今天是:2024年10月05日(星期六)
2018年10月05日 | 51单片机温度PID算法(C程序)
2018-10-05 来源:eefocus
#include "reg51.h"
#include "intrins.h"
#include "math.h"
#include "string.h"
struct PID
unsigned int SetPoint; // 设定目标 Desired Value
unsigned int Proportion; // 比例常数 Proportional Const
unsigned int Integral; // 积分常数 Integral Const
unsigned int Derivative; // 微分常数 Derivative Const
unsigned int LastError; // Error[-1]
unsigned int PrevError; // Error[-2]
unsigned int SumError; // Sums of Errors
struct PID spid; // PID Control Structure
unsigned int rout; // PID Response (Output)
unsigned int rin; // PID Feedback (Input)
sbit data1=P1^0;
sbit clk=P1^1;
sbit plus=P2^0;
sbit subs=P2^1;
sbit stop=P2^2;
sbit output=P3^4;
sbit DQ=P3^3;
unsigned char flag,flag_1=0;
unsigned char high_time,low_time,count=0;//占空比调节参数
unsigned char set_temper=25;
unsigned char temper;
unsigned char i;
unsigned char j=0;
unsigned int s;
void delay(unsigned char time)
unsigned char m,n;
for(n=0;n
for(m=0;m<2;m++){}
void write_bit(unsigned char bitval)
EA=0;
DQ=0;
if(bitval==1)
_nop_();
DQ=1;
delay(5);
DQ=1;
_nop_();
_nop_();
EA=1;
void write_byte(unsigned char val)
unsigned char i;
unsigned char temp;
EA=0;
TR0=0;
for(i=0;i<8;i++)
temp=val>>i;
temp=temp&1;
write_bit(temp);
delay(7);
// TR0=1;
EA=1;
unsigned char read_bit()
unsigned char i,value_bit;
EA=0;
DQ=0;
_nop_();
_nop_();
DQ=1;
for(i=0;i<2;i++){}
value_bit=DQ;
EA=1;
return(value_bit);
unsigned char read_byte()
unsigned char i,value=0;
EA=0;
for(i=0;i<8;i++)
if(read_bit())
value|=0x01<
delay(4);
EA=1;
return(value);
unsigned char reset()
unsigned char presence;
EA=0;
DQ=0;
delay(30);
DQ=1;
delay(3);
presence=DQ;
delay(28);
EA=1;
return(presence);
void get_temper()
unsigned char i,j;
do
i=reset();
} while(i!=0);
i=0xcc;
write_byte(i);
i=0x44;
write_byte(i);
delay(180);
do
i=reset();
} while(i!=0);
i=0xcc;
write_byte(i);
i=0xbe;
write_byte(i);
j=read_byte();
i=read_byte();
i=(i<<4)&0x7f;
s=(unsigned int)(j&0x0f); //得到小数部分
s=(s*100)/16;
j=j>>4;
temper=i|j;
void PIDInit (struct PID *pp)
memset ( pp,0,sizeof(struct PID)); //全部初始化为0
unsigned int PIDCalc( struct PID *pp, unsigned int NextPoint )
unsigned int dError,Error;
Error = pp->SetPoint - NextPoint; // 偏差
pp->SumError += Error; // 积分
dError = pp->LastError - pp->PrevError; // 当前微分
pp->PrevError = pp->LastError;
pp->LastError = Error;
return (pp->Proportion * Error // 比例项
+ pp->Integral * pp->SumError // 积分项
+ pp->Derivative * dError); // 微分项
void compare_temper()
unsigned char i;
if(set_temper>temper) //是否设置的温度大于实际温度
if(set_temper-temper>1) //设置的温度比实际的温度是否是大于1度
high_time=100; //如果是,则全速加热
low_time=0;
else //如果是在1度范围内,则运行PID计算
for(i=0;i<10;i++)
get_temper(); //获取温度
rin = s; // Read Input
rout = PIDCalc ( &spid,rin ); // Perform PID Interation
if (high_time<=100)
high_time=(unsigned char)(rout/800);
else
high_time=100;
low_time= (100-high_time);
else if(set_temper<=temper)
if(temper-set_temper>0)
high_time=0;
low_time=100;
else
for(i=0;i<10;i++)
get_temper();
if (high_time<100)
high_time=(unsigned char)(rout/10000);
else
high_time=0;
// else
void serve_T0() interrupt 1 using 1
if(++count<=(high_time))
output=1;
else if(count<=100)
output=0;
else
count=0;
TH0=0x2f;
TL0=0xe0;
void serve_sio() interrupt 4 using 2
void disp_1(unsigned char disp_num1[6])
unsigned char n,a,m;
for(n=0;n<6;n++)
// k=disp_num1[n];
for(a=0;a<8;a++)
clk=0;
m=(disp_num1[n]&1);
disp_num1[n]=disp_num1[n]>>1;
if(m==1)
data1=1;
else
data1=0;
_nop_();
clk=1;
_nop_();
void display()
unsigned char code number[]={0xfc,0x60,0xda,0xf2,0x66,0xb6,0xbe,0xe0,0xfe,0xf6};
unsigned char disp_num[6];
unsigned int k,k1;
k=high_time;
k=k00;
k1=k/100;
if(k1==0)
disp_num[0]=0;
else
disp_num[0]=0x60;
k=k0;
disp_num[1]=number[k/10];
disp_num[2]=number[k];
k=temper;
k=k0;
disp_num[3]=number[k/10];
disp_num[4]=number[k]+1;
disp_num[5]=number[s/10];
disp_1(disp_num);
void main()
unsigned char z;
unsigned char a,b,flag_2=1,count1=0;
unsigned char phil[]={2,0xce,0x6e,0x60,0x1c,2};
TMOD=0x21;
TH0=0x2f;
TL0=0x40;
SCON=0x50;
PCON=0x00;
TH1=0xfd;
TL1=0xfd;
PS=1;
EA=1;
EX1=0;
ET0=1;
ES=1;
TR0=1;
TR1=1;
high_time=50;
low_time=50;
PIDInit ( &spid ); // Initialize Structure
spid.Proportion = 10; // Set PID Coefficients 比例常数 Proportional Const
spid.Integral = 8; //积分常数 Integral Const
spid.Derivative =6; //微分常数 Derivative Const
spid.SetPoint = 100; // Set PID Setpoint 设定目标 Desired Value
while(1)
if(plus==0)
EA=0;
for(a=0;a<5;a++)
for(b=0;b<102;b++){}
if(plus==0)
set_temper++;
flag=0;
else if(subs==0)
for(a=0;a<5;a++)
for(b=0;a<102;b++){}
if(subs==0)
set_temper--;
flag=0;
else if(stop==0)
for(a=0;a<5;a++)
if(stop==0)
flag=0;
break;
EA=1;
get_temper();
b=temper;
if(flag_2==1)
a=b;
if((abs(a-b))>5)
temper=a;
else
temper=b;
a=temper;
flag_2=0;
if(++count1>30)
display();
count1=0;
compare_temper();
TR0=0;
z=1;
while(1)
EA=0;
if(stop==0)
for(a=0;a<5;a++)
if(stop==0)
disp_1(phil);
// break;
EA=1;
上一篇:12864液晶显示原理(C程序)
没有机器猫的万能口袋,也能把K歌房随身携带噢! 它就是一个月前刚刚上市的超炫小家电“Hi-kara”,TAKARATOMY公司推出的个人专用的迷你卡拉OK设备。机身是7cm的正方体,重量仅有150克,可以托在手掌上,说它是世界最小真是一点都不夸张。对照着 ...… 查看全部问答> |
下位机通过RS485向上位机发送数据,中间通过第三方的RS232-485转换器(购买的,型号HXSP-2108C)后,再通过USB转232接到PC端,再通过串口测试软件COMMASTER进行上位机和下位机的数据通讯。 但是现在碰到一个问题,下位机 ...… 查看全部问答> |
这是一款philips的ARM7芯片,希望上面打一个开发板出来,不知道哪位高手有用过的 希望指教 想搭一个开发平台,包括SD卡,USB口,液晶驱动和AD采集 QQ:12665590… 查看全部问答> |
小弟做应用层的,两个平台的区别就不想去研究了。 最近搞了wince和windows mobile的项目,都是基于mfc开发的,不知道两种开发有什么区别。… 查看全部问答> |
LF2407A,利用定时器定时读取AD转换值,为什么在中断处理程序中去掉将IFR清零的语句仍然可以不断的进入AD中断程序读取AD值呢?不是IFR如果不人工清零的话,对于以后的中断就不处理吗?谁能解释一下?好奇怪 … 查看全部问答> |
各位好,我有个问题请大家帮忙,我按照现成的例子: tcp_new,tcp_bind,tcp_listen,tcp_accept,走,可以后面收到测试包,但是用抓包工具,发现,我这边的本端在建链时,没有回应SYN ACK,我认为不对,请问怎么产生这个过程… 查看全部问答> |
