今天是:2025年03月15日(星期六)
2020年03月15日 | I2C配置及调试流程
2020-03-15 来源:eefocus
一、I2C配置
1.根据原理图,查找相关的i2c引脚对应的GPIO值,以GPIO10作为I2C_SDA,GPIO11作为I2C_SCL为例。
2.根据MSM8937 DEVICE SPECIFICATION文档,查找GPIO10与GPIO11对应的BLSP,以及检查GPIO10与GPIO11是否可以作为I2C来使用。根据文档,GPIO10对应BLSP3_1,GPIO11对应BLSP3_0。
3.根据80-nu767-1_h_linux_bam_low-speed_peripherals_configuration_and_debug_guide文件,查找I2C部分BLSP3_0与BLSP3_1对应内容,包括其物理地址、reg size、中断号......
4.进入kernel/msm-3.18/arch/arm/boot/dts/qcom/路径下修改msm8937-pinctrl.dtsi文件
GPIO配置如下:
i2c_3 {
            i2c_3_active: i2c_3_active {
                /* active state */
                mux {
                    pins = "gpio10", "gpio11";
                    function = "blsp_i2c3";
                config {
                    drive-strength = <2>;
                    bias-disable;
            i2c_3_sleep: i2c_3_sleep {
                /* suspended state */
                mux {
                    function = "gpio";
                config {
                    bias-disable;
5.进入kernel/msm-3.18/arch/arm/boot/dts/qcom/路径下修改msm8937.dtsi文件
添加一个新的设备树节点
(1)添加i2c_3
aliases {
        smd1 = &smdtty_apps_fm;
        smd2 = &smdtty_apps_riva_bt_acl;
        smd3 = &smdtty_apps_riva_bt_cmd;
        smd4 = &smdtty_mbalbridge;
        smd5 = &smdtty_apps_riva_ant_cmd;
        smd6 = &smdtty_apps_riva_ant_data;
        smd7 = &smdtty_data1;
        smd8 = &smdtty_data4;
        smd11 = &smdtty_data11;
        smd21 = &smdtty_data21;
        smd36 = &smdtty_loopback;
        spi3 = &spi_3;
        i2c2 = &i2c_2;
        i2c5 = &i2c_5;
        i2c3 = &i2c_3;
        sdhc1 = &sdhc_1; /* SDC1 eMMC slot */
        sdhc2 = &sdhc_2; /* SDC2 for SD card */
(2)配置i2c_3
i2c_3: i2c@78b7000 { /* BLSP1 QUP3 */
        compatible = "qcom,i2c-msm-v2";
        #address-cells = <1>;
        #size-cells = <0>;
        reg-names = "qup_phys_addr";
        reg = <0x78b7000 0x600>;
        interrupt-names = "qup_irq";
        interrupts = <0 97 0>;
        qcom,clk-freq-out = <400000>;
        qcom,clk-freq-in  = <19200000>;
        clock-names = "iface_clk", "core_clk";
        clocks = <&clock_gcc clk_gcc_blsp1_ahb_clk>,
            <&clock_gcc clk_gcc_blsp1_qup3_i2c_apps_clk>;
        pinctrl-names = "i2c_active", "i2c_sleep";
        pinctrl-0 = <&i2c_3_active>;
        pinctrl-1 = <&i2c_3_sleep>;
        qcom,noise-rjct-scl = <0>;
        qcom,noise-rjct-sda = <0>;
        qcom,master-id = <86>;
        dmas = <&dma_blsp1 8 64 0x20000020 0x20>,
            <&dma_blsp1 9 32 0x20000020 0x20>;
        dma-names = "tx", "rx";
        status = "okey";
6.进入kernel/msm-3.18/drivers/clk/msm路径下修改clock-gcc-8952.c文件
添加时钟节点如下图所示:
static struct rcg_clk blsp1_qup1_i2c_apps_clk_src = {
    .cmd_rcgr_reg = BLSP1_QUP1_I2C_APPS_CMD_RCGR,
    .set_rate = set_rate_hid,
    .freq_tbl = ftbl_gcc_blsp1_2_qup1_4_i2c_apps_clk,
    .current_freq = &rcg_dummy_freq,
    .base = &virt_bases[GCC_BASE],
    .c = {
        .dbg_name = "blsp1_qup1_i2c_apps_clk_src",
        .ops = &clk_ops_rcg,
        VDD_DIG_FMAX_MAP1(LOWER, 50000000),
        CLK_INIT(blsp1_qup1_i2c_apps_clk_src.c),
二、I2C BUS验证
配置好I2C后,我们需保证I2C BUS被注册
验证过程如下:
adb shell //-------> Get adb shell
cd /dev/
ls i2c* //--------> to list all the i2c buses
如果显示i2c-3,则表示I2C BUS已被注册
三、I2C调试检查
1、检查I2C配置的相关内容,是否存在错误,或者漏配。
2、确保SDA和SCL所配置的GPIO没有被配置,否则会硬件配置出问题或者GPIO设置无效。
3、若I2C配置无误后,检查相关硬件问题
使用万用表测量I2C_SDA以及I2C_SCL的供电电压,如果与原理图中所示供电电压相差无几,则表示I2C供电电压没有问题。反之,则代表供电电压存在问题。
4、添加从设备
(1)、 通过设备树来注册一个从设备
如果I2C总线正常工作,我们就可以创建一个从设备驱动程序并注册到i2c总线上
我们使用st1663i触摸屏的驱动注册作为范例,引用文件:
kernel/drivers/input/touchscreen/st1663i/sitronix_i2c_touch.c.c
(2)、创建一个设备树节点
文件修改:
/kernel/arch/arm/boot/dts/qcom/msm8917-pmi8937-qrd-sku5.dtsi
添加一个新的设备树节点:
i2c@78b7000 {
        status = "ok";
            st1663i@70 {
                compatible = "sitronix-tp";
                reg = <0x70>;
                interrupt-parent = <&tlmm>;
                interrupts = <65 0x00>;
                reset-gpio = <&tlmm 64 0x00>;
                irq-gpio = <&tlmm 65 0x2002>;
                /*avdd-supply = <&tp_power>;*/
                vdd-supply = <&pm8917_l17>;
                vcc_i2c-supply = <&pm8917_l5>;
                /* pins used by touchscreen */
                pinctrl-names = "pmx_ts_active",
                    "pmx_ts_suspend",
                    "pmx_ts_release";
                pinctrl-0 = <&ts_int_active &ts_reset_active>;
                pinctrl-1 = <&ts_int_suspend &ts_reset_suspend>;
                pinctrl-2 = <&ts_release>;
                st1663i,i2c-pull-up;
                st1663i,no-force-update;
                st1663i,num_max_touches = <10>;
                st1663i,panel-coords = <0 0 480 800>;
                st1663i,display-coords = <0 0 480 800>;
                st1663i,button-map= <139 172 158>;
                st1663i,have-touch-key;
                st1663i,driver-send-cfg;
(3)、编译完成后,利用示波器测量I2C_SDA以及I2C_SCL波形
测试流程如下
adb root
adb remount
adb push i2c_test system/bin
adb shell
cd system/bin
chmod 777 i2c_test
./i2c_test /dev/i2c-3 0xaddr(从设备物理地址) 0(读) 0xaddr(寄存器地址)
如果I2C没有问题,所示I2C_SDA波形应为以下形式
I2C start > 0xE0 (write of 0x70) > 0x1 (reg offset ) > I2C stop > delay > I2C start > 0xE1 (read of 0x70) > > 8 bytes > I2C stop
APSA公司的发展小趣事
在竞争激烈的电子行业中,APSA公司始终保持对技术的敏锐洞察和持续创新。公司不断投入研发资金,引进先进的技术和设备,推动产品升级换代。通过不断创新和技术升级,公司成功保持了市场领先地位。
ABB公司的发展小趣事
APSA公司在创业初期,专注于电子行业中某一特定领域的技术研发。通过团队的不懈努力和持续创新,公司成功开发出一款具有竞争力的产品,填补了市场空白。这一技术突破不仅为APSA公司赢得了首批客户,也为公司的后续发展奠定了坚实的基础。
台湾晶豪(ESMT)公司的发展小趣事
晶豪科技一直积极寻求与国内外企业的合作机会。通过与合作伙伴的紧密合作,公司不断拓展业务领域,进入了模拟及混合讯号IC领域。目前,公司提供的产品包括音讯转换器(ADC/DAC)及D类音频放大器等IC。这些新产品的推出不仅丰富了公司的产品线,还为客户提供了更多样化的选择。同时,通过与合作伙伴的资源共享和优势互补,晶豪科技在技术研发和市场拓展方面取得了更多突破。
C-MAC Automotive公司的发展小趣事
随着公司实力的不断增强,C-MAC Automotive公司开始实施全球化战略。公司先后在欧美和亚洲等地设立研发中心和生产基地,以便更好地满足当地市场需求。通过全球化布局,C-MAC不仅拓宽了市场渠道,还降低了生产成本,提升了整体竞争力。此外,公司还积极参与国际技术交流和合作,不断提升自身的技术水平和创新能力。
宜源科技(ETERNAL)公司的发展小趣事
面对日益严峻的环境问题,宜源科技公司积极响应国家环保政策,致力于绿色环保和可持续发展。公司采用先进的生产工艺和设备,减少生产过程中的污染排放。同时,宜源科技还积极推动绿色产品的研发和推广,为客户提供更加环保、节能的电子产品解决方案。这些努力不仅有助于保护环境,也为公司的可持续发展奠定了基础。
Alpha & Omega Semiconductor(万国半导体)公司的发展小趣事
宜源科技公司深知品质对于企业长远发展的重要性。因此,公司从原材料采购到生产流程控制,再到产品出厂检验,都严格遵循国际标准和行业规范。通过不断提升产品品质,宜源科技赢得了客户的信赖和市场的认可,逐渐树立起自己的品牌形象。
如下代码为什么不能实现动态扫描
#include #include unsigned char LED_CODE[]={0x3f,0x6,0x5b,0x4f,0x66,0x6d,0x7d,0x7,0x7f,0x6f}; void delay(void) { int k;   for(k=0;k…
元器件资料大全
元器件资料大全  可为以后电路搭建省时省力…
求助:WINCE系统运行后,如何保存个人修改的设置?
WINCE系统起来之后,修改一些配置,比如换个桌面背景,调整背光时间等,掉电之后重新启动又回到没有修改的状态。 如何实现掉电之后能够保存好修改的设置,在上电启动后这些设置还存在??? 希望各位大侠们能够赐教!!!…
新手请问如何显示对话框
我建了一个win32 application的工程,然后加了一个对话框资源,在对话框上又加了一个按钮,然后编译和模拟,发现对话框没有在屏幕上显示出来,请问怎样才能把对话框显示出来呢? …
扩展串口芯片16550中断问题
请教各位:     我的串口芯片16550用了外部中断EINT3     在注册表中:我需要加     \"SysIntr\"=dword:3      串口4的中断为EINT3     \"MeMBase\"=dword:0x20000000  &nbs ...…
来长沙参加飞思卡尔智能车竞赛第四天。。。。
补上的,因为刚把相关的视频,相片都拷过来,而且整理了大半天,呵呵~ 希望大家谅解~ 我们是属于华南赛区的,7月23号决赛,也就是我来长沙的第四天~ 决赛是按进入决赛的队伍在预赛时的成绩排名,倒序跑的。 首先进行的是电磁组的,接着是 ...…
求助仿真器总是连不上
烧程序时总是说"NO device found or device disconnected.please connect the device and press retry reconnect or press cancel to abort"请问这是什么原因啊? 仿真器和板子都是好的,是不是软件的设置有问题?…
如何消除用三角波调制正弦波后产生的方波的过冲
本人做三角波调制正弦波时候,产生的调制信号的方波在上升沿和下降沿都有过冲现象,如何消除?…
求解释!出奇稳定的相机
本帖最后由 qwqwqw2088 于 2014-1-9 22:08 编辑 也许你见过,或研究过,出奇稳定的相机稳定器,灵感来自鸡头稳定性?求解释 …
