电源管理
可处理76V电压的断路器,Circuit Breaker H
2011-05-19
Abstract: A current-sense amplifier, comparator, external CMOS switch, and an external transistor can be used to create a circuit breaker.
The simplicity of low-side current monitoring can mask the advantages of a high-side approach. You can monitor load currents in a power supply, a motor driver, or another power circuit on either the high or the low side (ground). However, you should not let the ease of low-side monitoring cause you either to overlook its dangers or the advantages of a high-side approach.
Various fault conditions can bypass the low-side monitor, thereby subjecting the load to dangerous and undetected stresses. However, a high-side monitor connected directly to the power source can detect any downstream failure and trigger the appropriate corrective action. Traditionally, such high-side monitors required a precision op amp, a boost power supply to accommodate the op amp's limited common-mode range, and some precision resistors. Now, the MAX4080 IC can sense high-side currents in the presence of common-mode voltages as high as 76V (Figure 1).
In this application circuit the MAX4080, IC1, provides a ground-referenced voltage-source output proportional to the high-side current of interest. This output voltage is proportional to the voltage across an external sense resistor multiplied by five.
Figure 1. A current sense amplifier, comparator, and a few external components form a low-cost circuit breaker.
IC1, IC2, and a few external parts form a low-cost circuit breaker. RSENSE senses load currents, and Q1 controls the currents. The design accepts inputs of 4.5V to 76V. The initial application of VIN and VDD places the breaker in its trip state. Pressing S1 resets the breaker and connects power to the load and IC1, thereby activating Q1. When the voltage across RSENSE is multiplied by five and exceeds 1.2V, then IC2 outputs a low signal on COUT which turns off Q2 and Q1. Press S1 to reset the breaker.
Reprinted from EDN Magazine May 25, 2000.
进入电源管理查看更多内容>>
    热门新闻
相关视频
  • 直播回放: Keysight 小探头,大学问,别让探头拖累你的测试结果!
  • 控制系统仿真与CAD
  • MIT 6.622 Power Electronics
  • 直播回放:基于英飞凌AIROC™ CYW20829低功耗蓝牙芯片的无线组网解决方案
  • 直播回放:ADI & WT·世健MCU痛点问题探索季:MCU应用难题全力击破!
  • Soc Design Lab - NYCU 2023
精选电路图
  • 光控电路设计与分析
  • IGBT模块通过控制门极阻断过电流
  • CCFL的工作原理及电子驱动电路解析
  • 开关电源的基本组成及工作原理
  • 基于M66T旋律发​​生器的电路图解析
  • 基于CA3193的热电偶放大器电路
    相关电子头条文章
