今天是:2025年03月13日(星期四)
正在发生
2019年03月13日 | STM32F4开发板----定时器(004)
2019-03-13 来源:eefocus
定时器
定时器功能:测量输入信号的脉冲长度(输入捕获)或者产生输出波形(输出比较和pwm)
1.通用定时器
1.1 初始化基本定时参数
  * @brief  TIM Time Base Init structure definition
  * @note   This structure is used with all TIMx except for TIM6 and TIM7.
typedef struct
  uint16_t TIM_Prescaler;         /*!< Specifies the prescaler value used to divide the TIM clock.
                                       This parameter can be a number between 0x0000 and 0xFFFF */
  uint16_t TIM_CounterMode;       /*!< Specifies the counter mode.
                                       This parameter can be a value of @ref TIM_Counter_Mode */
  uint32_t TIM_Period;            /*!< Specifies the period value to be loaded into the active
                                       Auto-Reload Register at the next update event.
                                       This parameter must be a number between 0x0000 and 0xFFFF.  */
  uint16_t TIM_ClockDivision;     /*!< Specifies the clock division.
                                      This parameter can be a value of @ref TIM_Clock_Division_CKD */
  uint8_t TIM_RepetitionCounter;  /*!< Specifies the repetition counter value. Each time the RCR downcounter
                                       reaches zero, an update event is generated and counting restarts
                                       from the RCR value (N).
                                       This means in PWM mode that (N+1) corresponds to:
                                          - the number of PWM periods in edge-aligned mode
                                          - the number of half PWM period in center-aligned mode
                                       This parameter must be a number between 0x00 and 0xFF.
                                       @note This parameter is valid only for TIM1 and TIM8. */
} TIM_TimeBaseInitTypeDef;
1.2 输出比较参数
  * @brief  TIM Output Compare Init structure definition
typedef struct
  uint16_t TIM_OCMode;        /*!< Specifies the TIM mode.
                                   This parameter can be a value of @ref TIM_Output_Compare_and_PWM_modes */
  uint16_t TIM_OutputState;   /*!< Specifies the TIM Output Compare state.
                                   This parameter can be a value of @ref TIM_Output_Compare_State */
  uint16_t TIM_OutputNState;  /*!< Specifies the TIM complementary Output Compare state.
                                   This parameter can be a value of @ref TIM_Output_Compare_N_State
  uint32_t TIM_Pulse;         /*!< Specifies the pulse value to be loaded into the Capture Compare Register.
  uint16_t TIM_OCPolarity;    /*!< Specifies the output polarity.
                                   This parameter can be a value of @ref TIM_Output_Compare_Polarity */
  uint16_t TIM_OCNPolarity;   /*!< Specifies the complementary output polarity.
                                   This parameter can be a value of @ref TIM_Output_Compare_N_Polarity
  uint16_t TIM_OCIdleState;   /*!< Specifies the TIM Output Compare pin state during Idle state.
                                   This parameter can be a value of @ref TIM_Output_Compare_Idle_State
  uint16_t TIM_OCNIdleState;  /*!< Specifies the TIM Output Compare pin state during Idle state.
                                   This parameter can be a value of @ref TIM_Output_Compare_N_Idle_State
} TIM_OCInitTypeDef;
1.3 输入比较参数初始化
  * @brief  TIM Input Capture Init structure definition
typedef struct
  uint16_t TIM_Channel;      /*!< Specifies the TIM channel.
                                  This parameter can be a value of @ref TIM_Channel */
  uint16_t TIM_ICPolarity;   /*!< Specifies the active edge of the input signal.
                                  This parameter can be a value of @ref TIM_Input_Capture_Polarity */
  uint16_t TIM_ICSelection;  /*!< Specifies the input.
                                  This parameter can be a value of @ref TIM_Input_Capture_Selection */
  uint16_t TIM_ICPrescaler;  /*!< Specifies the Input Capture Prescaler.
                                  This parameter can be a value of @ref TIM_Input_Capture_Prescaler */
  uint16_t TIM_ICFilter;     /*!< Specifies the input capture filter.
                                  This parameter can be a number between 0x0 and 0xF */
} TIM_ICInitTypeDef;
1.4 TIM1 and TIM8 高级定时器死区初始化
  * @brief  BDTR structure definition
  * @note   This structure is used only with TIM1 and TIM8.
typedef struct
  uint16_t TIM_OSSRState;        /*!< Specifies the Off-State selection used in Run mode.
                                      This parameter can be a value of @ref TIM_OSSR_Off_State_Selection_for_Run_mode_state */
  uint16_t TIM_OSSIState;        /*!< Specifies the Off-State used in Idle state.
                                      This parameter can be a value of @ref TIM_OSSI_Off_State_Selection_for_Idle_mode_state */
  uint16_t TIM_LOCKLevel;        /*!< Specifies the LOCK level parameters.
                                      This parameter can be a value of @ref TIM_Lock_level */
  uint16_t TIM_DeadTime;         /*!< Specifies the delay time between the switching-off and the
                                      switching-on of the outputs.
                                      This parameter can be a number between 0x00 and 0xFF  */
  uint16_t TIM_Break;            /*!< Specifies whether the TIM Break input is enabled or not.
                                      This parameter can be a value of @ref TIM_Break_Input_enable_disable */
  uint16_t TIM_BreakPolarity;    /*!< Specifies the TIM Break Input pin polarity.
                                      This parameter can be a value of @ref TIM_Break_Polarity */
  uint16_t TIM_AutomaticOutput;  /*!< Specifies whether the TIM Automatic Output feature is enabled or not.
                                      This parameter can be a value of @ref TIM_AOE_Bit_Set_Reset */
} TIM_BDTRInitTypeDef;
2 相关库函数
/* Exported macro ------------------------------------------------------------*/
/* Exported functions --------------------------------------------------------*/
/* TimeBase management ********************************************************/
void TIM_DeInit(TIM_TypeDef* TIMx);
void TIM_TimeBaseInit(TIM_TypeDef* TIMx, TIM_TimeBaseInitTypeDef* TIM_TimeBaseInitStruct);
void TIM_TimeBaseStructInit(TIM_TimeBaseInitTypeDef* TIM_TimeBaseInitStruct);
void TIM_PrescalerConfig(TIM_TypeDef* TIMx, uint16_t Prescaler, uint16_t TIM_PSCReloadMode);
void TIM_CounterModeConfig(TIM_TypeDef* TIMx, uint16_t TIM_CounterMode);
void TIM_SetCounter(TIM_TypeDef* TIMx, uint32_t Counter);
void TIM_SetAutoreload(TIM_TypeDef* TIMx, uint32_t Autoreload);
uint32_t TIM_GetCounter(TIM_TypeDef* TIMx);
uint16_t TIM_GetPrescaler(TIM_TypeDef* TIMx);
void TIM_UpdateDisableConfig(TIM_TypeDef* TIMx, FunctionalState NewState);
void TIM_UpdateRequestConfig(TIM_TypeDef* TIMx, uint16_t TIM_UpdateSource);
void TIM_ARRPreloadConfig(TIM_TypeDef* TIMx, FunctionalState NewState);
void TIM_SelectOnePulseMode(TIM_TypeDef* TIMx, uint16_t TIM_OPMode);
void TIM_SetClockDivision(TIM_TypeDef* TIMx, uint16_t TIM_CKD);
void TIM_Cmd(TIM_TypeDef* TIMx, FunctionalState NewState);
/* Output Compare management **************************************************/
void TIM_OC1Init(TIM_TypeDef* TIMx, TIM_OCInitTypeDef* TIM_OCInitStruct);
void TIM_OC2Init(TIM_TypeDef* TIMx, TIM_OCInitTypeDef* TIM_OCInitStruct);
void TIM_OC3Init(TIM_TypeDef* TIMx, TIM_OCInitTypeDef* TIM_OCInitStruct);
void TIM_OC4Init(TIM_TypeDef* TIMx, TIM_OCInitTypeDef* TIM_OCInitStruct);
void TIM_OCStructInit(TIM_OCInitTypeDef* TIM_OCInitStruct);
void TIM_SelectOCxM(TIM_TypeDef* TIMx, uint16_t TIM_Channel, uint16_t TIM_OCMode);
void TIM_SetCompare1(TIM_TypeDef* TIMx, uint32_t Compare1);
void TIM_SetCompare2(TIM_TypeDef* TIMx, uint32_t Compare2);
void TIM_SetCompare3(TIM_TypeDef* TIMx, uint32_t Compare3);
void TIM_SetCompare4(TIM_TypeDef* TIMx, uint32_t Compare4);
void TIM_ForcedOC1Config(TIM_TypeDef* TIMx, uint16_t TIM_ForcedAction);
void TIM_ForcedOC2Config(TIM_TypeDef* TIMx, uint16_t TIM_ForcedAction);
void TIM_ForcedOC3Config(TIM_TypeDef* TIMx, uint16_t TIM_ForcedAction);
void TIM_ForcedOC4Config(TIM_TypeDef* TIMx, uint16_t TIM_ForcedAction);
void TIM_OC1PreloadConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCPreload);
void TIM_OC2PreloadConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCPreload);
void TIM_OC3PreloadConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCPreload);
void TIM_OC4PreloadConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCPreload);
void TIM_OC1FastConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCFast);
void TIM_OC2FastConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCFast);
void TIM_OC3FastConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCFast);
void TIM_OC4FastConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCFast);
void TIM_ClearOC1Ref(TIM_TypeDef* TIMx, uint16_t TIM_OCClear);
void TIM_ClearOC2Ref(TIM_TypeDef* TIMx, uint16_t TIM_OCClear);
void TIM_ClearOC3Ref(TIM_TypeDef* TIMx, uint16_t TIM_OCClear);
void TIM_ClearOC4Ref(TIM_TypeDef* TIMx, uint16_t TIM_OCClear);
void TIM_OC1PolarityConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCPolarity);
void TIM_OC1NPolarityConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCNPolarity);
void TIM_OC2PolarityConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCPolarity);
void TIM_OC2NPolarityConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCNPolarity);
void TIM_OC3PolarityConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCPolarity);
void TIM_OC3NPolarityConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCNPolarity);
void TIM_OC4PolarityConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCPolarity);
void TIM_CCxCmd(TIM_TypeDef* TIMx, uint16_t TIM_Channel, uint16_t TIM_CCx);
void TIM_CCxNCmd(TIM_TypeDef* TIMx, uint16_t TIM_Channel, uint16_t TIM_CCxN);
/* Input Capture management ***************************************************/
void TIM_ICInit(TIM_TypeDef* TIMx, TIM_ICInitTypeDef* TIM_ICInitStruct);
void TIM_ICStructInit(TIM_ICInitTypeDef* TIM_ICInitStruct);
void TIM_PWMIConfig(TIM_TypeDef* TIMx, TIM_ICInitTypeDef* TIM_ICInitStruct);
uint32_t TIM_GetCapture1(TIM_TypeDef* TIMx);
uint32_t TIM_GetCapture2(TIM_TypeDef* TIMx);
uint32_t TIM_GetCapture3(TIM_TypeDef* TIMx);
uint32_t TIM_GetCapture4(TIM_TypeDef* TIMx);
void TIM_SetIC1Prescaler(TIM_TypeDef* TIMx, uint16_t TIM_ICPSC);
void TIM_SetIC2Prescaler(TIM_TypeDef* TIMx, uint16_t TIM_ICPSC);
void TIM_SetIC3Prescaler(TIM_TypeDef* TIMx, uint16_t TIM_ICPSC);
void TIM_SetIC4Prescaler(TIM_TypeDef* TIMx, uint16_t TIM_ICPSC);
/* Advanced-control timers (TIM1 and TIM8) specific features ******************/
void TIM_BDTRConfig(TIM_TypeDef* TIMx, TIM_BDTRInitTypeDef *TIM_BDTRInitStruct);
void TIM_BDTRStructInit(TIM_BDTRInitTypeDef* TIM_BDTRInitStruct);
void TIM_CtrlPWMOutputs(TIM_TypeDef* TIMx, FunctionalState NewState);
void TIM_SelectCOM(TIM_TypeDef* TIMx, FunctionalState NewState);
void TIM_CCPreloadControl(TIM_TypeDef* TIMx, FunctionalState NewState);
/* Interrupts, DMA and flags management ***************************************/
void TIM_ITConfig(TIM_TypeDef* TIMx, uint16_t TIM_IT, FunctionalState NewState);
void TIM_GenerateEvent(TIM_TypeDef* TIMx, uint16_t TIM_EventSource);
FlagStatus TIM_GetFlagStatus(TIM_TypeDef* TIMx, uint16_t TIM_FLAG);
void TIM_ClearFlag(TIM_TypeDef* TIMx, uint16_t TIM_FLAG);
ITStatus TIM_GetITStatus(TIM_TypeDef* TIMx, uint16_t TIM_IT);
void TIM_ClearITPendingBit(TIM_TypeDef* TIMx, uint16_t TIM_IT);
void TIM_DMAConfig(TIM_TypeDef* TIMx, uint16_t TIM_DMABase, uint16_t TIM_DMABurstLength);
void TIM_DMACmd(TIM_TypeDef* TIMx, uint16_t TIM_DMASource, FunctionalState NewState);
void TIM_SelectCCDMA(TIM_TypeDef* TIMx, FunctionalState NewState);
/* Clocks management **********************************************************/
void TIM_InternalClockConfig(TIM_TypeDef* TIMx);
void TIM_ITRxExternalClockConfig(TIM_TypeDef* TIMx, uint16_t TIM_InputTriggerSource);
void TIM_TIxExternalClockConfig(TIM_TypeDef* TIMx, uint16_t TIM_TIxExternalCLKSource,
                                uint16_t TIM_ICPolarity, uint16_t ICFilter);
void TIM_ETRClockMode1Config(TIM_TypeDef* TIMx, uint16_t TIM_ExtTRGPrescaler, uint16_t TIM_ExtTRGPolarity,
                             uint16_t ExtTRGFilter);
void TIM_ETRClockMode2Config(TIM_TypeDef* TIMx, uint16_t TIM_ExtTRGPrescaler,
                             uint16_t TIM_ExtTRGPolarity, uint16_t ExtTRGFilter);
/* Synchronization management *************************************************/
void TIM_SelectInputTrigger(TIM_TypeDef* TIMx, uint16_t TIM_InputTriggerSource);
void TIM_SelectOutputTrigger(TIM_TypeDef* TIMx, uint16_t TIM_TRGOSource);
void TIM_SelectSlaveMode(TIM_TypeDef* TIMx, uint16_t TIM_SlaveMode);
void TIM_SelectMasterSlaveMode(TIM_TypeDef* TIMx, uint16_t TIM_MasterSlaveMode);
void TIM_ETRConfig(TIM_TypeDef* TIMx, uint16_t TIM_ExtTRGPrescaler, uint16_t TIM_ExtTRGPolarity,
/* Specific interface management **********************************************/
void TIM_EncoderInterfaceConfig(TIM_TypeDef* TIMx, uint16_t TIM_EncoderMode,
                                uint16_t TIM_IC1Polarity, uint16_t TIM_IC2Polarity);
void TIM_SelectHallSensor(TIM_TypeDef* TIMx, FunctionalState NewState);
/* Specific remapping management **********************************************/
void TIM_RemapConfig(TIM_TypeDef* TIMx, uint16_t TIM_Remap);
Crane Co.公司的发展小趣事
在1870年代,Crane Co.在制造业改善方面争当先驱。公司引入了由R. T. Crane发明的多用途机器,以及移动模具和浇铸金属的传送系统。这些创新技术不仅提高了生产效率,还标志着铸造领域流水线生产的开端。这一时期的变革为Crane Co.在电子行业的发展奠定了技术基础。
AEMC Instruments公司的发展小趣事
AEMC Instruments公司成立于1976年,隶属于Chauvin Arnoux集团。这个新成立的公司在电子行业中崭露头角,凭借其在电气测试和测量领域的专业知识和技术,迅速获得了市场的认可。初创时期,AEMC Instruments公司以研发和生产电流测量探头、电能质量分析仪等核心产品为主,这些产品凭借其准确性和稳定性,为公司的快速发展奠定了坚实的基础。
Easy Braid公司的发展小趣事
作为一家有社会责任感的企业,Easy Braid始终关注环保和公益事业。公司采用环保材料和生产工艺,减少了对环境的污染。此外,Easy Braid还积极参与各种公益活动,为社会做出了积极贡献。这种关注社会责任的企业文化不仅增强了员工的凝聚力和归属感还提升了公司的社会形象和品牌价值。
ASPEED Technology公司的发展小趣事
2018年,ASPEED正式推出Cupola360 360度影像拼接处理芯片暨解决方案。这一创新产品的推出,标志着ASPEED将产品线成功扩展至图像处理相关领域。Cupola360芯片的高性能与广泛应用场景,使其在安防监控、虚拟现实等领域受到广泛关注,为ASPEED带来了新的增长点。
歌尔(Goertek)公司的发展小趣事
ASPEED的AST2600 BMC与瑞萨电子的I3C器件相结合,为客户提供了设计便捷、带宽增强且系统成本优化的解决方案。这一合作不仅展示了ASPEED在服务器管理领域的实力,还进一步推动了DDR5解决方案对I3C标准的推广使用。通过双方的努力,共同客户在实现向全新高速总线接口飞跃发展的过程中,获得了更加信心满满的设计体验。
EWC Controls公司的发展小趣事
EWC Controls公司非常重视人才培养和团队建设。公司建立了一套完善的人才培养体系,通过内部培训、外部引进等方式吸引和培养了一批高素质的人才。同时,公司还注重团队合作和文化建设,鼓励员工之间的交流和合作,营造了积极向上的工作氛围。这种人才培养和团队建设的策略为公司的发展提供了有力的保障。
寻求小天线的区分范围
  各位高手,有谁能告诉我,具体的小天线是指哪些天线,它的范围包括哪些?谢谢大家的帮助!!…
雷诺数
测量管内流体流量时往往必须了解其流动状态、流速分布等。雷诺数就是表征流体流动特性的一个重要参数。 流体流动时的惯性力Fg和粘性力(内摩擦力)Fm之比称为雷诺数。用符号Re表示。Re是一个无因次量。 式中的动力粘度η用运动粘度υ来代替,因 ...…
哪位高人能帮我设计一个射基跟随器呀?
我需要一个放大电路,它的要求是把我现有的一个0.6V的开关,放大成3.0V的开关,最后是要控制发光二极管亮灭,可以提供12.0V电源,哪位高人可以帮忙设计或有成品电路可以用请提供一下信息啊?…
哪个帮我修改个小地方?我十分着急,,对高手2分钟
我现在键盘上面有个PRG按键..长按进入C参数  界面,,但是我觉得时间还不够长,,哪个帮我看下程序应该修改什么地方??把时间搞长点,,现在只要0.5秒就进入C的样子,,我想搞到2S,,不明白的尽管问…
关于bios的问题
我是技嘉的主板,我从网上下了bios最新的文件mb_bios_ga-945gcmx-s2_6.6_f6i.exe,我把他解压后得到了三个文件9GCMXS2.F6、autoexec.bat、FLASHSPI.EXE 请问这三个文件各是什么用的 ?怎么没有bin文件 还有我查的我系统bios版本号是GBT &nb ...…
关于linux设备驱动的书
我是一个嵌入式linux开发的新手,现在想自学驱动开发,但是我一直有个疑问,请您指教: 我到底先读《linux设备驱动程序(第三版)》和宋老师编著的《linux设备驱动开发详解》哪一本书?我很苦恼。。。…
WM手机如何与单片机加USB_HOST芯片通信
如题 只考虑手机端。 随便问问,没希望得到答案 呵呵…
我给大家特别推荐的一款产品,非常棒!!!
c8051f 单片机(c2 ,jtag)和at89s5x单片机(isp)二合一串口编程下载线,支持3伏(c8051f 单片机),5伏(at89s5x单片机)电源, 目前通过实际验证可编程下载的芯片:c8051f310、c8051f320、c8051f330D、c8051f340、c8051f350、c8051f360、c8051f4 ...…
EVC表盘类?
现在evc上作界面开发,用到模拟压力表盘显示压力值,表针可以实时转动,刻度可以自己设置,不知谁用过,能否帮帮忙?…
