今天是:2025年02月28日(星期五)
2020年02月28日 | STM8等低端单片机打印各种格式数据
2020-02-28 来源:eefocus
#include “stm8l15x.h”
#include “delay.h”
#include “stdarg.h”
#include “stdio.h”
//定义LED与按键接口
#define LED_GPIO_PORT GPIOC
#define LED_GPIO_PINS GPIO_Pin_4
#define KEY_GPIO_PORT GPIOD
#define KEY_GPIO_PINS GPIO_Pin_4
uint8_t HexTable[]={‘0’,‘1’,‘2’,‘3’,‘4’,‘5’,‘6’,‘7’,‘8’,‘9’,‘A’,‘B’,‘C’,‘D’,‘E’,‘F’};
void USART1_SendStr(unsigned char *Str)
while(*Str!=0)//不为结束
USART_SendData8(USART1,*Str); //发送数据
while(!USART_GetFlagStatus (USART1,USART_FLAG_TXE));//等待发送完毕
Str++;//下一个数据
void USART1_SendHex(unsigned char dat)
USART_SendData8(USART1,‘0’);
USART_SendData8(USART1,‘x’);
USART_SendData8(USART1,HexTable[dat>>4]);
USART_SendData8(USART1,HexTable[dat&0x0f]);
USART_SendData8(USART1,’ ');
/发送串口数据/
void send_uart_data(uint8_t data)
while (USART_GetFlagStatus(USART1,USART_FLAG_TXE) == RESET);
USART_SendData8(USART1,data);
功能:将int型数据转为2,8,10,16进制字符串
参数:value — 输入的int整型数
str — 存储转换的字符串
radix — 进制类型选择
注意:8位单片机int字节只占2个字节
char *sky_itoa(int value, char *str, unsigned int radix)
char list[] = “0123456789ABCDEF”;
unsigned int tmp_value;
int i = 0, j, k = 0;
if (NULL == str) {
return NULL;
if (2 != radix && 8 != radix && 10 != radix && 16 != radix) {
return NULL;
if (radix == 10 && value < 0) {
//十进制且为负数
tmp_value = (unsigned int)(0 - value);
str[i++] = ‘-’;
k = 1;
} else {
tmp_value = (unsigned int)value;
//数据转换为字符串,逆序存储
do {
str[i ++] = list[tmp_value%radix];
tmp_value /= radix;
} while(tmp_value);
str[i] = ‘ ’;
//将逆序字符串转换为正序
char tmp;
for (j = k; j < (i+k)/2; j++) {
tmp = str[j];
str[j] = str[i-j-1+k];
str[i-j-1+k] = tmp;
return str;
功能:将double型数据转为字符串
参数:value — 输入的double浮点数
str — 存储转换的字符串
eps — 保留小数位选择,至少保留一个小数位,至多保留4个小数位
注意:8位单片机int字节只占2个字节
void sky_ftoa(double value, char *str, unsigned int eps)
unsigned int integer;
double decimal;
char list[] = “0123456789”;
//将整数及小数部分提取出来
if (value < 0) {
decimal = (double)(((int)value) - value);
integer = (unsigned int)(0 - value);
str[i ++] = ‘-’;
k = 1;
} else {
integer = (unsigned int)(value);
decimal = (double)(value - integer);
//整数部分数据转换为字符串,逆序存储
do {
str[i ++] = list[integer%10];
integer /= 10;
} while(integer);
str[i] = ‘ ’;
//将逆序字符串转换为正序
char tmp;
tmp = str[j];
str[i-j-1+k] = tmp;
//处理小数部分
if (eps < 1 || eps > 4) {
eps = 4;
//精度问题,防止输入1.2输出1.19等情况
double pp = 0.1;
for (j = 0; j <= eps; j++) {
pp *= 0.1;
decimal += pp;
while (eps) {
decimal *= 10;
eps --;
int tmp_decimal = (int)decimal;
str[i ++] = ‘.’;
k = i;
//整数部分数据转换为字符串,逆序存储
do {
str[i ++] = list[tmp_decimal%10];
tmp_decimal /= 10;
} while(tmp_decimal);
str[i] = ‘ ’;
//将逆序字符串转换为正序
tmp = str[j];
str[i-j-1+k] = tmp;
str[i] = ‘ ’;
void mprintf(char * Data, …)
const char *s;
int d;
char buf[16];
uint8_t txdata;
va_list ap;
va_start(ap, Data);
while ( * Data != 0 ) {
if ( * Data == 0x5c ) {
switch ( *++Data ) {
case ‘r’:
txdata = 0x0d;
send_uart_data(txdata);
Data ++;
break;
case ‘n’:
txdata = 0x0a;
Data ++;
break;
default:
Data ++;
break;
} else if ( * Data == ‘%’) {
case ‘s’:
s = va_arg(ap, const char *);
for ( ; s; s++) {
send_uart_data(((uint8_t *)s));
Data++;
break;
case ‘d’:
d = va_arg(ap, int);
sky_itoa(d, buf, 10);
for (s = buf; s; s++) {
Data++;
break;
case ‘x’: {
sky_itoa(d, buf, 16);
Data++;
break;
case ‘f’: {
double num = va_arg(ap, double);
sky_ftoa(num, buf, 4);
send_uart_data(((uint8_t )s));
Data++;
break;
default:
Data++;
break;
} else {
send_uart_data(((uint8_t *)Data));
Data++;
int main( void )
u16 u16_adc1_value;
CLK_PeripheralClockConfig (CLK_Peripheral_USART1,ENABLE);//开启ADC/USART时钟
CLK_PeripheralClockConfig (CLK_Peripheral_ADC1,ENABLE);//开启ADC/USART时钟
USART_Init(USART1,115200,USART_WordLength_8b,USART_StopBits_1,USART_Parity_No,USART_Mode_Tx);//USART初始化,9600,8N1
USART_Cmd (USART1,ENABLE);//使能USART
ADC_Init (ADC1,ADC_ConversionMode_Single,ADC_Resolution_12Bit,ADC_Prescaler_1);//单次转换,12位,ADC转换时钟1分频
ADC_Cmd(ADC1,ENABLE);//使能ADC1
ADC_ChannelCmd (ADC1,ADC_Channel_16,ENABLE);//使能通道11------PB2
while(1)
//USART1_SendStr("ADC转换结果为: ");
ADC_SoftwareStartConv (ADC1);//开始ADC软件转换
while(!ADC_GetFlagStatus (ADC1,ADC_FLAG_EOC));//等待转换结束
ADC_ClearFlag (ADC1,ADC_FLAG_EOC);//清除对应标志
u16_adc1_value=ADC_GetConversionValue (ADC1);//获取转换值
// USART1_SendHex((u16_adc1_value>>8));
//USART1_SendHex((u16_adc1_value&0xff));
//USART_SendData9(USART1, u16_adc1_value);
mprintf("%drn",u16_adc1_value );
/*mprintf("STM8L start...rn");
mprintf("%f %f %frn", 1.2, 12.36, -1.2364568);
mprintf("%x %x %xrn", 0x1035, 0x0830, 0x2018);
mprintf("%d %d %drn", 12, -12345, 2);
mprintf("STM8L end...rn");*/
delay_10us(100);
下一篇:单片机系统重写printf函数
MCS51之裸奔框架C++程序源码(菜农C++裸奔大法系列之三) /*------------------------------------------------------------------------ MCS51之裸奔框架C++程序源码(菜农C++裸奔大法) 本程序主要表现了C++多文件系统的 ...… 查看全部问答> |
可视对讲系统对于家居门户管理的最大特点是安全、便捷。在室内通过可视对讲器或对讲器对来访者进行识别,既可免除烦扰,又可简化开门 程序,是房屋的理想设施。 智能楼宇对讲系统是集微电子技术、计算机技术、通讯技术、多媒体技术为一体的 ...… 查看全部问答> |
找兼职 多普达手机发短信和接受短信息,服务器接受并解析和向pda发短信息 找兼职 多普达手机发短信和接受短信息,服务器接受并解析和向pda发短信息,pda操作系统是wm ,服务器操作系统xp,是要求有成功案例或项目经验。 联系 msn djliu221@163.com qq 412925762 谢绝新手… 查看全部问答> |
我刚购买的核心板不能从NOR启动,NOR里已经烧写了UBOOT,在开发板上能从NOR正常启动,我的板子和开发板地板复位电路和JTAG电路都一样,在我板子上也不能用h-jtag烧写NOR flash,我的板子电源正常,能从NAND启动EBOOT,请帮忙分析一下 原因,谢谢先~… 查看全部问答> |
如何定制应用程序shell 我想在系统启动时候直接就是我的应用程序画面,请问如何实现? 我是这么做的: [HKEY_LOCAL_MACHINE\\init] ; @CESYSGEN IF CE_MODULES_SHELL \"Launch10\"=\"shell.exe\" ; @C ...… 查看全部问答> |
刚刚看了个CroundButton类,注释不够清楚,图像处理的函数一点都没头绪 在这里个大家贴出来,有心人给我理理来龙去脉哈 ____________________________________________________________________________________________________ ______ ...… 查看全部问答> |
2600A系列数字源表的内置扫描生成能力支持更快的吞吐量和精密定时控制 设置正常运行时间是为在进行扫描之前配置SMU源和测量[1]参数。因此,设置间隔只需要一次。从那以后,根据用户需要,扫描可以运行多次。在这个测试中,2636型数字源表[2]被配置为在很短的积分时间内(NPLC = 0.001)进行测量,但默认源和测量延迟则 ...… 查看全部问答> |
