今天是:2025年07月16日(星期三)
2019年07月16日 | STM32开发笔记29:STM32L0低功耗设计——STOP_RTC模式的真实功耗
2019-07-16 来源:eefocus
单片机型号:STM32L053R8T6
本例程测试STOP_RTC模式的真实功耗,主程序如下:
int main(void)
while(1)
HAL_Delay(5000);
Target.HAL.Rtc.EnterStopRtcMode();
Target.HAL.SystemClock.SetMode(2);
系统进入主循环后,先进行5秒延时,然后进入低功耗模式,低功耗模式设置的RTC时间为4秒,4秒过后退出低功耗模式,重新进行时钟设置。
在进入main函数之前,执行了3个操作:时钟设置、低功耗设置和RTC设置,如下面程序:
class CHAL
public:
CSystemClock SystemClock;
CSystemLowPower SystemLowPower;
CRtc Rtc;
时钟设置相关程序如下:
void CClock::SetMode(uint8_t mode)
RCC_OscInitTypeDef RCC_OscInitStruct;
RCC_ClkInitTypeDef RCC_ClkInitStruct;
RCC_PeriphCLKInitTypeDef PeriphClkInit;
__HAL_RCC_PWR_CLK_ENABLE();
if (mode == 0)
//Configure the main internal regulator output voltage
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
//Initializes the CPU, AHB and APB busses clocks
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLMUL = RCC_PLLMUL_8;
RCC_OscInitStruct.PLL.PLLDIV = RCC_PLLDIV_3;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
Target.ErrorHandler(__FILE__, __LINE__);
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1|RCC_PERIPHCLK_USART2;
PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK2;
PeriphClkInit.Usart2ClockSelection = RCC_USART2CLKSOURCE_PCLK1;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
//Configure the Systick interrupt time
HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
//SysTick_IRQn interrupt configuration
HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
else if (mode == 1)
|RCC_PERIPHCLK_USB;
PeriphClkInit.UsbClockSelection = RCC_USBCLKSOURCE_PLL;
else if (mode == 2)
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSI | RCC_OSCILLATORTYPE_HSE | RCC_OSCILLATORTYPE_HSI;
RCC_OscInitStruct.LSIState = RCC_LSI_ON;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.HSICalibrationValue = 0x10; //HSIÐÞÕýÖµ
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1|RCC_PERIPHCLK_USART2|RCC_PERIPHCLK_RTC;
PeriphClkInit.RTCClockSelection = RCC_RTCCLKSOURCE_LSI;
低功耗设置相关程序如下:
CLowPower::CLowPower(uint8_t mode)
if (mode == 1)
GPIO_InitTypeDef GPIO_InitStructure;
HAL_PWREx_EnableUltraLowPower(); //ʹÄܳ¬µÍ¹¦ºÄ
HAL_PWREx_EnableFastWakeUp(); //ʹÄÜ¿ìËÙ»½ÐÑ
__HAL_RCC_WAKEUPSTOP_CLK_CONFIG(RCC_STOP_WAKEUPCLOCK_HSI); //½«HSIʱÖÓ×÷Ϊ»½ÐѺóµÄÖ÷ʱÖÓ
//½«ËùÓÐÒý½Å¶¼ÅäÖÃΪģÄâÊäÈëģʽ
__HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOB_CLK_ENABLE();
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOD_CLK_ENABLE();
__HAL_RCC_GPIOH_CLK_ENABLE();
GPIO_InitStructure.Pin = GPIO_PIN_All;
GPIO_InitStructure.Mode = GPIO_MODE_ANALOG;
GPIO_InitStructure.Pull = GPIO_NOPULL;
HAL_GPIO_Init(GPIOA, &GPIO_InitStructure);
HAL_GPIO_Init(GPIOB, &GPIO_InitStructure);
HAL_GPIO_Init(GPIOC, &GPIO_InitStructure);
HAL_GPIO_Init(GPIOD, &GPIO_InitStructure);
HAL_GPIO_Init(GPIOH, &GPIO_InitStructure);
__HAL_RCC_GPIOA_CLK_DISABLE();
__HAL_RCC_GPIOB_CLK_DISABLE();
__HAL_RCC_GPIOC_CLK_DISABLE();
__HAL_RCC_GPIOD_CLK_DISABLE();
__HAL_RCC_GPIOH_CLK_DISABLE();
RTC设置相关程序如下:
CRtc::CRtc(void)
this->hRTC.Instance = RTC;
pRTC = &this->hRTC;
this->hRTC.Init.HourFormat = RTC_HOURFORMAT_24;
this->hRTC.Init.AsynchPrediv = 124;
this->hRTC.Init.SynchPrediv = 295;
this->hRTC.Init.OutPut = RTC_OUTPUT_DISABLE;
this->hRTC.Init.OutPutRemap = RTC_OUTPUT_REMAP_NONE; //²»½øÐÐÊä³öÒý½ÅÖØÓ³Éä
this->hRTC.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
this->hRTC.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
if (HAL_RTC_Init(&this->hRTC) != HAL_OK)
程序运行后,5秒为正常功耗,4秒为低功耗,测得实际功耗2.4uA,手册中指出的STOP_RTC模式为1uA,产生差错的原因在《STM32L0低功耗设计3: Stop模式下的真实功耗》中已经介绍过,2.4uA已经能够满足项目本身的设计了,还算不错。
单片机双机同步通信 1 单片机PIC1编程(主控发送) #include <pic.h> /*该程序实现单片机双机同步通信功能,是主控发送部分。程序上电后显示 *相应的字符,表示系统正常工作。发送完毕后显示发送的数据*/ unsigned &nbs ...… 查看全部问答> |
摘要集成锁相源是通信设备至关重要的部件。本文叙述集成锁相源的原理,关健放术及设计过程。并应用MOTOROLA大规模镜相坏集成屯路,采用“脉冲吞食”可变分倾技术设计工另波段锁柏源,达到很好的指标。… 查看全部问答> |
模拟设计工程师短缺的情况正日益恶化,正迫使甚至像飞思卡尔半导体公司这样强大的数字芯片公司加倍努力征募和培养模拟设计工程师,以应对混合信号处理中“魔法艺术”的挑战。 “模拟集成电路设计存在一定的艺术性,”iSuppli公司负责模拟IC和半 ...… 查看全部问答> |
目前要在基于一套硬件平台来做wince下的视频处理,由于sdk不支持vfw,也不支持dshow的枚举,所以不知道该怎么采集视频信号了。在网上找了两天了,很多人问这个问题,但是没有妥当的解决方案,请知道的弟兄姐妹帮忙,谢谢! … 查看全部问答> |
最近做一个项目,想实现控制,能够降温,就打算用直流电机来模拟风扇。 我的开发板是tq2440,移植的是linux系统。初步想法是想买一个直流电机,再找到对应的直流电机驱动程序,将驱动程序编译进内核,通过编写程序,open( )设备文件,再write( )的 ...… 查看全部问答> |
