今天是:2025年04月27日(星期日)
2019年04月27日 | STM32的PWM设置4路相差90度的输出信号
2019-04-27 来源:eefocus
void TIM_Encoder_Config(u16 PPS)//设置编码器的4路相差90度的PWM信号
double temp = 4000;
/* Time Base configuration */
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
TIM_BDTRInitTypeDef TIM_BDTRInitStructure;
temp = temp*72/PPS -1;
TIM_TimeBaseStructure.TIM_Period = (u16)temp - 1; //总周期长度
TIM_TimeBaseStructure.TIM_Prescaler = 124; // TIMCLK
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up ;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Toggle;//输出比较模式
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
TIM_OCInitStructure.TIM_Pulse = 0;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
TIM_OC1Init(TIM4, &TIM_OCInitStructure);
TIM_OC1PreloadConfig(TIM4, TIM_OCPreload_Enable);
//TIM4_OC2模块设置(设置2通道相位)
TIM_OCInitStructure.TIM_Pulse = (u16)(temp/2-1);//1/4总周期长度
TIM_OC2Init(TIM4, &TIM_OCInitStructure);
TIM_OC2PreloadConfig(TIM4, TIM_OCPreload_Enable);
//TIM4_OC3模块设置(设置3通道相位)
TIM_OCInitStructure.TIM_Pulse = (u16)(temp-1);//1/2总周期长度
TIM_OC3Init(TIM4, &TIM_OCInitStructure);
TIM_OC3PreloadConfig(TIM4, TIM_OCPreload_Enable);
//TIM4_OC4模块设置(设置4通道相位)
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;//输出极性:TIM输出比较极性高
TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
TIM_OCInitStructure.TIM_Pulse = (u16)(temp/2-1);//3/4总周期长度
TIM_OC4Init(TIM4, &TIM_OCInitStructure);
TIM_OC4PreloadConfig(TIM4, TIM_OCPreload_Enable);
//死区设置
TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable;
TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable;
TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_1;
TIM_BDTRInitStructure.TIM_DeadTime = 70; //这里调整死区大小0-0xff
TIM_BDTRInitStructure.TIM_Break = TIM_Break_Enable;
TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_Low;
TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable;
TIM_BDTRConfig(TIM4, &TIM_BDTRInitStructure);
/* TIM4 counter enable */
TIM_Cmd(TIM4, ENABLE);
/* TIM4 Main Output Enable */
TIM_CtrlPWMOutputs(TIM4, ENABLE);
上一篇:stm32ADC的DMA模式
下一篇:SCA100T STM32代码
基于AP3768 的高效手机充电器方案 近年来,节能环保理念的深入人心,对半导体IC 设计和应用也提出了更高的要求。2008 年11 月,五大手机制造商诺基亚、三星、索尼爱立信、摩托罗拉和LG 电子联合发布了手机充电器的五星 ...… 查看全部问答> |
在驱动程序初始化函数里面,创建一线程 if ( (pAXP182->IST = CreateThread(NULL, 0, AXP182_IST, NULL, 0, NULL)) == NULL) { ...… 查看全部问答> |
我用AT指令通过计算机串口给模块发指令,但是一直不成功,不知道是什么原因? 波特率是115200 我发指令如下: 1.发送:at 返回:OK 2.发送:at+ccid 返回:+CCID: \"89860060190200147245\" OK 3.发送:at+csq ...… 查看全部问答> |
我在对话框下做了一个编辑框,因为编辑框比较大,原始的字的输出比较小,不想改变编辑框的大小,想知道怎么把输入的字的放大一些,有没有简单一些的方法?? 谢谢!!!… 查看全部问答> |
求助:工程怎样下载到目标机,可以只运行目标机就可以启动工程啊? 各位路过的大侠,请问:我在主机上装了tornado ,pentium处理器的,做了一个工程,然后通过对等线连接的主机和目标机,目标机是一个HMI,我每次调试的时候都要通过tornado download到目标机里面,然后在tornado里debug,再run,目标机的工程才启动 ...… 查看全部问答> |
使用LM3S8962 开发板 学习以太网的相关开发 8962集成了mac 和 phy 貌似没有协议栈, 现在还没看懂例程的lwip 所以索性先随便发数据吧. unsigned char nMACAddr[] = {0x12, 0x34, 0x56, 0x78, 0x90, 0xAB}; 先初始化以太网控制器 SysCtlClockSet( ...… 查看全部问答> |
__no_init volatile union{ unsigned char IE1; /* Interrupt Enable 1 */ struct { unsigned char WDTIE : 1; /* */ unsigned char OFIE &n ...… 查看全部问答> |
