今天是:2025年10月14日(星期二)
2022年10月14日 | min2440 uart中断模式(非fifo模式)
2022-10-14 来源:csdn
Makefile
uart_interrupt.bin : start.s function.c
arm-linux-gcc -g -c -o start.o start.s
arm-linux-gcc -g -c -o function.o function.c
arm-linux-ld -Ttext 0x30000000 -g start.o function.o -o uart_interrupt.elf
arm-linux-objcopy -O binary -S uart_interrupt.elf uart_interrupt.bin
arm-linux-objdump -D -m arm uart_interrupt.elf > uart_interrupt.dis
clean :
rm -f *.o *.bin *.dis
start.s
.text
.global _start
_start:
b reset
b .
b .
b .
b .
b .
b handle_irq
b .
reset:
@shut down the watchdog
ldr r0, =0x53000000
ldr r1, =0x00000000
str r1, [r0]
@init the stack address
ldr r1, =4096
ldr r0, =0x40000000
add sp, r1, r0
bl init_led
bl init_clock
bl display_led1
bl init_sdram
bl display_led2
@reset the stack pointer
ldr sp, =0x34000000 @change stack to the end of sdram
msr cpsr_c, #0xd2
ldr sp, =0x33F00000 @change the stack pointer of irq mode
msr cpsr_c, #0xd3 @change cpu back to svc mode
bl copy_code2sdram @copy 8KB data from norflash to sdram
ldr pc, =on_sdram
on_sdram:
bl init_uart0
bl init_interrupt
msr cpsr_c, #0x53 @clear the irq disable bit in cpsr
bl main
halt_loop:
b halt_loop
handle_irq:
sub lr, lr, #4 @set the address(int main function) to return when handle_irq ends
stmdb sp!, {r0-r12, lr} @save the universal registers and lr_irq to the stack of irq mode
bl handle_irq_func @branch to the irq handleing function achieved in function.c
ldmia sp!, {r0-r12, pc}^ @resume the universal registers and save lr to pc while copying spsr to cpsr
function.c
//gpb registers
#define GPBCON (*((volatile unsigned long *)0x56000010))
#define GPBDAT (*((volatile unsigned long *)0x56000014))
//mem controler registers
#define BWSCON (*((volatile unsigned long *)0x48000000))
#define BANKCON0 (*((volatile unsigned long *)0x48000004))
#define BANKCON1 (*((volatile unsigned long *)0x48000008))
#define BANKCON2 (*((volatile unsigned long *)0x4800000C))
#define BANKCON3 (*((volatile unsigned long *)0x48000010))
#define BANKCON4 (*((volatile unsigned long *)0x48000014))
#define BANKCON5 (*((volatile unsigned long *)0x48000018))
#define BANKCON6 (*((volatile unsigned long *)0x4800001C))
#define BANKCON7 (*((volatile unsigned long *)0x48000020))
#define REFRESH (*((volatile unsigned long *)0x48000024))
#define BANKSIZE (*((volatile unsigned long *)0x48000028))
#define MRSRB6 (*((volatile unsigned long *)0x4800002C))
#define MRSRB7 (*((volatile unsigned long *)0x48000030))
//gpg registers
#define GPGCON (*((volatile unsigned long *)0x56000060))
//gph registers
#define GPHCON (*((volatile unsigned long *)0x56000070))
#define GPHUP (*((volatile unsigned long *)0x56000078))
//interrupt related registers
#define EINTMASK (*((volatile unsigned long *)0x560000A4))
#define INTMSK (*((volatile unsigned long *)0x4A000008))
#define INTMOD (*((volatile unsigned long *)0x4A000004))
#define INTOFFSET (*((volatile unsigned long *)0x4A000014))
#define SRCPND (*((volatile unsigned long *)0x4A000000))
#define INTPND (*((volatile unsigned long *)0x4A000010))
#define EINTPEND (*((volatile unsigned long *)0x560000A8))
#define INTSUBMSK (*((volatile unsigned long *)0x4A00001C))
#define SUBSRCPND (*((volatile unsigned long *)0x4A000018))
//PLL related registers
#define LOCKTIME (*((volatile unsigned long *)0x4C000000))
#define MPLLCON (*((volatile unsigned long *)0x4C000004))
#define CLKDIVN (*((volatile unsigned long *)0x4C000014))
//uart related registers
#define ULCON0 (*((volatile unsigned long *)0x50000000))
#define UCON0 (*((volatile unsigned long *)0x50000004))
#define UFCON0 (*((volatile unsigned long *)0x50000008))
#define UMCON0 (*((volatile unsigned long *)0x5000000C))
#define UBRDIV0 (*((volatile unsigned long *)0x50000028))
#define UTRSTAT0 (*((volatile unsigned long *)0x50000010))
#define URXH0 (*((volatile unsigned char *)0x50000024))
#define UTXH0 (*((volatile unsigned char *)0x50000020))
void blink(void);
void display_led(int);
void init_sdram(){
BWSCON = 0x22011110;
BANKCON0 = 0x00000700;
BANKCON1 = 0x00000700;
BANKCON2 = 0x00000700;
BANKCON3 = 0x00000700;
BANKCON4 = 0x00000700;
BANKCON5 = 0x00000700;
BANKCON6 = 0x00018005;
BANKCON7 = 0x00018005;
//when hcls is 12MHz
//REFRESH = 0x008C07A3;
//when hckl is 100MHz
REFRESH = 0x008C04F4;
BANKSIZE = 0x000000B1;
MRSRB6 = 0x00000030;
MRSRB7 = 0x00000030;
void init_interrupt(){
//set the gpio pins of the six keys to interrupt mode
GPGCON = (1<<(0*2+1) | 1<<(3*2+1) | 1<<(5*2+1) | 1<<(6*2+1) | 1<<(7*2+1) | 1<<(11*2+1));
//set EINTMASK register to enable external interrupt
EINTMASK &= (~(1<<8 | 1<<11 | 1<<13 | 1<<14 | 1<<15 | 1<<19));
//set INTMSK register to enable eint8_23
INTMSK &= (~(1<<5));
//enable uart0 interrupt
INTMSK &= (~(1<<28));
//enable rxd0 interrupt and txd0 interrupt
INTSUBMSK &= (~(0b11));
//set INTMOD register to set int8_23 to irq mode
INTMOD &= (~(1<<5));
void init_uart0(){
GPHCON |= ( (1<<5) | (1<<7) );
GPHCON &= ~( (1<<4) | (1<<6) );
GPHUP |= ( (1<<2) | (1<<3) );
ULCON0 = 0x03; //8 data bits, 1 stop bits, no check
UCON0 = 0X05; //polling mode or interrupt mode
UFCON0 = 0x00;
UMCON0 = 0x00;
UBRDIV0 = 0x1A; //bit rate is 115200(pclk is 50MHz)
unsigned char getchar_uart0(){
blink();
while( !(UTRSTAT0&1) );
return URXH0;
void putchar_uart0(unsigned char ch){
while( !(UTRSTAT0&4) );
UTXH0 = ch;
blink();
void handle_key(){
int eint_v;
eint_v = EINTPEND;
if(eint_v & (1<<8)){
display_led(1);
EINTPEND = 1<<8;
return;
if(eint_v & (1<<11)){
display_led(2);
EINTPEND = 1<<11;
return;
if(eint_v & (1<<13)){
display_led(3);
EINTPEND = 1<<13;
return;
if(eint_v & (1<<14)){
display_led(4);
EINTPEND = 1<<14;
return;
if(eint_v & (1<<15)){
display_led(5);
EINTPEND = 1<<15;
return;
if(eint_v & (1<<19)){
display_led(6);
EINTPEND = 1<<19;
return;
void handle_uart0_interrupt(){
unsigned char ch;
if(SUBSRCPND & (1<<0)){ //rxd0 interrupt
ch = getchar_uart0();
SUBSRCPND |= (1<<0);
putchar_uart0(ch);
else if(SUBSRCPND & (1<<1)){ //txd0 itnerrupt
//do nothing
SUBSRCPND |= (1<<1);
void handle_irq_func(){
int offset_v;
offset_v = INTOFFSET;
switch(offset_v){
case 5: //external interrupt
handle_key();
break;
case 28:
handle_uart0_interrupt();
break;
default:
break;
//clear the interrupt
SRCPND = 1< void delay(int n){ int i, j; for(i=0; i } } void blink(){ GPBDAT = 0xffffffff; GPBDAT = 0x00000000; delay(1); GPBDAT = 0xffffffff; delay(1); } void display_led1(){ GPBDAT = ~(1<<5); delay(1); } void display_led2(){ GPBDAT = ~(3<<5); delay(1); } void display_led3(){ GPBDAT = ~(7<<5); delay(1); } void display_led4(){ GPBDAT = ~(15<<5); delay(1); } void display_led(int n){ GPBDAT = ~(n<<5); } void copy_code2sdram(){ int size, i; unsigned char *src, *des; size = 8*1024; des = (unsigned char*)(0x30000000); src = (unsigned char *)(0x00000000); for(i=0; i } } void init_led(){ GPBCON = 0x00015400; GPBDAT &= ~(0x0f<<5); } //initialize the clock of soc void init_clock(){ LOCKTIME = 0xffffffff; CLKDIVN = 0X03; //fclk:hclk:pclk=1:2:4 __asm__ ( "mrc p15, 0, r1, c1, c0, 0n" "orr r1, r1, #0xc0000000n" "mcr p15, 0, r1, c1, c0, 0n" ); MPLLCON = (92<<12)|(1<<4)|(2<<0); //fclk=200M, hclk=100M, pclk=50M } /* int main(void){ int i; GPBCON = 0x00015400; i = 0; while(1){ GPBDAT = ~(1<<(i+5)); delay(1); i = (i+1)%4; } return 0; } */ int main(void){ display_led3(); while(1){ //waiting for interrupt } return 0; }
大家好,迷茫了很久,还是看不到方向,请有智慧的您帮忙吧,诚心请教 我毕业直接来到深圳,工作两年,第一年几乎虚度了,第二年用三星八位单片机汇编语言做了点简单的事(按键,led,定时器,i/o口发音,固定显示的液晶之类,硬件电路也 ...… 查看全部问答> |
我的网络程序在linux下交插编译成功,是不是可以说明这个程序用硬件烧录器进烧录也必定能成功? 我的网络程序在linux下交插编译成功,是不是可以说明这个程序用硬件烧录器进烧录也必定能成功?… 查看全部问答> |
我在做写入flash的时候写入的是113个字节的数据,A段的从1000开始写的!!! 我把要写入的数据建立在一个结构里了!!! 可是写完以后读的时候总是后写入的两个读出的是0;如果写入的少的话,比如我写50个字节那么 就有最后1个读出是0;我想问问 ...… 查看全部问答> |
【10款典型实验室电路推荐】之八:图1所示电路提供一种简单的方法,可控制75 MHz低功耗(20 mW)波形发生器(DDS) AD9834的输出波形幅度。 DDS(直接数字频率合成器)器件能够产生正弦波、方波和三角输出波形,因此可以用作波形发生器。 &nbs ...… 查看全部问答> |
在用msp430f149自带的ADC_12测电压的时候,检测到的值抖动的厉害,怎么办? 内部AD,参与2.5V参考,12位,理论精度0.0006,但是实际测量的的时候测量值的百分位都会抖,求高手……… 查看全部问答> |
本帖最后由 paulhyde 于 2014-9-15 03:41 编辑 基于Stc的Spwm的Pid控制 Spwm实现同频同向输出 该怎么弄啊?最好是有现成 例子的... 就是09光伏并网的 程序有么 … 查看全部问答> |
