今天是:2024年09月22日(星期日)
2020年09月22日 | stm32时钟设置函数
2020-09-22 来源:eefocus
这里涉及到一个很重要的寄存器,时钟配置寄存器:RCC_CFGR
1 #if defined (STM32F10X_LD_VL) || (defined STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)
2 /* #define SYSCLK_FREQ_HSE HSE_VALUE */
3 #define SYSCLK_FREQ_24MHz 24000000
4 #else
5 /* #define SYSCLK_FREQ_HSE HSE_VALUE */
6 /* #define SYSCLK_FREQ_24MHz 24000000 */
7 /* #define SYSCLK_FREQ_36MHz 36000000 */
8 /* #define SYSCLK_FREQ_48MHz 48000000 */
9 /* #define SYSCLK_FREQ_56MHz 56000000 */
10 #define SYSCLK_FREQ_72MHz 72000000
11 #endif
1 /**
2 * @brief Setup the microcontroller system
3 * Initialize the Embedded Flash Interface, the PLL and update the
4 * SystemCoreClock variable.
5 * @note This function should be used only after reset.
6 * @param None
7 * @retval None
8 */
9 void SystemInit (void)
10 {
11 /* Reset the RCC clock configuration to the default reset state(for debug purpose) */
12 /* Set HSION bit */
13 RCC->CR |= (uint32_t)0x00000001;
15 /* Reset SW, HPRE, PPRE1, PPRE2, ADCPRE and MCO bits */
16 #ifndef STM32F10X_CL
17 RCC->CFGR &= (uint32_t)0xF8FF0000;
18 #else
19 RCC->CFGR &= (uint32_t)0xF0FF0000;
20 #endif /* STM32F10X_CL */
21
22 /* Reset HSEON, CSSON and PLLON bits */
23 RCC->CR &= (uint32_t)0xFEF6FFFF;
24
25 /* Reset HSEBYP bit */
26 RCC->CR &= (uint32_t)0xFFFBFFFF;
27
28 /* Reset PLLSRC, PLLXTPRE, PLLMUL and USBPRE/OTGFSPRE bits */
29 RCC->CFGR &= (uint32_t)0xFF80FFFF;
31 #ifdef STM32F10X_CL
32 /* Reset PLL2ON and PLL3ON bits */
33 RCC->CR &= (uint32_t)0xEBFFFFFF;
34
35 /* Disable all interrupts and clear pending bits */
36 RCC->CIR = 0x00FF0000;
37
38 /* Reset CFGR2 register */
39 RCC->CFGR2 = 0x00000000;
40 #elif defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)
41 /* Disable all interrupts and clear pending bits */
42 RCC->CIR = 0x009F0000;
43
44 /* Reset CFGR2 register */
45 RCC->CFGR2 = 0x00000000;
46 #else
47 /* Disable all interrupts and clear pending bits */
48 RCC->CIR = 0x009F0000;
49 #endif /* STM32F10X_CL */
51 #if defined (STM32F10X_HD) || (defined STM32F10X_XL) || (defined STM32F10X_HD_VL)
52 #ifdef DATA_IN_ExtSRAM
53 SystemInit_ExtMemCtl();
54 #endif /* DATA_IN_ExtSRAM */
55 #endif
56
57 /* Configure the System clock frequency, HCLK, PCLK2 and PCLK1 prescalers */
58 /* Configure the Flash Latency cycles and enable prefetch buffer */
59 SetSysClock();
61 #ifdef VECT_TAB_SRAM
62 SCB->VTOR = SRAM_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal SRAM. */
63 #else
64 SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH. */
65 #endif
66 }
* @brief Configures the System clock frequency, HCLK, PCLK2 and PCLK1 prescalers.
* @param None
* @retval None
static void SetSysClock(void)
#ifdef SYSCLK_FREQ_HSE
SetSysClockToHSE();
#elif defined SYSCLK_FREQ_24MHz
SetSysClockTo24();
#elif defined SYSCLK_FREQ_36MHz
SetSysClockTo36();
#elif defined SYSCLK_FREQ_48MHz
SetSysClockTo48();
#elif defined SYSCLK_FREQ_56MHz
SetSysClockTo56();
#elif defined SYSCLK_FREQ_72MHz
SetSysClockTo72();
#endif
设置RCC_CFGR寄存器的位参数,使其与外部晶振匹配得到72M系统时钟。
1 /**
2 * @brief Sets System clock frequency to 72MHz and configure HCLK, PCLK2
3 * and PCLK1 prescalers.
4 * @note This function should be used only after reset.
5 * @param None
6 * @retval None
7 */
8 static void SetSysClockTo72(void)
9 {
10 __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
12 /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration ---------------------------*/
13 /* Enable HSE */
14 RCC->CR |= ((uint32_t)RCC_CR_HSEON);
16 /* Wait till HSE is ready and if Time out is reached exit */
17 do
18 {
19 HSEStatus = RCC->CR & RCC_CR_HSERDY;
20 StartUpCounter++;
21 } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
22
23 if ((RCC->CR & RCC_CR_HSERDY) != RESET)
24 {
25 HSEStatus = (uint32_t)0x01;
26 }
27 else
28 {
29 HSEStatus = (uint32_t)0x00;
30 }
31
32 if (HSEStatus == (uint32_t)0x01)
33 {
34 /* Enable Prefetch Buffer */
35 FLASH->ACR |= FLASH_ACR_PRFTBE;
36
37 /* Flash 2 wait state */
38 FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
39 FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_2;
42 /* HCLK = SYSCLK */
43 RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;//AHB一分频
44
45 /* PCLK2 = HCLK */
46 RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
47
48 /* PCLK1 = HCLK */
49 RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;
51 #ifdef STM32F10X_CL
52 /* Configure PLLs ------------------------------------------------------*/
53 /* PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz */
54 /* PREDIV1 configuration: PREDIV1CLK = PLL2 / 5 = 8 MHz */
55
56 RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |
57 RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
58 RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |
59 RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5);
61 /* Enable PLL2 */
62 RCC->CR |= RCC_CR_PLL2ON;
63 /* Wait till PLL2 is ready */
64 while((RCC->CR & RCC_CR_PLL2RDY) == 0)
65 {
66 }
67
68
69 /* PLL configuration: PLLCLK = PREDIV1 * 9 = 72 MHz */
70 RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);
71 RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 |
72 RCC_CFGR_PLLMULL9);
73 #else
74 /* PLL configuration: PLLCLK = HSE * 9 = 72 MHz */
75 RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE |
76 RCC_CFGR_PLLMULL));
77 RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL9);
78 #endif /* STM32F10X_CL */
79
80 /* Enable PLL */
81 RCC->CR |= RCC_CR_PLLON;
82
83 /* Wait till PLL is ready */
84 while((RCC->CR & RCC_CR_PLLRDY) == 0)
85 {
86 }
87
88 /* Select PLL as system clock source */
89 RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
90 RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
91
92 /* Wait till PLL is used as system clock source */
93 while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
94 {
95 }
96 }
97 else
98 { /* If HSE fails to start-up, the application will have wrong clock
99 configuration. User can add here some code to deal with this error */
100 }
101 }
上一篇:STM32——时钟系统
我用的是飞凌的 ok2440 ,哎 菜鸟一只 AREA |DATA|,CODE,READONLY ENTRY ldr r13,=0x1000 IMPORT LedMain ...… 查看全部问答> |
我最近想学习一下CE驱动程序的开发。买了一本书,上面大谈本机驱动,流驱动,但是它并没有演示如何具体的去做一个驱动。只是给出了一些驱动代码。现在我主要是对WINCE5.0如何开发驱动程序的这个流程不清楚。根本不知道我的驱动代码该写在哪里,如何 ...… 查看全部问答> |
内存绘图之后, memDC, pDC, 我都RealseDC了。 但是最终,还是出现内存不足,循环一分钟就提示内存不足,内存泄露。 http://support.microsoft.com/kb/819635/zh-cn 上面的连接说明了这是一个bug. 但是他都是使用的是句柄,我用的MFC,然后不 ...… 查看全部问答> |
各位用过I2C模拟通信的前辈,我刚学这个,有一些地方不明白,还望大虾指点: 用的是带有I2C接口的tea5990收音机芯片,它支持100KHZ和400KHZ, 在电路板上是使用主控(其主频是184MHZ)的IO口产生的模拟I2C与它连接, 我自己写的软件模拟I2C,数据通过I2C写 ...… 查看全部问答> |
在我超级终端中进行AT命令测试如下: at ok at+cmgf=1 //设置成Text模式,我不要使用PDU模式 ok at+cmgs=\"00310033003000330037003300330037003900380032\" //指定收短信的手机号码130xxxxxxx >123 &nbs ...… 查看全部问答> |
void CRS2USBDlg::OnTimer(UINT nIDEvent) { // TODO: Add your message handler code here and/or call default HKEY hKey = HKEY_LOCAL_MACHINE; DWO ...… 查看全部问答> |
MSP430FR573x, MSP430FR572x C Code Examples (IAR and CCS) (Rev. B) MSP430FR573x, MSP430FR572x C Code Examples (IAR and CCS) (Rev. B)… 查看全部问答> |
本帖最后由 lonerzf 于 2014-9-27 09:04 编辑 最近看到一个利用TTP229做的电容式触摸开关电路。预期把它应用到MSP430FR5969中去,不知道PCB设计这块有什么要注意的。有已经使用过该方案的坛友还请指导下。谢谢~ 下面是淘宝上的模块。 中英 ...… 查看全部问答> |
