今天是:2024年09月01日(星期日)
2020年09月01日 | CC3220R主要特性介绍 单片无线ARM MCU解决方案
2020-09-01 来源:elecfans
TI公司的CC3220R是SimpleLink™ Wi-Fi®和物联网(IoT)单片无线MCU平台,包括Wi-Fi, Bluetooth®低功耗, Sub-1 GHz和主MCU以及丰富工具组合。应用处理器ARM® Cortex®-M4 MCU(工作频率80MHz)具有用户专用的256KB RAM和可选的1MB XIP闪存;网络处理器MCU运行所有Wi-Fi和互联网逻辑层,基于ROM的子系统包括802.11b/g/n无线电,基带和具有强大加密引擎的MAC,主要用在云连接,互联网网关,家庭和建筑物自动化,家用电器,接入控制,安全系统,智能能源,工业控制,智能插座和计量,无线音频,IP网络传感器节点,资产跟踪和医疗设备。本文介绍了CC3220R主要特性, 硬件和嵌入软件概述图,功能框图,应用电路及其材料清单,以及SimpleLink™ Wi-Fi® LaunchPad™ 开发板CC3220-LAUNCHXL主要特性,电路图,材料清单和PCB设计图。
The CC3220x device is part of the SimpleLink™ microcontroller (MCU) platform which consists of Wi-Fi, Bluetooth® low energy, Sub-1 GHz and host MCUs, which all share a common, easy-to-use development environment with a single core software development kit (SDK) and rich tool set. A one-TIme integraTIon of the SimpleLink platform enables you to add any combinaTIon of the portfolio’s devices into your design, allowing 100 percent code reuse when your design requirements change.
Start your Internet-of-Things (IoT) design with a Wi-Fi® CERTIFIED® single-chip MCU System-on-Chip (SoC) with built-in Wi-Fi connectivity. Created for the IoT, the SimpleLink™ CC3220x device family from Texas Instruments™ is a single-chip solution, integrating two physically separated, on-chip MCUs.
• An application processor – ARM® Cortex®-M4 MCU with a user-dedicated 256KB of RAM, and an optional 1MB of XIP flash.
• A network processor MCU to run all Wi-Fi and Internet logical layers. This ROM-based subsystem includes an 802.11b/g/n radio, baseband, and MAC with a powerful crypto engine for fast, secure internet connections with 256-bit encryption.
The CC3220x wireless MCU family is part of the second generation of TI’s Internet-on-a-chip™ family of solutions. This generation introduces new features and capabilities that further simplify the connectivity of things to the Internet. The new capabilities including the following:
Enhanced Wi-Fi provisioning
Enhanced power consumption
Enhanced file system security (supported only by the CC3220S and CC3220SF devices)
Wi-Fi AP connection with up to four stations
More concurrently opened BSD sockets; up to 16 BSD sockets, of which 6 are secure
HTTPS support
RESTful API support
Asymmetric keys crypto library
The CC3220x wireless MCU family supports the following modes: station, AP, and Wi-Fi Direct®。 The device also supports WPA2 personal and enterprise security. This subsystem includes embedded TCP/IP and TLS/SSL stacks, HTTP server, and multiple Internet protocols. The device supports a variety of Wi-Fi provisioning methods including HTTP based on AP mode, SmartConfig™ Technology, and WPS2.0.
The power-management subsystem includes integrated DC-DC converters that support a wide range of supply voltages. This subsystem enables low-power consumption modes for extended battery life, such as low-power deep sleep, hibernate with RTC (consuming only 4.5 μA), and shutdown mode (consuming only 1 μA)。
The device includes a wide variety of peripherals, including a fast parallel camera interface, I2S, SD, UART, SPI, I2C, and 4-channel ADC.The SimpleLink CC3220x device family comes in three different device variants: CC3220R, CC3220S, and CC3220SF.
The CC3220R and CC3220S devices include 256KB of application-dedicated embedded RAM for code and data, ROM with external serial flash bootloader, and peripheral drivers.
The CC3220SF device includes application-dedicated 1MB of XIP flash and 256KB of RAM for code and data, ROM with external serial flash bootloader, and peripheral drivers. The CC3220S and CC3220SF device options have additional security features, such as encrypted and authenticated file systems, user IP encryption and authentication, secured boot (authentication and integrity validation of the application image at flash and boot time), and more.
The CC3220x device family is a complete platform solution including software, sample applications, tools, user and programming guides, reference designs, and the E2E™ online community. The device family is also part of the SimpleLink MCU portfolio and supports the SimpleLink developers ecosystem.
CC3220R主要特性:
• CC3220x SimpleLink™ Wi-Fi® Wireless Microcontroller Unit (MCU) System-on-Chip (SoC) is a Single-Chip With Two Separate Execution Environments: a User Application Dedicated ARM® Cortex®-M4 MCU and a Network Processor MCU to Run All Wi-Fi and Internet Logical Layers
• Chip-Level, Wi-Fi Alliance Wi-Fi CERTIFIED™
• Applications Microcontroller Subsystem
– ARM® Cortex®-M4 Core at 80 MHz
– Embedded Memory
– The CC3220R and CC3220S Variants Include 256KB of RAM
– The CC3220SF Variant is a Flash-Based Wireless MCU With Integrated 1MB of Flash and 256KB of RAM
– External Serial Flash
– McASP Supports Two I2S Channels
– SD
– SPI
– I2C
– UART
– 8-Bit Parallel Camera
– Four General-Purpose Timers With 16-Bit PWM Mode
– Watchdog Timer
– 4-Channel 12-Bit ADCs
– Up to 27 GPIO Pins
– Debug Interfaces: JTAG, cJTAG, SWD
• Wi-Fi Network Processor (NWP) Subsystem
– Wi-Fi Internet-on-a-chip™ Dedicated ARM MCU Completely Offloads Wi-Fi and Internet
Protocols from the Application MCU
– Wi-Fi Modes:
– 802.11b/g/n Station
– 802.11b/g Access Point (AP) Supports up to Four Stations
– Wi-Fi Direct® Client and Group Owner
– WPA2 Personal and Enterprise Security: WEP, WPA/WPA2 PSK, WPA2 Enterprise (802.1x)
– IPv4 and IPv6 TCP/IP Stack
– Industry-Standard BSD Socket Application Programming Interfaces (APIs)
– 16 Simultaneous TCP or UDP Sockets
– 6 Simultaneous TLS and SSL Sockets
– IP Addressing: Static IP, LLA, DHCPv4, DHCPv6 With DAD
– SimpleLink Connection Manager for Autonomous and Fast Wi-Fi Connections
– Flexible Wi-Fi Provisioning With SmartConfig™ Technology, AP Mode, and WPS2 Options
– RESTful API Support Using the Internal HTTP Server
– Embedded Network Applications Running on Dedicated Network Processor
– Wide Set of Security Features:
– Hardware Features:
– Separate Execution Environments
– Device Identity
– Hardware Crypto Engine for Advanced Fast Security, Including: AES, DES, 3DES, SHA2, MD5, CRC, and Checksum
– Initial Secure Programming:
– Debug Security
– JTAG and Debug Ports are Locked
– Personal and Enterprise Wi-Fi Security
– Secure Sockets (SSLv3, TLS1.0/1.1/TLS1.2)
– Networking Security
– Secure Sockets (SSLv3, TLS1.0, TLS1.1, TLS1.2)
– HTTPS Server
– Trusted Root-Certificate Catalog
– TI Root-of-Trust Public key
– SW IP Protection
– Secure Key Storage
– File System Security
– Software Tamper Detection
– Cloning Protection
– Secure Boot: Validate the Integrity and Authenticity of the Runtime Binary During Boot
– Embedded Network Applications Running on the Dedicated Network Processor
– HTTP/HTTPS Web Server With Dynamic User Callbacks
– mDNS, DNS-SD, DHCP Server
– Ping
– Recovery Mechanism—Can Recover to Factory Defaults or to a Complete Factory Image
– Wi-Fi TX Power
– 18.0 dBm @ 1 DSSS
– 14.5 dBm @ 54 OFDM
– Wi-Fi RX Sensitivity
– –96 dBm @ 1 DSSS
– –74.5 dBm @ 54 OFDM
– Application Throughput
– UDP: 16 Mbps
– TCP: 13 Mbps
• Power-Management Subsystem
– Integrated DC-DC Converters Support a Wide Range of Supply Voltage:
– VBAT Wide-Voltage Mode: 2.1 V to 3.6 V
– VIO is Always Tied With VBAT
– Preregulated 1.85-V Mode
– Advanced Low-Power Modes
– Shutdown: 1 μA
– Hibernate: 4.5 μA
– Low-Power Deep Sleep (LPDS): 135 μA
– Wi-Fi TX Power
– 18.0 dBm @ 1 DSSS
– –96 dBm @ 1 DSSS
– UDP: 16 Mbps
– TCP: 13 Mbps
– Shutdown: 1 μA
– Hibernate: 4.5 μA
CC3220R应用:
• For Internet-of-Things (IoT) applications, such as:
– Cloud Connectivity
– Internet Gateway
– Home and Building Automation
– Appliances
– Access Control
– Security Systems
– Smart Energy
– Industrial Control
– Smart Plug and Metering
– Wireless Audio
– IP Network Sensor Nodes
– Asset Tracking
– Medical Devices
图1. CC322x硬件概述图
图2. CC322x嵌入软件概述图
图3. CC322x功能框图
图4. CC322x宽电压模式应用电路图
图4 CC322x宽电压模式应用电路材料清单:
图5. CC322x预调节1.85V模式应用电路图
图5 CC322x预调节1.85V模式应用电路材料清单:
CC3220 SimpleLink™ Wi-Fi® LaunchPad™ 开发板CC3220-LAUNCHXL
The CC3220 device is part of the SimpleLink™ microcontroller (MCU) platform which consists of Wi-Fi®, Bluetooth® low energy, Sub-1 GHz and host MCUs. All share a common, easy-to-use development environment with a single core software development kit (SDK) and rich tool set. A one-time integration of the SimpleLink platform lets you add any combination of devices from the portfolio into your design. The ultimate goal of the SimpleLink platform is to achieve 100 percent code reuse when your design requirements change.
The CC3220 SimpleLink LaunchPad™ Development Kit (CC3220-LAUNCHXL) is a low-cost evaluation platform for ARM® Cortex®-M4-based MCUs. The LaunchPad design highlights the CC3220 Internet-on-a chip™ solution and Wi-Fi capabilities. The CC3220 LaunchPad also features temperature and accelerometer sensors, programmable user buttons, three LEDs for custom applications, and onboard emulation for debugging. The stackable headers of the CC3220 LaunchPad XL interface demonstrate how easy it is to expand the functionality of the LaunchPad when interfacing with other peripherals on many existing BoosterPack™ Plug-in Module add-on boards, such as graphical displays, audio codecs, antenna selection, environmental sensing, and more.
开发板CC3220-LAUNCHXL主要特性:
• CC3220, SimpleLink, Wi-Fi, Internet-on-a chip solution with integrated MCU
• 40-pin LaunchPad standard that leverages the BoosterPack ecosystem
• XDS110-based JTAG emulation with serial port for flash programming
• Two buttons and three LEDs for user interaction
• Back-channel universal asynchronous receiver/transmitter (UART) through USB to PC
• Onboard chip antenna with U.FL for conducted testing
• Onboard accelerometer and temperature sensor for out-of-box demo
• Micro USB connector for power and debug connections
下一篇:ARM程序的执行过程详解
Q&A工程师在线:FPGA领域相关问题,可在此提问 https://bbs.eeworld.com.cn/thread-76800-1-1.html 呵呵,有问题可以试试啊!… 查看全部问答> |
6410平台上, IO口 GPN8(EINT8) 是一个复用的PIN, 如何从这个IO口(PIN)上得到中断后,再取得数据? 以下方法不行,总是 \"Bit8 = 1 \". 请指正. g_pGPIOReg->GPNCON &= ~(3 GPNCON &= ~(3 GPNDAT &= 0; Sleep(10); if(g_pGPIOReg->GPNDAT & (1GPNCON = (g_pGPIOReg->GPNC ...… 查看全部问答> |
请问一下各位朋友,在vista下可以使用ce5.0或者的ce6.0的相关开发工具吗?小弟的本本是vista~~不想换成xp~~特此请教一下~谢谢… 查看全部问答> |
我是软件工程系的学生,要考(上交)嵌入式方向的研究生,要深入看哪方面的书啊?跪求各位大侠指导。 此外,我本科上的软件学院,时几乎没学什么硬件方面的知识,是不是嵌入式方向硬件的知识要懂得比较多啊?… 查看全部问答> |
单片机做PLC...请有经验的大侠指点一下(关于梯形图转为单片机C51的问题) 本人乃一电子专业大专生...今年应届毕业开始工作第一个项目——老板轻描淡写得说:“用单片机做个PLC,随便发挥!” 然后......就衍生出很多问题,偏偏这个公司就我一人在搞弱电,没师傅带..晕倒~~结果PCB设计,金属外壳设计,抗干扰(防雷击防浪涌 ...… 查看全部问答> |
从51转过来,那种什么都自己写的观念要改变。学stm32需要熟悉C语言,STM32的寄存器都是以结构体形式出现的,具体外设是一个结构体指针,外设的寄存器通过引用结构体的成员。从ST提供的库函数就可以看出,都是通过这种方式操作的。入门的第一件事是 ...… 查看全部问答> |
