今天是:2024年11月15日(星期五)
2019年11月15日 | PIC18f4520单片机驱动H1632的C语言程序
2019-11-15 来源:51hei
#include
#include
//#pragma config OSC = HS //配置内部振荡器Fosc/4 RA7,IO口RA7
//#pragma config PWRT =OFF
//#pragma config BOREN = OFF
//#pragma config WDT = OFF
//#pragma config MCLRE = ON
//#pragma config PBADEN = OFF
//#pragma config LVP = OFF
#define CLK PORTCbits.RC3
#define DAT PORTCbits.RC5
#define CS1 PORTDbits.RD0
//#define CS1 PORTCbits.RC0
//#define CS2 PORTDbits.RD1
//#define CS3 PORTDbits.RD2
//#define CS4 PORTDbits.RD3
#define KEY PORTBbits.RB0
//#define KEY PORTAbits.RA4
void init_command(unsigned int command_data); /
nd commad data to HT1632
void set2416(void);
//initialize HT1632
void MCU_Data_0832(unsigned char Data1,unsigned char Data2); /
nd 16 bits
data to HT1632 once
void MCU_Address_2416(unsigned char address); /
nd address to 1632's RAM
void senddata1(void); /
nd data to HT1632(1st screen)to display information
void delay(void);
void KeyJudgement(void);
unsigned char KeyLast,KeyNow;//Record the state of key
unsigned char KeyCounter;
KeyNow=KEY;
if((KeyNow==0)&&(KeyLast==1))
Delay100TCYx(10);//Delay 2ms
KeyNow=KEY;
if(KeyNow==0)
KeyCounter++;
if(KeyCounter==6)
KeyCounter=0;
KeyLast=KeyNow;
void delay(void)
unsigned char i,j;
for(i=0;i<200;i++)
j++;
unsigned int i,j;
command_data=command_data&0xfff;
command_data=command_data<<4;
CS1=1;
CS1=0;
for(i=0;i<12;i++)
CLK=0;
j=command_data&0x8000;
command_data=command_data<<1;
j=j>>15;
DAT=j;
CLK=1;
CS1=1;
//CS2=1;
//CS3=1;
//CS4=1;
void set2416(void)
//sys en
init_command(0b100000000010);
//led on
init_command(0b100000000110);
//blink on
// init_command(0b100000010010);
//master mode
init_command(0b100000101110);
//RC
init_command(0b100000110110);
//commons option
//init_command(0b100001011110);//2416
init_command(0b100001010110);//0832
//pwm duty
init_command(0b100101111110);
unsigned char i,j,databuffer;
for(j=0;j<4;j++)
databuffer=Data1;
for(i=0 ; i<8 ; i++)
CLK=0; //clk = 0 for data ready
if(databuffer & 0x80)
DAT=1;
else
DAT=0;
CLK=1; //clk = 1 for data write into 2
databuffer=databuffer<<1;
databuffer=Data2;
DAT=1;
else
DAT=0;
unsigned char i,temp;
temp = 0x40; //address has 7 bits. MSB fisrt
for(i=0;i<7;i++)
CLK= 0; //clk = 0 for data ready
if((temp & address) == 0)
DAT= 0;
else
DAT= 1;
CLK= 1; //clk = 1 for data write into
1632
temp >>= 1;
unsigned char i,data1,data2;
CS1=1;
delay();
CS1=0;
delay();
CLK=0;
DAT=1;
CLK=1;
CLK=0;
DAT=0;
CLK=1;
CLK=0;
DAT=1;
CLK=1;
MCU_Address_2416(0x00);
switch (KeyCounter)
case 0:{
data1=0x00;
data2=0x00;
}break;
case 1:{
data1=0xaa;
data2=0xaa;
}break;
case 2:{
data1=0x55;
data2=0x55;
}break;
case 3:{
data1=0xff;
data2=0x00;
}break;
case 4:{
data1=0x00;
data2=0xff;
}break;
Page 30832Test
case 5:{
data1=0xff;
data2=0xff;
}break;
for(i=0;i<4;i++)
MCU_Data_0832(data1,data2);
delay();
CS1=1;
void main(void)
unsigned char CounterShallow;
TRISCbits.TRISC3=0;
TRISCbits.TRISC5=0;
TRISDbits.TRISD0=0;
//TRISCbits.TRISC0=0;
TRISDbits.TRISD1=0;
TRISDbits.TRISD2=0;
//TRISAbits.TRISA4=1;
TRISBbits.TRISB0=1;
KeyLast=1;
KeyNow=1;
KeyCounter=0;
CounterShallow=1;
set2416();
delay();
while(1)
KeyJudgement();
if(CounterShallow!=KeyCounter)
senddata1();
CounterShallow=KeyCounter;
Delay1KTCYx(100);//Keep from intervals
事无巨细,无源蜂鸣器 CEPARK AVR学习板上,最简单的内容也许就是蜂鸣器了。当然如果你硬要用它来唱歌的话,那还是有点难度的。所以我们还是让它先发出“滴滴“声好了。 先来拓展拓展我们的知识吧(内容部 ...… 查看全部问答> |
也许菜鸟们还不知道在哪可以下到labview,那么这个贴子应该可以帮助你们。 labview8.6完整官方下载地址 http://www.ni.com/labview/family/zhs/ ftp://evalftp86:LabV13w86@ftp.ni.com/ 附件中为labview2009官方下载地址 大家可以先用试用 ...… 查看全部问答> |
小弟定义了一个结构体,然后想用来进行windows和wince通信,内容是文件的一些信息。然后把文件从windows传到wince上去。不过每次传都收不到真确的东西。请问我哪里有问题,是wince的Unicode的问题吗?… 查看全部问答> |
一个DLL,一个exe工程,加载dll使用#pragma comment lib形式,在EVC下可以运行的; 但现在要移植到ce6下,使用vs2005编译通过,部署也成功,但运行不起来,调试发现连APP的构造函数也没运行,就报错提示:管道的另一端上无任何进程。网上搜索没有 ...… 查看全部问答> |
GPIO_StructInit(&GPIO_InitStruct); GPIO_InitStruct.GPIO_Direction = GPIO_PinInput; GPIO_InitStruct.GPIO_Pin = GPIO_Pin_6; GP ...… 查看全部问答> |
