警系统的要求也比较高和特殊。 &nbs ...… 查看全部问答> |
一直非常想要拥有一款自己喜欢的又很与众不同的笔记本电脑,因此也一直格外关注各个笔记本电脑厂商的定制业务。前阵子发现清华同方的imini推出了定制业务,进行了相关咨询后,发现机器价格才3198,定制费也只需再加400元,价格经济,当然立即一试。 ...… 查看全部问答> |
RTMATLAB做语音的信号处理很好,可以运用多种filter。但是如何将MATLAB运用到Visual Studio .NET中?请有经验的大侠给个建议谢谢… 查看全部问答> |
我用了如下3种方法都不能导入系统自带的inftee.dll的例子 1.使用了pb5.0编译得到的regsvr32.exe,然后使用 regsvr32.exe inftee.dll,系统返回错误:Registration Operation failed hr = 0x800700c1 2.使用了ce4.0的REGSVRCE.EXE ,说 DllRegiste ...… 查看全部问答> |
有人用过MaxplusII吗??模拟一个滚动条,做到这没思路了,哪位大人帮忙给个 问这个是发这吧 课程设计要求做一个模拟滚动条的电路,使用24个灯模拟Windows中的滚动条,有三个灯循环亮,或者正反循环亮。初始有一个灯亮,然后是两个,最后是三个,然后三个灯循环。 我用很笨的办法用了6个D触发器做到了6个灯的符合要求,可是 ...… 查看全部问答> |
#include #include #define uint unsigned int #define uchar unsigned char uchar bai,shi,ge,num; sbit k1=P1^0; sbit k2=P1^1; sbit k3=P1^2; uchar code table[]={ 0xc0,0xf9,0xa4,0xb0,0x99, 0x92,0x82,0xf8,0x80,0x90}; void dela ...… 查看全部问答> |
