51 IO口模拟串口通讯C源程序
2021-05-13 来源:eefocus
简介:本文主要介绍51 IO口模拟串口通讯C源程序。
#include sbitBT_SND=P1^0; sbitBT_REC=P1^1; /********************************************** IO口模拟232通讯程序 使用两种方式的C程序占用定时器0 **********************************************/ #defineMODE_QUICK #defineF_TMF0 #defineTIMER0_ENABLETL0=TH0;TR0=1; #defineTIMER0_DISABLETR0=0; sbitACC0=ACC^0; sbitACC1=ACC^1; sbitACC2=ACC^2; sbitACC3=ACC^3; sbitACC4=ACC^4; sbitACC5=ACC^5; sbitACC6=ACC^6; sbitACC7=ACC^7; voidIntTimer0()interrupt1 { F_TM=1; } //发送一个字符 voidPSendChar(unsignedcharinch) { #ifdefMODE_QUICK ACC=inch; F_TM=0; BT_SND=0;//startbit TIMER0_ENABLE;//启动 while(!F_TM); BT_SND=ACC0;//先送出低位 F_TM=0; while(!F_TM); BT_SND=ACC1; F_TM=0; while(!F_TM); BT_SND=ACC2; F_TM=0; while(!F_TM); BT_SND=ACC3; F_TM=0; while(!F_TM); BT_SND=ACC4; F_TM=0; while(!F_TM); BT_SND=ACC5; F_TM=0; while(!F_TM); BT_SND=ACC6; F_TM=0; while(!F_TM); BT_SND=ACC7; F_TM=0; while(!F_TM); BT_SND=1; F_TM=0; while(!F_TM); TIMER0_DISABLE;//停止timer #else unsignedcharii; ii=0; F_TM=0; BT_SND=0;//startbit TIMER0_ENABLE;//启动 while(!F_TM); while(ii<8) { if(inch&1) { BT_SND=1; } else { BT_SND=0; } F_TM=0; while(!F_TM); ii++; inch>>=1; } BT_SND=1; F_TM=0; while(!F_TM); #endif TIMER0_DISABLE;//停止timer } //接收一个字符 unsignedcharPGetChar() { #ifdefMODE_QUICK TIMER0_ENABLE; F_TM=0; while(!F_TM);//等过起始位 ACC0=BT_REC; TL0=TH0; F_TM=0; while(!F_TM); ACC1=BT_REC; F_TM=0; while(!F_TM); ACC2=BT_REC; F_TM=0; while(!F_TM); ACC3=BT_REC; F_TM=0; while(!F_TM); ACC4=BT_REC; F_TM=0; while(!F_TM); ACC5=BT_REC; F_TM=0; while(!F_TM); ACC6=BT_REC; F_TM=0; while(!F_TM); ACC7=BT_REC; F_TM=0; while(!F_TM) { if(BT_REC) { break; } } TIMER0_DISABLE;//停止timer returnACC; #else unsignedcharrch,ii; TIMER0_ENABLE; F_TM=0; ii=0; rch=0; while(!F_TM);//等过起始位 while(ii<8) { rch>>=1; if(BT_REC) { rch|=0x80; } ii++; F_TM=0; while(!F_TM); } F_TM=0; while(!F_TM) { if(BT_REC) { break; } } TIMER0_DISABLE;//停止timer returnrch; #endif } //检查是不是有起始位 bitStartBitOn() { return(BT_REC==0); } voidmain() { unsignedchargch; TMOD=0x22;/*定时器1为工作模式2(8位自动重装),0为模式2(8位 自动重装)*/ PCON=00; TR0=0;//在发送或接收才开始使用 TF0=0; TH0=(256-96);//9600bps就是1000000/9600=104.167微秒执行的 timer是 // 104.167*11.0592/12=96 TL0=TH0; ET0=1; EA=1; PSendChar(0x55); PSendChar(0xaa); PSendChar(0x00); PSendChar(0xff); while(1) { if(StartBitOn()) { gch=PGetChar(); PSendChar(gch); } } }
下一篇:关于51单片机扩展中断的四种方法
- 10月中国动力电池装车量同比增长51%
- 8位单片机体系的直接软件构架(C51系列)
- WINCE6.0+S3C2451环境搭建过程遇到的一些问题
- 要用STM32实现什么?为什么使用STM32而不是8051?
- STM32F051C4引脚图、封装及参数定义
- UM5100系列语音合成芯片特点及电路
- 语音合成芯片VP-1410连512K及EPROM电路
- 基于Kinetis MK60N512和MAX5556的立体声音频接口设计
- Nordic nRF9151:面向大规模物联网市场的小型、低功耗蜂窝物联网解决方案已投入生产并上市
- AS5147U/AS5247U-用于高速电机的新型位置传感器
