今天是:2025年08月09日(星期六)
2019年08月09日 | STM32学习之路:I2C的基本读写
2019-08-09 来源:eefocus
宏定义:
/*I2C传输速度,最高为400kHz*/
#define I2C_SPEED     400000
/* STM32 自身的 I2C 地址, 这个地址只要与 STM32 外挂的 I2C 器件地址不一样即可 */
#define I2C_OWN_ADDR 0x77
/*EEPROM地址*/
#define EEPROM_ADDR (0x50<<1)   //0xA0
#define EEPROM_SCL_GPIO_CLK   RCC_AHB1Periph_GPIOB
#define EEPROM_SCL_PIN        GPIO_Pin_6
#define EEPROM_SCL_GPIO_PORT GPIOB
#define EEPROM_SCL_AF          GPIO_AF_I2C1
#define EEPROM_SCL_SOURCE           GPIO_PinSource6
#define EEPROM_SDA_GPIO_CLK   RCC_AHB1Periph_GPIOB
#define EEPROM_SDA_PIN        GPIO_Pin_7
#define EEPROM_SDA_GPIO_PORT GPIOB
#define EEPROM_SDA_AF                    GPIO_AF_I2C1
#define EEPROM_SDA_SOURCE  GPIO_PinSource7
#define EEPROM_I2C_CLK  RCC_APB1Periph_I2C1
#define EEPROM_I2C                    I2C1
/*================1-初始化 EEPROM_GPIO 口(复用引脚功能参照USART)==========================*/
void EEPROM_GPIO_Config(void)
  GPIO_InitTypeDef GPIO_InitStructure;
RCC_AHB1PeriphClockCmd(EEPROM_SCL_GPIO_CLK|EEPROM_SDA_GPIO_CLK,ENABLE);
/* GPIO初始化 */
/* 推挽输出/上拉电阻/50M输出速度 */
  GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
/* 配置SCL引脚为复用功能  */
/* 选择复用功能模式/选择SCL引脚*/
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
        GPIO_InitStructure.GPIO_Pin = EEPROM_SCL_PIN ;
  GPIO_Init(EEPROM_SDA_GPIO_PORT, &GPIO_InitStructure);
  /* 配置SDA引脚为复用功能 */
 /* 选择复用功能模式/选择SDA引脚*/
  GPIO_InitStructure.GPIO_Pin = EEPROM_SDA_PIN;
  GPIO_Init(EEPROM_SCL_GPIO_PORT, &GPIO_InitStructure);
/* 连接 PXx 到 EEPROM_SCL*/
  GPIO_PinAFConfig(EEPROM_SCL_GPIO_PORT,EEPROM_SCL_SOURCE,EEPROM_SCL_AF);
  /*  连接 PXx 到 EEPROM_SDA*/
  GPIO_PinAFConfig(EEPROM_SDA_GPIO_PORT,EEPROM_SDA_SOURCE,EEPROM_SDA_AF);
/*================2-初始化 IIC 模式==========================================*/
I2C结构体
ClockSpeed :设置I2C的传输速率
要求:低于400kHz
Mode :I2C的使用模式
I2C_Mode_I2C :I2C正常模式
I2C主从模式
I2C_Mode_SMBusDevice
I2C_Mode_SMBusHost
DutyCycle: 设置的是 I2C的 SCL 线时钟的占空比
I2C_DutyCycle_16_9 占空比16:9
I2C_DutyCycle_2    占空比 2:1
OwnAddress1 : STM32 的 I2C 设备自己的地址
Ack: I2C 应答使能设置
I2C_Ack_Enable:使能
I2C_Ack_Disable:不使能
AcknowledgedAddress:I2C 的寻址模式
I2C_AcknowledgedAddress_7bit 7位寻址
I2C_AcknowledgedAddress_10bit 10位寻址
void EEPROM_I2C_ModeConfig(void)
/* 定义 I2C 结构体声明 */
I2C_InitTypeDef I2C_InitStruct;
/* 打开外设 I2C 时钟 */
RCC_APB1PeriphClockCmd(EEPROM_I2C_CLK,ENABLE);
/* I2C 传输速率 */
I2C_InitStruct.I2C_ClockSpeed = I2C_SPEED;
/* I2C 模式*/
I2C_InitStruct.I2C_Mode = I2C_Mode_I2C;
/* 占空比 */
I2C_InitStruct.I2C_DutyCycle = I2C_DutyCycle_2;
/* I2C 本身地址 */
I2C_InitStruct.I2C_OwnAddress1 = I2C_OWN_ADDR;
/* 答应使能 */
I2C_InitStruct.I2C_Ack = I2C_Ack_Enable;
/* 寻址模式 */
I2C_InitStruct.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
/* 初始化 I2C */
I2C_Init(EEPROM_I2C,&I2C_InitStruct);
  /* 使能 I2C */
  I2C_Cmd(EEPROM_I2C,ENABLE);
/*==============3-写一个字节函数==============================================*/
void EEPROM_Byte_Write(uint8_t* pData,uint8_t addr)
/* 起始信号 */
  I2C_GenerateSTART(EEPROM_I2C,ENABLE);
/* 检测 EV5 事件,用于起始信号后 */
  while(I2C_CheckEvent(EEPROM_I2C,I2C_EVENT_MASTER_MODE_SELECT) != SUCCESS )
/* 发送 EEPROM 地址 */
  I2C_Send7bitAddress(EEPROM_I2C,EEPROM_ADDR,I2C_Direction_Transmitter);
  /* 检测 EV6 事件,用于从机地址后 */
  while(I2C_CheckEvent(EEPROM_I2C,I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED) != SUCCESS )
  /* 发送储存地址,即 EEPROM 内部地址 */
  I2C_SendData(EEPROM_I2C,addr);
  /* 检测 EV8 事件,用于传输数据后 */
  while(I2C_CheckEvent(EEPROM_I2C,I2C_EVENT_MASTER_BYTE_TRANSMITTED) != SUCCESS )
  /* 发送数据 */
  I2C_SendData(EEPROM_I2C,*pData);
  /* 检测 EV8 事件 */
  /* 停止信号 */
  I2C_GenerateSTOP(EEPROM_I2C,ENABLE);
/*==============4-读一个字节函数==============================================*/
uint8_t EEPROM_Byte_Read(uint8_t addr)
  uint8_t readTemp;
  /* 等待 EEPROM 内部写完毕 */
  Wait_for_EEPROM();
  /* 起始信号 */
  /* 发送 EEPROM 地址 */
  /* 发送读取数据的 EEPROM 内部地址 */
  /* 检测 EV8_2 事件 */
  /* 起始信号 */
  /* 发送 EEPROM 地址 */
  I2C_Send7bitAddress(EEPROM_I2C,EEPROM_ADDR,I2C_Direction_Receiver);
  while(I2C_CheckEvent(EEPROM_I2C,I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED) != SUCCESS )
  /* 终止使能应答 */
  I2C_AcknowledgeConfig(EEPROM_I2C,DISABLE);
  /* 检测 EV7 事件 */
  while(I2C_CheckEvent(EEPROM_I2C,I2C_EVENT_MASTER_BYTE_RECEIVED) != SUCCESS )
  /* 读取接收数据 */
  readTemp = I2C_ReceiveData(EEPROM_I2C);
  /* 停止信号 */
  return readTemp;
/*==============5-等待EEPROM内部写完毕(具体的我也不是很明白)==============================================*/
void Wait_for_EEPROM(void)
  do
//    while(I2C_CheckEvent(EEPROM_I2C,I2C_EVENT_MASTER_MODE_SELECT) != SUCCESS )
  }while(I2C_GetFlagStatus(EEPROM_I2C,I2C_FLAG_ADDR) == RESET);
  //等待ADDR = 1 才执行下面的语句
  I2C_ClearFlag(EEPROM_I2C,I2C_FLAG_AF);
  while(I2C_GetFlagStatus(EEPROM_I2C,I2C_FLAG_BUSY) == SET);
  //总线空闲,执行下面的语句
友盟(AP)公司的发展小趣事
在追求商业成功的同时,友盟(AP)公司也积极履行社会责任,致力于可持续发展。公司关注环境保护、公益事业等方面的问题,积极参与相关活动和项目。同时,友盟还通过技术创新和产品优化,推动电子行业的绿色发展和数字化转型。这些努力不仅提升了公司的社会形象,也为其未来的发展注入了新的动力。
以上是关于电子行业里友盟(AP)公司发展起来的5个相关故事。这些故事从不同角度展现了友盟在技术创新、合作伙伴关系、市场拓展、人才团队建设以及社会责任等方面的努力和成就。当然,每个公司的发展都是一个复杂而多元的过程,这些故事只是其中的一部分。
Davico Industrial Ltd公司的发展小趣事
友盟(AP)公司深知人才是企业发展的核心动力。因此,公司一直注重人才团队的建设和发展。通过招聘优秀人才、提供完善的培训体系和激励机制,友盟成功打造了一支高素质、专业化的团队。这支团队不仅具备深厚的技术功底和创新能力,还具备敏锐的市场洞察力和执行力,为公司的快速发展提供了有力保障。
Bce Sud公司的发展小趣事
在快速发展的同时,Bce Sud始终关注企业社会责任和可持续发展。公司积极参与环保、公益等活动,致力于为社会做出贡献。同时,公司还注重员工的培训与发展,为员工提供良好的工作环境和职业发展机会。这些举措不仅提升了公司的社会形象,也为公司的长远发展奠定了坚实基础。
这些故事基于一般的电子行业公司成长经历构建,旨在展示一个虚构的电子行业公司如何从初创走向成功的过程。虽然故事中的公司名称和具体细节是虚构的,但其中的发展逻辑和经验教训对于现实中的电子行业公司来说仍具有一定的参考价值。
E-tec Interconnect Ltd公司的发展小趣事
在电子行业快速发展的背景下,E-tec始终保持对技术创新的关注。他们投入大量资金进行研发,不断推出新产品和新技术。例如,他们成功开发了一种新型的微型连接器,该连接器具有体积小、传输速度快、抗干扰能力强等优点,受到了市场的热烈欢迎。此外,E-tec还注重产品升级和换代,确保产品始终保持在行业前列。
博流(Bouffalo Lab)公司的发展小趣事
博流智能科技始创于2016年,由一群来自硅谷顶级芯片公司的创始团队组成。他们凭借在移动通讯及物联网技术领域的深厚积累,以及对未来科技趋势的敏锐洞察,决定投身于新一代物联网集成电路芯片的研发。初创时期,公司面临着资金、技术和市场等多重挑战,但团队凭借坚定的信念和不懈的努力,逐步克服了困难,为公司的长远发展奠定了坚实基础。
BB公司的发展小趣事
在成立后的几年里,BB公司逐渐在国内市场站稳了脚跟。然而,创始人并没有满足于此,他看到了更广阔的国际市场。1961年,BB公司首次进入国际市场,凭借其高品质的产品和专业的服务,迅速赢得了国际客户的青睐。此后,BB公司不断加快国际化步伐,先后在英国和日本设立子公司,进一步扩大了市场份额。这一系列的国际化举措,不仅提升了BB公司的知名度,也为其带来了丰厚的回报。
wince中数据库同步总报异常
在ce中用sqlmobile连接pc中sqlserver2005时,在产生new SqlCeRemoteDataAccess这个类的时候总报异常,说 “在 System.Data.SqlServerCe.SqlCeException 中第一次偶然出现的“System.Data.SqlServerCe.dll”类型的异常 ”,哪位大侠帮忙解决一下 ...…
请教一个简单的C51程序,
#include main() {         TMOD=0X10;         TH1=0XFE;         TL1=0X0C;         TR1=1;         ET1=1;       ...…
关于VC6.0代码迁移至WINCE环境的问题
大家好,请教一下,我有个VC程序想迁移到WINCE下,不知道有没有什么简单快捷的修改方案,还是要重新在EVC下重新组织代码? 是不是VC下的代码并不完全被WINCE接受的?…
wince下调用软键盘的问题
在wince下调用软键盘,代码如下 void CRecorderDlg::OnBnClickedButton6() {         // TODO: Add your control notification handler code here         SipShowIM(SIPF_ON);  //Shows&nb ...…
在wince 下怎么能读取 一个像素 alpha 通道的值
我想把一个带 透明通道的bitmap作为前景贴到一个不带透明通道的背景bitmap上,试了几种方法 都不理想,包括 TransparentBlt(...),alphablend(...),还使用过maskdc 的方法,都不理想。 前两种方法把我的小的前景,拉伸到跟背景一样大;而且Transpa ...…
发个清华蓬远地取模软件
前几天取汉字模从网上下个软件,不太好,就因为取然的格式带H地,我要C语言数组地,以前用过清华蓬远的取模软件,我认为是最好地,今天翻出特发上来,大家共享,我也MARK,省得以后再找不到,呵呵…
一个晶振引发的问题
本来是51好板,就是CPU座松了,让同事搞一下变紧,拿回来突然不好用,仿真器上也不好用,本来屏幕可显开机画面,但怎么也搞不定,由于急有找了另一台机器总算把程序实验完,第二天对着这个坏板研究起来,首先是换51的40脚DIP座,小心得很,因为板上 ...…
菜农友情为STM32设计一种通用加密方法之原理
今天连续看了两篇关于加密方面的帖子,感觉自己应该友情奉献一回了~~~ 设想一种加密办法,大家看看可行吗? 关于STM32F器件电子签名以及加密问题-请指点 今日方知STM32的UID为96位即12个字节,以前知道STM32内嵌CRC32. 网上在线CRC演算工 ...…
基于Keil的LM3S811调试笔记
拿到开发板后就第一时间对LM3S811进行调试,图片已经有网友上传了我就不再上传,就说说自己调试碰到的问题一级解决方法! 1、由于我的电脑没有光驱,所以智能是手动安装仿真器的驱动,安装的过程中会出现对话框让你选择的文件,此时你只要双击那文 ...…
NOR市场晴转多云 spansion突破寻曙光
   如今,无论我们在车上、家里或是旅途中,都希望能够随时随地顺畅地浏览多媒体内容和信息。特别是在玩游戏时,我们更是贪求一个畅快、愉悦的美好体验。而这些体验的实现与提升,很大程度上取决于NOR内存产品的性能和密度。   &n ...…
