今天是:2024年10月21日(星期一)
2019年10月21日 | 以C语言完成读写24LCxx系列的EEPROM的实例
2019-10-21 来源:eefocus
//* Using I2C Master Mode for access Slave (EEPRM)
//* Written by: Richard Yang
//* Sr. Corporate Application Engineer
//* Microchip Technology Inc.
//* Date: Oct. 3nd '2002
//* Revision: 1.00
//* Language tools : MPLAB-C18 v2.09.13
//* MPLINK v3.10
//* MPLAB-IDE v6.00.17 & ICD2
/* Include Header files */
#include #include #include #include "P18LCD.h" // Load P18LCD Header file form current working direct /* Declare the Function Prototype */ void Initialize_I2C_Master(void); void EE_Page_Write(unsigned char,unsigned char,unsigned char,unsigned char *); void EE_SEQU_Read(unsigned char,unsigned char,unsigned char,unsigned char *); void EEPROM_Write(unsigned char,unsigned char,unsigned char); void EEPROM_ACK(unsigned char); unsigned char EEPROM_Read(unsigned char,unsigned char); void I2C_Done(void); void Initialize_Timer2(void); void isr_high_direct(void); void isr_high(void); #pragma romdata My_romdata=0x1000 const rom far unsigned char LCD_MSG1[]="SW2: Byte Write "; const rom far unsigned char LCD_MSG2[]="SW6: Random Read"; const rom far unsigned char LCD_MSG3[]="Byte Write Mode "; const rom far unsigned char LCD_MSG4[]="Random Read Mode"; const rom far unsigned char LCD_MSG5[]="Sended: "; const rom far unsigned char LCD_MSG6[]="Send: "; const rom unsigned char I2C_Write_Buffer[]="Microchip Technology"; #pragma romdata /* Define following array in data memory */ unsigned char I2C_Read_Buffer [32]; /* define following variable in data memory at Access Bank */ #pragma udata access My_RAM near unsigned char Debounce; near unsigned char Send_Addr; near unsigned char Send_Data; near unsigned char Send_Length; near unsigned char Read_Data; near unsigned char P_SW2; near unsigned char P_SW6; #pragma udata #define Page_Length 8 #define SW2 PORTAbits.RA4 #define SW6 PORTEbits.RE1 #define Bounce_Time 6 #define EE_CMD 0xA0 //*********************************************************** /* */ /* Main Program */ /* */ //*********************************************************** void main(void) { ADCON1=0b00000110; // Disable A/D Function TRISAbits.TRISA4=1; // Set SW2 for input TRISEbits.TRISE1=1; // Set SW6 for Input Initialize_Timer2( ); Initialize_I2C_Master( ); OpenLCD( ); if (SW2 & SW6)Debounce=0; else Debounce = Bounce_Time; while(1) { LCD_Set_Cursor(0,0); // Put LCD Cursor on (0,0) putrsLCD(LCD_MSG1); LCD_Set_Cursor(1,0); // Put LCD Cursor on (1,0) putrsLCD(LCD_MSG2); P_SW2=P_SW6=0; Send_Addr=0; while(1) { if (P_SW2) { P_SW2=0; Debounce = Bounce_Time; LCD_Set_Cursor(0,0); // Put LCD Cursor on (0,0) putrsLCD(LCD_MSG3); LCD_Set_Cursor(1,0); // Put LCD Cursor on (0,0) putrsLCD(LCD_MSG5); do { while (!P_SW2); P_SW2=0; LCD_Set_Cursor(1,8); Send_Data=I2C_Write_Buffer[Send_Addr]; EEPROM_Write(EE_CMD,Send_Addr,Send_Data); puthexLCD(EE_CMD); putcLCD(' '); puthexLCD(Send_Addr); putcLCD(' '); puthexLCD(Send_Data); EEPROM_ACK(EE_CMD); Send_Addr++; } while (I2C_Write_Buffer[Send_Addr]!=0x00); break; } if (P_SW6) { P_SW6=0; Debounce = Bounce_Time; LCD_Set_Cursor(0,0); // Put LCD Cursor on (0,0) putrsLCD(LCD_MSG4); LCD_Set_Cursor(1,0); // Put LCD Cursor on (0,0) putrsLCD(LCD_MSG6); while(1) { if (P_SW6) { P_SW6=0; LCD_Set_Cursor(1,5); Read_Data = EEPROM_Read(EE_CMD,Send_Addr); puthexLCD(EE_CMD); putcLCD(' '); puthexLCD(Send_Addr); putcLCD(' '); puthexLCD(EE_CMD); putcLCD(' '); puthexLCD(Read_Data); Send_Addr++; } if (P_SW2) break; } if (P_SW2) break; } if (P_SW2) { P_SW2=0; break; } } } } //************************************************ //* #pragma Interrupt Declarations * //* * //* Function: isr_high_direct * //* - Direct execution to the actual * //* high-priority interrupt code. * //************************************************ #pragma code isrhighcode = 0x0008 void isr_high_direct(void) { _asm //begin in-line assembly goto isr_high //go to isr_high function _endasm //end in-line assembly } #pragma code //************************************************ //* Function: isr_high(void) * //* High priority interrupt for Timer2 * //************************************************ #pragma interrupt isr_high void isr_high(void) { PIR1bits.TMR2IF=0; // Clear Timer2 interrupt Flag if (Debounce==0) { if (!SW2) { P_SW2=1; Debounce =Bounce_Time; } if (!SW6) { P_SW6=1; Debounce =Bounce_Time; } } else if (SW2 & SW6)Debounce--; else Debounce =Bounce_Time; } #pragma code //*********************************************** //* Write a Byte to EEPROM //* - ctrl : Control Byte of EEPROM //* - addr : Location of EEPROM //* - data : Data Byte of EEPROM //*********************************************** void Initialize_Timer2(void) { RCONbits.IPEN=1; // Enable Interrupt Priority bit IPR1bits.TMR2IP=1; // Set Timer2 for High Priority INTCONbits.GIEH=1; // Enable High Priority Interrupt OpenTimer2 (TIMER_INT_ON // Turn On the Timer2 with Interrupt & T2_PS_1_4 // (4Mhz/4) [4*10*(99+1)] = 4mS */ & T2_POST_1_10); PR2 = 99; } //*********************************************** //* Write a Byte to EEPROM * //* - ctrl : Control Byte of EEPROM * //* - addr : Location of EEPROM * //* - data : Data Byte of EEPROM * //*********************************************** void EEPROM_Write(unsigned char ctrl,unsigned char addr,unsigned char data) { IdleI2C(); // ensure module is idle StartI2C(); // Start condition I2C_Done(); // Wait Start condition completed and clear SSPIF flag WriteI2C(ctrl); // Write Control+Write to EEPROM & Check BF flag while(SSPCON2bits.ACKSTAT); // wait until received the Acknowledge from EEPROM I2C_Done(); // Clear SSPIF flag WriteI2C(addr); // Write Address to EEPROM while(SSPCON2bits.ACKSTAT); // wait until received the Acknowledge from EEPROM I2C_Done(); WriteI2C(data); // Write Data to EEPROM while(SSPCON2bits.ACKSTAT); // wait until received the Acknowledge from EEPROM I2C_Done(); StopI2C(); // Stop condition I2C_Done(); // Wait the Stop condition completed } //*********************************************** //* Pae Write to EEPROM //* //* - ctrl : Control Byte of EEPROM //* - addr : Location of EEPROM //* - length : Write counter //* - *dptr : RAM point --> EEPROM //* //*********************************************** void EE_Page_Write(unsigned char ctrl,unsigned char addr,unsigned char length,unsigned char *dptr) { IdleI2C(); // ensure module is idle StartI2C(); // Start condition I2C_Done(); // Wait Start condition completed WriteI2C(ctrl); // Write Control+Write to EEPROM & Check BF flag while(SSPCON2bits.ACKSTAT); // wait until received the Acknowledge from EEPROM I2C_Done(); // Clear SSPIF flag WriteI2C(addr); // Write Address to EEPROM while(SSPCON2bits.ACKSTAT); // wait until received the Acknowledge from EEPROM I2C_Done(); while (length!=0) // Check write completed ? { WriteI2C(*dptr); // Write data to EEPROM while(SSPCON2bits.ACKSTAT); // wait until received the Acknowledge from EEPROM I2C_Done(); dptr++; // Point to next byte length--; } StopI2C(); // Stop condition I2C_Done(); // Wait the Stop condition completed } //*********************************************** //* EEPROM Acknowledge Polling * //* -- The routine will polling the ACK * //* response from EEPROM * //* -- ACK=0 return * //* -- ACK=1 send Restart & loop check * //*********************************************** void EEPROM_ACK(unsigned char ctrl)
今天做实验,本来我的驱动板能驱动3.8V 650ma的电流; 给1W的LED(3.3v350ma)的通电,长时间后,虽然电压 没有多大的变化3。8+-0.1V;LED的电流就开始乱跳 , 为470MA-520ma;再也升不到650,这是为何原因;我这个 驱动其实是为1*3W的灯做的驱 ...… 查看全部问答> |
我在我的开发板上运行CE5.0的SMDK2410(flash读写已经修改了) EBoot,运行到OEMPreDownload函数时 打印调试信息发现始终没运行到EbootInitEtherTransport这个函数中 请高人指点一下啊??… 查看全部问答> |
/*----------------------------------------------------------------------- STM32菜鸟之IAR环境下的C++演示程序包本程序主要是IAR环境下C++工程的建立,LED/LCD显示及按钮/操作杆的中断.从 ...… 查看全部问答> |
谁知道C2000 Launchpad几个拨键做用吗。关于工程建立,谁能出个视频呀。 谁知道C2000 Launchpad几个拨键做用吗。关于工程建立,谁能出个视频呀。初学者很痛苦!论坛建工程方式试了不下5次,但还是有错误啊啊!能出个详细视频就好啦!谢谢啦!… 查看全部问答> |
