今天是:2024年08月27日(星期二)
正在发生
2019年08月27日 | 【STM32H7教程】第12章 STM32H7的HAL库框架设计学习
2019-08-27 来源:eefocus
12.1 初学者重要提示
学习使用HAL库前,有必要对他们的基本设计框架有所了解,然后深入学习,效果更好。
为了方便调用,HAL库为各种外设基本都配了三套API,查询,中断和DMA。
12.2 HAL库的配置文件
HAL库有一个专门的配置文件叫stm32h7xx_hal_conf.h,这个文件里面有一个很重要的参数,就是HSE_VALUE,大家所设计板子使用的实际晶振大小一定要与这个数值一致。比如V7的外置晶振是25MHz,那么这里就务必配置宏定义为:
#define HSE_VALUE    ((uint32_t)25000000)
完整的代码如下:
/* ########################## Module Selection ############################## */
  * @brief This is the list of modules to be used in the HAL driver
#define HAL_MODULE_ENABLED
#define HAL_ADC_MODULE_ENABLED
#define HAL_CEC_MODULE_ENABLED
 /* 省略未写 */
/* ########################## Oscillator Values adaptation ####################*/
  * @brief Adjust the value of External High Speed oscillator (HSE) used in your application.
  *        This value is used by the RCC HAL module to compute the system frequency
  *        (when HSE is used as system clock source, directly or through the PLL).
#if !defined  (HSE_VALUE)
#define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz */
#endif /* HSE_VALUE */
#if !defined  (HSE_STARTUP_TIMEOUT)
  #define HSE_STARTUP_TIMEOUT    ((uint32_t)5000)   /*!< Time out for HSE start up, in ms */
#endif /* HSE_STARTUP_TIMEOUT */
  * @brief Internal  oscillator (CSI) default value.
  *        This value is the default CSI value after Reset.
#if !defined  (CSI_VALUE)
  #define CSI_VALUE    ((uint32_t)4000000) /*!< Value of the Internal oscillator in Hz*/
#endif /* CSI_VALUE */
  * @brief Internal High Speed oscillator (HSI) value.
  *        (when HSI is used as system clock source, directly or through the PLL).
#if !defined  (HSI_VALUE)
  #define HSI_VALUE    ((uint32_t)64000000) /*!< Value of the Internal oscillator in Hz*/
#endif /* HSI_VALUE */
  * @brief External Low Speed oscillator (LSE) value.
  *        This value is used by the UART, RTC HAL module to compute the system frequency
#if !defined  (LSE_VALUE)
  #define LSE_VALUE    ((uint32_t)32768) /*!< Value of the External oscillator in Hz*/
#endif /* LSE_VALUE */
#if !defined  (LSE_STARTUP_TIMEOUT)
  #define LSE_STARTUP_TIMEOUT    ((uint32_t)5000)   /*!< Time out for LSE start up, in ms */
#endif /* LSE_STARTUP_TIMEOUT */
  * @brief External clock source for I2S peripheral
  *        This value is used by the I2S HAL module to compute the I2S clock source
  *        frequency, this source is inserted directly through I2S_CKIN pad.
#if !defined  (EXTERNAL_CLOCK_VALUE)
  #define EXTERNAL_CLOCK_VALUE    12288000U /*!< Value of the External clock in Hz*/
#endif /* EXTERNAL_CLOCK_VALUE */
/* Tip: To avoid modifying this file each time you need to use different HSE,
   ===  you can define the HSE value in your toolchain compiler preprocessor. */
/* ########################### System Configuration ######################### */
  * @brief This is the HAL system configuration section
#define  VDD_VALUE                    ((uint32_t)3300) /*!< Value of VDD in mv */
#define  TICK_INT_PRIORITY            ((uint32_t)0x0F) /*!< tick interrupt priority */
#define  USE_RTOS                     0
/* #define  USE_SD_TRANSCEIVER           1U   */            /*!< use uSD Transceiver */
/* ########################### Ethernet Configuration ######################### */
#define ETH_TX_DESC_CNT         4  /* number of Ethernet Tx DMA descriptors */
#define ETH_RX_DESC_CNT         4  /* number of Ethernet Rx DMA descriptors */
#define ETH_MAC_ADDR0    ((uint8_t)0x02)
#define ETH_MAC_ADDR1    ((uint8_t)0x00)
#define ETH_MAC_ADDR2    ((uint8_t)0x00)
#define ETH_MAC_ADDR3    ((uint8_t)0x00)
#define ETH_MAC_ADDR4    ((uint8_t)0x00)
#define ETH_MAC_ADDR5    ((uint8_t)0x00)
/* ########################## Assert Selection ############################## */
  * @brief Uncomment the line below to expanse the "assert_param" macro in the
  *        HAL drivers code
/* #define USE_FULL_ASSERT    1 */
/* ################## SPI peripheral configuration ########################## */
  * @brief Used to activate CRC feature inside HAL SPI Driver
  *        Activated   (1U): CRC code is compiled within HAL SPI driver
  *        Deactivated (0U): CRC code excluded from HAL SPI driver
#define USE_SPI_CRC                   1U
/* Includes ------------------------------------------------------------------*/
  * @brief Include module's header file
#ifdef HAL_RCC_MODULE_ENABLED
  #include "stm32h7xx_hal_rcc.h"
#endif /* HAL_RCC_MODULE_ENABLED */
/* 省略未写 */
/* Exported macro ------------------------------------------------------------*/
#ifdef  USE_FULL_ASSERT
  * @brief  The assert_param macro is used for function's parameters check.
  * @param  expr: If expr is false, it calls assert_failed function
  *         which reports the name of the source file and the source
  *         line number of the call that failed.
  *         If expr is true, it returns no value.
  * @retval None
  #define assert_param(expr) ((expr) ? (void)0 : assert_failed((uint8_t *)__FILE__, __LINE__))
/* Exported functions ------------------------------------------------------- */
  void assert_failed(uint8_t* file, uint32_t line);
#else
  #define assert_param(expr) ((void)0)
#endif /* USE_FULL_ASSERT */
除了HSE_VALUE,下面几个也要作为了解:
  第72行,滴答定时器的优先级设置。这个优先级的设置至关重要。因为HAL库中各个外设驱动里面的延迟实现是基于此文件提供的时间基准。
如果在中断服务程序里面调用基于此时间基准的延迟函数HAL_Delay要特别注意,因为这个函数的时间基准是基于滴答定时器或者其他通用定时器实现,实现方式是滴答定时器或者其他通用定时器里面对变量计数。如此以来,结果是显而易见的,如果其他中断服务程序调用了此函数,且中断优先级高于滴答定时器,会导致滴答定时器中断服务程序一直得不到执行,从而卡死在里面。所以滴答定时器的中断优先级一定要比他们高。
另外这个时间基准既可以使用滴答定时器实现也可以使用通用的定时器实现,默认情况下是用的滴答定时器。
  第73行,当前HAL库还不支持RTOS方式。
  第74行,STM32H7的SDIO外接支持UHS-I 模式 (SDR12, SDR25, SDR50, SDR104和DDR50)的SD卡,需要1.8的电平转换器,此选项就是来使能此功能用的。
  第92行,用于使能断言功能,在HAL库的API里面都有用到,用来判断函数形参是否有效。默认情况下是关闭的。
  第126行,使能断言功能后,实际对应的代码位置。这里没有对函数void assert_failed(uint8_t* file, uint32_t line)做具体实现,大家可以根据自己的需求去实现,这里提供一个参考:
ST库函数使用了C编译器的断言功能,如果定义了USE_FULL_ASSERT,那么所有的ST库函数将检查函数形参
是否正确。如果不正确将调用 assert_failed() 函数,这个函数是一个死循环,便于用户检查代码。
关键字 __LINE__ 表示源代码行号。
关键字__FILE__表示源代码文件名。
断言功能使能后将增大代码大小,推荐用户仅在调试时使能,在正式发布软件是禁止。
用户可以选择是否使能ST固件库的断言供能。使能断言的方法有两种:
(1) 在C编译器的预定义宏选项中定义USE_FULL_ASSERT。
(2) 在本文件取消"#define USE_FULL_ASSERT    1"行的注释。
* 函 数 名: assert_failed
* 形    参:file : 源代码文件名称。关键字__FILE__表示源代码文件名。
*   line :代码行号。关键字 __LINE__ 表示源代码行号
* 返 回 值: 无
用户可以添加自己的代码报告源代码文件名和代码行号,比如将错误文件和行号打印到串口
printf("Wrong parameters value: file %s on line %drn", file, line) */
/* 这是一个死循环,断言失败时程序会在此处死机,以便于用户查错 */
while (1)
12.3 HAL库的时间基准
为了方便各种外设延迟的实现,HAL库专门搞了一个时间基准,默认来源是滴答定时器,也可以通过重定向使用其他定时器实现。相关函数全部集中在stm32h7xx_hal.c文件里面实现,关于这些函数在本教程的第16章有详细讲解。
12.4 HAL库的启动流程
这里通过V7板子初始化流程做个说明:
* 函 数 名: bsp_Init
* 功能说明: 初始化所有的硬件设备。该函数配置CPU寄存器和外设的寄存器并初始化一些全局变量。
*              只需要调用一次
* 形    参:无
* 返 回 值: 无
void bsp_Init(void)
    /* 配置MPU */
MPU_Config();
/* 使能L1 Cache */
CPU_CACHE_Enable();
       STM32H7xx HAL 库初始化,此时系统用的还是H7自带的64MHz,HSI时钟:
   - 调用函数HAL_InitTick,初始化滴答时钟中断1ms。
   - 设置NVIV优先级分组为4。
HAL_Init();
       配置系统时钟到400MHz
       - 切换使用HSE。
       - 此函数会更新全局变量SystemCoreClock,并重新配置HAL_InitTick。
SystemClock_Config();
bsp_InitKey();    /* 按键初始化,要放在滴答定时器之前,因为按钮检测是通过滴答定时器扫描 */
bsp_InitTimer();  /* 初始化滴答定时器 */
bsp_InitUart(); /* 初始化串口 */
bsp_InitExtIO(); /* 初始化FMC总线74HC574扩展IO. 必须在 bsp_InitLed()前执行 */
bsp_InitLed();    /* 初始化LED */
bsp_InitLPTIMOutPWM(); /* 低功耗定时器PWM输出 */
  第13 – 16行,配置MPU和使能Cache,对于H7而已,这两个函数要优先执行,因为Flash速度,SRAM速度跟CPU和TCM有些差距的,所以要使能Cache。而不同存储区的Cache策略要通过MPU分别进行配置。
  第23行,调用函数HAL_Init时,系统依然使用的64MHz HSI时钟,这点要特别注意。此函数会调用函数HAL_InitTick,初始化滴答时钟中断1ms,并设置NVIV优先级分组为4。
这里就隐含了一个知识点,就是它会开启滴答定时器中断,如果用户也要使用滴答定时器中断,此问题就要引起注意,我们的bsp_timer.C文件解决办法如下:
* 函 数 名: SysTick_Handler
* 功能说明: 系统嘀嗒定时器中断服务程序。启动文件中引用了该函数。
* 形    参:  无
* 返 回 值: 无
Dicon Fiberoptics Inc公司的发展小趣事
为了进一步扩大市场份额和提升品牌影响力,DiCon积极开展国际合作与全球布局。公司与多家国际知名企业建立了战略合作关系,共同研发和推广光纤通信技术。同时,DiCon还在全球范围内设立了多个研发中心和销售分支机构,以便更好地服务当地客户和市场。
Electrocube Inc公司的发展小趣事
Electrocube Inc公司的创始人在创立之初便面临着重重挑战。当时,电子行业正处于快速发展阶段,市场竞争激烈。然而,创始人凭借对电子技术的深刻理解和敏锐的市场洞察力,成功开发出了一款高性能、低成本的电容器产品。这款产品迅速获得了市场的认可,为公司赢得了第一桶金,也为后续的发展奠定了坚实的基础。
BSI公司的发展小趣事
在电子行业的初期,由于缺乏统一的标准,各种电子产品之间的兼容性和互通性成为了一个大问题。这时,BSI作为国际标准化组织的重要参与者,积极推动了电子产品的标准化工作。通过与各国政府、行业协会和企业的合作,BSI制定了一系列电子产品的标准,为行业的发展提供了可靠的参考依据。这些标准的出台,极大地促进了电子产品的互通性和兼容性,推动了电子行业的健康发展。
EICHHOFF公司的发展小趣事
在快速发展的同时,EICHHOFF公司也积极关注环保和可持续发展问题。公司认识到作为电子行业的一员,必须承担起保护环境、节约资源的责任。为此,EICHHOFF公司采取了一系列措施来降低生产过程中的能耗和排放。例如:引入节能设备和技术、优化生产流程、推广绿色包装等。
此外,EICHHOFF公司还积极参与环保公益活动和社会责任项目,为社会做出积极贡献。这些努力不仅提升了公司的社会形象,也为公司的可持续发展奠定了基础。
EMC Technology RF Labs公司的发展小趣事
EMC Technology RF Labs成立于XXXX年,作为EMC Technology公司的一个专门研究射频(RF)技术的实验室。创立之初,RF Labs的目标是为电子通信行业提供高质量的射频元件和解决方案。公司聚集了一批在射频技术领域具有丰富经验和专业知识的工程师,开始了对射频技术的深入研究和探索。
Bridgelux公司的发展小趣事
XXXX年,Bridgelux与Cree公司爆发了一场专利纠纷。Cree公司指控Bridgelux侵犯了其LED专利技术。经过一段时间的激烈争辩,双方最终达成了和解协议。Bridgelux同意支付一定的赔偿金,并获得了部分专利的授权。这次纠纷虽然给Bridgelux带来了一定的经济损失,但也使其更加注重知识产权保护,提升了自身的技术实力。
搜集的两份FPGA实现FFT程序
本帖最后由 paulhyde 于 2014-9-15 03:27 编辑 1024点8位的,用verilog编写 1024点16位,用vhdl编写 都已经测试过    …
CSS、UWB技术相关对比
一、 CSS技术简介 CSS技术是Chirp Spread Spectrum的简称,即线性调频扩频技术。这种技术以前主要用于脉冲压缩雷达,能够很好的解决冲击雷达系统测距长度和测距精度不能同时优化的矛盾。因此国内外的研究,一直局限在雷达领域。近年来,随着IEEE ...…
芯片型号识别
有的电子设备上的芯片标识型号被擦除,有什么办法识别…
做一个arm7的小核心板,有人接活么
要求: 设计一个arm7为核心的板子,加上ram和flash,跑上uclinux操作系统,加上一个有线网络。 就这么简单。 北京地区朋友,有愿意的联系我,有效期3天。 会者不难。 mfd_2000@126.com…
Luminary 的网站从此消失了,直接映射到 TI 官网
Luminary 的网站从此消失了,直接映射到 TI 官网,www.luminarymicro.com?,今天想去 luminary 官网下个资料,发现没了。…
ads1247的pt100测温,寄存器配置后REFP0和REFN0两端电压始终为零
现在可以对ADS1247的寄存器进行读写操作,问题是不管我怎么配置MUX1和IDAC0,REFP0和REFN0之间始终没有电压,而且ANI0和ANI1对地没有电流。请高手指点。主要寄存器配置是:MUX0  01  ;VBias   00;MUX1  70;SYS0  ...…
pic16f877控制的电风扇,遥控或者是自然风
急求啊~要是能有电路图就更完美了~~跪求各位大神帮忙啊~~~…
基于mbed平台(IAR编译器)SPI驱动LCD5110显示屏
最近刚得到一块F072的NUCLEO板,闲来无事测试了F072的SPI,基于mbed平台的离线编程,C++编程相比C简单很多,和HAL库或者标准库相比,mbed操作相对简单,但是由于加入了C++,库读起来就没那么简单了!下面是具体操作过程:1.在github上下载mbed的库 ...…
【YL-KL26Z】USB键盘测试
replyreload += \',\' + 1819432;KL26Z带有USB接口,可以做USB设备。我们在YL-KL26Z开发板上,先试试USB键盘的使用。还是利用Mbed,几分钟就可以做出一个USB键盘。按下K3,输出“Hello World from Mbed”;按下K4,输出字母s。可以先打开记事本,在 ...…
自平衡小车DIY续...
       自平衡车折腾好久,现在能实现平衡效果了,期间各种波折.....这几天整理出一份文档,由于排版格式有点不合适在 论坛编辑,所以这里只好以截图的形式发表了,各位可以先看看,觉得写的不错的在下载看文档,写的是心里面 ...…
