今天是:2024年08月24日(星期六)
2019年08月24日 | 51单片机 nrf24l01收发
2019-08-24 来源:eefocus
引脚图
引脚1:GND,接地端;引脚2:VCC,1.9V~3.6V
引脚3:CE, NRF24L01模式控制端
引脚4:CSN,片选信号
引脚5:SCK,SPI时钟输入端
引脚6:MOSI,SPI数据输入端
引脚7:MISO,SPI数据输出端
引脚8:IRQ,中断输出端,低电平使能,即中断输出低电平
对于电源不要超过3.6V,否则可能损坏芯片
对于端口引脚,可以耐压5V,即可以接TTL端口
发送端
#include #define uchar unsigned char #define TX_ADR_WIDTH 5 // 5字节宽度的发送/接收地址 #define TX_PLOAD_WIDTH 4 // 数据通道有效数据宽度 uchar code TX_ADDRESS[TX_ADR_WIDTH] = {0x34,0x43,0x10,0x10,0x01}; // 定义一个静态发送地址 uchar RX_BUF[TX_PLOAD_WIDTH]; uchar TX_BUF[TX_PLOAD_WIDTH]; uchar flag; uchar DATA = 0x01; uchar bdata sta; sbit RX_DR = sta^6; sbit TX_DS = sta^5; sbit MAX_RT = sta^4; sbit CE = P1^5; sbit CSN= P1^4; sbit SCK= P1^3; sbit MOSI= P1^2; sbit MISO= P1^1; sbit IRQ = P1^0; // SPI(nRF24L01) commands #define READ_REG 0x00 // Define read command to register #define WRITE_REG 0x20 // Define write command to register #define RD_RX_PLOAD 0x61 // Define RX payload register address #define WR_TX_PLOAD 0xA0 // Define TX payload register address #define FLUSH_TX 0xE1 // Define flush TX register command #define FLUSH_RX 0xE2 // Define flush RX register command #define REUSE_TX_PL 0xE3 // Define reuse TX payload register command #define NOP 0xFF // Define No Operation, might be used to read status register // SPI(nRF24L01) registers(addresses) #define CONFIG 0x00 // 'Config' register address #define EN_AA 0x01 // 'Enable Auto Acknowledgment' register address #define EN_RXADDR 0x02 // 'Enabled RX addresses' register address #define SETUP_AW 0x03 // 'Setup address width' register address #define SETUP_RETR 0x04 // 'Setup Auto. Retrans' register address #define RF_CH 0x05 // 'RF channel' register address #define RF_SETUP 0x06 // 'RF setup' register address #define STATUS 0x07 // 'Status' register address #define OBSERVE_TX 0x08 // 'Observe TX' register address #define CD 0x09 // 'Carrier Detect' register address #define RX_ADDR_P0 0x0A // 'RX address pipe0' register address #define RX_ADDR_P1 0x0B // 'RX address pipe1' register address #define RX_ADDR_P2 0x0C // 'RX address pipe2' register address #define RX_ADDR_P3 0x0D // 'RX address pipe3' register address #define RX_ADDR_P4 0x0E // 'RX address pipe4' register address #define RX_ADDR_P5 0x0F // 'RX address pipe5' register address #define TX_ADDR 0x10 // 'TX address' register address #define RX_PW_P0 0x11 // 'RX payload width, pipe0' register address #define RX_PW_P1 0x12 // 'RX payload width, pipe1' register address #define RX_PW_P2 0x13 // 'RX payload width, pipe2' register address #define RX_PW_P3 0x14 // 'RX payload width, pipe3' register address #define RX_PW_P4 0x15 // 'RX payload width, pipe4' register address #define RX_PW_P5 0x16 // 'RX payload width, pipe5' register address #define FIFO_STATUS 0x17 // 'FIFO Status Register' register address /************************************************** 函数: init_io() 描述: 初始化IO /**************************************************/ void init_io(void) { CE = 0; // 待机 CSN = 1; // SPI禁止 SCK = 0; // SPI时钟置低 IRQ = 1; // 中断复位 LED = 1; // 关闭指示灯 } /**************************************************/ /************************************************** 函数:delay_ms() 描述: 延迟x毫秒 /**************************************************/ void delay_ms(uchar x) { uchar i, j; i = 0; for(i=0; i j = 250; while(--j); j = 250; while(--j); } } /**************************************************/ /************************************************** 函数:SPI_RW() 描述: 根据SPI协议,写一字节数据到nRF24L01,同时从nRF24L01 读出一字节 /**************************************************/ uchar SPI_RW(uchar byte) { uchar i; for(i=0; i<8; i++) // 循环8次 { MOSI = (byte & 0x80); // byte最高位输出到MOSI byte <<= 1; // 低一位移位到最高位 SCK = 1; // 拉高SCK,nRF24L01从MOSI读入1位数据,同时从MISO输出1位数据 byte |= MISO; // 读MISO到byte最低位 SCK = 0; // SCK置低 } return(byte); // 返回读出的一字节 } /**************************************************/ /************************************************** 函数:SPI_RW_Reg() 描述: 写数据value到reg寄存器 /**************************************************/ uchar SPI_RW_Reg(uchar reg, uchar value) { uchar status; CSN = 0; // CSN置低,开始传输数据 status = SPI_RW(reg); // 选择寄存器,同时返回状态字 SPI_RW(value); // 然后写数据到该寄存器 CSN = 1; // CSN拉高,结束数据传输 return(status); // 返回状态寄存器 } /**************************************************/ /************************************************** 函数:SPI_Read() 描述: 从reg寄存器读一字节 /**************************************************/ uchar SPI_Read(uchar reg) { uchar reg_val; CSN = 0; // CSN置低,开始传输数据 SPI_RW(reg); // 选择寄存器 reg_val = SPI_RW(0); // 然后从该寄存器读数据 CSN = 1; // CSN拉高,结束数据传输 return(reg_val); // 返回寄存器数据 } /**************************************************/ /************************************************** 函数:SPI_Read_Buf() 描述: 从reg寄存器读出bytes个字节,通常用来读取接收通道 数据或接收/发送地址 /**************************************************/ uchar SPI_Read_Buf(uchar reg, uchar * pBuf, uchar bytes) { uchar status, i; CSN = 0; // CSN置低,开始传输数据 status = SPI_RW(reg); // 选择寄存器,同时返回状态字 for(i=0; i CSN = 1; // CSN拉高,结束数据传输 return(status); // 返回状态寄存器 } /**************************************************/ /************************************************** 函数:SPI_Write_Buf() 描述: 把pBuf缓存中的数据写入到nRF24L01,通常用来写入发 射通道数据或接收/发送地址 /**************************************************/ uchar SPI_Write_Buf(uchar reg, uchar * pBuf, uchar bytes) { uchar status, i; CSN = 0; // CSN置低,开始传输数据 status = SPI_RW(reg); // 选择寄存器,同时返回状态字 for(i=0; i CSN = 1; // CSN拉高,结束数据传输 return(status); // 返回状态寄存器 } /**************************************************/ /************************************************** 函数:RX_Mode() 描述: 这个函数设置nRF24L01为接收模式,等待接收发送设备的数据包 /**************************************************/ void RX_Mode(void) { CE = 0; SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 接收设备接收通道0使用和发送设备相同的发送地址 SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // 使能接收通道0自动应答 SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // 使能接收通道0 SPI_RW_Reg(WRITE_REG + RF_CH, 40); // 选择射频通道0x40 SPI_RW_Reg(WRITE_REG + RX_PW_P0, TX_PLOAD_WIDTH); // 接收通道0选择和发送通道相同有效数据宽度 SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); // 数据传输率1Mbps,发射功率0dBm,低噪声放大器增益 SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // CRC使能,16位CRC校验,上电,接收模式
上一篇:51单片机 矩阵键盘
下一篇:51单片机 LCD1602显示
总结的一些笔试面试题资料,数字电路方面的比较多,还期望大家看完之后多提意见。 [ 本帖最后由 linda_xia 于 2010-4-12 08:25 编辑 ]… 查看全部问答> |
请教,有过Windows上的C++和汇编开发经验,没有电子方面的基础,要学习单片机的该从什么开始? 来这里诚心请教各位,以前有过Windows上C++和汇编开发的经验,但是大学学的是计算机相关专业而不是电子专业的,所以没有什么电子方面的基础识,现在如果要学单片机的话,据说要从学习模拟电路和数字电路的开始,是这样吗? 另外问下,有本书是电子 ...… 查看全部问答> |
各位老师,前辈们,我的毕业设计涉及到了这两个模块之间的连接,SP12是温度压力传感器,我的工作就是把SP12采集到的数据通过430的处理,最后经过一个无线发射模块把数据发射出去。 但是现在的问题是,SP12和43 ...… 查看全部问答> |
请问用Source Insight怎么看bootloader里的代码流程 不知道大家分析代码用到什么工具,听说Source Insight好用,下了一个但是不太会用,哪位大侠用过的告诉在下一声,怎么看bootloader里的代码流程?… 查看全部问答> |
为什么在EVC的Emulator中使用IImage,出现CoCreateInstance失败,返回-2147221164.应该如何做呢? 急救!谢谢!… 查看全部问答> |
我一直在考虑一个问题:导线的载流量是靠什么来衡量的? 相同粗细的导线在任何电压下电阻是一样的;如果是根据导线的温升来确定导线的载流量,那么在不同的电压下的载流量是不一样的。如果在220v 的电压中0.5平方导线能承受3A 电流,那么在DC24V 中 ...… 查看全部问答> |
【问TI】Stelleris系列ARM芯片用SWD方式,硬件如何连接 由于SWD方式貌似比JTAG方式仿真和调试能少用两个IO口,以后想只留SWD调试接口来做产品,看了一下芯片的DataSheet,还是不清楚到底要连几根线才好用。有的说要3根SWCLK,SWDIO,和TRST信号线,有的朋友说还要用引线到仿真器的SWO。请专家给个典型连接 ...… 查看全部问答> |
test_freq[31:0]; base_cnt_reg[31:0]; test_cnt_reg[31:0]; test_freq <= 50000000 * test_cnt_reg / base_cnt_reg;和这句 test_freq <= 50000000 / base_cnt_reg * test_cnt_reg ; 有什么区别吗? 这两句在数学上不是等价的吗?为什 ...… 查看全部问答> |
因驱动光盘里附带的MLink驱动不支持在WIN764位系统下安装 为此我花了不下一整天的时间来解决MLINK驱动的问题 最后换了32位Windows Server 2008总算可以使用 可实在不甘心一个64位硬件跑个32位版本的系统在同事的帮助下我安装了微软自带的虚拟XP ...… 查看全部问答> |
