今天是:2025年01月02日(星期四)
2020年01月02日 | ARM裸机篇---启动代码分析
2020-01-02 来源:eefocus
先搞清楚启动代码和Bootloader的区别,启动代码是指CPU复位后到进入C语言的main函数之前需要执行的那段汇编代码。
下面的代码先暂且这样吧,没啥注释的,时间关系,我还是先搞些应用再说^_^
; NAME: 2410INIT.S
; DESC: C start up codes
; Configure memory, ISR ,stacks
; Initialize C-variables
; HISTORY:
; 2002.02.25:kwtark: ver 0.0
; 2002.03.20:purnnamu: Add some functions for testing STOP,POWER_OFF mode
; 2002.04.10:SJS:sub interrupt disable 0x3ff -> 0x7ff
GET option.s
GET memcfg.s
GET 2410addr.s
BIT_SELFREFRESH EQU (1<<22)
;Pre-defined constants
USERMODE EQU 0x10
FIQMODE EQU 0x11
IRQMODE EQU 0x12
SVCMODE EQU 0x13
ABORTMODE EQU 0x17
UNDEFMODE EQU 0x1b
MODEMASK EQU 0x1f
NOINT EQU 0xc0
;The location of stacks
UserStack EQU (_STACK_BASEADDRESS-0x3800) ;0x33ff4800 ~
SVCStack EQU (_STACK_BASEADDRESS-0x2800) ;0x33ff5800 ~
UndefStack EQU (_STACK_BASEADDRESS-0x2400) ;0x33ff5c00 ~
AbortStack EQU (_STACK_BASEADDRESS-0x2000) ;0x33ff6000 ~
IRQStack EQU (_STACK_BASEADDRESS-0x1000) ;0x33ff7000 ~
FIQStack EQU (_STACK_BASEADDRESS-0x0) ;0x33ff8000 ~
;Check if tasm.exe(armasm -16 ...@ADS 1.0) is used.
GBLL THUMBCODE
[ {CONFIG} = 16
THUMBCODE SETL {TRUE}
CODE32
THUMBCODE SETL {FALSE}
MACRO
MOV_PC_LR
[ THUMBCODE
bx lr
mov pc,lr
MEND
MACRO
MOVEQ_PC_LR
[ THUMBCODE
bxeq lr
moveq pc,lr
MEND
MACRO
$HandlerLabel HANDLER $HandleLabel
$HandlerLabel
sub sp,sp,#4 ;decrement sp(to store jump address)
stmfd sp!,{r0} ;PUSH the work register to stack(lr does't push because it return to original address)
ldr r0,=$HandleLabel;load the address of HandleXXX to r0
ldr r0,[r0] ;load the contents(service routine start address) of HandleXXX
str r0,[sp,#4] ;store the contents(ISR) of HandleXXX to stack
ldmfd sp!,{r0,pc} ;POP the work register and pc(jump to ISR)
MEND
IMPORT |Image$$RO$$Limit| ; End of ROM code (=start of ROM data)
IMPORT |Image$$RW$$Base| ; Base of RAM to initialise
IMPORT |Image$$ZI$$Base| ; Base and limit of area
IMPORT |Image$$ZI$$Limit| ; to zero initialise
IMPORT Main ; The main entry of mon program
AREA Init,CODE,READONLY
ENTRY
;1)The code, which converts to Big-endian, should be in little endian code.
;2)The following little endian code will be compiled in Big-Endian mode.
; The code byte order should be changed as the memory bus width.
;3)The pseudo instruction,DCD can't be used here because the linker generates error.
ASSERT :DEF:ENDIAN_CHANGE
[ ENDIAN_CHANGE
ASSERT :DEF:ENTRY_BUS_WIDTH
[ ENTRY_BUS_WIDTH=32
b ChangeBigEndian ;DCD 0xea000007
[ ENTRY_BUS_WIDTH=16
andeq r14,r7,r0,lsl #20 ;DCD 0x0007ea00
[ ENTRY_BUS_WIDTH=8
streq r0,[r0,-r10,ror #1] ;DCD 0x070000ea
b ResetHandler
b HandlerUndef ;handler for Undefined mode
b HandlerSWI ;handler for SWI interrupt
b HandlerPabort ;handler for PAbort
b HandlerDabort ;handler for DAbort
b . ;reserved
b HandlerIRQ ;handler for IRQ interrupt
b HandlerFIQ ;handler for FIQ interrupt
;@0x20
b EnterPWDN
ChangeBigEndian
;@0x24
DCD 0xee110f10 ;0xee110f10 => mrc p15,0,r0,c1,c0,0
DCD 0xe3800080 ;0xe3800080 => orr r0,r0,#0x80; //Big-endian
DCD 0xee010f10 ;0xee010f10 => mcr p15,0,r0,c1,c0,0
DCD 0x0f10ee11
DCD 0x0080e380
DCD 0x0f10ee01
[ ENTRY_BUS_WIDTH=8
DCD 0x100f11ee
DCD 0x800080e3
DCD 0x100f01ee
DCD 0xffffffff ;swinv 0xffffff is similar with NOP and run well in both endian mode.
DCD 0xffffffff
DCD 0xffffffff
DCD 0xffffffff
DCD 0xffffffff
b ResetHandler
;Function for entering power down mode
; 1. SDRAM should be in self-refresh mode.
; 2. All interrupt should be maksked for SDRAM/DRAM self-refresh.
; 3. LCD controller should be disabled for SDRAM/DRAM self-refresh.
; 4. The I-cache may have to be turned on.
; 5. The location of the following code may have not to be changed.
;void EnterPWDN(int CLKCON);
EnterPWDN
mov r2,r0 ;r2=rCLKCON
tst r0,#0x8 ;POWER_OFF mode?
bne ENTER_POWER_OFF
ENTER_STOP
ldr r0,=REFRESH
ldr r3,[r0] ;r3=rREFRESH
mov r1, r3
orr r1, r1, #BIT_SELFREFRESH
str r1, [r0] ;Enable SDRAM self-refresh
mov r1,#16 ;wait until self-refresh is issued. may not be needed.
0 subs r1,r1,#1
bne %B0
ldr r0,=CLKCON ;enter STOP mode.
str r2,[r0]
mov r1,#32
0 subs r1,r1,#1 ;1) wait until the STOP mode is in effect.
bne %B0 ;2) Or wait here until the CPU&Peripherals will be turned-off
; Entering POWER_OFF mode, only the reset by wake-up is available.
ldr r0,=REFRESH ;exit from SDRAM self refresh mode.
str r3,[r0]
MOV_PC_LR
ENTER_POWER_OFF
;NOTE.
;1) rGSTATUS3 should have the return address after wake-up from POWER_OFF mode.
ldr r0,=REFRESH
ldr r1,[r0] ;r1=rREFRESH
mov r1,#16 ;Wait until self-refresh is issued,which may not be needed.
0 subs r1,r1,#1
bne %B0
ldr r1,=MISCCR
ldr r0,[r1]
orr r0,r0,#(7<<17) ;Make sure that SCLK0:SCLK->0, SCLK1:SCLK->0, SCKE=L during boot-up
str r0,[r1]
ldr r0,=CLKCON
str r2,[r0]
b . ;CPU will die here.
WAKEUP_POWER_OFF
;Release SCLKn after wake-up from the POWER_OFF mode.
ldr r1,=MISCCR
ldr r0,[r1]
bic r0,r0,#(7<<17) ;SCLK0:0->SCLK, SCLK1:0->SCLK, SCKE:L->H
str r0,[r1]
;Set memory control registers
ldr r0,=SMRDATA
ldr r1,=BWSCON ;BWSCON Address
add r2, r0, #52 ;End address of SMRDATA
ldr r3, [r0], #4
str r3, [r1], #4
cmp r2, r0
bne %B0
mov r1,#256
0 subs r1,r1,#1 ;1) wait until the SelfRefresh is released.
bne %B0
ldr r1,=GSTATUS3 ;GSTATUS3 has the start address just after POWER_OFF wake-up
上一篇:arm 汇编语法
下一篇:44B0启动代码INIT.S分析
在一般的代码中都可以看到如下定义的帧结构 struct ip { uint EtherHead[9]; uchar VerandIphLen; & ...… 查看全部问答> |
ucos的信息邮箱用在子函数里,是不是消息邮箱的指针就传递不出来了啊? ucos 用在任务之间,任务不删除任务中的变量就还在生存,所以邮箱能够把指针传递出来,但是如果用在子函数中,子函数运行结束,变量就没了,那么邮箱传递的地址内容就不对了。我的理解对吗,如果对的话,那怎么从子函数中传递出多个数据例如一个数 ...… 查看全部问答> |
主要分为两部分,上面是交流信号,可输出三角波和正弦波,每个信号可选择输出电压幅度,频率和相位。左边的波形显示是调节参数后即将输出的波形的形状(目前还没有输出),当用户确定需要输出该波形后点击 “开始交流输出”后信号源即开始输出波 ...… 查看全部问答> |
今天突然打不开以前的www.stcmcu.com 联系STC的人员才知道网址换了,这里给大家提个醒,省得下东东找不到地方 www.gxwmcu.com … 查看全部问答> |
现在越来越多的IC厂商推出图形配置界面,图形配置,生成代码。 工作中机型和机型之间也只是功能有所差异,能否通过图形界面选择功能,生成代码。 如何写这类图形配置界面软件? … 查看全部问答> |
设计狮大神你怎么看?这个可以替代带灯轻触开关的结构--可发光可贴片的硅胶按键 LED SMD Rubber Touch Switch 贴片带灯硅胶按键。 寿命300W次,过回流焊,耐高温280度。发光均匀。 能否替代带灯轻触开关呢? … 查看全部问答> |
