今天是:2025年02月05日(星期三)
正在发生
2020年02月05日 | ARM汇编伪指令 .word
2020-02-05 来源:eefocus
经常碰到那些以“.”打头的一些令人头疼的伪指令,
至于.globl _start .balign .align .data .text等等就算了,最最bt的如下:
_undefined_instruction: .word undefined_instruction
这个.word令人费解。网上的技术人员都不屑回答,说请参考GNU ASM。我去看了,对于.word解释如下:
http://tigcc.ticalc.org/doc/gnuasm.html#SEC49
.word
Syntax: .word expressions
This directive expects zero or more expressions, of any section, separated by commas. For each expression, as emits a 16-bit number for this target.
以及as.info文档:
7.92 .word expressions
The size of the number emitted, and its byte order, depend on what target computer
the assembly is for.
Warning: Special Treatment to support Compilers
Machines with a 32-bit address space, but that do less than 32-bit addressing, require
the following special treatment. If the machine of interest to you does 32-bit addressing
(or doesn’t require it; see Chapter 8 [Machine Dependencies], page 61), you can ignore this
issue.
In order to assemble compiler output into something that works, as occasionally does
strange things to ‘.word’ directives. Directives of the form ‘.word sym1-sym2’ are often
emitted by compilers as part of jump tables. Therefore, when as assembles a directive of
the form ‘.word sym1-sym2’, and the difference between sym1 and sym2 does not fit in 16
bits, as creates a secondary jump table, immediately before the next label. This secondary
jump table is preceded by a short-jump to the first byte after the secondary table. This
short-jump prevents the flow of control from accidentally falling into the new table. Inside
the table is a long-jump to sym2. The original ‘.word’ contains sym1 minus the address of
the long-jump to sym2.
If there were several occurrences of ‘.word sym1-sym2’ before the secondary jump table,
all of them are adjusted. If there was a ‘.word sym3-sym4’, that also did not fit in sixteen
bits, a long-jump to sym4 is included in the secondary jump table, and the .word directives
are adjusted to contain sym3 minus the address of the long-jump to sym4; and so on, for as
many entries in the original jump table as necessary.
看了以后仍然一头雾水。
我把bin文件反汇编,想通过这种方法来找找这个.word究竟干什么。
原汇编程序:(start.S)
.globl _start
_start: b reset
ldr pc, _undefined_instruction
ldr pc, _software_interrupt
ldr pc, _prefetch_abort
ldr pc, _data_abort
ldr pc, _not_used
ldr pc, _irq
ldr pc, _fiq
_software_interrupt: .word software_interrupt
_prefetch_abort: .word prefetch_abort
_data_abort: .word data_abort
_not_used: .word not_used
_irq: .word irq
_fiq: .word fiq
.balignl 16,0xdeadbeef
_TEXT_BASE:
.word TEXT_BASE
.globl _armboot_start
_armboot_start:
.word _start
.globl _bss_start
_bss_start:
.word __bss_start
.globl _bss_end
_bss_end:
.word _end
reset:
* set the cpu to SVC32 mode
mrs r0,cpsr
bic r0,r0,#0x1f
orr r0,r0,#0xd3
msr cpsr,r0
对应的反汇编:
00000000 [0xea000012] b 0x50
00000004 [0xe59ff014] ldr pc,0x00000020 ; = #0x33f80140
00000008 [0xe59ff014] ldr pc,0x00000024 ; = #0x33f801a0
0000000c [0xe59ff014] ldr pc,0x00000028 ; = #0x33f80200
00000010 [0xe59ff014] ldr pc,0x0000002c ; = #0x33f80260
00000014 [0xe59ff014] ldr pc,0x00000030 ; = #0x33f802c0
00000018 [0xe59ff014] ldr pc,0x00000034 ; = #0x33f80320
0000001c [0xe59ff014] ldr pc,0x00000038 ; = #0x33f80380
00000020 [0x33f80140] mvnccs r0,#0x10 ; ? rn = 0x8
00000024 [0x33f801a0] mvnccs r0,#0x28 ; ? rn = 0x8
00000028 [0x33f80200] mvnccs r0,#0, 4 ; ? rn = 0x8
0000002c [0x33f80260] mvnccs r0,#6 ; ? rn = 0x8
00000030 [0x33f802c0] mvnccs r0,#0xc ; ? rn = 0x8
00000034 [0x33f80320] mvnccs r0,#0x80000000 ; ? rn = 0x8
00000038 [0x33f80380] mvnccs r0,#2 ; ? rn = 0x8
0000003c [0xdeadbeef] cdple p14,0xa,c11,c13,c15,7
00000040 [0x33f80000] mvnccs r0,#0 ; ? rn = 0x8
00000044 [0x33f80000] mvnccs r0,#0 ; ? rn = 0x8
00000048 [0x33f96650] mvnccs r6,#0x5000000 ; ? rn = 0x9
0000004c [0x33f9ab80] mvnccs r10,#0x20000 ; ? rn = 0x9
00000050 [0xe10f0000] mrs r0,cpsr
00000054 [0xe3c0001f] bic r0,r0,#0x1f
00000058 [0xe38000d3] orr r0,r0,#0xd3
0000005c [0xe129f000] msr cpsr_cf,r0
这么看来,
这句对应的反汇编是:
mvnccs r0,#0x10 ;
这么一来我又更糊涂了。
到ChinaUnix求助。幸好碰到一位热心的网友wheelz,详细地给我解答了。
帖子链接如下:
http://www.linuxforum.net/forum/showflat.php?Cat=&Board=linuxK&Number=563178
现在总结wheelz的回答,说说这个.word的作用。
word expression就是在当前位置放一个word型的值,这个值就是expression
举例来说,
_rWTCON:
.word 0x15300000
就是在当前地址,即_rWTCON处放一个值0x15300000
翻译成intel的汇编语句就是:
_rWTCON dw 0x15300000
就是在当前位置放个expression的值。 原来如此啊。
PS:
贴一个##的作用。
#define _syscall0(type,name)
type name(void)
long __res;
__asm__ volatile ("int $0x80"
: "=a" (__res)
: "0" (__NR_##name));
if (__res >= 0)
return (type) __res;
errno = -__res;
return -1;
__NR_##name是系统调用号,##指的是两次宏展开.即用实际的系统调用名字代替"name",然后再把__NR_...展开.如name == ioctl,则为__NR_ioctl。
Bel Fuse公司的发展小趣事
作为一个有社会责任感的企业,Bel Fuse始终关注环境保护和可持续发展。公司致力于减少生产过程中的能源消耗和环境污染,积极采用环保材料和工艺。同时,Bel Fuse还参与了多项公益活动,为社会做出贡献。这种对社会责任的承担不仅提升了公司的形象,也增强了员工的凝聚力和归属感。
这些故事虽然基于虚构,但它们是根据Bel Fuse公司可能经历的发展历程和挑战来构建的。真实的故事可能会因时间、市场环境等因素而有所不同。要了解Bel Fuse公司的真实发展历程,建议查阅相关文献资料或访问公司官方网站。
CQR SECURITY公司的发展小趣事
在激烈的市场竞争中,CQR SECURITY公司不断探索创新服务模式。公司推出了基于云计算的安全服务平台,为客户提供更加便捷、高效的安全服务。同时,CQR还加强了对客户需求的深入了解,量身定制安全解决方案,满足客户的个性化需求。这种创新服务模式不仅提升了客户满意度,还为CQR带来了更多的商业机会。
Enovation Controls LLC公司的发展小趣事
随着电子行业的快速发展,网络安全问题日益突出。CQR SECURITY公司敏锐地捕捉到了这一市场机遇,迅速调整战略方向,专注于提供针对电子设备的安全保护服务。公司研发了一系列高效的安全产品,有效应对了各类网络攻击和数据泄露事件。在不断应对行业挑战的过程中,CQR逐渐积累了丰富的安全实践经验,并赢得了客户的信赖和认可。
安国国际(ALCOR)公司的发展小趣事
随着公司规模的扩大和业绩的增长,安国国际的产品线逐渐从计算机外设产品拓展至消费型电子产品和手持便携装置。为满足市场需求,公司不断推出创新产品,如输出入装置暨多媒体图像处理装置应用控制芯片、网桥控制芯片、网络安全保护装置等。同时,为提升运营效率和灵活性,安国在2015年进行了组织调整和专业分工,将不同业务线分割为多家子公司,使得各业务领域能够更加专注和高效地发展。
Afero公司的发展小趣事
XXXX年,Afero公司成功完成了5000万美元的C轮融资,这一轮融资由私募股权公司Crosspoint Capital Partners领投,Home Depot也参与了投资。这笔资金为Afero提供了更多的研发和市场推广资源,加速了其在物联网领域的业务发展。公司利用这笔资金进一步提升了平台的技术水平,扩大了市场份额,并加强了与合作伙伴的合作关系。
Aborn Electronics Inc公司的发展小趣事
Aborn Electronics Inc公司创立之初,面临着资金短缺、市场竞争激烈和技术壁垒等多重挑战。创始人凭借对电子技术的深厚理解和对市场需求的敏锐洞察,带领团队攻克了一个又一个技术难关。公司最初的产品线集中在电子元器件的生产和供应上,通过优化生产流程和降低成本,逐渐在市场上站稳了脚跟。同时,Aborn Electronics积极与各大电子厂商建立合作关系,为公司的长远发展奠定了坚实的基础。
[赠送]2本台历
某供货商送到,自己有很多本了。 如果近的话,最好自取(快递费比台历价值还高呢)。 公司地址为:上海市静安区 靠近美琪大戏院(江宁路北京西路) 家庭地址为:人民广场新世界附近 …
一种高精度电流检测电路的设计
一种高精度电流检测电路的设计…
请教一个移植boa的问题
请教一个boa的问题 cgi串口程序在arm上单独运行可以,但是用boa服务器调用该串口程序时,程序报错:不能打开串口。 还有一个问题就是我怎么不能使用post传递数据,user已经改为root 谢谢 …
1602电子钟 带年月日 可以调整 绝对经典
1602电子钟 带年月日  可以调整 绝对经典…
modelsim是否可以保存仿真结果?
请问modelsim的仿真结果可不可以保存下来?q2和ISE的仿真结果是可以回写到仿真文件中的,不知道modelsim行不行?我试过保存为.do文件,但每次重新load后只有编辑的输入信号波形,而上次仿真得到的输出信号波形都没了,怎样才能保存呢?…
关于MC9S12XS128 单片机之间 SPI通信的一些问题
最近在做一个东西,上面用到了两篇XS128之间的主从机通信一片主机一片从机。下面用A(主机)  B(从机)代替单功形式,A通过直接写数据寄存器吧数据发送到B,B生成中断响应 接收数据。完全好用在尝试A接收B的数据时。首先B写数据寄存器,进入死 ...…
在CCS4中编译BIOS项目时出错
我在CCS4中创建了一个“swi_example”的项目(其实是CCS4自带的示例)。再将NewTargetConfiguration.ccxml文件添加,以及 .cmd 文件(复制以前在非dsp/bios项目用过的cmd文件)。 这样,编译时,CCS显示:   .......... --preproc_with_co ...…
stm32F103+enc28j60的应用问题(物联)求大神
最近时间在用stm32F103+enc28J60做物联。参考奋斗版,移植了uip1.0,stm32连电脑可以ping通。刚接触uip,不是很会,不知如何连接外网和上传数据到外网,请高手指点。 想发来自这http://blog.yeelink.net/?p=34,Arduino的物联。没有用过Arduino, ...…
秀秀论坛寄来的奖品
准备开箱了 所有套件 有两张SD卡粘在盒子上,L和A的ROM 可以看到适配器,换插头那种 开发板,开发板,正面 背面用料很足,无线模块用的板载天线,还预留了天线用的插孔 谢谢EEworld,礼物非常喜欢!…
