今天是:2024年08月30日(星期五)
2019年08月30日 | S5PV210开发 -- 通过 SD 卡烧写
2019-08-30 来源:eefocus
上文 烧写/启动模式 提到使用 SD 卡启动。那么接下来看看怎么做。
一、首先备份
一开始购买的开发板是 Android 系统的,将拨码开关调到 SD 启动模式下。按POWER按钮,备份一份在 SecureCRT 下查看的启动信息。
U-Boot 1.3.4-dirty (May 21 2016 - 18:17:00) for x210
CPU: S5PV210@1000MHz(OK)
APLL = 1000MHz, HclkMsys = 200MHz, PclkMsys = 100MHz
MPLL = 667MHz, EPLL = 96MHz
HclkDsys = 166MHz, PclkDsys = 83MHz
HclkPsys = 133MHz, PclkPsys = 66MHz
SCLKA2M = 200MHz
Serial = CLKUART
Board: X210
DRAM: 512 MB
Flash: 8 MB
SD/MMC: 3776MB
*** Warning - using default environment
In: serial
Out: serial
Err: serial
[LEFT UP] boot mode
checking mode for fastboot ...
Hit any key to stop autoboot: 0
reading kernel.. 1073, 8192
MMC read: dev # 0, block # 1073, count 8192 ...8192 blocks read: OK
completed
reading RFS.. 9265, 6144
MMC read: dev # 0, block # 9265, count 6144 ...6144 blocks read: OK
completed
Boot with zImage
get_format
-------- 0 --------
Wrong Ramdisk Image Format
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Initializing cgroup subsys cpu
Linux version 3.0.8 (lqm@lqm) (gcc version 4.4.1 (Sourcery G++ Lite 2009q3-67) ) #49 PREEMPT Tue Mar 22 19:35:49 CST 2016
CPU: ARMv7 Processor [412fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: X210
Ignoring unrecognised tag 0x41001099
Memory policy: ECC disabled, Data cache writeback
CPU S5PV210/S5PC110 (id 0x43110220)
S3C24XX Clocks, Copyright 2004 Simtec Electronics
S5PV210: PLL settings, A=1000000000, M=667000000, E=96000000 V=54000000
S5PV210: ARMCLK=1000000000, HCLKM=200000000, HCLKD=166750000
HCLKP=133400000, PCLKM=100000000, PCLKD=83375000, PCLKP=66700000
sclk_dmc: source is sclk_a2m (0), rate is 200000000
sclk_onenand: source is hclk_psys (0), rate is 66700000
uclk1: source is mout_mpll (6), rate is 66700000
sclk_mixer: source is sclk_dac (0), rate is 24000000
sclk_fimc: source is ext_xtal (0), rate is 24000000
sclk_cam0: source is xusbxti (1), rate is 12000000
sclk_cam1: source is ext_xtal (0), rate is 12000000
sclk_fimd: source is ext_xtal (0), rate is 24000000
sclk_mmc: source is mout_mpll (6), rate is 47642857
sclk_mmc: source is mout_epll (7), rate is 96000000
sclk_mfc: source is sclk_a2m (0), rate is 200000000
sclk_g2d: source is sclk_a2m (0), rate is 200000000
sclk_g3d: source is sclk_a2m (0), rate is 100000000
sclk_csis: source is ext_xtal (0), rate is 24000000
sclk_spi: source is ext_xtal (0), rate is 24000000
sclk_pwi: source is ext_xtal (0), rate is 24000000
sclk_pwm: source is ext_xtal (0), rate is 24000000
s5p: 37748736 bytes system memory reserved for mfc at 0x3dc00000, 0-bank base(0x3dc00000)
s5p: 37748736 bytes system memory reserved for mfc at 0x4dbf5000, 1-bank base(0x4dbf5000)
s5p: 25165824 bytes system memory reserved for fimc0 at 0x4c3f5000, 1-bank base(0x4c3f5000)
s5p: 10137600 bytes system memory reserved for fimc1 at 0x4ba4a000, 1-bank base(0x4ba4a000)
s5p: 6291456 bytes system memory reserved for fimc2 at 0x4b44a000, 1-bank base(0x4b44a000)
s5p: 25165824 bytes system memory reserved for jpeg at 0x3c400000, 0-bank base(0x3c400000)
s5p: 12288000 bytes system memory reserved for fimd at 0x4a892000, 1-bank base(0x4a892000)
s5p: 1843200 bytes system memory reserved for pmem_gpu1 at 0x3c23e000, 0-bank base(0x3c23e000)
s5p: 8388608 bytes system memory reserved for g2d at 0x3ba3e000, 0-bank base(0x3ba3e000)
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 89819
Kernel command line: console=ttySAC2,115200
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 186MB 168MB 0MB = 354MB total
Memory: 350232k/511148k available, 13140k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xff000000 - 0xffe00000 ( 14 MB)
vmalloc : 0xe0800000 - 0xfd000000 ( 456 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.init : 0xc0008000 - 0xc0079000 ( 452 kB)
.text : 0xc0079000 - 0xc06cf6c0 (6490 kB)
.data : 0xc06d0000 - 0xc0719900 ( 295 kB)
.bss : 0xc0719924 - 0xc085a250 (1283 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Preemptible hierarchical RCU implementation.
NR_IRQS:208
VIC @fd000000: id 0x00041192, vendor 0x41
VIC @fd010000: id 0x00041192, vendor 0x41
VIC @fd020000: id 0x00041192, vendor 0x41
VIC @fd030000: id 0x00041192, vendor 0x41
mult[140737]
max_delta_ns[2937815369]
min_delta_ns[30517]
rate[32768]
HZ[200]
Console: colour dummy device 80x30
Calibrating delay loop... 992.87 BogoMIPS (lpj=2482176)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
Initializing cgroup subsys debug
Initializing cgroup subsys cpuacct
Initializing cgroup subsys freezer
CPU: Testing write buffer coherency: ok
print_constraints: dummy:
NET: Registered protocol family 16
S3C Power Management, Copyright 2004 Simtec Electronics
pmstats at 00000000
pmem_start is 0x0
---pmem_start is 0x4a892000
Open OV2655 camema sensor
smdkc110_setup_clocks: sclk_mmc: source is mout_mpll, rate is 47642857
S5PV210: Initializing architecture
s3c-adc s5pv210-adc: attached adc driver
s3c24xx-pwm s3c24xx-pwm.0: tin at 66700000, tdiv at 66700000, tin=divclk, base 0
print_constraints: pd_tv_supply: 5000 mV normal
print_constraints: pd_lcd_supply: 5000 mV normal
print_constraints: pd_g3d_supply: 5000 mV normal
print_constraints: pd_mfc_supply: 5000 mV normal
print_constraints: pd_audio_supply: 5000 mV normal
print_constraints: pd_cam_supply: 5000 mV normal
bio: create slab print_constraints: B_PWR_5V: 5000 mV SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb s3c-i2c s3c2440-i2c.0: slave address 0x10 s3c-i2c s3c2440-i2c.0: bus frequency set to 43 KHz s3c-i2c s3c2440-i2c.0: i2c-0: S3C I2C adapter s3c-i2c s3c2440-i2c.1: slave address 0x10 s3c-i2c s3c2440-i2c.1: bus frequency set to 65 KHz s3c-i2c s3c2440-i2c.1: i2c-1: S3C I2C adapter s3c-i2c s3c2440-i2c.2: slave address 0x10 s3c-i2c s3c2440-i2c.2: bus frequency set to 65 KHz machine_constraints_voltage: VALIVE_1.1V: failed to apply 1100000uV constraint (NULL device *): regulator init failed s3c-i2c s3c2440-i2c.2: i2c-2: S3C I2C adapter Advanced Linux Sound Architecture Driver Version 1.0.24. cfg80211: Calling CRDA to update world regulatory domain Switching to clocksource clock_source_systimer Switched to NOHz mode on CPU #0 NET: Registered protocol family 2 IP route cache hash table entries: 4096 (order: 2, 16384 bytes) TCP established hash table entries: 16384 (order: 5, 131072 bytes) TCP bind hash table entries: 16384 (order: 6, 327680 bytes) TCP: Hash tables configured (established 16384 bind 16384) TCP reno registered UDP hash table entries: 256 (order: 1, 12288 bytes) UDP-Lite hash table entries: 256 (order: 1, 12288 bytes) NET: Registered protocol family 1 PMU: registered new PMU device of type 0 input: s3c-button as /devices/virtual/input/input0 s3c button Initialized!! Loaded driver for PL330 DMAC-0 s3c-pl330 DBUFF-64x8bytes Num_Chans-8 Num_Peri-2 Num_Events-32 Loaded driver for PL330 DMAC-1 s3c-pl330 DBUFF-8x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32 Loaded driver for PL330 DMAC-2 s3c-pl330 DBUFF-8x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32 ashmem: initialized NTFS driver 2.1.30 [Flags: R/O]. ROMFS MTD (C) 2007 Red Hat, Inc. yaffs: yaffs built Jan 18 2016 11:34:32 Installing. msgmni has been set to 684 io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) start plist test end plist test win->id=2, pmem_start=0x4af9a000 s3cfb s3cfb: [fb2] dma: 0x4af9a000, cpu: 0xe1000000, size: 0x004b0000 FIMD src sclk = 166750000 s3cfb s3cfb: registered successfully Start display and show logo s5pv210-uart.0: ttySAC0 at MMIO 0xe2900000 (irq = 16) is a S3C6400/10 s5pv210-uart.1: ttySAC1 at MMIO 0xe2900400 (irq = 20) is a S3C6400/10 s5pv210-uart.2: ttySAC2 at MMIO 0xe2900800 (irq = 24) is a S3C6400/10 console [ttySAC2] enabled s5pv210-uart.3: ttySAC3 at MMIO 0xe2900c00 (irq = 28) is a S3C6400/10 x210 led driver Initial GSensor Driver input: gsensor as /devices/virtual/input/input1 gsensor's ID: 0x01 Found Gsensor hardware i2c-core: driver [gsensor-iic] using legacy suspend method i2c-core: driver [gsensor-iic] using legacy resume method PA FB = 0x4AF9A000, bits per pixel = 32 screen width=1024 height=600 va=0xdaf9a000 pa=0x4af9a000 xres_virtual = 1024, yres_virtual = 1200, xoffset = 0, yoffset = 0 fb_size=4915200 Back frameBuffer[0].VAddr=db1f2000 PAddr=4b1f2000 size=2457600 brd: module loaded loop: module loaded S3C NAND Driver, (c) 2008 Samsung Electronics Unknown NAND Device. PPP generic driver version 2.4.2 PPP Deflate Compression module registered
该电路图的目的是分析对输入信号进行分类,然后输出,对输出脉冲进行计数的功能。 此电路图只对信号分类。 可是我还不能很理解。 请求给予帮住。 [ 本帖最后由 阳光如烟 于 2008-8-25 17:34 编辑 ]… 查看全部问答> |
呵呵,那位坛友手中有多余一套LM3S8962开发板,或者闲着不用的,砸个过来 坛友们,您们谁有多余的或者不用的,有偿转让一下呵呵,本人近期有时间想认真学习一下,谢谢啦嘿嘿 本人的QQ是282574314,嘿嘿或者想学STM32的互换一下。… 查看全部问答> |
有谁使用过了vxworks6.6及其开发workbench的,一起来分享啊。 我先自己说下自己的使用后的感受吧,vxworks6.6的系统启动代码和5.5区别还是很大,而对与新的平台的使用我用的也不是很爽,之中遇到了很多的问题。 哎~ 又要开始一个新的痛苦的学习过 ...… 查看全部问答> |
我打算通过扩展定时器的方法测出多路PWM信号的占空比,利用GATE门控位,当GATE低电平的时候读取外部定时器8253计数器的值。可是我怎么也读不出来值,当我使RD位有效时,读的计数器的值也总是不变是个固定值,大家看看我的程序有什么问题??怎么改 ...… 查看全部问答> |
用51板做东西的时候,AD转换芯片用的是ICL7135(双积分AD转换芯片)。我看见一些资料上面写着 用计数器对积分阶段进行计数,最后得到的计数减去1001就是AD的转换结果。 我有一点不明白:计数器的结果-1001就直接是AD 转换的数字结果 ...… 查看全部问答> |
【TI首届低功耗设计大赛】+@fxyc87+CCS编译环境初识+第一课 点亮LED 【TI首届低功耗设计大赛】+@fxyc87+CCS编译环境初识+第一课 点亮LED在论坛搜索 【TI首届低功耗设计大赛】+@fxyc87+ 上一次发布了开发板的秀,https://bbs.eeworld.com.cn/thread-446740-1-1.html 以及IAR编译环境的使用说明及点亮LED,见贴[url]h ...… 查看全部问答> |
