今天是:2024年11月09日(星期六)
2021年11月09日 | Mini2440 DM9000 驱动分析
2021-11-09 来源:eefocus
net_device_ops中方法的相应说明
* This structure defines the management hooks for network devices.
* The following hooks can be defined; unless noted otherwise, they are
* optional and can be filled with a null pointer.
* int (*ndo_init)(struct net_device *dev);
* This function is called once when network device is registered.
* The network device can use this to any late stage initializaton
* or semantic validattion. It can fail with an error code which will
* be propogated back to register_netdev
* void (*ndo_uninit)(struct net_device *dev);
* This function is called when device is unregistered or when registration
* fails. It is not called if init fails.
* int (*ndo_open)(struct net_device *dev);
* This function is called when network device transistions to the up
* state.
* int (*ndo_stop)(struct net_device *dev);
* This function is called when network device transistions to the down
* state.
* netdev_tx_t (*ndo_start_xmit)(struct sk_buff *skb,
* struct net_device *dev);
* Called when a packet needs to be transmitted.
* Must return NETDEV_TX_OK , NETDEV_TX_BUSY.
* (can also return NETDEV_TX_LOCKED iff NETIF_F_LLTX)
* Required can not be NULL.
* u16 (*ndo_select_queue)(struct net_device *dev, struct sk_buff *skb);
* Called to decide which queue to when device supports multiple
* transmit queues.
* void (*ndo_change_rx_flags)(struct net_device *dev, int flags);
* This function is called to allow device receiver to make
* changes to configuration when multicast or promiscious is enabled.
* void (*ndo_set_rx_mode)(struct net_device *dev);
* This function is called device changes address list filtering.
* void (*ndo_set_multicast_list)(struct net_device *dev);
* This function is called when the multicast address list changes.
* int (*ndo_set_mac_address)(struct net_device *dev, void *addr);
* This function is called when the Media Access Control address
* needs to be changed. If this interface is not defined, the
* mac address can not be changed.
* int (*ndo_validate_addr)(struct net_device *dev);
* Test if Media Access Control address is valid for the device.
* int (*ndo_do_ioctl)(struct net_device *dev, struct ifreq *ifr, int cmd);
* Called when a user request an ioctl which can't be handled by
* the generic interface code. If not defined ioctl's return
* not supported error code.
* int (*ndo_set_config)(struct net_device *dev, struct ifmap *map);
* Used to set network devices bus interface parameters. This interface
* is retained for legacy reason, new devices should use the bus
* interface (PCI) for low level management.
* int (*ndo_change_mtu)(struct net_device *dev, int new_mtu);
* Called when a user wants to change the Maximum Transfer Unit
* of a device. If not defined, any request to change MTU will
* will return an error.
* void (*ndo_tx_timeout)(struct net_device *dev);
* Callback uses when the transmitter has not made any progress
* for dev->watchdog ticks.
* struct net_device_stats* (*ndo_get_stats)(struct net_device *dev);
* Called when a user wants to get the network device usage
* statistics. If not defined, the counters in dev->stats will
* be used.
* void (*ndo_vlan_rx_register)(struct net_device *dev, struct vlan_group *grp);
* If device support VLAN receive accleration
* (ie. dev->features & NETIF_F_HW_VLAN_RX), then this function is called
* when vlan groups for the device changes. Note: grp is NULL
* if no vlan's groups are being used.
* void (*ndo_vlan_rx_add_vid)(struct net_device *dev, unsigned short vid);
* If device support VLAN filtering (dev->features & NETIF_F_HW_VLAN_FILTER)
* this function is called when a VLAN id is registered.
* void (*ndo_vlan_rx_kill_vid)(struct net_device *dev, unsigned short vid);
* this function is called when a VLAN id is unregistered.
* void (*ndo_poll_controller)(struct net_device *dev);
#define HAVE_NET_DEVICE_OPS
struct net_device_ops {
netdev_tx_t (*ndo_start_xmit) (struct sk_buff *skb,
#define HAVE_CHANGE_RX_FLAGS
int flags);
#define HAVE_SET_RX_MODE
#define HAVE_MULTICAST
#define HAVE_SET_MAC_ADDR
void *addr);
#define HAVE_VALIDATE_ADDR
#define HAVE_PRIVATE_IOCTL
#define HAVE_SET_CONFIG
struct ifmap *map);
#define HAVE_CHANGE_MTU
int new_mtu);
int (*ndo_neigh_setup)(struct net_device *dev,
struct neigh_parms *);
#define HAVE_TX_TIMEOUT
void (*ndo_tx_timeout) (struct net_device *dev);
#ifdef CONFIG_NET_POLL_CONTROLLER
#define HAVE_NETDEV_POLL
#endif
#if defined(CONFIG_FCOE) || defined(CONFIG_FCOE_MODULE)
int (*ndo_fcoe_enable)(struct net_device *dev);
int (*ndo_fcoe_disable)(struct net_device *dev);
int (*ndo_fcoe_ddp_setup)(struct net_device *dev,
u16 xid,
struct scatterlist *sgl,
unsigned int sgc);
int (*ndo_fcoe_ddp_done)(struct net_device *dev,
u16 xid);
#endif
ethtool_ops 中方法的相应说明
* ðtool_ops - Alter and report network device settings
* get_settings: Get device-specific settings
* set_settings: Set device-specific settings
* get_drvinfo: Report driver information
* get_regs: Get device registers
* get_wol: Report whether Wake-on-Lan is enabled
* set_wol: Turn Wake-on-Lan on or off
* get_msglevel: Report driver message level
* set_msglevel: Set driver message level
* nway_reset: Restart autonegotiation
* get_link: Get link status
* get_eeprom: Read data from the device EEPROM
* set_eeprom: Write data to the device EEPROM
* get_coalesce: Get interrupt coalescing parameters
* set_coalesce: Set interrupt coalescing parameters
* get_ringparam: Report ring sizes
* set_ringparam: Set ring sizes
* get_pauseparam: Report pause parameters
* set_pauseparam: Set pause parameters
* get_rx_csum: Report whether receive checksums are turned on or off
* set_rx_csum: Turn receive checksum on or off
* get_tx_csum: Report whether transmit checksums are turned on or off
* set_tx_csum: Turn transmit checksums on or off
* get_sg: Report whether scatter-gather is enabled
* set_sg: Turn scatter-gather on or off
* get_tso: Report whether TCP segmentation offload is enabled
* set_tso: Turn TCP segmentation offload on or off
* get_ufo: Report whether UDP fragmentation offload is enabled
* set_ufo: Turn UDP fragmentation offload on or off
* self_test: Run specified self-tests
* get_strings: Return a set of strings that describe the requested objects
* phys_id: Identify the device
* get_stats: Return statistics about the device
* get_flags: get 32-bit flags bitmap
* set_flags: set 32-bit flags bitmap
* Description:
* get_settings:
* @get_settings is passed an ðtool_cmd to fill in. It returns
* an negative errno or zero.
* set_settings:
* @set_settings is passed an ðtool_cmd and should attempt to set
* all the settings this device supports. It may return an error value
* if something goes wrong (otherwise 0).
* get_eeprom:
* Should fill in the magic field. Don't need to check len for zero
* or wraparound. Fill in the data argument with the eeprom values
* from offset to offset + len. Update len to the amount read.
* Returns an error or zero.
* set_eeprom:
* Should validate the magic field. Don't need to check len for zero
* or wraparound. Update len to the amount written. Returns an error
* or zero.
struct ethtool_ops {
int (*get_settings)(struct net_device *, struct ethtool_cmd *);
刚对WinAVR自带的延时函数进行一下研究,有些收获,与大家分享,不对之处请斧正,谢谢。 先看_delay_loop_1(uint8_t __count)函数,从其函数注释里面可以了解到,该函数用来延迟3个晶振时钟周期,不包括程序调用和退出该函数所花费 ...… 查看全部问答> |
小弟第一次接触嵌入式系统,将自己的问题详细描述一下,以便各位大哥大姐多多帮忙! 我用的硬件平台是三星2440,在这套平台上嵌入了Windows CE操作系统。2440内部带有两个SPI口同外部通信,我们要做的是通过SPI接口用一块单片机给2440发送数据,同 ...… 查看全部问答> |
请大侠指点:哪里可以下到基于TCP的网络打印协议。 本人准备在嵌入系统中开发网络打印功能,在网上只找到了IPP、以及互联网的打印介绍。 谢谢!… 查看全部问答> |
[紧急求助]c51编译警告"UNRESOLVED EXTERNAL SYMBOL" *** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: RXPNT MODULE: com.obj (COM) 找遍了网上也没能找出个究竟 keil的官方网站看了,也不在它的解释范围内 其中,变量RxPnt我已在头文件里 ...… 查看全部问答> |
我是按如下步作的:利用PC RS232下载程序到281x flash的方法:第一步:安装CCS2.2或更高版本 以确保你的源代码能编译为下载源码:xxx.out文件第二步:安装串口编程算法项目文件:sdf28xx_v3_0_serial (Ti网站上有下载) 详情请阅读包含 ...… 查看全部问答> |
但是设置为其实地址 (0,23),宽度 240,高度 100 时液晶按照设置显示(设置为竖着刷的,即高度为320,宽度为240) 但是我将高度设置为280(或者只要大于120左右)的时候,背景的设置显示就仅仅在液晶的上半部分实现了。。下面一大截都没刷成指定的颜 ...… 查看全部问答> |
