今天是:2025年04月10日(星期四)
2019年04月10日 | stm32 pwm 呼吸灯
2019-04-10 来源:eefocus
#include "main.h"
#include "stm32f0xx_hal.h"
/* USER CODE BEGIN Includes */
int i=0;
/* USER CODE END Includes */
/* Private variables ---------------------------------------------------------*/
TIM_HandleTypeDef htim3;
UART_HandleTypeDef huart1;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_USART1_UART_Init(void);
static void MX_TIM3_Init(void);
void HAL_TIM_MspPostInit(TIM_HandleTypeDef *htim);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
//Öжϴ¦Àí
void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin)
HAL_GPIO_TogglePin(GPIOB, GPIO_PIN_1|GPIO_PIN_2);
//¶¨Ê±Æ÷×ÔÔöº¯Êý
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
i++;
/* USER CODE END 0 */
* @brief The application entry point.
* @retval None
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/* MCU Configuration----------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
/* Configure the system clock */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
/* Initialize all configured peripherals */
MX_GPIO_Init();
MX_USART1_UART_Init();
MX_TIM3_Init();
/* USER CODE BEGIN 2 */
HAL_TIM_Base_Start_IT(&htim3);
HAL_TIM_PWM_Start(&htim3, TIM_CHANNEL_3);
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
/*uint8_t data = 0;
HAL_UART_Receive(&huart1, &data, 1, 0);
if(data == 'l')
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2, GPIO_PIN_RESET);
HAL_UART_Transmit(&huart1, &data, 1, 0);
else if(data == 'h')
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2, GPIO_PIN_SET);
int j;
for(j=100;j>=50;j--)
__HAL_TIM_SET_COMPARE(&htim3, TIM_CHANNEL_3, j);
HAL_Delay(15);
for(j=50;j<=100;j++)
HAL_Delay(15);
/* USER CODE END 3 */
我在用CGI返回中文时 printf(\"中文\\n\"); 浏览器在该行显示Invalid multibyte format string 在网上搜了一下有一种说法如下 在MIME头里加上对字符集 charset:gb2312 现在我的MIME头如下:printf(\"Content ...… 查看全部问答> |
RT! 要求:使用亿道XSBASE255开发板,在eMbedded Visual C++ 4.0、Platform Builder 4.2开发平台上,软件环境在wince下的串口助手的软件开发。有意者请加QQ943486228,JQ好商量。… 查看全部问答> |
在LINUX 0.11内核原代码中,如何实现显示字符? __asm__(\"movb _attr,%%ah\\n\\t\" \"movw %%ax,%1\\n\\t\" ::\"a\" (c),\"m\" (*(short *)pos) &nb ...… 查看全部问答> |
WinCE系统中,动态申请内存是否可以超过32M 如果不行,当碰到处理大数据量的时候,如果要申请的buffer超过了32M,该用什么办法解决这个问题? 应该描述清楚了吧,呵。。。… 查看全部问答> |
看见论坛里面那么多人回复\"女生单片机\"这个话题贴,我突然想了一下什么是MCU,为什么都是男生喜欢? MCU就是(MM Computer unite)MM和电脑的联合体,所以有那多男生喜欢。 大家还有什么好的解释啊 ...… 查看全部问答> |
香版主,可以用STM32F103VD代替STM32F103VB吗,我的RAM不够用了 只是STM32F103VB的RAM不够用了,别的都不动,也不改程序,可不可以直接用STM32F103VD代替STM32F103VB呢,所有的管教是否向下兼容?我直接换片子就行吗,还有什么要注意的吗?谢谢你一年来回答了我这么多的问题,谢谢了。… 查看全部问答> |
大家好,我用的是Keil UV4 MDK4.0 的编译器,用STM32 的SPI接口与CC2420通信时,发现程序未做优化时(LEVEL 0),MISO能正常接收信息,优化后(LEVE03),MISO接收的信息都是错误的,不知道是什么原因,难道KEIL的优化功能正有BUG? BYTE SPI ...… 查看全部问答> |
德州仪器:C6-Integra DSP+ARM处理器——OMAP-L138和C6748的安全特性 随着越来越多大公司的安全系统被攻破,嵌入式安全系统的保护工作变得既艰巨又迫切。本视频为你介绍嵌入式系统的系统安全,以及TI C6-Integra OMAP-L138 DSP+ARM和C6748 DSP这两款芯片所提供的安全特性。$(\'swf_uJq\').innerHTML=AC_FL_RunContent( ...… 查看全部问答> |
