今天是:2024年10月18日(星期五)
2019年10月18日 | PIC16C74单片机SPI方式读写串行EEPROM程序
2019-10-18 来源:eefocus
; list p=16C74, st=off
; PORTC PIN DESCRIPTION
; SCK bit 3, SDI bit 4, SDO bit 5, CS bit 7
; Fosc = 10.0 MHz, thus each instr. cycle = 400ns
;***************Ram Register Definitions*******************************
rxdata equ 25h
addr equ 26h
loops equ 27h
;***************Bit Definitions****************************************
;#define CS PORTC,7 ; SPI chip select bit definition
;***************25Cxxx command definitions
;#define WREN 6 ;write enable latch
;#define WRDI 4 ;reset the write enable latch
;#define RDSR 5 ;read status register
;#define WRSR 1 ;write status register
;#define READ 3 ;read data from memory
;#define WRITE 2 ;write data to memory
; Bit defines within status register
;#define WIP 0 ;write in progress
;#define WEL 1 ;write enable latch
;#define BP0 2 ;block protection bit
;#define BP1 3 ;block protection bit
; include "p16c74.inc" ; 16C74 include file
; __CONFIG _WDT_OFF & _CP_OFF & _HS_OSC & _PWRTE_ON
page
org 0000 ; Reset Vector
clrf PCLATH ; ensure PCLATH bit 3 is cleared
clrf INTCON ; ensure all interrupts are disabled
goto start ; jump to the beginning of the program
org 004 ; interrupt vector, do nothing
isr: goto isr ; do nothing, location just
; identified in code
;***************BEGIN MAIN PROGRAM*************************************
start: bcf STATUS,5 ; need to set bank 0
clrf PORTC ; initialize port c
bsf CS ; make sure cs is set
bsf STATUS,5 ; need to set bank 1
movlw 0x10 ; all bits are outputs except SDI
movwf TRISC ; for SPI setup
bcf STATUS,RP0 ; need to set bank 0
movlw 0x31 ; SPI master, clk/16, ckp=1
movwf SSPCON ; SSPEN enabled
movlw 0x10 ; *** put beginning address in addr**
movwf addr ; for later use
loop
;The first thing we will do is the WREN
call wren ; call the write enable routine
;Next write status reg. to clear the block protect bits
call wrsr ; call the write status routine
;Next do a busy test
call busy_test ; test WIP bit in status register
;Then do the WREN before writing to the array
call wren ; call the write enable command
;Next write 0xA5 (or any other value) to 0x10
bcf CS ; set chip select line low
movlw WRITE ; WRITE control byte
call output ; call the output subroutine
movlw b'00000000' ; high addr byte is all 0's
movf addr,w ; low addr byte
movlw b'10100101' ; load 0xA5 as data to be sent out
bcf SSPCON,CKP ; set clock idle low, mode 0,1
bsf CS ; set chip select, begin write cycle
bsf SSPCON,CKP ; set clock idle high, mode 1,1
call busy_test
call rdsr ; call the read status subroutine
;Now, read location 0x10h and store in rxdata. With Picmaster a
;user can break, read that memory location to see if the read worked
movlw READ ; READ control byte
movf addr,w ; get ready to send next byte
movlw b'01011010' ; move don't care byte of 0x5A into
bsf CS ; bring chip select high end
; terminate read command
;While program is continuously looping, the user may halt (if using an
;emulator), and look at the data in rxdata. If it is 0xA5, the
;read/write worked.
call wait ; little delay between SPI sequence
goto loop ; do it all over again
; loop can be used to evaluate SPI
; signals on oscilloscope
;********************* BEGIN SUBROUTINES*******************************
;*** DELAY ROUTINE - 400uS ***
wait movlw .200 ; timing adjustment variable
movwf loops ; move variable into loops
top nop ; sit and wait
nop ; no operation
decfsz loops,f ; loop complete?
goto top ; no, go again
return ; yes, return from sub
;****** This is the OUTPUT transmit/receive subroutine. ***************
output movwf SSPBUF ; place data in buffer to send
loop1 bsf STATUS,RP0 ; specify bank 1
btfss SSPSTAT,BF ; has data been received (xmit done)?
goto loop1 ; not done yet, keep trying
bcf STATUS,RP0 ; specify bank 0
movf SSPBUF,W ; empty receive buffer
movwf rxdata ; put received byte into rxdata
return ; return from subroutine
;*******Write Enable Subroutine****************************************
wren bcf CS ; set chip select line low
movlw WREN ; WREN control byte
call output ; Call the output subroutine
;*******Read Status Register Subroutine********************************
rdsr movlw RDSR ; RDSR control byte
movlw b'00000101' ; this byte is a don't care byte
call output ; status reg data will be in rxdata
;*******Write Status Register Subroutine*******************************
wrsr bcf CS ; set chip select line low
movlw WRSR ; WRSR control byte
movlw b'00001000' ; set BP1 bit in status register
call output ; this will clear block protect bits
;*******Busy Test - WIP bit in Status Register*************************
busy_test
movlw b'00000000' ; send dummy byte
call output ; to initiate clock sequence for read
bsf CS ; else, set chip select high
btfsc rxdata,WIP ; test WIP bit read from status register
goto busy_test ; repeat busy test
end
上一篇:PIC单片机定时器中断源程序
我编译时提示 LInker not found C:\\Silabs...\\BIN\\bi51.exe是怎么回事,是我的软件没有装好吗? 可是我卸载了又装了还是这样 怎么回事刚开始用不懂 谢谢了… 查看全部问答> |
下图是STM32F10xx时钟系统的框图,通过这个图可以一目了然地看到各个部件时钟产生的路径,还可以很方便地计算出各部分的时钟频率。STM32的四个时钟源(HSI、HSE、LSI和LSE)也在图中标出;图中间的时钟监视系统(CSS)是在很多ST7的单片机中就出现 ...… 查看全部问答> |
我是一个菜鸟,目前有任务利用MSP430F1611制作一个函数发生器,信号最后经DAC12输出,函数波形方波,正弦波,三角波等,频率要求不高200Hz以下,请问各位高手应如何入手,有什么思路,小弟在此谢谢了。… 查看全部问答> |
玩这块板子,涵盖的知识太过广泛,刚开始熟悉大概流程,试过几个例子之后。觉得就那样,都是别人写好的代码,自己移植过去,自己想要一个深刻的理解,所以看了一些另外的一些协议之类的东西,也没着急弄这个东西,看了这么长时间后, ...… 查看全部问答> |
市面上售有各种类型的稳压器,但很难选择一款直流/直流稳压器。大多数汽车应用都要求在整个负载范围内保持高效率,因为它们一直在耗电。但话又说回来,许多工业应用在高负载时需要高效率,而在轻负载时,效率并不是很重要。因此必须了解直流/直流稳 ...… 查看全部问答> |
