今天是:2024年12月17日(星期二)
2019年12月17日 | MSP430杂谈--AD7793硬件SPI驱动与模拟SPI驱动
2019-12-17 来源:eefocus
最近项目中用到了AD7793读取铂电阻值来得到相应的温度,编写了基于MSP430的硬件驱动程序和模拟驱动程序,并且能成功运行,现在记录一下分享给大家。
AD7793硬件IIC驱动完整版下载链接:https://download.csdn.net/download/qq_42580947/11041933
AD7793模拟IIC驱动完整版下载链接:https://download.csdn.net/download/qq_42580947/11041961
PS:目前资源积分无法自行调整,有谁知道可以修改积分的方法请告知,我想免费分享给大家。
1. AD7793硬件SPI驱动
单片机型号为:MSP430F57XX
硬件SPI驱动失败的几个原因有:单片机配置SPI资源错误(包括SPI的时钟,SPI的运行模型等配置错误),单片机的系统时钟配置错误(注意MCLK, SMCLK, ACLK的分配)
1.1 SPI read with AD7793
/******************** SPI read with AD7793 ***********************/
void AD7793_R(unsigned char addr, unsigned char *buffer, int n)
unsigned int index;
unsigned char temp;
AD7793_CS_DIS;
__delay_cycles(200);
AD7793_CS_EN;
// t1>0ns
// send address
while(!(UCB0IFG & UCTXIFG));
UCB0TXBUF = addr;
while(!(UCB0IFG & UCRXIFG));
temp = UCB0RXBUF;
// Delay > 10us, after writing to RAM
Delay10us(2);
// Read data from register and load in buffer[]
for(index=0; index < n; index++)
UCB0TXBUF = 0x00;
buffer[index] = UCB0RXBUF;
Delay10us(100);
AD7793_CS_DIS;
1.2 SPI write with AD7793
/******************** SPI write with AD7793 ***********************/
void AD7793_W(unsigned char addr, unsigned char *buffer, char n)
unsigned char index;
AD7793_CS_EN;
// t1>0ns
// send address
UCB0TXBUF = addr;
Delay10us(2);
UCB0TXBUF = buffer[index];
AD7793_CS_DIS;
1.3 AD7793 相关寄存器配置
/******************** AD7793 Configuration ***********************/
void AD7793_CON(void)
AD7793_CS_EN;
//single model
SPI_Data[0] = 0x20;
//64k intenal CLK,4.17Hz update rate(stable time 500ms)
SPI_Data[1] = 0x0f;
//Model regeister
AD7793_W(0x08, SPI_Data, 2);
AD7793_CS_DIS;
1.4 电压测量
/******************** voltage measurement ***********************/
void V_measure (void)
/*** Read the both sides voltage of RTD ***/
//bioplar encoding, 8 times, input range 312.5mV
//external reference voltage, buffer mode, AIN1 input
AD7793_CON();
SPI_Data[0] = 0x03;
SPI_Data[1] = 0x10;
AD7793_W(0x10, SPI_Data, 2);
//IEXC1,IEXC2 connected with IOUT1,current is 210uA
//IO register
SPI_Data[0] = 0x0E;
AD7793_W(0x28, SPI_Data, 1);
//data register
AD7793_R(0x58, SPI_Data, 3);
//get the temperature values
ad_result_T = SPI_Data[0];
ad_result_T <<= 8;
ad_result_T += SPI_Data[1];
ad_result_T <<= 8;
ad_result_T += SPI_Data[2];
ad_result_T &= 0x00ffffff;
ad_result_T -= 8388608;
T =(float)ad_result_T*3.7104E-5;
/*** Read the ambient temperature ***/
SPI_Data[0] = 0x00;
SPI_Data[1] = 0x86;
//data register
//get the ambient temperature
ad_result_T1 = SPI_Data[0];
ad_result_T1 <<= 8;
ad_result_T1 += SPI_Data[1];
ad_result_T1 <<= 8;
ad_result_T1 += SPI_Data[2];
ad_result_T1 &= 0x00ffffff;
ad_result_T1 -= 8388608;
Tenvir =(float)ad_result_T1*3.7104E-5;
2. AD7793模拟SPI驱动
模拟SPI驱动失败的最主要原因是:时钟!时钟!时钟!注意时钟的配置和延时的处理
2.1 AD7793基础子函数的处理
void AD7793_CS_SET()//CS置1
P1OUT |= BIT1;
void AD7793_CS_CLR()//CS置0
P1OUT &=~ BIT1;
void AD7793_SCLK_SET()
P2OUT |= BIT2;
void AD7793_SCLK_CLR()
P2OUT &=~ BIT2;
void AD7793_DIN_SET()
P1OUT |= BIT6;
void AD7793_DIN_CLR()
P1OUT &=~ BIT6;
unsigned int AD7793_DOUT_GET()
unsigned int i;
if(P1IN & BIT7)
i = 1;
else
i = 0;
return i;
2.2 向AD7793写入一个字节
void WriteToReg(unsigned char ByteData) //向AD7793写入一个字节
unsigned char temp;
unsigned char i;
AD7793_CS_CLR();
AD7793_SCLK_SET();
temp=0x80;
for(i=0;i<8;i++)
if((temp & ByteData)==0)
AD7793_DIN_CLR();
else
AD7793_DIN_SET();
AD7793_SCLK_CLR();
Delay();
AD7793_SCLK_SET();
Delay();
temp=temp>>1;
AD7793_CS_SET();
2.3 复位AD7793
void AD7793_Reset(void)//AD7793复位
P1DIR |= BIT6;
P2DIR |= BIT2;
P1DIR &=~ BIT7;
unsigned int ResetTime;
ResetTime = 32;
AD7793_SCLK_SET();
AD7793_CS_CLR();
AD7793_DIN_SET();
while(ResetTime--)
Delay();
AD7793_SCLK_CLR();
Delay();
AD7793_SCLK_SET();
AD7793_CS_SET();
2.4 读取AD7793
unsigned char AD7793_ReadStatusRegister(void) //读取7793的状态寄存器
unsigned char j;
unsigned char temp;
WriteToReg(0x40);
AD7793_DIN_SET();
AD7793_CS_CLR();
temp=0;
for(j=0; j<8; j++)
AD7793_SCLK_CLR();
if(AD7793_DOUT_GET()==0)
temp=temp<<1;
else
temp=temp<<1;
temp=temp+0x01;
Delay();
AD7793_SCLK_SET();
Delay();
AD7793_CS_SET();
return temp;
2.5 配置相关寄存器
void Ad7793_WriteModeRegister(unsigned char ModeRegisterH,unsigned char ModeRegisterL)
//配置模式寄存器
WriteToReg(0x08);
WriteToReg(ModeRegisterH);
WriteToReg(ModeRegisterL);
void Ad7793_WriteConfigRegister(unsigned char ConfigRegisterH,unsigned char ConfigRegisterL)
//配置配置寄存器
WriteToReg(0x10);
WriteToReg(ConfigRegisterH);
WriteToReg(ConfigRegisterL);
void Ad7793_WriteIORegister(unsigned char IORegister)
//配置IO寄存器
WriteToReg(0x28);
WriteToReg(IORegister);
2.6 读取AD7793数据寄存器
long AD7793_ReadDataRegister(void)
union
unsigned char chardata[3];
unsigned long longdata;
}AD7793Result;
unsigned char i,j;
unsigned char temp;
temp=AD7793_ReadStatusRegister();
while((temp&0x80)==0x80)
WriteToReg(0x58);
AD7793_DIN_SET();
AD7793_CS_CLR();
for(i=0; i<3; i++)
for(j=0; j<8; j++)
AD7793_SCLK_CLR();
temp=temp<<1;
else
temp=temp<<1;
temp=temp+0x01;
Delay();
AD7793_SCLK_SET();
Delay();
AD7793Result.chardata[3-i]=temp;
AD7793_CS_SET();
AD7793Result.longdata=AD7793Result.longdata>>8;
return AD7793Result.longdata;
2.7 初始化AD7793
void Init_AD7793(void)//AD7793的初始化
AD7793_CS_SET();
AD7793_Reset();
Ad7793_WriteModeRegister(0x00,0x0F);//连续转换
Ad7793_WriteConfigRegister(0x03,0x10);//292.5mv,1.65V偏压
Ad7793_WriteIORegister(0x0E);
书中提到的8237A 8259A 8253-PIT 8255A 8250 8251A这些片子总觉得不是很熟,不会编程,大家有什么好的建议,能让我掌握他们。有什么好的资料吗?… 查看全部问答> |
驱动使用DDK写的,不是DS+DDK,以前用DS+DDK的时候是应用把一个Event的HANDLE传进去,然后驱动里面用传进来的HANDLE生成一个KEVENT,应用那里启动一个线程,线程里面等待那个Event就行了,这样当发生中断时驱动的DPC就把KEVENT设置,应用的那个线程就 ...… 查看全部问答> |
在做430向SD卡写数据时候,SD卡可以,但是用SDHC卡初始化过程中CMD0的响应正确,ACMD41响应总是0x01,是不是argument有问题呢?… 查看全部问答> |
2012TI杯山东省大学生电子设计竞赛 基本仪器和主要元器件清单 1、基本仪器清单 数字电桥 直流稳压电源 量角器 米尺 四位半数字万用表 0~200℃温度 ...… 查看全部问答> |
请问在main中进入LPM4,在外部中断唤醒后在中断进入LPM3,这时程序是回到main中了... 首先在main吧,我运行了“_BIS_SR(LPM4_bits + GIE); // Enter LPM4” 先外部IO口中断函数中我又运行了“_BIS_SR(LPM3_bits + GIE);”,请问在此之后,程序是继续执行完中断函数后面的内容再进入LPM3,还是 ...… 查看全部问答> |
