今天是:2024年11月28日(星期四)
2019年11月28日 | LPC1788 SPI主从机代码
2019-11-28 来源:51hei
单片机源程序如下:
* $Id[ DISCUZ_CODE_1 ]nbsp; mcu_main_new.c 2012-05-04
* @file mcu_main_new.c
* @brief User program.
* @version 1.0
* @date 04. May. 2012
* @author NXP MCU SW Application Team
* Copyright(C) 2011, NXP Semiconductor
* All rights reserved.
* Software that is described herein is for illustrative purposes only
* which provides customers with programming information regarding the
* products. This software is supplied "AS IS" without any warranties.
* NXP Semiconductors assumes no responsibility or liability for the
* use of the software, conveys no license or title under any patent,
* copyright, or mask work right to the product. NXP Semiconductors
* reserves the right to make changes in the software without
* notification. NXP Semiconductors also make no representation or
* warranty that such application will be suitable for the specified
* use without further testing or modification.
* Permission to use, copy, modify, and distribute this software and its
* documentation is hereby granted, under NXP Semiconductors'
* relevant copyright in the software, without fee, provided that it
* is used in conjunction with NXP Semiconductors microcontrollers. This
* copyright, permission, and disclaimer notice must appear in all copies of
* this code.
#include "includes.h"
#define VTOR_OFFSET (0x00001000)
SBL_FirmVerion_Type firm_vers __attribute__((section("firmware_id_section")))= {0,1,'b'};
/************************** PRIVATE DEFINITIONS *************************/
#ifdef __MCU_LPC17xx
#define MCB_1700
//#define IAR_LPC_1768
#elif defined (__MCU_LPC11xx)
#define MCB_1100
#endif
#if defined (MCB_1700)
/* Number of user LEDs */
#define LED_NUM 4
const unsigned long led_mask[] = { 1<<3, 1<<4, 1<<5, 1<<6 };
#elif defined(MCB_1100)
#define LED_NUM 4
const unsigned long led_pin[] = { 3, 4, 5, 6 };
#endif
/************************** PRIVATE VARIABLES *************************/
/* SysTick Counter */
volatile unsigned long SysTickCnt;
/************************** PRIVATE FUNCTIONS *************************/
void SysTick_Handler (void);
void ReAllocateNVIC(void);
/*----------------- INTERRUPT SERVICE ROUTINES --------------------------*/
* @brief SysTick handler sub-routine (1ms)
* @param[in] None
* @return None
void SysTick_Handler (void) {
SysTickCnt++;
/*-------------------------PRIVATE FUNCTIONS------------------------------*/
* @brief Re-allocate vector interrupt table
* @param[in] None
* @return int
__disable_irq();
NVIC_SetVTOR(VTOR_OFFSET);
__enable_irq();
uint32_t* src,*dst;
int32_t size;
__disable_irq();
// copy vector table
src = (uint32_t*)VTOR_OFFSET;
dst = (uint32_t*)0x10000000;
size = 192;
while(size > 0)
*dst++ = *src++;
size -= 4;
LPC_SYSCON->SYSMEMREMAP = 0x1; /* remap to internal RAM */
__enable_irq();
#endif
/*-------------------------MAIN FUNCTION------------------------------*/
* @brief c_entry: Main program body
* @param[in] None
* @return None
void c_entry(void)
int num = 0;
uint32_t systickcnt;
SBL_SlaveInit();
/* Relocate NVIC */
ReAllocateNVIC();
SystemCoreClockUpdate();
SysTick_Config(SystemCoreClock/1000 - 1); /* Generate interrupt each 1 ms */
GPIO_SetDir(2, 0x0000007C, 1); /* LEDs on PORT2 defined as Output */
GPIO_ClearValue(2, 0x0000007C);
for(num = LED_NUM-1;num>=0;num--)
GPIO_SetDir(2, led_pin[num],1);
GPIO_SetValue(2, led_pin[num]);
#elif defined(IAR_LPC_1768)
GPIO_SetDir(1, (1<<25), 1);
GPIO_ClearValue(1, (1<<25));
#endif
while(1)
if(SBL_SlaveCmdRecv())
SBL_SlaveCmdHandler(SBL_SlaveGetRecvCmd());
else
if(((SysTickCnt - systickcnt) < 500))
GPIO_SetValue(2, led_mask[num]);
#else
GPIO_SetValue(2,(1<<25));
#endif
else if(((SysTickCnt - systickcnt) < 1000))
#ifdef MCB_1700
GPIO_ClearValue(2, led_mask[num]);
GPIO_ClearValue(2, led_pin[num]);
#else
GPIO_ClearValue(1,(1<<25));
#endif
else
systickcnt = SysTickCnt;
//SBL_DeInit();
/* With ARM and GHS toolsets, the entry point is main() - this will
allow the linker to generate wrapper code to setup stacks, allocate
heap area, and initialize and copy code and data segments. For GNU
toolsets, the entry point is through __start() in the crt0_gnu.asm
file, and that startup code will setup stacks and data */
int main(void)
c_entry();
return 0;
本人初学驱动开发 照着例子写了个简单的GPIO驱动 控制开发板上的LED 可是动态加载驱动后显示错误 过程如下: 硬件:s3c2440开发板 GPB5-8接4个LED 软件:linux-2.6.29内核 arm-linux-gcc- ...… 查看全部问答> |
模拟信号都好采集,但是有的传感器是BCD码输出的,每个传感器的引脚是24条线输出,有4个,请问怎么设计和选型? 这里面可能要用到数据选择器或者寄存器;还有USB控制器… 查看全部问答> |
nand flash驱动unable to mount partition 我的nand flash驱动加载时可以创建分区,也可以找到对应的文件系统驱动,但却无法mount这个分区,所以也出现不了盘符,请大家帮帮忙啊~~… 查看全部问答> |
我的手机有一个摄像头,而且可以以USB接口连接到桌面计算机上,作为摄像头使用。请问怎样在WinCE设备里也可以这样用呢?需要怎样开发相关驱动?… 查看全部问答> |
我的电脑前些天还好好的现在开机显示器黑屏只显示Brilho=0 我拿去别的机子试了不是主机的问题,各位大哥大姐教教小第 我该怎么处理啊 显示器调节按钮 按了都没反应。… 查看全部问答> |
VS2005调试目标机上应用程序时,用TCP/IP方式连接总是“设备未就绪”?? 使用VS2005开发win ce的应用程序,在调试的时间用TCP/IP方式连接到开发板,老说“设备未就绪”,该怎么解决啊?… 查看全部问答> |
请教,我用ads1.2编译c++程序总是报一些头文件找不到,我把system path加了vc的库,结果有出了“only win32 and Mac supported\"这个问题,请问怎么办?ads1.2上可以编译c++吗?要怎么做? … 查看全部问答> |
Wait mode: The CPU clock is stopped, but selected peripherals keep running. 想请教前辈如何使用这种模式,我不明白进入等待模式后外设工作的时钟源从哪里来,是不是要使能LSI ? CPU停止工作应该不代表HSI停止工作吧? 有 ...… 查看全部问答> |
