今天是:2025年08月06日(星期三)
2019年08月06日 | Ubuntu环境下使用stlink调试和下载stm32f4-discovery程序
2019-08-06 来源:eefocus
首先下载stlink的Linux版本。
然后解压到你所指定的路径下,参照其中的README文件进行编译配置。如下:(笔者在此将对关键点进行标注)
HOWTO
First, you have to know there are several boards supported by the software.
Those boards use a chip to translate from USB to JTAG commands. The chip is
called stlink and there are 2 versions:
. STLINKv1, present on STM32VL discovery kits,
. STLINKv2, present on STM32L discovery and later kits.
2 different transport layers are used:
. STLINKv1 uses SCSI passthru commands over USB,
. STLINKv2 uses raw USB commands.
Common requirements(依赖环境)
. libusb-1.0 (You probably already have this, but you'll need the
development version to compile)
(这个工具只需要执行sudo apt-get install libusb-dev && sudo apt-get install libusb-1.0-0-dev这两个命令即可。)
. pkg-config
(这个工具一般Ubuntu都会默认安装,注意变量PKG-CONFIG-PATH的设置)
IF YOU HAVE AN STLINKv1
The STLINKv1's SCSI emulation is very broken, so the best thing to do
is tell your operating system to completely ignore it.
Options (do one of these before you plug it in)
*) modprobe -r usb-storage && modprobe usb-storage quirks=483:3744:i
or *)1. add "options usb-storage quirks=483:3744:i" to /etc/modprobe.conf
*)2. modprobe -r usb-storage && modprobe usb-storage
or *)1. cp stlink_v1.modprobe.conf /etc/modprobe.d
IF YOU HAVE AN STLINKv2(我们的开发板支持STLINKv2,所以这里不做配置)
You're ready to go :)
COMPILING(编译:下边3个指令即可)
This project was converted to Autotools by a well meaning individual. The
following steps will build the project for you.
$ ./autogen.sh
$ ./configure
$ make
USING THE GDBSERVER(使用GDB调试服务)
To run the gdb server: (you do not need sudo if you have set up
permissions correctly)
(此时连上你的开发板,一般都要sudo)
$ make && [sudo] ./st-util
There are a few options:
./st-util - usage:
-h, --help Print this help
-vXX, --verbose=XX Specify a specific verbosity level (0..99)
-v, --verbose Specify generally verbose logging
-s X, --stlink_version=X
Choose what version of stlink to use, (defaults to 2)
-1, --stlinkv1 Force stlink version 1
-p 4242, --listen_port=1234
Set the gdb server listen port. (default port: 4242)
-m, --multi
Set gdb server to extended mode.
st-util will continue listening for connections after disconnect.
-n, --no-reset
Do not reset board on connection.
The STLINKv2 device to use can be specified in the environment
variable STLINK_DEVICE on the format Then, in your project directory, someting like this... (remember, you need to run an _ARM_ gdb, not an x86 gdb) (重新打开一个终端,找到你编译好的应用程序的目录,就是存在elf文件的地方) $ arm-none-eabi-gdb fancyblink.elf (开启调试) ... (gdb) tar extended-remote :4242 (连上GDB服务) ... (gdb) load Loading section .text, size 0x458 lma 0x8000000 Loading section .data, size 0x8 lma 0x8000458 Start address 0x80001c1, load size 1120 Transfer rate: 1 KB/sec, 560 bytes/write. (gdb) ... (gdb) continue Have fun! Resetting the chip from GDB =========================== You may reset the chip using GDB if you want. You'll need to use `target extended-remote' command like in this session: (gdb) target extended-remote localhost:4242 Remote debugging using localhost:4242 0x080007a8 in _startup () (gdb) kill Kill the program being debugged? (y or n) y (gdb) run Starting program: /home/whitequark/ST/apps/bally/firmware.elf Remember that you can shorten the commands. `tar ext :4242' is good enough for GDB. Setting up udev rules ===================== For convenience, you may install udev rules file, 49-stlinkv*.rules, located in the root of repository. You will need to copy it to /etc/udev/rules.d, and then either reboot or execute $ udevadm control --reload-rules $ udevadm trigger Udev will now create a /dev/stlinkv2_XX or /dev/stlinkv1_XX file, with the appropriate permissions. This is currently all the device is for, (only one stlink of each version is supported at any time presently) Running programs from SRAM(在RAM上运行) ========================== You can run your firmware directly from SRAM if you want to. Just link it at 0x20000000 and do (gdb) load firmware.elf It will be loaded, and pc will be adjusted to point to start of the code, if it is linked correctly (i.e. ELF has correct entry point). Writing to flash(烧写Flash) ================ The GDB stub ships with a correct memory map, including the flash area. If you would link your executable to 0x08000000 and then do (gdb) load firmware.elf then it would be written to the memory. FAQ === Q: My breakpoints do not work at all or only work once. A: Optimizations can cause severe instruction reordering. For example, if you are doing something like `REG = 0x100;' in a loop, the code may be split into two parts: loading 0x100 into some intermediate register and moving that value to REG. When you set up a breakpoint, GDB will hook to the first instruction, which may be called only once if there are enough unused registers. In my experience, -O3 causes that frequently. Q: At some point I use GDB command `next', and it hangs. A: Sometimes when you will try to use GDB `next' command to skip a loop, it will use a rather inefficient single-stepping way of doing that. Set up a breakpoint manually in that case and do `continue'. Currently known working combinations of programmer and target ============================================================= STLink v1 (as found on the 32VL Discovery board) Known Working Targets: * STM32F100xx (Medium Density VL) * STM32F103 (according to jpa- on ##stm32) No information: * everything else! STLink v2 (as found on the 32L and F4 Discovery boards) Known Working Targets: * STM32F0Discovery (STM32F0 Discovery board) * STM32F100xx (Medium Density VL, as on the 32VL Discovery board) * STM32L1xx (STM32L Discovery board) * STM32F103VC, STM32F107RC, STM32L151RB, STM32F205RE and STM32F405RE on custom boards (https://github.com/UweBonnes/wiki_fuer_alex/layout/usps...) * STM32F303xx (STM32F3 Discovery board) * STM32F407xx (STM32F4 Discovery board) * STM32F429I-DISCO (STM32F4 Discovery board with LCD) * STM32F439VIT6 (discovery board reseated CPU) * STM32L151CB (custom board) * STM32L152RB (STM32L-Discovery board, custom board) STLink v2-1 (as found on the Nucleo boards) Known Working Targets: * STM32F401xx (STM32 Nucleo-F401RE board) Please report any and all known working combinations so I can update this! 按照上边步骤编译配置,就可以调试和下载应用程序。
刚看到一个帖子,与大家分享: 这次,我要讨论的是国企元器件。国产元器件应该分成两种,一种是国有企业生产的,另一种是民营企业生产的。民营企业生产出来的东西,水平参差不齐,但是也有一些比较优秀的企业。而有国营背景的企业,由于体制的 ...… 查看全部问答> |
高分求救:谁用过Application Verifier在WINCE上检测过内存泄露啊 我在PC端用Application Verifier 检测WINCE上应用程序的内存泄露,已经连接到设备上,可Application Verifier界面右边的Test Settings栏目中始终都没有检测项目,就是空的,谁能告诉我是怎么回事呀?… 查看全部问答> |
零基础学单片机视频教程——02讲 并行端口仿真实例 本讲演示了标准51系列单片机并行I/O端口的使用,程序实现了并行I/O端口的读操作和写操作。其中,演示了一个完整程序的创建,同时还演示了并行端口的仿真操作。通过本 ...… 查看全部问答> |
采用恒压设计会危害LED未来! 1. LED肯定是需要恒流方式点亮,还是有些使用恒压方式设计,主要原因:一是,恒流方式限制达不到某些客户要求,迫于无赖!二是,电源IC厂家为了自己利益,会有些偏离实际的宣传。恒压方式是暂时的过度,很快会被成熟 ...… 查看全部问答> |
本文转自ADI技术杂志《模拟对话》https://ezchina.analog.com/message/28501#28501 任何高性能ADC,尤其是射频采样ADC,输入或前端的设计对于实现所需的系统级性能而言很关键。很多情况下,射频采样ADC可以对几百MHz的信号带宽进行数字量化。前端 ...… 查看全部问答> |
