今天是:2025年02月21日(星期五)
2020年02月21日 | JZ2440开发笔记(2)——minicom的安装和配置使用
2020-02-21 来源:eefocus
一、安装配置minicom
1、安装minicom
lingd@ubuntu:~$ sudo apt-get install minicom
2、配置minicom
lingd@ubuntu:~$ sudo minicom -s
出现这样的配置界面:
+-----[configuration]------+
| Filenames and paths |
| File transfer protocols |
| Serial port setup |
| Modem and dialing |
| Screen and keyboard |
| Save setup as dfl |
| Save setup as.. |
| Exit |
| Exit from Minicom |
选择Serial port setup, 会看到这样的选项:
| A - Serial Device : /dev/ttyS0 |
| B - Lockfile Location : /var/lock |
| C - Callin Program : |
| D - Callout Program : |
| E - Bps/Par/Bits : 115200 8N1 |
| F - Hardware Flow Control : No |
| G - Software Flow Control : No |
| Change which setting? |
输入前面对应的字母即可进入相应的选项。将选项A的值设置为/dev/ttyS0 表示是串口1,将选项E的值设置为115200,将选项F设置为NO(请根据实际情况配置).
设置默认上传/下载的目录,选择Filenames and paths , 会看到这样的选项:
| A - Download directory : /home/lingd/arm/download |
| B - Upload directory : /home/lingd/arm/upload |
| C - Script directory : |
| D - Script program : runscript |
| E - Kermit program : |
| F - Logging options |
注意:开发板发送给pc的文件将保存在Download directory所设定的目录中,而pc要下载到开发板的文件保存在Upload directory所设定的目录中
设置完成后,选择”Save setup as dfl”,保存为默认设置.
然后选择“Exit”,即可进入Minicom的主界面:
Welcome to minicom 2.4
OPTIONS: I18n
Compiled on Jan 25 2010, 06:49:09.
Port /dev/ttyS0
Press CTRL-A Z for help on special keys
按Ctrl-A,再按z,可以获取到minicom CTRL-A命令的帮助信息
Welco+-------------------------------------------------------------------+
| Minicom Command Summary |
OPTIO| |
Compi| Commands can be called by CTRL-A Port | | | Main Functions Other Functions | Press| | | Dialing directory..D run script (Go)....G | Clear Screen.......C | | Send files.........S Receive files......R | cOnfigure Minicom..O | | comm Parameters....P Add linefeed.......A | Suspend minicom....J | | Capture on/off.....L Hangup.............H | eXit and reset.....X | | send break.........F initialize Modem...M | Quit with no reset.Q | | Terminal settings..T run Kermit.........K | Cursor key mode....I | | lineWrap on/off....W local Echo on/off..E | Help screen........Z | | Paste file.........Y | scroll Back........B | | | | Select function or press Enter for none. | | | | Written by Miquel van Smoorenburg 1991-1995 | | Some additions by Jukka Lahtinen 1997-2000 | | i18n by Arnaldo Carvalho de Melo 1998 | +-------------------------------------------------------------------+ CTRL-A Z for help |115200 8N1 | NOR | Minicom 2.4 | VT102 | Offline 其中,我们用CTRL-A s来发送文件给开发板;而用CTRL-A r来接收开发板上的文件 二、为pc安装lrzsz lrzsz is a unix communication package providing the XMODEM, YMODEM ZMODEM file transfer protocols. lingd@ubuntu:~$ sudo apt-get install lrzsz 三、交叉编译lrzsz并下载到开发板上 1、下载lrzsz源码包 到http://download.chinaunix.net/download/0007000/6293.shtml,下一个lrzsz的tar包, 2、解压缩后,到解压目录中执行./configure lingd@ubuntu:~/arm$ tar -zxf lrzsz-0.12.20.tar.gz lingd@ubuntu:~/arm$ cd lrzsz-0.12.20/ lingd@ubuntu:~/arm/lrzsz-0.12.20$ ./configure creating cache ./config.cache checking for a BSD compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking whether make sets ${MAKE}... yes checking for working aclocal... missing checking for working autoconf... missing checking for working automake... missing
我搜了一些做ARM开发板的公司,甚少有支持wince6.0的开发板在卖。立宇泰、友善之臂、扬创、周立功、英蓓特等都没找到一块。优龙也是在最近才出了一款LPC3250的板子有wince6.0,但是驱动还没有做全。搜到有两家卖S3C6410X和S3C6400开发板的公司,海 ...… 查看全部问答> |
BUILDREL: Copying PLATFORMCOMMON binaries from C:\\WINCE600\\platform\\common Can\'t create hard link. (FAT file system?) Copying files instead of creating hard links. 编译到最后的时候,出现这样几个错误?? 这是什么 ...… 查看全部问答> |
我有个动态链接库,头文件里定义了结构体和函数名 struct FvFixed { CString m_str; public: friend FvFixed const operator+(const FvFixed x, const ...… 查看全部问答> |
急需此两题的解答!小弟多年不碰单片机,两眼一抹黑,请各位大大救命啊! 在线等,解出来立刻双手把分奉上!! 邮箱:[email=darkstarxw@163.com][/email]… 查看全部问答> |
1、模拟量值和A/D转换值的转换假设模拟量的标准电信号是A0—Am(如:4—20mA),A/D转换后数值为D0—Dm(如:6400—32000),设模拟量的标准电信号是A,A/D转换后的相应数值为D,由于是线性关系,函数关系A=f(D)可以表示为数学方程: &nb ...… 查看全部问答> |
最近在学习使用STM32的ADC,单ADC已经调试成功了,LCD可以显示实际波形。 看到有双ADC快速交替模式,可以提高一倍的速度,就改为该模式,用二个ADC采样同一个输入。 但是无论如何都调试不出来,只有ADC1的值,没有ADC2的值。 看了论坛几乎 ...… 查看全部问答> |
各位大虾:我在DM642里面对TLV320AIC23进行Transmit操作时,遇到一个问题。代码如下,各同步时钟信号AFSX、ACLKX、AHCLKX由AIC23提供。 MCASP_ConfigSrctl MysrctlRegs = { 0x00000009, //AXR00=Xmt &nbs ...… 查看全部问答> |
