今天是:2024年12月06日(星期五)
2020年12月06日 | STM32F107——W5500网络通信
2020-12-06 来源:eefocus
#ifndef _W5500_QUEUE_H_
#define _W5500_QUEUE_H_
#include "type.h"
#define W5500_FRAME_SIZE 2048
#define W5500_RECV_QUEUE_SIZE 20
typedef enum
W5500_FAILURE = 0,
W5500_OK = 1,
} w5500_queue_status_t;
typedef __packed struct
uint8_t data[W5500_FRAME_SIZE];
uint16_t length;
} w5500_frame_t;
typedef struct
uint16_t in;
uint16_t out;
uint16_t count;
uint16_t item_size[W5500_RECV_QUEUE_SIZE];
uint8_t data[W5500_RECV_QUEUE_SIZE][W5500_FRAME_SIZE];
} w5500_queue_t;
extern w5500_queue_t w5500_queue_recv;
void W5500QueueInit(w5500_queue_t *q);
uint8_t W5500QueueWrite(w5500_queue_t *q, w5500_frame_t *data);
uint8_t W5500QueueRead(w5500_queue_t *q, w5500_frame_t *data);
#endif /* _W5500_QUEUE_H_ */
#include "w5500_queue.h"
#include #include #include "debug.h" w5500_queue_t w5500_queue_recv; void W5500QueueInit(w5500_queue_t *q) { int i; for(i = 0; i < W5500_RECV_QUEUE_SIZE; ++i) { memset(q->data[i], 0, W5500_FRAME_SIZE); } memset(q->item_size, 0, sizeof(q->item_size)); q->in = 0; q->out = 0; q->count = 0; } uint8_t W5500QueueWrite(w5500_queue_t *q, w5500_frame_t *frame) { if((q->out % W5500_RECV_QUEUE_SIZE == q->in) && (q->count == W5500_RECV_QUEUE_SIZE)) { return W5500_FAILURE; } q->item_size[q->in] = frame->length; memcpy(q->data[q->in], frame->data, frame->length); q->in = (q->in + 1) % W5500_RECV_QUEUE_SIZE; q->count++; return W5500_OK; } uint8_t W5500QueueRead(w5500_queue_t *q, w5500_frame_t *frame) { if((q->in == q->out) && (q->count == 0)) { return W5500_FAILURE; } frame->length = q->item_size[q->out]; memcpy(frame->data, q->data[q->out], q->item_size[q->out]); q->out = (q->out + 1) % W5500_RECV_QUEUE_SIZE; q->count--; return W5500_OK; } #ifndef _W5500_H_ #define _W5500_H_ #include "type.h" #include "debug.h" /***************** Common Register *****************/ #define MR 0x0000 #define RST 0x80 #define WOL 0x20 #define PB 0x10 #define PPP 0x08 #define FARP 0x02 #define GAR 0x0001 #define SUBR 0x0005 #define SHAR 0x0009 #define SIPR 0x000f #define INTLEVEL 0x0013 #define IR 0x0015 #define CONFLICT 0x80 #define UNREACH 0x40 #define PPPOE 0x20 #define MP 0x10 #define IMR 0x0016 #define IM_IR7 0x80 #define IM_IR6 0x40 #define IM_IR5 0x20 #define IM_IR4 0x10 #define SIR 0x0017 #define S7_INT 0x80 #define S6_INT 0x40 #define S5_INT 0x20 #define S4_INT 0x10 #define S3_INT 0x08 #define S2_INT 0x04 #define S1_INT 0x02 #define S0_INT 0x01 #define SIMR 0x0018 #define S7_IMR 0x80 #define S6_IMR 0x40 #define S5_IMR 0x20 #define S4_IMR 0x10 #define S3_IMR 0x08 #define S2_IMR 0x04 #define S1_IMR 0x02 #define S0_IMR 0x01 #define RTR_w5500 0x0019 #define RCR_w5500 0x001b #define PTIMER 0x001c #define PMAGIC 0x001d #define PHA 0x001e #define PSID 0x0024 #define PMRU 0x0026 #define UIPR 0x0028 #define UPORT 0x002c #define PHYCFGR 0x002e #define RST_PHY 0x80 #define OPMODE 0x40 #define DPX 0x04 #define SPD 0x02 #define LINK 0x01 #define VERR 0x0039 /********************* Socket Register *******************/ #define Sn_MR 0x0000 #define MULTI_MFEN 0x80 #define BCASTB 0x40 #define ND_MC_MMB 0x20 #define UCASTB_MIP6B 0x10 #define MR_CLOSE 0x00 #define MR_TCP 0x01 #define MR_UDP 0x02 #define MR_MACRAW 0x04 #define Sn_CR 0x0001 #define OPEN 0x01 #define LISTEN 0x02 #define CONNECT 0x04 #define DISCON 0x08 #define CLOSE 0x10 #define SEND 0x20 #define SEND_MAC 0x21 #define SEND_KEEP 0x22 #define RECV 0x40 #define Sn_IR 0x0002 #define IR_SEND_OK 0x10 #define IR_TIMEOUT 0x08 #define IR_RECV 0x04 #define IR_DISCON 0x02 #define IR_CON 0x01 #define Sn_SR 0x0003 #define SOCK_CLOSED 0x00 #define SOCK_INIT 0x13 #define SOCK_LISTEN 0x14 #define SOCK_ESTABLISHED 0x17 #define SOCK_CLOSE_WAIT 0x1c #define SOCK_UDP 0x22 #define SOCK_MACRAW 0x02 #define SOCK_SYNSEND 0x15 #define SOCK_SYNRECV 0x16 #define SOCK_FIN_WAI 0x18 #define SOCK_CLOSING 0x1a #define SOCK_TIME_WAIT 0x1b #define SOCK_LAST_ACK 0x1d #define Sn_PORT 0x0004 #define Sn_DHAR 0x0006 #define Sn_DIPR 0x000c #define Sn_DPORTR 0x0010 #define Sn_MSSR 0x0012 #define Sn_TOS 0x0015 #define Sn_TTL 0x0016 #define Sn_RXBUF_SIZE 0x001e #define Sn_TXBUF_SIZE 0x001f #define Sn_TX_FSR 0x0020 #define Sn_TX_RD 0x0022 #define Sn_TX_WR 0x0024 #define Sn_RX_RSR 0x0026 #define Sn_RX_RD 0x0028 #define Sn_RX_WR 0x002a #define Sn_IMR 0x002c #define IMR_SENDOK 0x10 #define IMR_TIMEOUT 0x08 #define IMR_RECV 0x04 #define IMR_DISCON 0x02 #define IMR_CON 0x01 #define Sn_FRAG 0x002d #define Sn_KPALVTR 0x002f /*******************************************************************/ /************************ SPI Control Byte *************************/ /*******************************************************************/ /* Operation mode bits */ #define VDM 0x00 #define FDM1 0x01 #define FDM2 0x02 #define FDM4 0x03 /* Read_Write control bit */ #define RWB_READ 0x00 #define RWB_WRITE 0x04 /* Block select bits */ #define COMMON_R 0x00 /* Socket 0 */ #define S0_REG 0x08 #define S0_TX_BUF 0x10 #define S0_RX_BUF 0x18 /* Socket 1 */ #define S1_REG 0x28 #define S1_TX_BUF 0x30 #define S1_RX_BUF 0x38 /* Socket 2 */ #define S2_REG 0x48 #define S2_TX_BUF 0x50 #define S2_RX_BUF 0x58 /* Socket 3 */ #define S3_REG 0x68 #define S3_TX_BUF 0x70 #define S3_RX_BUF 0x78 /* Socket 4 */ #define S4_REG 0x88 #define S4_TX_BUF 0x90 #define S4_RX_BUF 0x98 /* Socket 5 */ #define S5_REG 0xa8 #define S5_TX_BUF 0xb0 #define S5_RX_BUF 0xb8 /* Socket 6 */ #define S6_REG 0xc8 #define S6_TX_BUF 0xd0 #define S6_RX_BUF 0xd8 /* Socket 7 */ #define S7_REG 0xe8 #define S7_TX_BUF 0xf0 #define S7_RX_BUF 0xf8 #define SOCKET_OK 0xff #define SOCKET_FAILURE 0x00 #define S_RX_SIZE 2048 /*定义Socket接收缓冲区的大小,可以根据W5500_RMSR的设置修改 */ #define S_TX_SIZE 2048 /*定义Socket发送缓冲区的大小,可以根据W5500_TMSR的设置修改 */ /***************----- 端口数据缓冲区 -----***************/ extern uint8_t socket_rx_buffer[2048]; //端口接收数据缓冲区 extern uint8_t socket_tx_buffer[2048]; //端口发送数据缓冲区 typedef unsigned char SOCKET; //自定义端口号数据类型 void W5500Init(void); void W5500SocketScan(void); uint16_t W5500SocketRecv(uint8_t *buffer); void W5500SocketSend(uint8_t *buffer, uint16_t length); void W5500Process(void); extern void w5500_test(void); #endif #include #include "stm32f10x.h" #include "stm32f10x_spi.h" #include "target.h" #include "delay.h" #include "w5500.h" #include "w5500_queue.h" #include "debug.h" static uint8_t gateway_addr[4]; static uint8_t sub_mask[4]; static uint8_t mac_addr[6]; static uint8_t ip_addr[4]; static uint8_t s0_port[2]; //端口0的端口号(5000) static uint8_t s0_dip[4]; //端口0目的IP地址 static uint8_t s0_dport[2]; //端口0目的端口号(6000) static uint8_t udp_daddr[4]; //UDP(广播)模式,目的主机IP地址 static uint8_t udp_dport[2]; //UDP(广播)模式,目的主机端口号 /***************----- 端口的运行模式 -----***************/ static uint8_t s0_mode = 3; //端口0的运行模式,0:TCP服务器模式,1:TCP客户端模式,2:UDP(广播)模式 #define TCP_SERVER 0x00 //TCP服务器模式 #define TCP_CLIENT 0x01 //TCP客户端模式 #define UDP_MODE 0x02 //UDP(广播)模式 /***************----- 端口的运行状态 -----***************/ static uint8_t s0_state = 0; //端口0状态记录,1:端口完成初始化,2端口完成连接(可以正常传输数据) #define S_INIT 0x01 //端口完成初始化 #define S_CONN 0x02 //端口完成连接,可以正常传输数据 /***************----- 端口收发数据的状态 -----***************/ static uint8_t s0_data; //端口0接收和发送数据的状态,1:端口接收到数据,2:端口发送数据完成 #define S_RECEIVE 0x01 //端口接收到一个数据包 #define S_TRANSMITOK 0x02 //端口发送一个数据包完成 /***************----- 端口数据缓冲区 -----***************/ uint8_t socket_rx_buffer[2048]; //端口接收数据缓冲区
下一篇:STM32 —— 多路ADC采集
难分伯仲的PLD双雄——Xilinx和Altera (二) 三、DSP变数 在过去一年左右的时间里,尽管Xilinx与Altera的收入都有增长,但是双方的争斗处于相对平静的状态。在2004至2005年期间,Xilinx的收入 ...… 查看全部问答> |
移植openssl到arm平台之后,ssh就会出现segmentation,是不是少了什么库,还是那个选项没打开 version: openssl-0.9.7e openssh-3.9p1 … 查看全部问答> |
想请教大神,MSP430 存储器有boot memory :地址0xc000h ~ 0x0fffh, 这段memory用户可以进行读写么?… 查看全部问答> |
DA中settling time和update rate的关系 在DA的选型中我们经常发现settling time要大于update rate的倒数。快速率的转换, 需要短的output rising time 才能让输出能够跟上. settling time一般是指两个码之间的转换的rising time + 输出稳定到一定精度内的时间,一般是是输出最终稳定到0.1 ...… 查看全部问答> |
while(1) { Load_Sys_ICO3( ); // AI_LoadPicFile(\"0:/sg.bmp\",34,30,134,60); // AI_LoadPicFile(\"0:/qu.bmp\",168,30,223,60); // AI ...… 查看全部问答> |
