今天是:2025年01月29日(星期三)
2019年01月29日 | STM32基础设计(5)---ADC转换(中断方式)
2019-01-29 来源:eefocus
本文简单介绍了STM32F103C8,通过中断方式读取电压,不过最后楼主读取参考电压失败,还没有找到错误,所以读取的电压只能十六进制显示,如有不便请忽略本文!
本文的介绍按照一般流程来走:
1,串口的初始化
2,ADC初始化
3,中断初始化
4,编写中断函数
5,编写主函数
接下来详细介绍:
1,串口的初始化:
void usart_init()
GPIO_InitTypeDef Uart_A;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA ,ENABLE);
Uart_A.GPIO_Pin = GPIO_Pin_9;
Uart_A.GPIO_Speed = GPIO_Speed_50MHz;
Uart_A.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA,&Uart_A);
Uart_A.GPIO_Pin = GPIO_Pin_10;
Uart_A.GPIO_Mode = GPIO_Mode_IN_FLOATING;
USART_InitTypeDef Uart;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);
Uart.USART_BaudRate = 115200;
Uart.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
Uart.USART_Mode = USART_Mode_Tx;
Uart.USART_Parity = USART_Parity_No;
Uart.USART_StopBits = USART_StopBits_1;
Uart.USART_WordLength = USART_WordLength_8b;
USART_Init(USART1,&Uart);
USART_Cmd(USART1,ENABLE);
USART_ClearFlag(USART1,USART_FLAG_TC);
关于本段代码,我前面写的文章STM32基础设计(3)有详细讲解,此处不再赘述。
2,ADC初始化
typedef struct
{//配置ADC的模式,一个ADC是独立模式,2个是双模式
uint32_t ADC_Mode; /*!< Configures the ADC to operate in independent or
dual mode.
This parameter can be a value of @ref ADC_mode */
//配置ADC是否使用扫描,单通道不扫描,多通道扫描
FunctionalState ADC_ScanConvMode; /*!< Specifies whether the conversion is performed in
Scan (multichannels) or Single (one channel) mode.
This parameter can be set to ENABLE or DISABLE */
//配置ADC是单次转换还是连续转换
FunctionalState ADC_ContinuousConvMode; /*!< Specifies whether the conversion is performed in
Continuous or Single mode.
This parameter can be set to ENABLE or DISABLE. */
//外部触发选择
uint32_t ADC_ExternalTrigConv; /*!< Defines the external trigger used to start the analog
to digital conversion of regular channels. This parameter
can be a value of @ref ADC_external_trigger_sources_for_regular_channels_conversion */
//转换结果数据对其方式
uint32_t ADC_DataAlign; /*!< Specifies whether the ADC data alignment is left or right.
This parameter can be a value of @ref ADC_data_align */
//ADC转换的通道数目
uint8_t ADC_NbrOfChannel; /*!< Specifies the number of ADC channels that will be converted
using the sequencer for regular channel group.
This parameter must range from 1 to 16. */
}ADC_InitTypeDef;
下面粘贴代码:
void Adc_Init()
ADC_InitTypeDef adc;//定义ADC结构的变量
GPIO_InitTypeDef io_b;//定义串口结构体变量 ,开发板上的电源接的是GPIOB端口的 1引脚,查数据手册,其为ADC1的9通道
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOB,ENABLE);//开时钟(即把心脏激活)
RCC_ADCCLKConfig(RCC_PCLK2_Div6);
io_b.GPIO_Pin = GPIO_Pin_1;//设置端口引脚为 引脚1
io_b.GPIO_Mode = GPIO_Mode_AIN;//设置为输入模式
io_b.GPIO_Speed = GPIO_Speed_50MHz;//最高速率为50MHz
GPIO_Init(GPIOB,&io_b);初始化引脚
ADC_DeInit(ADC1);先将外设ADC1的全部寄存器重设为默认值 ADC_TempSensorVrefintCmd(ENABLE);谁能外部参照电压(勿忘)
adc.ADC_Mode = ADC_Mode_Independent;设置ADC为独立模式
adc.ADC_ScanConvMode = ENABLE;使能扫描模式
adc.ADC_ContinuousConvMode = ENABLE;使能连续扫描
adc.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;不使用外部触发
adc.ADC_DataAlign = ADC_DataAlign_Right;数据右对齐
adc.ADC_NbrOfChannel = 2;来制定用几个ADC通达(勿忘)
ADC_Init(ADC1,&adc);初始化ADC寄存器
ADC_RegularChannelConfig(ADC1,ADC_Channel_9,1,ADC_SampleTime_239Cycles5);制定用哪个ADC转换、第几个通道,转换的顺序、转换的周期
ADC_RegularChannelConfig(ADC1,ADC_Channel_17,2,ADC_SampleTime_239Cycles5);
//这里需要根据数据手册来设定通道,数据手册上会说明那个引脚对应那个通道,外接电源接到那个引脚上就可以了,必须按照数据手册的要求来,不然肯定会出错,博主在这里就有一个很大很大的教训,望读者谨记
ADC_ITConfig(ADC1,ADC_IT_EOC,ENABLE);打开ADC中断
ADC_Cmd(ADC1,ENABLE);使能ADC1
ADC_ResetCalibration(ADC1);复位ADC1的校准寄存器
while(ADC_GetResetCalibrationStatus(ADC1));等待校准寄存器复位完成
ADC_StartCalibration(ADC1);开始ADC1校准
while(ADC_GetCalibrationStatus(ADC1));等待ADC1校准完成
ADC_SoftwareStartConvCmd(ADC1,ENABLE);使能指定的ADC1的软件转换启动功能
3.中断初始化
void adc_nvic_init()
NVIC_InitTypeDef nvic;定义中断结构体
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);设置中断分组
nvic.NVIC_IRQChannel = ADC1_2_IRQn;制定专断通道
nvic.NVIC_IRQChannelCmd = ENABLE;使能中断
nvic.NVIC_IRQChannelPreemptionPriority = 1;抢占优先级
nvic.NVIC_IRQChannelSubPriority = 1;子优先级
NVIC_Init(&nvic);初始化
NVIC_InitTypeDef usart1;定义中断结构体
usart1.NVIC_IRQChannel = USART1_IRQn;指定中断通道
usart1.NVIC_IRQChannelCmd = ENABLE;设能中断通道
usart1.NVIC_IRQChannelPreemptionPriority = 0;抢占优先级
usart1.NVIC_IRQChannelSubPriority= 0;子优先级
NVIC_Init(&usart1);中断初始化
博主在这里遇到一个问题,该问题时,中断分组的设置,上面两段程序得分别设置中断分组,要不然会有一个中断不会执行(没有再次设置中断分组的那个),不知道是博主代码规范的问题还是就必须这样设置。博主还未搞懂,如果读者有知道这个问题答案的,请在评论里赐教,不胜感激。
4,编写中断函数
先粘贴代码:
void ADC1_2_IRQHandler()
if(ADC_GetITStatus(ADC1,ADC_IT_EOC) == SET)这里使用来判断,如果已经转换完成EOC位为1,具体请查看参考手册ADC状态寄存器ADC_SR的eEOC位
{if(count_1%2 == 0){代码中的if语句中的嵌套if语句是用来区分外接电源电压和内部参考电压的。具体见下面的解释
ADC_ConvertedValue = ADC_GetConversionValue(ADC1);
count_1++;
}else
ADC_ConvertedValue_1 = ADC_GetConversionValue(ADC1);
//ADC_ConvertedValue_1 = ADC1->DR;
count_1++;
ADC_ClearITPendingBit(ADC1,ADC_IT_EOC);
void USART1_IRQHandler(void)
if(USART_GetFlagStatus(USART1,USART_FLAG_TXE))判断是否可以发送数据
USART1->CR1 &= ~USART_CR1_TXEIE;在这里笔者也碰到了问题,详见下文
USART1->DR = car;
while(USART_GetFlagStatus(USART1,USART_FLAG_TXE) == RESET);
//USART1->CR1 &= ~USART_CR1_TXEIE;
if(USART1->SR & USART_SR_RXNE)判断是否可以接收数据
volatile int8_t com_data;
com_data = USART1->DR;
在ADC中断服务函数中,代码中的if语句中的嵌套if语句是用来区分外接电源电压和内部参考电压的,因为第一次接受的是外部电源电压,第二次接受的是内部参考电压,所以可以利用奇偶数,即偶数用ADC_ConvertedValue来存放外部电源电压值,奇数时用ADC_ConvertedValue_1来存放参考电压值。但是,笔者发现,这样会失败,经过串口调试发现两次接受到的值都一样,笔者初步认为,可能是ADC的转换速率太快了,具体什么歌情况还不清楚,等下一个基础设计ADC转换(DMA方式)的时候在细究。
笔者,在调试程序的时候发现,通过中断的方式进行串口通信必须在给DR赋值之前将CR1寄存器的 TXEIE寄存器置0,以防止DE接受完数据后再次进入中断,要不然将数据赋值给DR后会一直进入中断(笔者在调试的时候发现,会一直重复输出一个值,笔者猜测这不是因为中断结束不了,而是因为,嵌套了N层循环,但是根据STM32参考手册的543页,TXEIE为明明解释是由软件设置,笔者在主函数里设置了TXEIE为0,发现没有用,如果在中断服务函数中不再次清零,就跳不出中断。),另外DR接受完数据后,还要加一句
要是没有这一句,串口调试时发现,一个值连续打印两次。(笔者猜测是不是因为电脑速度太快了。)
以上两个问题,笔者还没有找到原因,只是找到了解决方法,希望看到这篇文章的读者,如果知道原因,请不吝赐教,在下不胜感激。
2018年3月27日补:
关于那个还要在中断服务函数中再次将TXEIE设置为零,是因为发送中断是通过 打开中断函数(USART_ITConfig)进入的,该函数中已经将CR1寄存器中的TXEIE位置1 的,所以中断服务函数中还要再次清0,以防止再中断。
5,编写主函数
int main()
void PrintU16(uint16_t num);
void PrintHexU8(uint8_t data);
Adc_Init();
adc_nvic_init();
usart_init();
while(1)
num = (uint16_t)(2.0f* ADC_ConvertedValue/ADC_ConvertedValue_1 *1.2f*100 );参考电压是1.2f通过比例关系算出实际电压。
PrintU16(num);
delay(1000);
笔者并没有计算出准确的电压值,只是采集到两个电压值,笔者猜测,可能是因为ADC的转换速率太快,导致笔者的 通过奇偶数来区分内部电压和外部电压不管用了,笔者还在思考解决方式,如果读者有好的方法,请指教。
本文到此结束,下面是完整代码:
#include
#define uint unsigned int
#define uchar unsigned char
char car;
static char count_1=0;//当做奇偶数
uint16_t ADC_ConvertedValue;//存放电源电压
uint16_t ADC_ConvertedValue_1;//存放内部参照电压
static uint16_t num=0;
void delay(uint n)
int i,j;
for(i=0;i for(j=0;j<8500;j++); } void Adc_Init() { ADC_InitTypeDef adc; GPIO_InitTypeDef io_b; RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOB,ENABLE); RCC_ADCCLKConfig(RCC_PCLK2_Div6); io_b.GPIO_Pin = GPIO_Pin_1; io_b.GPIO_Mode = GPIO_Mode_AIN; io_b.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOB,&io_b); ADC_DeInit(ADC1); ADC_TempSensorVrefintCmd(ENABLE); adc.ADC_Mode = ADC_Mode_Independent; adc.ADC_ScanConvMode = ENABLE; adc.ADC_ContinuousConvMode = ENABLE; adc.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; adc.ADC_DataAlign = ADC_DataAlign_Right; adc.ADC_NbrOfChannel = 2; ADC_Init(ADC1,&adc); ADC_RegularChannelConfig(ADC1,ADC_Channel_9,1,ADC_SampleTime_239Cycles5); ADC_RegularChannelConfig(ADC1,ADC_Channel_17,2,ADC_SampleTime_239Cycles5); ADC_ITConfig(ADC1,ADC_IT_EOC,ENABLE); ADC_Cmd(ADC1,ENABLE); ADC_ResetCalibration(ADC1); while(ADC_GetResetCalibrationStatus(ADC1)); ADC_StartCalibration(ADC1); while(ADC_GetCalibrationStatus(ADC1)); ADC_SoftwareStartConvCmd(ADC1,ENABLE); } void adc_nvic_init() { NVIC_InitTypeDef nvic; NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); nvic.NVIC_IRQChannel = ADC1_2_IRQn; nvic.NVIC_IRQChannelCmd = ENABLE; nvic.NVIC_IRQChannelPreemptionPriority = 1; nvic.NVIC_IRQChannelSubPriority = 1; NVIC_Init(&nvic); NVIC_InitTypeDef usart1; NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); usart1.NVIC_IRQChannel = USART1_IRQn; usart1.NVIC_IRQChannelCmd = ENABLE; usart1.NVIC_IRQChannelPreemptionPriority = 0; usart1.NVIC_IRQChannelSubPriority= 0; NVIC_Init(&usart1); } void usart_init() { GPIO_InitTypeDef Uart_A; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA ,ENABLE); Uart_A.GPIO_Pin = GPIO_Pin_9; Uart_A.GPIO_Speed = GPIO_Speed_50MHz; Uart_A.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOA,&Uart_A); Uart_A.GPIO_Pin = GPIO_Pin_10; Uart_A.GPIO_Speed = GPIO_Speed_50MHz; Uart_A.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOA,&Uart_A); USART_InitTypeDef Uart; RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE); Uart.USART_BaudRate = 115200; Uart.USART_HardwareFlowControl = USART_HardwareFlowControl_None; Uart.USART_Mode = USART_Mode_Tx; Uart.USART_Parity = USART_Parity_No; Uart.USART_StopBits = USART_StopBits_1; Uart.USART_WordLength = USART_WordLength_8b; USART_Init(USART1,&Uart); USART_Cmd(USART1,ENABLE); USART_ClearFlag(USART1,USART_FLAG_TC); } int main() { void PrintU16(uint16_t num); void PrintHexU8(uint8_t data); Adc_Init(); adc_nvic_init(); usart_init(); while(1) { num = (uint16_t)(2.0f* ADC_ConvertedValue/ADC_ConvertedValue_1 *1.2f*100 ); PrintU16(num); delay(1000); } } void PrintU16(uint16_t num) { void PrintHexU8(uint8_t data); uint8_t w5,w4,w3,w2,w1; w5 = num % 100000/10000; w4 = num % 10000/1000; w3 = num % 1000/100; w2 = num % 100/10; w1 = num % 10; PrintHexU8('0' + w5); PrintHexU8('0' + w4); PrintHexU8('0' + w3); PrintHexU8('0' + w2); PrintHexU8('0' + w1); } void PrintHexU8(uint8_t data) { car = data; if(!(USART1->CR1 & USART_CR1_TXEIE)) USART_ITConfig(USART1,USART_IT_TXE,ENABLE);//打开发送中断 } void ADC1_2_IRQHandler() { if(ADC_GetITStatus(ADC1,ADC_IT_EOC) == SET) {if(count_1%2 == 0){ ADC_ConvertedValue = ADC_GetConversionValue(ADC1); count_1++; }else { ADC_ConvertedValue_1 = ADC_GetConversionValue(ADC1); count_1++; } } ADC_ClearITPendingBit(ADC1,ADC_IT_EOC); } void USART1_IRQHandler(void) { if(USART_GetFlagStatus(USART1,USART_FLAG_TXE)) { USART1->CR1 &= ~USART_CR1_TXEIE; USART1->DR = car; while(USART_GetFlagStatus(USART1,USART_FLAG_TXE) == RESET); //USART1->CR1 &= ~USART_CR1_TXEIE; } if(USART1->SR & USART_SR_RXNE) { volatile int8_t com_data; com_data = USART1->DR; } }
[导言] 本人做过几年单片机的开发工作,主要用的是8051内核的和瑞萨740系列的,在这个ARM大行其道的时代,也曾经试着接触过,不过很容易在复杂的内核中迷失了自己~~~一直对这种能全局掌控的小系统痴迷,一个国外朋友无意间提到Zigbee这种技术 ...… 查看全部问答> |
请教一个用在PC上用windows CE sync 驱动开发通信应用程序的问题 我在activesync自己带的windows CE sync驱动上开发一个与activesync功能很像的手机通信的程序。 我的pc方面程序流程是 取得pathname,createfile,然后readfile 但是发现手机方面打开usb之后无法与pc方面接通,CE上面的createfil ...… 查看全部问答> |
上次说的驱动4.3寸TFT的板子已经出来了,看是否有朋友需要,形式跟上次的FPGA活动一样,我可以为大家找齐元件,大家只要付出成本价格和自己焊接就可以了。 目前样机已经打样,我自己用过没有问题就可以发到有兴趣的朋友手上。至于如何发, ...… 查看全部问答> |
