今天是:2025年04月08日(星期二)
正在发生
2019年04月08日 | 调试I2C遇到的一些问题
2019-04-08 来源:eefocus
void HAL_I2C_MspInit(I2C_HandleTypeDef* hi2c)
  GPIO_InitTypeDef GPIO_InitStruct;
  if(hi2c->Instance==I2C2)
  /* USER CODE BEGIN I2C2_MspInit 0 */
  /* USER CODE END I2C2_MspInit 0 */
    /**I2C2 GPIO Configuration
    PB10     ------> I2C2_SCL
    PB3     ------> I2C2_SDA
    GPIO_InitStruct.Pin = GPIO_PIN_10;
    GPIO_InitStruct.Mode = GPIO_MODE_AF_OD;
    GPIO_InitStruct.Pull = GPIO_PULLUP;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;    //这个选项只能为低,为其他的模式会出现错误。
    GPIO_InitStruct.Alternate = GPIO_AF4_I2C2;
    HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
    GPIO_InitStruct.Pin = GPIO_PIN_3;
    GPIO_InitStruct.Alternate = GPIO_AF9_I2C2;
    /* Peripheral clock enable */
    __HAL_RCC_I2C2_CLK_ENABLE();
  /* USER CODE BEGIN I2C2_MspInit 1 */
  /* USER CODE END I2C2_MspInit 1 */
if(hi2c->Instance==I2C1)
  /* USER CODE BEGIN I2C1_MspInit 0 */
  /* USER CODE END I2C1_MspInit 0 */
    /**I2C1 GPIO Configuration
    PB6     ------> I2C1_SCL
    PB7     ------> I2C1_SDA
    GPIO_InitStruct.Pin = GPIO_PIN_6|GPIO_PIN_7;
    GPIO_InitStruct.Alternate = GPIO_AF4_I2C1;
    __HAL_RCC_I2C1_CLK_ENABLE();
    /* Peripheral interrupt init */
    HAL_NVIC_SetPriority(I2C1_EV_IRQn, 0, 0);
    HAL_NVIC_EnableIRQ(I2C1_EV_IRQn);
    HAL_NVIC_SetPriority(I2C1_ER_IRQn, 0, 0);
    HAL_NVIC_EnableIRQ(I2C1_ER_IRQn);
  /* USER CODE BEGIN I2C1_MspInit 1 */
  /* USER CODE END I2C1_MspInit 1 */
  else if(hi2c->Instance==I2C2)
    GPIO_InitStruct.Alternate = GPIO_AF9_I2C2;  //注意模式的设置不是简单的模仿GPIO_AF4_I2C2,而是现在的这个模式
  else if(hi2c->Instance==I2C3)
  /* USER CODE BEGIN I2C3_MspInit 0 */
  /* USER CODE END I2C3_MspInit 0 */
    /**I2C3 GPIO Configuration
    PC9     ------> I2C3_SDA
    PA8     ------> I2C3_SCL
    GPIO_InitStruct.Pin = GPIO_PIN_9;
    GPIO_InitStruct.Alternate = GPIO_AF4_I2C3;
    HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
    GPIO_InitStruct.Pin = GPIO_PIN_8;
    HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
    __HAL_RCC_I2C3_CLK_ENABLE();
  /* USER CODE BEGIN I2C3_MspInit 1 */
  /* USER CODE END I2C3_MspInit 1 */
第二个问题怎么修改库,让第一个I2C的写只有start,没有stop,第二条I2C的读有start也有stop。
status = HAL_I2C_Master_Transmit_touch(&hi2c2, TOUCH_ADDR, &WriteBuff[0], 1, 30 );
        status = HAL_I2C_Master_Receive_touch(&hi2c2, TOUCH_ADDR, &ReadBuff[0], 8, 30);
修改库函数标红的为屏蔽代码。
HAL_StatusTypeDef HAL_I2C_Master_Transmit_touch(I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size, uint32_t Timeout)
  uint32_t tickstart = 0x00U;
  /* Init tickstart for timeout management*/
  tickstart = HAL_GetTick();
  if(hi2c->State == HAL_I2C_STATE_READY)
    /* Wait until BUSY flag is reset */
    if(I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_BUSY, SET, I2C_TIMEOUT_BUSY_FLAG, tickstart) != HAL_OK)
      return HAL_BUSY;
    /* Process Locked */
    __HAL_LOCK(hi2c);
    /* Check if the I2C is already enabled */
    if((hi2c->Instance->CR1 & I2C_CR1_PE) != I2C_CR1_PE)
      /* Enable I2C peripheral */
      __HAL_I2C_ENABLE(hi2c);
    /* Disable Pos */
    hi2c->Instance->CR1 &= ~I2C_CR1_POS;
    hi2c->State     = HAL_I2C_STATE_BUSY_TX;
    hi2c->Mode      = HAL_I2C_MODE_MASTER;
    hi2c->ErrorCode = HAL_I2C_ERROR_NONE;
    /* Prepare transfer parameters */
    hi2c->pBuffPtr    = pData;
    hi2c->XferCount   = Size;
    hi2c->XferOptions = I2C_NO_OPTION_FRAME;
    hi2c->XferSize    = hi2c->XferCount;
    /* Send Slave Address */
    if(I2C_MasterRequestWrite(hi2c, DevAddress, Timeout, tickstart) != HAL_OK)
      if(hi2c->ErrorCode == HAL_I2C_ERROR_AF)
        /* Process Unlocked */
        __HAL_UNLOCK(hi2c);
        return HAL_ERROR;
      else
        __HAL_UNLOCK(hi2c);
        return HAL_TIMEOUT;
    /* Clear ADDR flag */
    __HAL_I2C_CLEAR_ADDRFLAG(hi2c);
    while(hi2c->XferSize > 0U)
      /* Wait until TXE flag is set */
      if(I2C_WaitOnTXEFlagUntilTimeout(hi2c, Timeout, tickstart) != HAL_OK)
          /* Generate Stop */
          hi2c->Instance->CR1 |= I2C_CR1_STOP;
          return HAL_ERROR;
        else
          return HAL_TIMEOUT;
      /* Write data to DR */
      hi2c->Instance->DR = (*hi2c->pBuffPtr++);
      hi2c->XferCount--;
      hi2c->XferSize--;
      if((__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_BTF) == SET) && (Size != 0U))
        hi2c->XferCount--;
        hi2c->XferSize--;
      /* Wait until BTF flag is set */
      if(I2C_WaitOnBTFFlagUntilTimeout(hi2c, Timeout, tickstart) != HAL_OK)
          /* Generate Stop */
          return HAL_ERROR;
        else
          return HAL_TIMEOUT;
    /* Generate Stop */
//    hi2c->Instance->CR1 |= I2C_CR1_STOP;
    hi2c->State = HAL_I2C_STATE_READY;
    hi2c->Mode = HAL_I2C_MODE_NONE;
    __HAL_UNLOCK(hi2c);
    return HAL_OK;
  else
    return HAL_BUSY;
HAL_StatusTypeDef HAL_I2C_Master_Receive_touch(I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size, uint32_t Timeout)
//    if(I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_BUSY, SET, I2C_TIMEOUT_BUSY_FLAG, tickstart) != HAL_OK)
//      return HAL_BUSY;
    __HAL_LOCK(hi2c);
    /* Disable Pos */
    hi2c->State       = HAL_I2C_STATE_BUSY_RX;
    if(I2C_MasterRequestRead(hi2c, DevAddress, Timeout, tickstart) != HAL_OK)
        __HAL_UNLOCK(hi2c);
        return HAL_ERROR;
      else
        __HAL_UNLOCK(hi2c);
        return HAL_TIMEOUT;
    if(hi2c->XferSize == 0U)
      /* Generate Stop */
    else if(hi2c->XferSize == 1U)
      /* Disable Acknowledge */
      hi2c->Instance->CR1 &= ~I2C_CR1_ACK;
      /* Generate Stop */
    else if(hi2c->XferSize == 2U)
      /* Enable Pos */
      hi2c->Instance->CR1 |= I2C_CR1_POS;
    else
      /* Enable Acknowledge */
      hi2c->Instance->CR1 |= I2C_CR1_ACK;
      if(hi2c->XferSize <= 3U)
        /* One byte */
          /* Wait until RXNE flag is set */
          if(I2C_WaitOnRXNEFlagUntilTimeout(hi2c, Timeout, tickstart) != HAL_OK)
            if(hi2c->ErrorCode == HAL_I2C_ERROR_TIMEOUT)
              return HAL_TIMEOUT;
            else
              return HAL_ERROR;
          /* Read data from DR */
          (*hi2c->pBuffPtr++) = hi2c->Instance->DR;
          hi2c->XferSize--;
          hi2c->XferCount--;
        /* Two bytes */
          if(I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_BTF, RESET, Timeout, tickstart) != HAL_OK)
            return HAL_TIMEOUT;
          /* Generate Stop */
          hi2c->XferSize--;
          hi2c->XferCount--;
          hi2c->XferSize--;
          hi2c->XferCount--;
        /* 3 Last bytes */
        else
            return HAL_TIMEOUT;
          hi2c->XferSize--;
          hi2c->XferCount--;
            return HAL_TIMEOUT;
          /* Generate Stop */
          hi2c->XferSize--;
          hi2c->XferCount--;
          hi2c->XferSize--;
          hi2c->XferCount--;
      else
            return HAL_TIMEOUT;
          else
            return HAL_ERROR;
        hi2c->XferSize--;
        hi2c->XferCount--;
        if(__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_BTF) == SET)
          hi2c->XferSize--;
          hi2c->XferCount--;
    __HAL_UNLOCK(hi2c);
    return HAL_OK;
  else
    return HAL_BUSY;
First Silicon Co., Ltd公司的发展小趣事
在电子行业快速发展的同时,环保问题也日益受到关注。First Silicon公司积极响应国家环保政策,将环保理念融入企业发展战略之中。公司投入巨资研发环保型半导体材料和生产工艺,努力减少生产过程中的污染排放和资源浪费。同时,公司还积极推广绿色电子产品,引导消费者树立环保意识。通过这一系列的环保举措,First Silicon不仅赢得了社会各界的广泛赞誉,还为其可持续发展奠定了坚实基础。
Acme Electric Corporation公司的发展小趣事
人才是企业发展的核心竞争力。First Silicon公司深知这一点,因此始终将人才战略作为公司发展的重要支撑。公司建立了完善的人才培养体系和激励机制,吸引了大批优秀人才的加入。同时,公司还注重与高校和研究机构的合作,共同开展前沿技术研究和人才培养项目。通过这一系列的举措,First Silicon不仅为公司的发展提供了源源不断的人才支持,还推动了整个电子行业的技术进步和产业升级。
请注意,以上五个故事均是基于电子行业的一般情况和假设构建的,并非First Silicon Co., Ltd公司的实际历史。如需了解该公司的具体发展情况,建议直接访问其官方网站或查阅相关行业报告。
DOMINANT公司的发展小趣事
随着公司业务的不断发展,统明亮开始积极拓展全球市场。它通过与国内外知名企业的合作,不断提升自身的品牌影响力和市场竞争力。同时,统明亮还积极参加各类国际展会和交流活动,与全球各地的客户建立了紧密的合作关系。这些努力使得统明亮在全球LED市场中的份额不断扩大,其品牌影响力也得到了进一步提升。
请注意,由于篇幅限制,以上仅为三个简要故事。如果需要更多关于DOMINANT公司的发展故事,建议查阅相关报道和资料。
佰鸿(BrtLed)公司的发展小趣事
近年来,佰鸿公司开始将业务触角延伸至再生医学领域。通过多年的努力,公司成功建立了再生医学医疗与健康科技生态圈,并逐步实现了产业集群化。在再生医学领域,佰鸿不仅建立了产业化场地和研发设备,还计划在未来几年内打造国际领先的再生医学产业集群。这一多元化的发展战略,使得佰鸿在电子行业之外,也找到了新的增长点。
COILCRAFT公司的发展小趣事
COILCRAFT公司成立于1945年,是美国较早的磁性元件制造商。在创立初期,公司以生产高频电感器和变压器为主,凭借着卓越的技术和稳定的质量,逐渐在电子元器件市场中崭露头角。公司总部位于伊利诺伊州卡里,这个地理位置为其提供了便捷的物流和人才资源,为其后续的发展奠定了坚实的基础。
EnerSys公司的发展小趣事
EnerSys公司及其前身在工业电池制造领域拥有超过100年的历史。自20世纪初起,公司就开始专注于为各种工业应用提供可靠的电池解决方案。随着时间的推移,EnerSys不断吸收新技术和制造工艺,逐渐发展成为工业电池市场的领导者。这一长期的历史积淀,为EnerSys在电子行业中的发展奠定了坚实的基础。
有没有人有STM32 DXP的PCB库呢?
有没有人有STM32 DXP的PCB库呢?…
基于OMAP5910芯片Windows CE系统的WCDMA移动终端设计.pdf
基于OMAP5910芯片Windows CE系统的WCDMA移动终端设计.pdf…
VHDL中定义字符串,出错!
type char_arry is array(0 to 15) of character;constant fist_line:char_arry:={\' \',\'t\',\'h\',\'e\',\' \',\'F\',\'I\',\'R\',\' \',\'d\',\'a\',\'t\',\'a\',\' \',\'i\',\'s\'}; 报错为:Error (10500): VHDL syntax error at LCD1602.VH ...…
C# 调用Imange接口
一哪位高手帮我解决下掉用后内存释放问题哦…
Tornado启动失败
在电驴上下载了Tornado2.2 for 奔腾,安装之后启动Tornado总是显示“Lecensing Failed...”,但是我已经把lecense.dat放到c:\\flexlm下,而且设置了环境变量。请问怎么解决这个问题?…
安装SQL CE2.0之后只有帮助的文档,是怎么回事?
我几天安装完SQL CE2.0以后,准备在SQL CE 2.0里建立数据库,于是在开始-程序准备打开SQL CE 2.0 结果发现只有SQL CE2.0的帮助文档。是怎么回事? 是不时还要装SQL SEVER阿 我的SQL CE2.0时从微软下载的,40多M,IIS也装了…
基于LabVIEW图形界面的TI LM3S8962的开发续--ADC
以下图片为本次例程的程序框图,附件为工程文件和VI。 本例程主要是从开发板ADC0取得模拟电压值,然后简单的显示在开发板的OLED上。 注:开发板的模拟参考电压为3.3V,不是5V。 …
iTouch FPGA
在大家的一起努力下,“<50元的FPGA核心板,会否有朋友顶啊?”这个帖子得到热烈的回应,板子也大家的期盼中完工,为了方便大家的交流和资料的跟进,特意新开这个帖子,有兴趣的朋友可以在这个帖子进行跟新。   首先再介绍一下这个板子: ...…
针对the Xilinx Virtex™ LX130 的电源参考设计
Xilinx® Virtex-6 FPGA参考设计是一款采用TPS40190控制器及TI NextFETs™的Virtex 6 LX130设计,旨在提供最高效率和最佳性能。…
我看运放的压摆率
从接触运放开始,就很关注运放的SR和G、GBP(即GBW),这三个参数一般是我用运放关注的,但是一直不是很明白压摆率和增益带宽积还有就是放大倍数的关系,今天我认真的查资料分析了一下,结果如下:     1、压摆率(slew rate) ...…
