今天是:2024年10月18日(星期五)
2019年10月18日 | 用PIC12C509单片机控制LED
2019-10-18 来源:eefocus
PIC12C509 - Getting Around the Stack Limitation
The 12C5 series PIC has only a two level stack which limits the number of nested subroutine calls to two. This may be a very serious limitation.
(The 16C84 has an eight level stack which permits nested subroutines to eight deep. I can't imagine a program where this will not be sufficient).
In the following programs an alternative user stack is presented which provides the programmer with alternative "call" and "return" capability.
Note that a user stack is implemented using the highest data address. The idea is that the user stack grows down from 1FH, while user variables are assigned from 07H and up. Thus, the degree of nesting permitted using this approach is the full variable space (25) less the number of bytes which are used as variables in the program.
There are two other limitations to this approach;
1. Only the low byte of the program counter is saved on the user stack. Thus, this limits the calling of all functions and the implementation of the functions to the same page.
However, this does not preclude one from splitting a program over several pages and implementing each called function on each page. Of course, the same implementation of functions on different pages must have different names. That is, one must be careful and think. But with the price of the 12C5XX declining to a mere $1.00 it pays to think!
This approach of splitting a program is shown in another discussion dealing with the I2C bus.
2. The FSR is used as the user defined stack pointer. Thus, if the FSR register is used elsewhere, one must be careful to save the user stack pointer in a temporary variable when using the FSR for other applications and of course, restoring it to the FSR when calls and returns are made using this approach.
Please refer to program STACK_1.ASM which continually flashes an LED on and off. Note that the main calls routines SUB1, DELAY, SUB2 and DELAY and then loops back to repeat the process.
The FSR register is intialized to the highest data location, 01FH.
Each "call" consists of the following instructions.
MOVF PCL, W ; fetch PCL to W
ADDWF OFFSET, W ; add 4
MOVWF INDF ; save to location pointed to by FSR
DECF FSR, F ; for next subroutine
GOTO SUB1 ; turn LED on
RET_POINT1:
;... continuation of program
In the above, note that the current content of the low byte of the program counter is fetched. The address to return to (RET_POINT1) is calculated by adding 4 and this is saved to the location pointed to by the user stack pointer. The stack pointer is then decremented to accommodate the next return address. Finally, a jump to the function is executed.
In the subroutine, the task is first performed. The "return" is then implemented using the following code.
; task performed
INCF FSR, F ; return
MOVF INDF, W
MOVWF PCL
In the above, the user stack pointer is incremented so as to point to the location containing the value of the program counter which was stored in the calling routine. This is fetched and placed in the low byte of the program counter. Thus, execution continues at the return point in the calling routine.
; STACK_1.ASM (12C509)
; Illustrates how to use user stack to implement "calls" and "returns".
; This is particularly important on the 12C509 as to stack is limited to
; two levels.
; Flashes LED on GPIO0, 250 ms on and 250 ms off.
LIST p=12c509
#include __CONFIG 1AH LOOP1 EQU 07H ; for timing loops LOOP2 EQU 08H OFFSET EQU 09H ORG 000H MOVLW 1FH ; intitialize FSR to point to top of "stack" MOVWF FSR MOVLW .4 MOVWF OFFSET ; offset initialized to 4 MOVLW 1EH ; least sign bit is an output TRIS GPIO TOP: ; save return address on stack MOVF PCL, W ; fetch PCL, add 4 and save at location ADDWF OFFSET, W ; pointed to by FSR MOVWF INDF DECF FSR, F ; dec stack pointer for next subroutine GOTO SUB1 ; turn LED on MOVF PCL, W ADDWF OFFSET, W MOVWF INDF DECF FSR, F GOTO DELAY ; 250 ms delay MOVF PCL, W ADDWF OFFSET, W MOVWF INDF DECF FSR, F GOTO SUB2 ; turn LED off MOVF PCL, W ADDWF OFFSET, W MOVWF INDF DECF FSR, F GOTO DELAY ; 250 ms delay GOTO TOP SUB1: BCF GPIO, 0 ; logic zero turns LED on ; these three lines are the equiv of a return INCF FSR, F ; increment FSR MOVF INDF, W ; get return address MOVWF PCL ; and put in program counter SUB2: BSF GPIO, 0 ; logic one turns LED off INCF FSR, F ; return MOVF INDF, W MOVWF PCL DELAY: ; when running set LOOP1 to .250 and LOOP2 to .110. ; this will result in 250 ms delay. MOVLW .250 MOVWF LOOP1 OUTTER: MOVLW .110 ; close to 1.0 msec delay when set to .110 MOVWF LOOP2 INNER: NOP NOP DECFSZ LOOP2, F ; decrement and leave result in LOOP2 ; skip next statement if zero GOTO INNER DECFSZ LOOP1, F GOTO OUTTER INCF FSR, F ; return MOVF INDF, W MOVWF PCL END In program STACK_2.ASM, the "calls" and "returns" are implemented using macros which have been labelled as GOSUB and RET. Note that macros make the program considerably more understandable. ; STACK_2.ASM. ; ; Same as STACK_1.ASM except implemented using macros. ; ; coyright, Peter H. Anderson, MSU, June 1, '97 LIST p=12c509 #include __CONFIG 1AH ; Macros defined GOSUB MACRO arg1 ; uses user defined stack to save return address MOVF PCL, W ; and jumps to specified routine. ADDWF OFFSET, W MOVWF INDF DECF FSR, F GOTO arg1 ENDM RET MACRO ; fetches return address from stack INCF FSR, F MOVF INDF, W MOVWF PCL ENDM LOOP1 EQU 0CH ; for timing loops LOOP2 EQU 0DH OFFSET EQU 0EH ORG 000H MOVLW 1FH ; intitialize FSR to point to top of "stack" MOVWF FSR MOVLW .4 MOVWF OFFSET ; intialize OFFSET to 4 MOVLW 1EH TRIS GPIO ; least sign bit is defined as output TOP: GOSUB SUB1 GOSUB DELAY GOSUB SUB2 GOSUB DELAY GOTO TOP SUB1: BCF GPIO, 0 RET SUB2: BSF GPIO, 0 RET DELAY: ; when running set LOOP1 to .250 and LOOP2 to .110. ; this will result in 250 ms delay. MOVLW .250 MOVWF LOOP1 OUTTER: MOVLW .110 ; close to 1.0 msec delay when set to .110 MOVWF LOOP2 INNER: NOP NOP DECFSZ LOOP2, F ; decrement and leave result in LOOP2 ; skip next statement if zero GOTO INNER DECFSZ LOOP1, F GOTO OUTTER RET END
理想、激情、生存—— 一位技术管理人员的20年工作经历和感悟 我是一个有10年电子产品研发经验的工程师和10年IT知名公司研发中心管理经验的技术管理者。世上好的管理理念可能归纳起来就那么1~2百条,也都好理解,难的是怎么适当地运用在特定的环境中。下面的文章共18篇,是我20年工作中的片段,也是我在研发及 ...… 查看全部问答> |
中国科学院光电技术研究所2010年招聘 根据目前光电所学科领域与科研项目发展的需要,现将2010年招聘岗位公布如下(详情请查看中科院光电所网站http://www.ioe.ac.cn,各类岗位将根据招聘进展情况随时进行调整):一、 招聘岗位招聘对象:国家重点 ...… 查看全部问答> |
1、 报警系统由哪几部分组成? 简单的报警系统由前端探测器、中间传输部分和报警主机组成。大一些的系统也可将探测器和报警主机看做是前端部分,从报警主机到接警机之间是传输部分,中心接警部分看做是后端部分。 2、 报警系统按信息传输方式 ...… 查看全部问答> |
好消息无线手表开发工具(售价仅24.50 美元), 介绍TI Deals !购买 TI折扣优惠工具及套件的全新方式!8 月 16 日,德州仪器推出 TI Deals 网站,设计人员有机会购买大额折扣的易用型开发工具及套件。现正5 折优惠销售 eZ430-Chronos 无线手 ...… 查看全部问答> |
