今天是:2025年03月04日(星期二)
2019年03月04日 | STM32 DMA发送完成标志位的查询
2019-03-04 来源:eefocus
void HAL_DMA_IRQHandler(DMA_HandleTypeDef *hdma)
uint32_t flag_it = hdma->DmaBaseAddress->ISR;
uint32_t source_it = hdma->Instance->CCR;
/* Half Transfer Complete Interrupt management ******************************/
if ((RESET != (flag_it & (DMA_FLAG_HT1 << hdma->ChannelIndex))) && (RESET != (source_it & DMA_IT_HT)))
/* Disable the half transfer interrupt if the DMA mode is not CIRCULAR */
if((hdma->Instance->CCR & DMA_CCR_CIRC) == 0U)
/* Disable the half transfer interrupt */
hdma->Instance->CCR &= ~DMA_IT_HT;
/* Clear the half transfer complete flag */
hdma->DmaBaseAddress->IFCR = DMA_FLAG_HT1 << hdma->ChannelIndex;
/* DMA peripheral state is not updated in Half Transfer */
/* State is updated only in Transfer Complete case */
if(hdma->XferHalfCpltCallback != NULL)
/* Half transfer callback */
hdma->XferHalfCpltCallback(hdma);
/* Transfer Complete Interrupt management ***********************************/
else if ((RESET != (flag_it & (DMA_FLAG_TC1 << hdma->ChannelIndex))) && (RESET != (source_it & DMA_IT_TC)))
/* Disable the transfer complete & transfer error interrupts */
/* if the DMA mode is not CIRCULAR */
hdma->Instance->CCR &= ~(DMA_IT_TC | DMA_IT_TE);
/* Change the DMA state */
hdma->State = HAL_DMA_STATE_READY;
/* Clear the transfer complete flag */
hdma->DmaBaseAddress->IFCR = DMA_FLAG_TC1 << hdma->ChannelIndex;
/* Process Unlocked */
__HAL_UNLOCK(hdma);
if(hdma->XferCpltCallback != NULL)
/* Transfer complete callback */
hdma->XferCpltCallback(hdma);
if (hdma == huart2.hdmatx)
dma_finish_flag = 1;
/* Transfer Error Interrupt management ***************************************/
else if (( RESET != (flag_it & (DMA_FLAG_TE1 << hdma->ChannelIndex))) && (RESET != (source_it & DMA_IT_TE)))
/* When a DMA transfer error occurs */
/* A hardware clear of its EN bits is performed */
/* Then, disable all DMA interrupts */
hdma->Instance->CCR &= ~(DMA_IT_TC | DMA_IT_HT | DMA_IT_TE);
/* Clear all flags */
hdma->DmaBaseAddress->IFCR = DMA_FLAG_GL1 << hdma->ChannelIndex;
/* Update error code */
hdma->ErrorCode = HAL_DMA_ERROR_TE;
__HAL_UNLOCK(hdma);
if(hdma->XferErrorCallback != NULL)
/* Transfer error callback */
hdma->XferErrorCallback(hdma);
多年来,人们一直预测低压差线性调整器(LDO)要退出在汽车领域的应用。但是,LDO调整器持续生存着甚至茁壮成长,因为它们的价格便宜且使用方便。本文中,我将阐述LDO调整器的复杂性,考察市场上的最新进展(确实有一些进展),并分析随着汽车电源需求 ...… 查看全部问答> |
选用热继电器一般以电机额定电流为准.如电机额定电流为3A,而选择热继电器为1.5~3.5间.设定时以电机的负载为准.如负载比较稳定时,热继电器设定的电流为电机额定电流.如负载波动比较大时可稍微加大些. 如果是电机直接启动开关设备热继电器电流应选 ...… 查看全部问答> |
我在PB5.0中调试单一的工程可以么?就是我不想每次都生成新的系统镜像。就像在VS2005中调试一样,修改代码、F5就开始编译链接、部署、断点,这样就方便多了阿,要不我不是在PB中每次都得从新生成系统镜像了?多麻烦… 查看全部问答> |
103K作为从属, 另外一块CPU作为主控, 时钟频率大概200HZ 在103K这边经常会收到错误的地址 但使用逻辑分析仪看波形是正确的 可能是哪里出错了呢?… 查看全部问答> |
本帖最后由 paulhyde 于 2014-9-15 03:19 编辑 这是我用OP07构成的简单恒流源,第一个运放是隔离输入端对恒流源的影响,但是发现当负载端接上电阻,无论输入端电压 怎么调,J4端电压都没改变,而且负载电阻变化时,J4端电压变化,达不到恒流源 ...… 查看全部问答> |
