今天是:2024年09月12日(星期四)
2018年09月12日 | SPI通信(SPI1主机与SPI2从机)
2018-09-12 来源:eefocus
芯片型号stm32f103
主机采用spi1,从机spi2,中断接收测试
主机配置函数:
#include "spi.h"
void SPI1_Init(void)
NVIC_InitTypeDef NVIC_InitStructure;
GPIO_InitTypeDef GPIO_InitStructure;
SPI_InitTypeDef SPI_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); //ʹÄÜPA¶Ë¿ÚʱÖÓ
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_AFIO, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1,ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //ÍÆÍìÊä³ö
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
//SPI_SSOutputCmd(SPI1,ENABLE);
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;//SPI_Mode_Master SPI_Mode_Slave
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //SPI_NSS_Hard SPI_NSS_Soft
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_Init(SPI1, &SPI_InitStructure);
SPI_Cmd(SPI1, ENABLE);
SPI_I2S_ITConfig(SPI1,SPI_I2S_IT_RXNE,ENABLE);
NVIC_InitStructure.NVIC_IRQChannel = SPI1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
GPIO_SetBits(GPIOA,GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
SPI1_ReadWriteByte(0xff);//Æô¶¯´«Êä
void SPI1_SetSpeed(u8 SpeedSet)
SPI1->CR1&=0XFFC7;//Fsck=Fcpu/256
if(SpeedSet==SPI_SPEED_2)//¶þ·ÖƵ
SPI1->CR1|=0<<3;//Fsck=Fpclk/2=36Mhz
}else if(SpeedSet==SPI_SPEED_8)//°Ë·ÖƵ
SPI1->CR1|=2<<3;//Fsck=Fpclk/8=9Mhz
}else if(SpeedSet==SPI_SPEED_16)//Ê®Áù·ÖƵ
SPI1->CR1|=3<<3;//Fsck=Fpclk/16=4.5Mhz
}else //256·ÖƵ
SPI1->CR1|=7<<3; //Fsck=Fpclk/256=281.25Khz µÍË
SPI1->CR1|=1<<6; //
u8 SPI1_ReadWriteByte(u8 TxData)
u8 retry=0;
while((SPI1->SR&1<<1)==0)//µÈ´ý·¢ËÍÇø¿Õ
retry++;
if(retry>200)return 0;
SPI1->DR=TxData; //·¢ËÍÒ»¸öbyte
retry=0;
while((SPI1->SR&1<<0)==0) //µÈ´ý½ÓÊÕÍêÒ»¸öbyte
retry++;
return SPI1->DR; //·µ»ØÊÕµ½µÄÊý¾Ý
u8 SPI1_ReadByte(u8 TxData)
u8 retry=0;
retry++;
#include "spi.h"
#include "sys.h" //ϵͳ×Óº¯Êý
#include "delay.h" //ÑÓʱ×Óº¯Êý
//PA4 SPI1_NSS
//PA5 SPI1_SCK
//PA6 SPI1_MISO
//PA7 SPI1_MOSI
u8 Master_Temp =0;
int main(void)
SystemInit();
delay_init(72); //ÑÓʱ³õʼ»¯
NVIC_Configuration();
SPI1_Init(); //SPI1³õʼ»¯
SPI1_SetSpeed(SPI_SPEED_256);
GPIO_ResetBits(GPIOA,GPIO_Pin_4);
while(1)
SPI1_ReadWriteByte(0x22);
delay_ms(100);
void SPI1_IRQHandler(void)
if((SPI1->SR&1<<0)==1)
Master_Temp = SPI1_ReadByte(0x00);
从机SPI2配置函数:
#include "spi.h"
void SPI2_Init(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_AFIO, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2,ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14|GPIO_Pin_15;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;//GPIO_Mode_IPD;
GPIO_SetBits(GPIOB,GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15);
SPI_InitStructure.SPI_Mode = SPI_Mode_Slave;//SPI_Mode_Master SPI_Mode_Slave
SPI_InitStructure.SPI_NSS = SPI_NSS_Hard; //SPI_NSS_Hard SPI_NSS_Soft
SPI_Init(SPI2, &SPI_InitStructure);
SPI_I2S_ITConfig(SPI2,SPI_I2S_IT_RXNE,ENABLE);
NVIC_InitStructure.NVIC_IRQChannel = SPI2_IRQn;
SPI_Cmd(SPI2, ENABLE); //ʹÄÜSPIÍâÉè
//SpeedSet:
//SPI_SPEED_2 2·ÖƵ (SPI 12M --sys 24M)
//SPI_SPEED_8 8·ÖƵ (SPI 3M --sys 24M)
//SPI_SPEED_16 16·ÖƵ (SPI 1.5M --sys 24M)
//SPI_SPEED_256 256·ÖƵ (SPI 905.6K --sys 24M)
void SPI2_SetSpeed(u8 SpeedSet)
SPI2->CR1&=0XFFC7;//Fsck=Fcpu/256
SPI2->CR1|=0<<3;//Fsck=Fpclk/2=36Mhz
SPI2->CR1|=2<<3;//Fsck=Fpclk/8=9Mhz
SPI2->CR1|=3<<3;//Fsck=Fpclk/16=4.5Mhz
else //256·ÖƵ
SPI2->CR1|=7<<3; //Fsck=Fpclk/256=281.25Khz µÍËÙģʽ
SPI2->CR1|=1<<6; //SPIÉ豸ʹÄÜ
u8 SPI2_ReadWriteByte(u8 TxData)
u8 retry=0;
while((SPI2->SR&1<<1)==0)//µÈ´ý·¢ËÍÇø¿Õ
retry++;
SPI2->DR=TxData; //·¢ËÍÒ»¸öbyte
retry=0;
while((SPI2->SR&1<<0)==0) //µÈ´ý½ÓÊÕÍêÒ»¸öbyte
retry++;
return SPI2->DR; //·µ»ØÊÕµ½µÄÊý¾Ý
u8 SPI2_ReadByte(u8 TxData)
u8 retry=0;
retry++;
#include "spi.h"
u8 Slave_Temp=0;
void SPI2_Init(void); //³õʼ»¯SPI¿Ú
void SPI2_SetSpeed(u8 SpeedSet); //ÉèÖÃSPIËÙ¶È
u8 SPI2_ReadWriteByte(u8 TxData);
//PB13 SPI2_SCK
//PB14 SPI2_MISO
//PB15 SPI2_MOSI
int main(void)
SystemInit();
SPI2_Init(); //SPI2³õʼ»¯
SPI2_SetSpeed(SPI_SPEED_256);//SPI2ËÙ¶ÈÁ½·ÖƵ
while(1)
delay_ms(100);
void SPI2_IRQHandler(void)
if((SPI2->SR&1<<0)==1)
Slave_Temp = SPI2_ReadByte(0x00);
注意事项:主机片选引脚模式为推完输出,配置为复用无法控制输出电平,从机为硬件模式,上拉输入,主机初始化SPI时候,拉高nss引脚,发数据前拉低nss,从而从机nss被硬件拉低,选中该芯片。
仪器仪表相关产品包括:温度仪表,流量仪表,压力仪表,机械仪表(称重,转速,测厚),液位仪表,料位仪表,显示仪表,有纸/无纸记录仪,分析仪表,校验仪表等。 仪器功能在于物理、化学或生物的方法,获取被检测对象运动或变化的信息。在科 ...… 查看全部问答> |
为AMD硬件平台定制一个wince平台想实现下面几个东西 1.创建一个桌面快捷方式。 2.在WINDOWS目录下默认创建一个文件夹。 3.添加额外的文件到NK,并且开机运行 请问如何实现… 查看全部问答> |
用DS18B20测温度,现在遇到问题,对STM32的延时和 GPIO口的输出不太明白,与51单片机不一样。移植不成功,做 ...… 查看全部问答> |
前阵子我在别的论坛买了一块16×64的点阵屏,带STC89C52RC驱动的,根据实物,我已绘制出其电路,并下载了一个左移程序,但搞了很久,都无法解决重影问题!如果一帧只扫一次的话,没有重影,每行扫频为1ms,但移动速度很多,没什么实用价值,于是设 ...… 查看全部问答> |
【设计工具】Spartan-3 FPGA 系列中高效PCB 布局的LVDS 信号倒相设计技巧 本应用指南说明 Spartan- 3 FPGA 系列如何仅通过在接收器数据通路中加入一个倒相器即可避免大量使用过孔,并且在不要求 PCB 重新设计的情况下即可解决意外的 PCB 迹线交换问题。 在比较简单的未大量使用过孔的四层或六层 PCB 上,可能很难 ...… 查看全部问答> |
协议栈里一个自定义的任务ID是怎么设置的,我没想通,请各位大神指点迷津file:///C:\\Users\\WANGJI~1\\AppData\\Local\\Temp\\G@YVKCPZR)X}3UKB(_VF`LW.gif … 查看全部问答> |
