今天是:2024年12月27日(星期五)
2018年12月27日 | stm32中中断源名和中断处理函数名所在位置
2018-12-27 来源:eefocus
两个文件分别在stm32f4xx.h(中断名)
CORE—startup_stm32f40_41xxx.s(中断函数名)
#if defined (STM32F40_41xxx)
CAN1_TX_IRQn = 19, /*!< CAN1 TX Interrupt */
CAN1_RX0_IRQn = 20, /*!< CAN1 RX0 Interrupt */
CAN1_RX1_IRQn = 21, /*!< CAN1 RX1 Interrupt */
CAN1_SCE_IRQn = 22, /*!< CAN1 SCE Interrupt */
EXTI9_5_IRQn = 23, /*!< External Line[9:5] Interrupts */
TIM1_BRK_TIM9_IRQn = 24, /*!< TIM1 Break interrupt and TIM9 global interrupt */
TIM1_UP_TIM10_IRQn = 25, /*!< TIM1 Update Interrupt and TIM10 global interrupt */
TIM1_TRG_COM_TIM11_IRQn = 26, /*!< TIM1 Trigger and Commutation Interrupt and TIM11 global interrupt */
TIM1_CC_IRQn = 27, /*!< TIM1 Capture Compare Interrupt */
TIM2_IRQn = 28, /*!< TIM2 global Interrupt */
TIM3_IRQn = 29, /*!< TIM3 global Interrupt */
TIM4_IRQn = 30, /*!< TIM4 global Interrupt */
I2C1_EV_IRQn = 31, /*!< I2C1 Event Interrupt */
I2C1_ER_IRQn = 32, /*!< I2C1 Error Interrupt */
I2C2_EV_IRQn = 33, /*!< I2C2 Event Interrupt */
I2C2_ER_IRQn = 34, /*!< I2C2 Error Interrupt */
SPI1_IRQn = 35, /*!< SPI1 global Interrupt */
SPI2_IRQn = 36, /*!< SPI2 global Interrupt */
USART1_IRQn = 37, /*!< USART1 global Interrupt */
USART2_IRQn = 38, /*!< USART2 global Interrupt */
USART3_IRQn = 39, /*!< USART3 global Interrupt */
EXTI15_10_IRQn = 40, /*!< External Line[15:10] Interrupts */
RTC_Alarm_IRQn = 41, /*!< RTC Alarm (A and B) through EXTI Line Interrupt */
OTG_FS_WKUP_IRQn = 42, /*!< USB OTG FS Wakeup through EXTI line interrupt */
TIM8_BRK_TIM12_IRQn = 43, /*!< TIM8 Break Interrupt and TIM12 global interrupt */
TIM8_UP_TIM13_IRQn = 44, /*!< TIM8 Update Interrupt and TIM13 global interrupt */
TIM8_TRG_COM_TIM14_IRQn = 45, /*!< TIM8 Trigger and Commutation Interrupt and TIM14 global interrupt */
TIM8_CC_IRQn = 46, /*!< TIM8 Capture Compare Interrupt */
DMA1_Stream7_IRQn = 47, /*!< DMA1 Stream7 Interrupt */
FSMC_IRQn = 48, /*!< FSMC global Interrupt */
SDIO_IRQn = 49, /*!< SDIO global Interrupt */
TIM5_IRQn = 50, /*!< TIM5 global Interrupt */
SPI3_IRQn = 51, /*!< SPI3 global Interrupt */
UART4_IRQn = 52, /*!< UART4 global Interrupt */
UART5_IRQn = 53, /*!< UART5 global Interrupt */
TIM6_DAC_IRQn = 54, /*!< TIM6 global and DAC1&2 underrun error interrupts */
TIM7_IRQn = 55, /*!< TIM7 global interrupt */
DMA2_Stream0_IRQn = 56, /*!< DMA2 Stream 0 global Interrupt */
DMA2_Stream1_IRQn = 57, /*!< DMA2 Stream 1 global Interrupt */
DMA2_Stream2_IRQn = 58, /*!< DMA2 Stream 2 global Interrupt */
DMA2_Stream3_IRQn = 59, /*!< DMA2 Stream 3 global Interrupt */
DMA2_Stream4_IRQn = 60, /*!< DMA2 Stream 4 global Interrupt */
ETH_IRQn = 61, /*!< Ethernet global Interrupt */
ETH_WKUP_IRQn = 62, /*!< Ethernet Wakeup through EXTI line Interrupt */
CAN2_TX_IRQn = 63, /*!< CAN2 TX Interrupt */
CAN2_RX0_IRQn = 64, /*!< CAN2 RX0 Interrupt */
CAN2_RX1_IRQn = 65, /*!< CAN2 RX1 Interrupt */
CAN2_SCE_IRQn = 66, /*!< CAN2 SCE Interrupt */
OTG_FS_IRQn = 67, /*!< USB OTG FS global Interrupt */
DMA2_Stream5_IRQn = 68, /*!< DMA2 Stream 5 global interrupt */
DMA2_Stream6_IRQn = 69, /*!< DMA2 Stream 6 global interrupt */
DMA2_Stream7_IRQn = 70, /*!< DMA2 Stream 7 global interrupt */
USART6_IRQn = 71, /*!< USART6 global interrupt */
I2C3_EV_IRQn = 72, /*!< I2C3 event interrupt */
I2C3_ER_IRQn = 73, /*!< I2C3 error interrupt */
OTG_HS_EP1_OUT_IRQn = 74, /*!< USB OTG HS End Point 1 Out global interrupt */
OTG_HS_EP1_IN_IRQn = 75, /*!< USB OTG HS End Point 1 In global interrupt */
OTG_HS_WKUP_IRQn = 76, /*!< USB OTG HS Wakeup through EXTI interrupt */
OTG_HS_IRQn = 77, /*!< USB OTG HS global interrupt */
DCMI_IRQn = 78, /*!< DCMI global interrupt */
CRYP_IRQn = 79, /*!< CRYP crypto global interrupt */
HASH_RNG_IRQn = 80, /*!< Hash and Rng global interrupt */
FPU_IRQn = 81 /*!< FPU global interrupt */
#endif /* STM32F40_41xxx */
中断函数名
WWDG_IRQHandler
PVD_IRQHandler
TAMP_STAMP_IRQHandler
RTC_WKUP_IRQHandler
FLASH_IRQHandler
RCC_IRQHandler
EXTI0_IRQHandler
EXTI1_IRQHandler
EXTI2_IRQHandler
EXTI3_IRQHandler
EXTI4_IRQHandler
DMA1_Stream0_IRQHandler
DMA1_Stream1_IRQHandler
DMA1_Stream2_IRQHandler
DMA1_Stream3_IRQHandler
DMA1_Stream4_IRQHandler
DMA1_Stream5_IRQHandler
DMA1_Stream6_IRQHandler
ADC_IRQHandler
CAN1_TX_IRQHandler
CAN1_RX0_IRQHandler
CAN1_RX1_IRQHandler
CAN1_SCE_IRQHandler
EXTI9_5_IRQHandler
TIM1_BRK_TIM9_IRQHandler
TIM1_UP_TIM10_IRQHandler
TIM1_TRG_COM_TIM11_IRQHandler
TIM1_CC_IRQHandler
TIM2_IRQHandler
TIM3_IRQHandler
TIM4_IRQHandler
I2C1_EV_IRQHandler
I2C1_ER_IRQHandler
I2C2_EV_IRQHandler
I2C2_ER_IRQHandler
SPI1_IRQHandler
SPI2_IRQHandler
USART1_IRQHandler
USART2_IRQHandler
USART3_IRQHandler
EXTI15_10_IRQHandler
RTC_Alarm_IRQHandler
OTG_FS_WKUP_IRQHandler
TIM8_BRK_TIM12_IRQHandler
TIM8_UP_TIM13_IRQHandler
TIM8_TRG_COM_TIM14_IRQHandler
TIM8_CC_IRQHandler
DMA1_Stream7_IRQHandler
FSMC_IRQHandler
SDIO_IRQHandler
TIM5_IRQHandler
SPI3_IRQHandler
UART4_IRQHandler
UART5_IRQHandler
TIM6_DAC_IRQHandler
TIM7_IRQHandler
DMA2_Stream0_IRQHandler
DMA2_Stream1_IRQHandler
DMA2_Stream2_IRQHandler
DMA2_Stream3_IRQHandler
DMA2_Stream4_IRQHandler
ETH_IRQHandler
ETH_WKUP_IRQHandler
CAN2_TX_IRQHandler
CAN2_RX0_IRQHandler
CAN2_RX1_IRQHandler
CAN2_SCE_IRQHandler
OTG_FS_IRQHandler
DMA2_Stream5_IRQHandler
DMA2_Stream6_IRQHandler
DMA2_Stream7_IRQHandler
USART6_IRQHandler
I2C3_EV_IRQHandler
I2C3_ER_IRQHandler
OTG_HS_EP1_OUT_IRQHandler
OTG_HS_EP1_IN_IRQHandler
OTG_HS_WKUP_IRQHandler
OTG_HS_IRQHandler
DCMI_IRQHandler
CRYP_IRQHandler
HASH_RNG_IRQHandler
FPU_IRQHandler
存活之道 有人形容,目前中国的IC设计产业处在国际竞争的“万山围子”里,存活不易,发展更难。好在“山高自有行客路”,存活和发展之道还是有的,把握得好,这个行业由“弱冠”而“成人”的时间应不会太长。 华为和中兴这两家大企业利用其 ...… 查看全部问答> |
前言 FPGA(现场可编程门阵列)是由掩膜可编程门阵列和PLD(可编程逻辑器件)演变而来的,并将二者的特性结合在一起,使FPGA既有掩膜可编程门阵列的高逻辑密度和通用性,又有PLD的可编程特性。FPAG技术的发展使得单个芯片上集成的逻辑门数越来越多 ...… 查看全部问答> |
代码如下,我通过亮灯显示执行情况,发现我执行休眠时,在设置内存自刷新后,就直接跑飞了。不知道为何? ; 7. Go to Power-Off Mode ldr r0, =vMISCCR ; hit the TLB ldr r0, [r0] ldr r0, =vCLKCON ldr r0, [r0] ...… 查看全部问答> |
新手求教Serdes的Deterministic Latency模式 pattern信号与0xBC对不齐 数据检测出错 如题,本人正在使用Cyclone IV GX EP4CGX75CF23,现在在调试serdes的时候遇到了大问题,还请知道的好心朋友帮指导指导,先提前谢过了! Serdes使用的Deterministic Latency模式做收发器,现发现接收到的rx_patterndetect信号有时候与0xBC对不齐, ...… 查看全部问答> |
提到TI,不得不说,缘分还真近,听我从头说起。 其实我的专业是网络工程,这个专业其实与电类专业没啥交集,能有点关系的就是计算机体系结构的基础课程—数字电路与逻辑设计,稍微讲了讲常用数字器件与非门什么的。然而,在内心深处 ...… 查看全部问答> |
