今天是:2025年03月08日(星期六)
2019年03月08日 | STM32之SPI从机DMA例程
2019-03-08 来源:eefocus
#include "stm32f10x.h"
/* RCC时钟配置 */
void RCC_config(void)
ErrorStatus HSEStartUpStatus;
/* RCC寄存器设置为默认配置 */
RCC_DeInit();
/* 打开外部高速时钟 */
RCC_HSEConfig(RCC_HSE_ON);
/* 等待外部高速时钟稳定 */
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if(HSEStartUpStatus == SUCCESS)
/* 设置HCLK = SYSCLK */
RCC_HCLKConfig(RCC_SYSCLK_Div1);
/* 设置PCLK2 = HCLK */
RCC_PCLK2Config(RCC_HCLK_Div1);
/* 设置PCLK1 = HCLK / 2 */
RCC_PCLK1Config(RCC_HCLK_Div2);
// /* 设置FLASH代码延时 */
// FLASH_SetLatency(FLASH_Latency_2);
// /* 使能预取址缓存 */
// FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
/* 设置PLL时钟源为HSE倍频9 72MHz */
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
/* 使能PLL */
RCC_PLLCmd(ENABLE);
/* 等待PLL稳定 */
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
/* 设置PLL为系统时钟源 */
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
/* 等待系统时钟源切换到PLL */
while(RCC_GetSYSCLKSource() != 0x08);
/* GPIO配置 */
void GPIO_config(void)
GPIO_InitTypeDef GPIO_InitStructure;
/* 时钟配置 */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
/* MISO配置为复用推挽输出 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* SCK和MOSI配置为浮空输入 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
/* NSS配置为浮空输入 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
/* SPI配置 */
void SPI_config(void)
SPI_InitTypeDef SPI_InitStructure;
/* 时钟配置 */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO | RCC_APB2Periph_SPI1, ENABLE);
/* 配置SPI模式 */
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode = SPI_Mode_Slave;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_Init(SPI1, &SPI_InitStructure);
/* 打开SPI1 */
SPI_Cmd(SPI1, ENABLE);
/* 使能DMA接收 */
SPI_I2S_DMACmd(SPI1, SPI_I2S_DMAReq_Rx, ENABLE);
uint8_t rx_buf[100];
/* DMA配置 */
void DMA_config(void)
DMA_InitTypeDef DMA_InitStructure;
/* 使能DMA1时钟 */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
DMA_DeInit(DMA1_Channel2);
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)(&SPI1->DR);
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)rx_buf;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
DMA_InitStructure.DMA_BufferSize = 100;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA1_Channel2, &DMA_InitStructure);
DMA_Cmd(DMA1_Channel2, ENABLE);
/* 中断嵌套控制器配置 */
void NVIC_config(void)
NVIC_InitTypeDef NVIC_InitStructure;
/* 选择中断分组2 */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
/* 设置外部中断4的先占优先级为3,从占优先级为3 */
NVIC_InitStructure.NVIC_IRQChannel = EXTI4_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
/* 外部中断配置 */
void EXIT_config(void)
EXTI_InitTypeDef EXTI_InitStructure;
/* 将GPIOA_0和中断线连接 */
GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource4);
/* 设置中断线0位外部下降沿中断 */
EXTI_InitStructure.EXTI_Line = EXTI_Line4;
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_Init(&EXTI_InitStructure);
/* 毫秒延时函数 */
void delay_ms(uint16_t time)
uint16_t i = 0;
while(time--)
i = 12000;
while(i--);
/* 主函数 */
int main(void)
/* RCC时钟配置 */
RCC_config();
/* GPIO配置 */
GPIO_config();
/* 外部中断配置 */
EXIT_config();
/* 中断嵌套控制器配置 */
NVIC_config();
/* DMA配置 */
DMA_config();
/* SPI配置 */
SPI_config();
while(1)
delay_ms(1000);
/* 外部中断4 */
void EXTI4_IRQHandler(void)
volatile uint8_t len;
/* 检查中断状态 */
if(EXTI_GetITStatus(EXTI_Line4) != RESET)
len = 100 - DMA1_Channel2->CNDTR;
/* 接收完成,修改接收通道数据个数 */
DMA_Cmd(DMA1_Channel2, DISABLE);
DMA1_Channel2->CNDTR = 100;
DMA1_Channel2->CMAR = (uint32_t)rx_buf;
/* 清除中断状态寄存器 */
EXTI_ClearITPendingBit(EXTI_Line4);
上一篇:STM32之高级定时器互补输出
下一篇:STM32之ADC单通道单次例程
龙芯在SOC市场上的意义:第一 工业级芯片第二 ARM的巨大市场第三 2008年10月第一批批量CPU下线第四 比ARM9更强第五 比ARM7便宜龙芯作为中国第一也是中国惟一的理由:目前,符合下面七个条件的SOC芯片,HS3210是全国第一款:1)关键IP再国内2)设 ...… 查看全部问答> |
很多大学生一听到用人单位提到工作经验就头晕了,因为自己还没有参加工作,哪来的工作经验呢?站在招聘者的立场来看,我认为不要死搬硬套地将工作经验理解为实实在在参加工作所积累的经验,就电类专业来看,用人单位需要应聘者熟练掌握产品开发所需 ...… 查看全部问答> |
最近要去搞一个智能小车的大赛。::: 规定时间组装调试一台自动控制小车,并在嵌入式开发环境下编制个性化的控制软件。“小车”制作完成后在大赛提供的模拟环境中执行寻迹、定位、图像识别 ...… 查看全部问答> |
这两天在分析当前案子的媒体播放器为什么播放部分文件会非常的不流畅。 发个帖子大家一起讨论下。集中下大家在调试wince下媒体播放器播放媒体文件不流畅的原因 我先说下这里的问题 1. 系统基于ARM 9 + WINCE 5.O + MPU屏 320*240 2. 播放器测试 ...… 查看全部问答> |
我现在在WinCE的Local Machine下的software下建立了subkey,AA,然后我就行用代码删除subkey,用registrykey=registry.loacalmachine.openkey(\"software\",true);然后registrykey.deletsubkey(\"AA\"),老是提示没有权限去删除,请问该怎么做好?… 查看全部问答> |
c8051f,at89s5x,sst89等51系列单片机仿真器、编程器和学习板 西安杨工 13002928013 email: yang96381@126.com http://c8051fmcu.blog.sohu.com … 查看全部问答> |
#include #include //*************************************************************** #define uchar unsigned char #define uint unsigned int #define EEPROMSTARTADDR 0x2000 //STC89C52RD+为0x2000 //STC ...… 查看全部问答> |
